[GRASS-SVN] r57293 - grass/branches/develbranch_6
Sat Jul 27 06:32:51 PDT 2013
Author: martinl
Date: 2013-07-27 06:32:51 -0700 (Sat, 27 Jul 2013)
New Revision: 57293
   grass/branches/develbranch_6/configure
   grass/branches/develbranch_6/configure.in
 configure.in: disable `pwd -W` (WinGRASS)
Modified: grass/branches/develbranch_6/configure
--- grass/branches/develbranch_6/configure	2013-07-27 11:19:06 UTC (rev 57292)
+++ grass/branches/develbranch_6/configure	2013-07-27 13:32:51 UTC (rev 57293)
@@ -1201,14 +1201,9 @@
 fi
-if test "$MINGW32" = yes ; then
-  winpwd="$pwd -W"
-else
-  winpwd="$pwd"
-fi
 echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1212: checking for source directory" >&5
+echo "configure:1207: checking for source directory" >&5
 if test -z "$srcdir" ; then
   SRCDIR=`$pwd`
@@ -1219,10 +1214,9 @@
 echo "$ac_t"""$SRCDIR"" 1>&6
 echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1223: checking for build directory" >&5
+echo "configure:1218: checking for build directory" >&5
 DSTDIR=`$pwd`
-WINDSTDIR=`$winpwd`
 echo "$ac_t"""$DSTDIR"" 1>&6
@@ -1264,7 +1258,7 @@
 # Set GISBASE and GRASS_BIN
-GISBASE="${WINDSTDIR}/dist.${ARCH}"
+GISBASE="${DSTDIR}/dist.${ARCH}"
 GRASS_BIN="${DSTDIR}/bin.${ARCH}"
@@ -1287,7 +1281,7 @@
 # Extract the first word of "svnversion", so it can be a program name with args.
 set dummy svnversion; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:1291: checking for $ac_word" >&5
+echo "configure:1285: checking for $ac_word" >&5
 case "$SVN_VERSION" in
@@ -1346,7 +1340,7 @@
 echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1350: checking for MacOSX App" >&5
+echo "configure:1344: checking for MacOSX App" >&5
 case "$enable_macosx_app" in
 	yes)	MACOSX_APP=1	;;
 	no)	MACOSX_APP=	;;
@@ -1358,7 +1352,7 @@
 # Check for MacOSX archs
 echo $ac_n "checking for MacOSX architectures""... $ac_c" 1>&6
-echo "configure:1362: checking for MacOSX architectures" >&5
+echo "configure:1356: checking for MacOSX architectures" >&5
 MACOSX_ARCHS=
@@ -1387,7 +1381,7 @@
 # Check for MacOSX SDK
 echo $ac_n "checking for MacOSX SDK""... $ac_c" 1>&6
-echo "configure:1391: checking for MacOSX SDK" >&5
+echo "configure:1385: checking for MacOSX SDK" >&5
 MACOSX_SDK=
@@ -1397,7 +1391,7 @@
 ac_safe=`echo "$with_macosx_sdk/SDKSettings.plist" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $with_macosx_sdk/SDKSettings.plist""... $ac_c" 1>&6
-echo "configure:1401: checking for $with_macosx_sdk/SDKSettings.plist" >&5
+echo "configure:1395: checking for $with_macosx_sdk/SDKSettings.plist" >&5
 if test "$cross_compiling" = yes; then
     { echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -1441,7 +1435,7 @@
     echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1445: checking how to build libraries" >&5
+echo "configure:1439: checking how to build libraries" >&5
     # Check whether --enable-shared or --disable-shared was given.
 if test "${enable_shared+set}" = set; then
   enableval="$enable_shared"
@@ -1484,7 +1478,7 @@
 # Extract the first word of "ranlib", so it can be a program name with args.
 set dummy ranlib; ac_word=$2
-echo "configure:1488: checking for $ac_word" >&5
+echo "configure:1482: checking for $ac_word" >&5
 if test -n "$RANLIB"; then
   ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -1509,7 +1503,7 @@
 fi
 echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:1513: checking how to run the C preprocessor" >&5
+echo "configure:1507: checking how to run the C preprocessor" >&5
 # On Suns, sometimes $CPP names a directory.
 if test -n "$CPP" && test -d "$CPP"; then
   CPP=
@@ -1522,13 +1516,13 @@
   # On the NeXT, cc -E runs the code through the compiler's parser,
   # not just through cpp.
   cat > conftest.$ac_ext <<EOF
-#line 1526 "configure"
+#line 1520 "configure"
 #include "confdefs.h"
 #include <assert.h>
 Syntax Error
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:1532: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1526: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
@@ -1539,13 +1533,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -E -traditional-cpp"
-#line 1543 "configure"
+#line 1537 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:1549: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1543: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1556,13 +1550,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -nologo -E"
-#line 1560 "configure"
+#line 1554 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:1566: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1560: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1590,7 +1584,7 @@
     # Step 0.a: Enable 64 bit support?
     echo $ac_n "checking if 64bit support is requested""... $ac_c" 1>&6
-echo "configure:1594: checking if 64bit support is requested" >&5
+echo "configure:1588: checking if 64bit support is requested" >&5
     # Check whether --enable-64bit or --disable-64bit was given.
 if test "${enable_64bit+set}" = set; then
   enableval="$enable_64bit"
@@ -1610,7 +1604,7 @@
     # Step 0.b: Enable Solaris 64 bit VIS support?
     echo $ac_n "checking if 64bit Sparc VIS support is requested""... $ac_c" 1>&6
-echo "configure:1614: checking if 64bit Sparc VIS support is requested" >&5
+echo "configure:1608: checking if 64bit Sparc VIS support is requested" >&5
     # Check whether --enable-64bit-vis or --disable-64bit-vis was given.
 if test "${enable_64bit_vis+set}" = set; then
   enableval="$enable_64bit_vis"
@@ -1634,7 +1628,7 @@
     # there are a few systems, like Next, where this doesn't work.
     echo $ac_n "checking system version (for dynamic loading)""... $ac_c" 1>&6
-echo "configure:1638: checking system version (for dynamic loading)" >&5
+echo "configure:1632: checking system version (for dynamic loading)" >&5
     if test -f /usr/lib/NextStep/software_version; then
 	system=NEXTSTEP-`awk '/3/,/3/' /usr/lib/NextStep/software_version`
     else
@@ -1660,13 +1654,13 @@
     # Linux can use either -ldl or -ldld for dynamic loading.
     echo $ac_n "checking for dlopen in -ldl""... $ac_c" 1>&6
-echo "configure:1664: checking for dlopen in -ldl" >&5
+echo "configure:1658: checking for dlopen in -ldl" >&5
 ac_lib_var=`echo dl'_'dlopen | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-ldl  $LIBS"
-#line 1670 "configure"
+#line 1664 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -1677,7 +1671,7 @@
 dlopen()
 ; return 0; }
 EOF
-if { (eval echo configure:1681: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1675: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -1724,7 +1718,7 @@
     # Extract the first word of "ar", so it can be a program name with args.
 set dummy ar; ac_word=$2
-echo "configure:1728: checking for $ac_word" >&5
+echo "configure:1722: checking for $ac_word" >&5
 if test -n "$AR"; then
   ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -1853,13 +1847,13 @@
 	    # known GMT value.
 	    echo $ac_n "checking for gettimeofday in -lbsd""... $ac_c" 1>&6
-echo "configure:1857: checking for gettimeofday in -lbsd" >&5
+echo "configure:1851: checking for gettimeofday in -lbsd" >&5
 ac_lib_var=`echo bsd'_'gettimeofday | sed 'y%./+-%__p_%'`
 LIBS="-lbsd  $LIBS"
-#line 1863 "configure"
+#line 1857 "configure"
@@ -1870,7 +1864,7 @@
 gettimeofday()
 ; return 0; }
 EOF
-if { (eval echo configure:1874: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1911,13 +1905,13 @@
 	    # is always linked to, for compatibility.
 	    echo $ac_n "checking for inet_ntoa in -lbind""... $ac_c" 1>&6
-echo "configure:1915: checking for inet_ntoa in -lbind" >&5
+echo "configure:1909: checking for inet_ntoa in -lbind" >&5
 ac_lib_var=`echo bind'_'inet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-lbind  $LIBS"
-#line 1921 "configure"
+#line 1915 "configure"
@@ -1928,7 +1922,7 @@
 inet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:1932: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1989,13 +1983,13 @@
 	    SHLIB_SUFFIX=".sl"
 	    echo $ac_n "checking for shl_load in -ldld""... $ac_c" 1>&6
-echo "configure:1993: checking for shl_load in -ldld" >&5
+echo "configure:1987: checking for shl_load in -ldld" >&5
 ac_lib_var=`echo dld'_'shl_load | sed 'y%./+-%__p_%'`
 LIBS="-ldld  $LIBS"
-#line 1999 "configure"
+#line 1993 "configure"
@@ -2006,7 +2000,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:2010: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2004: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -2071,13 +2065,13 @@
 	HP-UX-*.08.*|HP-UX-*.09.*|HP-UX-*.10.*)
 	    SHLIB_SUFFIX=".sl"
-echo "configure:2075: checking for shl_load in -ldld" >&5
+echo "configure:2069: checking for shl_load in -ldld" >&5
 LIBS="-ldld  $LIBS"
-#line 2081 "configure"
+#line 2075 "configure"
@@ -2088,7 +2082,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:2092: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2086: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -2210,15 +2204,15 @@
 	    else
 		ac_safe=`echo "dld.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dld.h""... $ac_c" 1>&6
-echo "configure:2214: checking for dld.h" >&5
+echo "configure:2208: checking for dld.h" >&5
-#line 2217 "configure"
+#line 2211 "configure"
 #include <dld.h>
 EOF
-{ (eval echo configure:2222: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2216: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2278,15 +2272,15 @@
 	    else
-echo "configure:2282: checking for dld.h" >&5
+echo "configure:2276: checking for dld.h" >&5
-#line 2285 "configure"
+#line 2279 "configure"
 #include <dld.h>
 EOF
-{ (eval echo configure:2290: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2284: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2383,9 +2377,9 @@
 	    CC_SEARCH_FLAGS=""
 	    LD_SEARCH_FLAGS=""
 	    echo $ac_n "checking for ELF""... $ac_c" 1>&6
-echo "configure:2387: checking for ELF" >&5
+echo "configure:2381: checking for ELF" >&5
-#line 2389 "configure"
+#line 2383 "configure"
 #ifdef __ELF__
@@ -2415,15 +2409,15 @@
 	    # Not available on all versions:  check for include file.
 	    ac_safe=`echo "dlfcn.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dlfcn.h""... $ac_c" 1>&6
-echo "configure:2419: checking for dlfcn.h" >&5
+echo "configure:2413: checking for dlfcn.h" >&5
-#line 2422 "configure"
+#line 2416 "configure"
 #include <dlfcn.h>
 EOF
-{ (eval echo configure:2427: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2421: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2447,9 +2441,9 @@
 		CC_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
 		LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
-echo "configure:2451: checking for ELF" >&5
+echo "configure:2445: checking for ELF" >&5
-#line 2453 "configure"
+#line 2447 "configure"
 #ifdef __ELF__
@@ -2773,17 +2767,17 @@
 	    # that don't grok the -Bexport option.  Test that it does.
 	    hold_ldflags=$LDFLAGS
 	    echo $ac_n "checking for ld accepts -Bexport flag""... $ac_c" 1>&6
-echo "configure:2777: checking for ld accepts -Bexport flag" >&5
+echo "configure:2771: checking for ld accepts -Bexport flag" >&5
 	    LDFLAGS="${LDFLAGS} -Wl,-Bexport"
-#line 2780 "configure"
+#line 2774 "configure"
 int main() {
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:2787: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2781: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   found=yes
 else
@@ -3581,7 +3575,7 @@
 # Done checking fortran
 echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:3585: checking for additional include dirs" >&5
+echo "configure:3579: checking for additional include dirs" >&5
 case "$with_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -3604,7 +3598,7 @@
 # With libs option
 echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:3608: checking for additional library dirs" >&5
+echo "configure:3602: checking for additional library dirs" >&5
 case "$with_libs" in
 	{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -3638,7 +3632,7 @@
 # SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
 # ./install, which can be erroneously created by make from ./install.sh.
 echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:3642: checking for a BSD compatible install" >&5
+echo "configure:3636: checking for a BSD compatible install" >&5
 if test -z "$INSTALL"; then
   IFS="${IFS= 	}"; ac_save_IFS="$IFS"; IFS=":"
@@ -3691,7 +3685,7 @@
 # Extract the first word of "flex", so it can be a program name with args.
 set dummy flex; ac_word=$2
-echo "configure:3695: checking for $ac_word" >&5
+echo "configure:3689: checking for $ac_word" >&5
 if test -n "$LEX"; then
   ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -3722,13 +3716,13 @@
   *) ac_lib=l ;;
   esac
   echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:3726: checking for yywrap in -l$ac_lib" >&5
+echo "configure:3720: checking for yywrap in -l$ac_lib" >&5
 ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
 LIBS="-l$ac_lib  $LIBS"
-#line 3732 "configure"
+#line 3726 "configure"
@@ -3739,7 +3733,7 @@
 yywrap()
 ; return 0; }
 EOF
-if { (eval echo configure:3743: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3737: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3764,7 +3758,7 @@
     # Extract the first word of "lex", so it can be a program name with args.
 set dummy lex; ac_word=$2
-echo "configure:3768: checking for $ac_word" >&5
+echo "configure:3762: checking for $ac_word" >&5
 case "$LEXPATH" in
@@ -3804,7 +3798,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
-echo "configure:3808: checking for $ac_word" >&5
+echo "configure:3802: checking for $ac_word" >&5
 if test -n "$YACC"; then
   ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -3835,7 +3829,7 @@
     # Extract the first word of "yacc", so it can be a program name with args.
 set dummy yacc; ac_word=$2
-echo "configure:3839: checking for $ac_word" >&5
+echo "configure:3833: checking for $ac_word" >&5
 case "$YACCPATH" in
@@ -3873,7 +3867,7 @@
-echo "configure:3877: checking for $ac_word" >&5
+echo "configure:3871: checking for $ac_word" >&5
@@ -3902,7 +3896,7 @@
-echo "configure:3906: checking for $ac_word" >&5
+echo "configure:3900: checking for $ac_word" >&5
@@ -3933,7 +3927,7 @@
-echo "configure:3937: checking for $ac_word" >&5
+echo "configure:3931: checking for $ac_word" >&5
 if test -n "$ENV"; then
   ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -3962,7 +3956,7 @@
 # Extract the first word of "perl", so it can be a program name with args.
 set dummy perl; ac_word=$2
-echo "configure:3966: checking for $ac_word" >&5
+echo "configure:3960: checking for $ac_word" >&5
 case "$PERL" in
@@ -3993,10 +3987,10 @@
 fi
 echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:3997: checking for ANSI C header files" >&5
+echo "configure:3991: checking for ANSI C header files" >&5
-#line 4000 "configure"
+#line 3994 "configure"
 #include <stdlib.h>
 #include <stdarg.h>
@@ -4004,7 +3998,7 @@
 #include <float.h>
 EOF
-{ (eval echo configure:4008: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4002: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4021,7 +4015,7 @@
 if test $ac_cv_header_stdc = yes; then
   # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 4025 "configure"
+#line 4019 "configure"
 #include <string.h>
 EOF
@@ -4039,7 +4033,7 @@
   # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 4043 "configure"
+#line 4037 "configure"
 #include <stdlib.h>
 EOF
@@ -4060,7 +4054,7 @@
 else
-#line 4064 "configure"
+#line 4058 "configure"
 #include <ctype.h>
 #define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -4071,7 +4065,7 @@
 exit (0); }
 EOF
-if { (eval echo configure:4075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4069: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
 else
@@ -4098,15 +4092,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:4102: checking for $ac_hdr" >&5
+echo "configure:4096: checking for $ac_hdr" >&5
-#line 4105 "configure"
+#line 4099 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4110: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4104: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4135,15 +4129,15 @@
 do
-echo "configure:4139: checking for $ac_hdr" >&5
+echo "configure:4133: checking for $ac_hdr" >&5
-#line 4142 "configure"
+#line 4136 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4147: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4141: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4172,15 +4166,15 @@
 do
-echo "configure:4176: checking for $ac_hdr" >&5
+echo "configure:4170: checking for $ac_hdr" >&5
-#line 4179 "configure"
+#line 4173 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4184: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4178: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4209,15 +4203,15 @@
 do
-echo "configure:4213: checking for $ac_hdr" >&5
+echo "configure:4207: checking for $ac_hdr" >&5
-#line 4216 "configure"
+#line 4210 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4221: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4215: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4246,15 +4240,15 @@
 do
-echo "configure:4250: checking for $ac_hdr" >&5
+echo "configure:4244: checking for $ac_hdr" >&5
-#line 4253 "configure"
+#line 4247 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4258: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4252: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4280,10 +4274,10 @@
 done
 echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:4284: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:4278: checking whether time.h and sys/time.h may both be included" >&5
-#line 4287 "configure"
+#line 4281 "configure"
 #include <sys/types.h>
 #include <sys/time.h>
@@ -4292,7 +4286,7 @@
 struct tm *tp;
 ; return 0; }
 EOF
-if { (eval echo configure:4296: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4290: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_header_time=yes
 else
@@ -4312,10 +4306,10 @@
 fi
 echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:4316: checking for off_t" >&5
+echo "configure:4310: checking for off_t" >&5
-#line 4319 "configure"
+#line 4313 "configure"
 #if STDC_HEADERS
@@ -4342,10 +4336,10 @@
 fi
 echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:4346: checking for uid_t in sys/types.h" >&5
+echo "configure:4340: checking for uid_t in sys/types.h" >&5
-#line 4349 "configure"
+#line 4343 "configure"
 EOF
@@ -4373,10 +4367,10 @@
 fi
 echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:4377: checking return type of signal handlers" >&5
+echo "configure:4371: checking return type of signal handlers" >&5
-#line 4380 "configure"
+#line 4374 "configure"
 #include <signal.h>
@@ -4393,7 +4387,7 @@
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:4397: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4391: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_type_signal=void
 else
@@ -4411,10 +4405,10 @@
 echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:4415: checking for Cygwin environment" >&5
+echo "configure:4409: checking for Cygwin environment" >&5
-#line 4418 "configure"
+#line 4412 "configure"
 int main() {
@@ -4425,7 +4419,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:4429: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4423: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -4443,10 +4437,10 @@
 for ac_func in ftime gethostname gettimeofday lseek nice time uname
 do
 echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:4447: checking for $ac_func" >&5
+echo "configure:4441: checking for $ac_func" >&5
-#line 4450 "configure"
+#line 4444 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char $ac_func(); below.  */
@@ -4469,7 +4463,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4473: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4467: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_$ac_func=yes"
 else
@@ -4495,10 +4489,10 @@
 for ac_func in seteuid setpriority setreuid setruid
 do
-echo "configure:4499: checking for $ac_func" >&5
+echo "configure:4493: checking for $ac_func" >&5
-#line 4502 "configure"
+#line 4496 "configure"
@@ -4521,7 +4515,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4525: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4519: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4547,10 +4541,10 @@
 for ac_func in drand48
 do
-echo "configure:4551: checking for $ac_func" >&5
+echo "configure:4545: checking for $ac_func" >&5
-#line 4554 "configure"
+#line 4548 "configure"
@@ -4573,7 +4567,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4577: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4571: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4599,10 +4593,10 @@
 for ac_func in putenv setenv
 do
-echo "configure:4603: checking for $ac_func" >&5
+echo "configure:4597: checking for $ac_func" >&5
-#line 4606 "configure"
+#line 4600 "configure"
@@ -4625,7 +4619,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4629: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4623: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4651,10 +4645,10 @@
 for ac_func in nanosleep
 do
-echo "configure:4655: checking for $ac_func" >&5
+echo "configure:4649: checking for $ac_func" >&5
-#line 4658 "configure"
+#line 4652 "configure"
@@ -4677,7 +4671,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4681: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4675: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4702,13 +4696,13 @@
 if test "$cross_compiling" != "yes" ; then
 echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:4706: checking whether setpgrp takes no argument" >&5
+echo "configure:4700: checking whether setpgrp takes no argument" >&5
   { echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
 else
-#line 4712 "configure"
+#line 4706 "configure"
 #ifdef HAVE_UNISTD_H
@@ -4728,7 +4722,7 @@
 EOF
-if { (eval echo configure:4732: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4726: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
   ac_cv_func_setpgrp_void=no
 else
@@ -4756,16 +4750,16 @@
 fi
 echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:4760: checking for long long int" >&5
+echo "configure:4754: checking for long long int" >&5
-#line 4762 "configure"
+#line 4756 "configure"
 int main() {
 long long int x;
 ; return 0; }
 EOF
-if { (eval echo configure:4769: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4763: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
 echo "$ac_t""yes" 1>&6
@@ -4785,7 +4779,7 @@
 rm -f conftest*
 echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:4789: checking for W11" >&5
+echo "configure:4783: checking for W11" >&5
 case "$enable_w11" in
 	yes|no)	echo "$ac_t"""$enable_w11"" 1>&6	;;
 	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
@@ -4813,7 +4807,7 @@
 # Uses ac_ vars as temps to allow command line to override cache and checks.
 # --without-x overrides everything else, but does not touch the cache.
 echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:4817: checking for X" >&5
+echo "configure:4811: checking for X" >&5
 # Check whether --with-x or --without-x was given.
 if test "${with_x+set}" = set; then
@@ -4873,12 +4867,12 @@
   # First, try using that file with no special directory specified.
-#line 4877 "configure"
+#line 4871 "configure"
 #include <$x_direct_test_include>
 EOF
-{ (eval echo configure:4882: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4876: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4947,14 +4941,14 @@
   LIBS="-l$x_direct_test_library $LIBS"
-#line 4951 "configure"
+#line 4945 "configure"
 int main() {
 ${x_direct_test_function}()
 ; return 0; }
 EOF
-if { (eval echo configure:4958: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4952: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LIBS="$ac_save_LIBS"
 # We can link X programs with no special library path.
@@ -5059,17 +5053,17 @@
     case "`(uname -sr) 2>/dev/null`" in
     "SunOS 5"*)
       echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:5063: checking whether -R must be followed by a space" >&5
+echo "configure:5057: checking whether -R must be followed by a space" >&5
       ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 5066 "configure"
+#line 5060 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:5073: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5067: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_nospace=yes
 else
@@ -5085,14 +5079,14 @@
       else
 	LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 5089 "configure"
+#line 5083 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:5096: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5090: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_space=yes
 else
@@ -5124,13 +5118,13 @@
     # libraries were built with DECnet support.  And karl at cs.umb.edu says
     # the Alpha needs dnet_stub (dnet does not exist).
     echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:5128: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:5122: checking for dnet_ntoa in -ldnet" >&5
 ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet  $LIBS"
-#line 5134 "configure"
+#line 5128 "configure"
@@ -5141,7 +5135,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:5145: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5162,13 +5156,13 @@
     if test $ac_cv_lib_dnet_dnet_ntoa = no; then
       echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:5166: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:5160: checking for dnet_ntoa in -ldnet_stub" >&5
 ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet_stub  $LIBS"
-#line 5172 "configure"
+#line 5166 "configure"
@@ -5179,7 +5173,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:5183: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5177: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5207,10 +5201,10 @@
     # The nsl library prevents programs from opening the X display
     # on Irix 5.2, according to dickey at clark.net.
     echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:5211: checking for gethostbyname" >&5
+echo "configure:5205: checking for gethostbyname" >&5
-#line 5214 "configure"
+#line 5208 "configure"
     which can conflict with char gethostbyname(); below.  */
@@ -5233,7 +5227,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5237: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5231: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gethostbyname=yes"
 else
@@ -5253,13 +5247,13 @@
     if test $ac_cv_func_gethostbyname = no; then
       echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:5257: checking for gethostbyname in -lnsl" >&5
+echo "configure:5251: checking for gethostbyname in -lnsl" >&5
 ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 5263 "configure"
+#line 5257 "configure"
@@ -5270,7 +5264,7 @@
 gethostbyname()
 ; return 0; }
 EOF
-if { (eval echo configure:5274: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5268: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5299,10 +5293,10 @@
     # -lsocket must be given before -lnsl if both are needed.
     # We assume that if connect needs -lnsl, so does gethostbyname.
     echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:5303: checking for connect" >&5
+echo "configure:5297: checking for connect" >&5
-#line 5306 "configure"
+#line 5300 "configure"
     which can conflict with char connect(); below.  */
@@ -5325,7 +5319,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5329: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5323: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_connect=yes"
 else
@@ -5345,13 +5339,13 @@
     if test $ac_cv_func_connect = no; then
       echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:5349: checking for connect in -lsocket" >&5
+echo "configure:5343: checking for connect in -lsocket" >&5
 ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
 LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 5355 "configure"
+#line 5349 "configure"
@@ -5362,7 +5356,7 @@
 connect()
 ; return 0; }
 EOF
-if { (eval echo configure:5366: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5360: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5385,10 +5379,10 @@
     # gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
     echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:5389: checking for remove" >&5
+echo "configure:5383: checking for remove" >&5
-#line 5392 "configure"
+#line 5386 "configure"
     which can conflict with char remove(); below.  */
@@ -5411,7 +5405,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5415: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5409: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_remove=yes"
 else
@@ -5431,13 +5425,13 @@
     if test $ac_cv_func_remove = no; then
       echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:5435: checking for remove in -lposix" >&5
+echo "configure:5429: checking for remove in -lposix" >&5
 ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
 LIBS="-lposix  $LIBS"
-#line 5441 "configure"
+#line 5435 "configure"
@@ -5448,7 +5442,7 @@
 remove()
 ; return 0; }
 EOF
-if { (eval echo configure:5452: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5471,10 +5465,10 @@
     # BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
     echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:5475: checking for shmat" >&5
+echo "configure:5469: checking for shmat" >&5
-#line 5478 "configure"
+#line 5472 "configure"
     which can conflict with char shmat(); below.  */
@@ -5497,7 +5491,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5501: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5495: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_shmat=yes"
 else
@@ -5517,13 +5511,13 @@
     if test $ac_cv_func_shmat = no; then
       echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:5521: checking for shmat in -lipc" >&5
+echo "configure:5515: checking for shmat in -lipc" >&5
 ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
 LIBS="-lipc  $LIBS"
-#line 5527 "configure"
+#line 5521 "configure"
@@ -5534,7 +5528,7 @@
 shmat()
 ; return 0; }
 EOF
-if { (eval echo configure:5538: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5532: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5566,13 +5560,13 @@
   # libraries we check for below, so use a different variable.
   #  --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
   echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:5570: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:5564: checking for IceConnectionNumber in -lICE" >&5
 ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
 LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 5576 "configure"
+#line 5570 "configure"
@@ -5583,7 +5577,7 @@
 IceConnectionNumber()
 ; return 0; }
 EOF
-if { (eval echo configure:5587: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5581: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5621,7 +5615,7 @@
 echo $ac_n "checking whether to use Curses""... $ac_c" 1>&6
-echo "configure:5625: checking whether to use Curses" >&5
+echo "configure:5619: checking whether to use Curses" >&5
 echo "$ac_t"""$with_curses"" 1>&6
 case "$with_curses" in
 	"no")	USE_CURSES=	;;
@@ -5640,15 +5634,15 @@
 do
-echo "configure:5644: checking for $ac_hdr" >&5
+echo "configure:5638: checking for $ac_hdr" >&5
-#line 5647 "configure"
+#line 5641 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5652: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5646: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5679,10 +5673,10 @@
 echo $ac_n "checking curses.h WINDOW structure component""... $ac_c" 1>&6
-echo "configure:5683: checking curses.h WINDOW structure component" >&5
+echo "configure:5677: checking curses.h WINDOW structure component" >&5
 CURSES_MAXY=NONE
-#line 5686 "configure"
+#line 5680 "configure"
 #include <curses.h>
@@ -5691,7 +5685,7 @@
 WINDOW w; w.maxy = 0;
 ; return 0; }
 EOF
-if { (eval echo configure:5695: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5689: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   CURSES_MAXY=maxy
 else
@@ -5700,7 +5694,7 @@
 fi
 rm -f conftest*
-#line 5704 "configure"
+#line 5698 "configure"
 #include <curses.h>
@@ -5709,7 +5703,7 @@
 WINDOW w; w._maxy = 0;
 ; return 0; }
 EOF
-if { (eval echo configure:5713: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5707: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   CURSES_MAXY=_maxy
 else
@@ -5725,13 +5719,13 @@
 echo "$ac_t""$CURSES_MAXY" 1>&6
 echo $ac_n "checking for initscr in -lncurses""... $ac_c" 1>&6
-echo "configure:5729: checking for initscr in -lncurses" >&5
+echo "configure:5723: checking for initscr in -lncurses" >&5
 ac_lib_var=`echo ncurses'_'initscr | sed 'y%./+-%__p_%'`
 LIBS="-lncurses  $LIBS"
-#line 5735 "configure"
+#line 5729 "configure"
@@ -5742,7 +5736,7 @@
 initscr()
 ; return 0; }
 EOF
-if { (eval echo configure:5746: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5740: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5761,13 +5755,13 @@
   echo "$ac_t""no" 1>&6
 echo $ac_n "checking for initscr in -lcurses""... $ac_c" 1>&6
-echo "configure:5765: checking for initscr in -lcurses" >&5
+echo "configure:5759: checking for initscr in -lcurses" >&5
 ac_lib_var=`echo curses'_'initscr | sed 'y%./+-%__p_%'`
 LIBS="-lcurses  $LIBS"
-#line 5771 "configure"
+#line 5765 "configure"
@@ -5778,7 +5772,7 @@
 initscr()
 ; return 0; }
 EOF
-if { (eval echo configure:5782: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5776: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5807,13 +5801,13 @@
 echo $ac_n "checking for keypad in -lncurses""... $ac_c" 1>&6
-echo "configure:5811: checking for keypad in -lncurses" >&5
+echo "configure:5805: checking for keypad in -lncurses" >&5
 ac_lib_var=`echo ncurses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5817 "configure"
+#line 5811 "configure"
@@ -5824,7 +5818,7 @@
 keypad()
 ; return 0; }
 EOF
-if { (eval echo configure:5828: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5846,13 +5840,13 @@
 echo $ac_n "checking for keypad in -lcurses""... $ac_c" 1>&6
-echo "configure:5850: checking for keypad in -lcurses" >&5
+echo "configure:5844: checking for keypad in -lcurses" >&5
 ac_lib_var=`echo curses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5856 "configure"
+#line 5850 "configure"
@@ -5863,7 +5857,7 @@
 keypad()
 ; return 0; }
 EOF
-if { (eval echo configure:5867: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5861: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5893,13 +5887,13 @@
 fi # $USE_CURSES
 echo $ac_n "checking for gtty in -lcompat""... $ac_c" 1>&6
-echo "configure:5897: checking for gtty in -lcompat" >&5
+echo "configure:5891: checking for gtty in -lcompat" >&5
 ac_lib_var=`echo compat'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lcompat  $LIBS"
-#line 5903 "configure"
+#line 5897 "configure"
@@ -5910,7 +5904,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5914: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5908: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5929,13 +5923,13 @@
 echo $ac_n "checking for gtty in -lbsd-compat""... $ac_c" 1>&6
-echo "configure:5933: checking for gtty in -lbsd-compat" >&5
+echo "configure:5927: checking for gtty in -lbsd-compat" >&5
 ac_lib_var=`echo bsd-compat'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lbsd-compat  $LIBS"
-#line 5939 "configure"
+#line 5933 "configure"
@@ -5946,7 +5940,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5944: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5965,13 +5959,13 @@
 echo $ac_n "checking for gtty in -lbsd""... $ac_c" 1>&6
-echo "configure:5969: checking for gtty in -lbsd" >&5
+echo "configure:5963: checking for gtty in -lbsd" >&5
 ac_lib_var=`echo bsd'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lbsd  $LIBS"
-#line 5975 "configure"
+#line 5969 "configure"
@@ -5982,7 +5976,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5986: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5980: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6016,12 +6010,12 @@
 LIBS=""
 echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:6020: checking for library containing cuserid" >&5
+echo "configure:6014: checking for library containing cuserid" >&5
 ac_func_search_save_LIBS="$LIBS"
 ac_cv_search_cuserid="no"
-#line 6025 "configure"
+#line 6019 "configure"
@@ -6032,7 +6026,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:6036: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6030: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="none required"
 else
@@ -6043,7 +6037,7 @@
 test "$ac_cv_search_cuserid" = "no" && for i in compat; do
 LIBS="-l$i  $ac_func_search_save_LIBS"
-#line 6047 "configure"
+#line 6041 "configure"
@@ -6054,7 +6048,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:6058: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6052: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="-l$i"
 break
@@ -6080,10 +6074,10 @@
 # Note: -lxdr -liberty -lws2_32 is for MinGW
 echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:6084: checking for xdrmem_create" >&5
+echo "configure:6078: checking for xdrmem_create" >&5
-#line 6087 "configure"
+#line 6081 "configure"
     which can conflict with char xdrmem_create(); below.  */
@@ -6106,7 +6100,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6110: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6104: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_xdrmem_create=yes"
 else
@@ -6124,13 +6118,13 @@
 echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:6128: checking for xdrmem_create in -lsun" >&5
+echo "configure:6122: checking for xdrmem_create in -lsun" >&5
 ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lsun  $LIBS"
-#line 6134 "configure"
+#line 6128 "configure"
@@ -6141,7 +6135,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6145: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6160,13 +6154,13 @@
 echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:6164: checking for xdrmem_create in -lnsl" >&5
+echo "configure:6158: checking for xdrmem_create in -lnsl" >&5
 ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 6170 "configure"
+#line 6164 "configure"
@@ -6177,7 +6171,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6181: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6196,13 +6190,13 @@
 echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:6200: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:6194: checking for xdrmem_create in -lrpclib" >&5
 ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lrpclib  $LIBS"
-#line 6206 "configure"
+#line 6200 "configure"
@@ -6213,7 +6207,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6217: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6211: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6232,13 +6226,13 @@
 echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:6236: checking for xdrmem_create in -lxdr" >&5
+echo "configure:6230: checking for xdrmem_create in -lxdr" >&5
 ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lxdr -liberty -lws2_32  $LIBS"
-#line 6242 "configure"
+#line 6236 "configure"
@@ -6249,7 +6243,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6253: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6247: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6283,10 +6277,10 @@
 for ac_func in asprintf
 do
-echo "configure:6287: checking for $ac_func" >&5
+echo "configure:6281: checking for $ac_func" >&5
-#line 6290 "configure"
+#line 6284 "configure"
@@ -6309,7 +6303,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6313: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6307: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6336,10 +6330,10 @@
 # Test if mathlib needs -lm flag or is included with libc
 echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:6340: checking for atan" >&5
+echo "configure:6334: checking for atan" >&5
-#line 6343 "configure"
+#line 6337 "configure"
     which can conflict with char atan(); below.  */
@@ -6362,7 +6356,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6366: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6360: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_atan=yes"
 else
@@ -6380,13 +6374,13 @@
 echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:6384: checking for atan in -lm" >&5
+echo "configure:6378: checking for atan in -lm" >&5
 ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
 LIBS="-lm  $LIBS"
-#line 6390 "configure"
+#line 6384 "configure"
@@ -6397,7 +6391,7 @@
 atan()
 ; return 0; }
 EOF
-if { (eval echo configure:6401: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6395: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6424,10 +6418,10 @@
 echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:6428: checking for dlsym" >&5
+echo "configure:6422: checking for dlsym" >&5
-#line 6431 "configure"
+#line 6425 "configure"
     which can conflict with char dlsym(); below.  */
@@ -6450,7 +6444,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6454: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6448: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dlsym=yes"
 else
@@ -6468,13 +6462,13 @@
 echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:6472: checking for dlsym in -ldl" >&5
+echo "configure:6466: checking for dlsym in -ldl" >&5
 ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
 LIBS="-ldl  $LIBS"
-#line 6478 "configure"
+#line 6472 "configure"
@@ -6485,7 +6479,7 @@
 dlsym()
 ; return 0; }
 EOF
-if { (eval echo configure:6489: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6483: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6512,10 +6506,10 @@
 echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:6516: checking for iconv" >&5
+echo "configure:6510: checking for iconv" >&5
-#line 6519 "configure"
+#line 6513 "configure"
     which can conflict with char iconv(); below.  */
@@ -6538,7 +6532,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6542: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6536: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_iconv=yes"
 else
@@ -6556,13 +6550,13 @@
 echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:6560: checking for iconv in -liconv" >&5
+echo "configure:6554: checking for iconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-liconv  $LIBS"
-#line 6566 "configure"
+#line 6560 "configure"
@@ -6573,7 +6567,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6577: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6571: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6592,13 +6586,13 @@
 echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6596: checking for iconv in -lgiconv" >&5
+echo "configure:6590: checking for iconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-lgiconv  $LIBS"
-#line 6602 "configure"
+#line 6596 "configure"
@@ -6609,7 +6603,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6613: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6607: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6628,10 +6622,10 @@
 echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:6632: checking for libiconv" >&5
+echo "configure:6626: checking for libiconv" >&5
-#line 6635 "configure"
+#line 6629 "configure"
     which can conflict with char libiconv(); below.  */
@@ -6654,7 +6648,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6658: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6652: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_libiconv=yes"
 else
@@ -6672,13 +6666,13 @@
 echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:6676: checking for libiconv in -liconv" >&5
+echo "configure:6670: checking for libiconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6682 "configure"
+#line 6676 "configure"
@@ -6689,7 +6683,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6693: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6687: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6708,13 +6702,13 @@
 echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6712: checking for libiconv in -lgiconv" >&5
+echo "configure:6706: checking for libiconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6718 "configure"
+#line 6712 "configure"
@@ -6725,7 +6719,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6729: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6723: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6762,10 +6756,10 @@
 have_socket=1
 echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:6766: checking for socket" >&5
+echo "configure:6760: checking for socket" >&5
-#line 6769 "configure"
+#line 6763 "configure"
     which can conflict with char socket(); below.  */
@@ -6788,7 +6782,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6792: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6786: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_socket=yes"
 else
@@ -6806,13 +6800,13 @@
 echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:6810: checking for socket in -lsocket" >&5
+echo "configure:6804: checking for socket in -lsocket" >&5
 ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
 LIBS="-lsocket  $LIBS"
-#line 6816 "configure"
+#line 6810 "configure"
@@ -6823,7 +6817,7 @@
 socket()
 ; return 0; }
 EOF
-if { (eval echo configure:6827: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6871,7 +6865,7 @@
 echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:6875: checking for location of zlib includes" >&5
+echo "configure:6869: checking for location of zlib includes" >&5
 case "$with_zlib_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -6897,15 +6891,15 @@
 do
-echo "configure:6901: checking for $ac_hdr" >&5
+echo "configure:6895: checking for $ac_hdr" >&5
-#line 6904 "configure"
+#line 6898 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6909: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6903: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6939,7 +6933,7 @@
 echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:6943: checking for location of zlib library" >&5
+echo "configure:6937: checking for location of zlib library" >&5
 case "$with_zlib_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -6964,13 +6958,13 @@
 echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:6968: checking for deflate in -lz" >&5
+echo "configure:6962: checking for deflate in -lz" >&5
 ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
 LIBS="-lz  $LIBS"
-#line 6974 "configure"
+#line 6968 "configure"
@@ -6981,7 +6975,7 @@
 deflate()
 ; return 0; }
 EOF
-if { (eval echo configure:6985: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6979: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7029,7 +7023,7 @@
 echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:7033: checking for location of External PROJ.4 includes" >&5
+echo "configure:7027: checking for location of External PROJ.4 includes" >&5
 case "$with_proj_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -7055,15 +7049,15 @@
 do
-echo "configure:7059: checking for $ac_hdr" >&5
+echo "configure:7053: checking for $ac_hdr" >&5
-#line 7062 "configure"
+#line 7056 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7067: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7061: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7100,7 +7094,7 @@
 else
 echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:7104: checking External PROJ.4 version" >&5
+echo "configure:7098: checking External PROJ.4 version" >&5
 ac_save_cppflags="$CPPFLAGS"
 CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -7108,7 +7102,7 @@
         echo "$ac_t""unknown (cross-compiling)" 1>&6
 else
-#line 7112 "configure"
+#line 7106 "configure"
 #include <stdio.h>
@@ -7120,7 +7114,7 @@
 EOF
-if { (eval echo configure:7124: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:7118: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      proj_ver=`cat conftestdata`
         echo "$ac_t""$proj_ver" 1>&6
@@ -7145,7 +7139,7 @@
 echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:7149: checking for location of External PROJ.4 library" >&5
+echo "configure:7143: checking for location of External PROJ.4 library" >&5
 case "$with_proj_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -7170,13 +7164,13 @@
 echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:7174: checking for pj_get_def in -lproj" >&5
+echo "configure:7168: checking for pj_get_def in -lproj" >&5
 ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
 LIBS="-lproj  $LIBS"
-#line 7180 "configure"
+#line 7174 "configure"
@@ -7187,7 +7181,7 @@
 pj_get_def()
 ; return 0; }
 EOF
-if { (eval echo configure:7191: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7185: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7221,7 +7215,7 @@
 echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:7225: checking for location of External PROJ.4 data files" >&5
+echo "configure:7219: checking for location of External PROJ.4 data files" >&5
 case "$with_proj_share" in
         { echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -7245,14 +7239,14 @@
 # LOC_CHECK_SHARE does not work when cross compiling
 if test "$cross_compiling" = "yes" ; then
     echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:7249: checking for epsg" >&5
+echo "configure:7243: checking for epsg" >&5
 else
 ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:7256: checking for $PROJSHARE/epsg" >&5
+echo "configure:7250: checking for $PROJSHARE/epsg" >&5
@@ -7284,7 +7278,7 @@
 # Extract the first word of "nad2bin", so it can be a program name with args.
 set dummy nad2bin; ac_word=$2
-echo "configure:7288: checking for $ac_word" >&5
+echo "configure:7282: checking for $ac_word" >&5
 case "$NAD2BIN" in
@@ -7324,7 +7318,7 @@
 echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:7328: checking whether to use regex" >&5
+echo "configure:7322: checking whether to use regex" >&5
 echo "$ac_t"""$with_regex"" 1>&6
 case "$with_regex" in
 	"no")	USE_REGEX=	;;
@@ -7344,7 +7338,7 @@
 echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:7348: checking for location of regex includes" >&5
+echo "configure:7342: checking for location of regex includes" >&5
 case "$with_regex_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -7370,15 +7364,15 @@
 do
-echo "configure:7374: checking for $ac_hdr" >&5
+echo "configure:7368: checking for $ac_hdr" >&5
-#line 7377 "configure"
+#line 7371 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7382: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7376: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7412,7 +7406,7 @@
 echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:7416: checking for location of regex library" >&5
+echo "configure:7410: checking for location of regex library" >&5
 case "$with_regex_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -7437,10 +7431,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:7441: checking for regcomp" >&5
+echo "configure:7435: checking for regcomp" >&5
-#line 7444 "configure"
+#line 7438 "configure"
     which can conflict with char regcomp(); below.  */
@@ -7463,7 +7457,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:7467: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7461: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_regcomp=yes"
 else
@@ -7490,13 +7484,13 @@
 echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:7494: checking for regcomp in -lregex" >&5
+echo "configure:7488: checking for regcomp in -lregex" >&5
 ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
 LIBS="-lregex  $LIBS"
-#line 7500 "configure"
+#line 7494 "configure"
@@ -7507,7 +7501,7 @@
 regcomp()
 ; return 0; }
 EOF
-if { (eval echo configure:7511: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7505: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7557,7 +7551,7 @@
 echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:7561: checking whether to use Readline" >&5
+echo "configure:7555: checking whether to use Readline" >&5
 echo "$ac_t"""$with_readline"" 1>&6
 case "$with_readline" in
 	"no")	USE_READLINE=	;;
@@ -7578,7 +7572,7 @@
 echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:7582: checking for location of Readline includes" >&5
+echo "configure:7576: checking for location of Readline includes" >&5
 case "$with_readline_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -7604,15 +7598,15 @@
 do
-echo "configure:7608: checking for $ac_hdr" >&5
+echo "configure:7602: checking for $ac_hdr" >&5
-#line 7611 "configure"
+#line 7605 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7616: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7610: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7648,15 +7642,15 @@
 do
-echo "configure:7652: checking for $ac_hdr" >&5
+echo "configure:7646: checking for $ac_hdr" >&5
-#line 7655 "configure"
+#line 7649 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7660: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7654: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7690,7 +7684,7 @@
 echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:7694: checking for location of Readline library" >&5
+echo "configure:7688: checking for location of Readline library" >&5
 case "$with_readline_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -7715,13 +7709,13 @@
 echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:7719: checking for readline in -lreadline" >&5
+echo "configure:7713: checking for readline in -lreadline" >&5
 ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
 LIBS="-lreadline  $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 7725 "configure"
+#line 7719 "configure"
 #include "confdefs.h"
@@ -7732,7 +7726,7 @@
 readline()
 ; return 0; }
 EOF
-if { (eval echo configure:7736: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7730: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7767,13 +7761,13 @@
 echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:7771: checking for add_history in -lhistory" >&5
+echo "configure:7765: checking for add_history in -lhistory" >&5
 ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
 LIBS="-lhistory  $LIBS"
-#line 7777 "configure"
+#line 7771 "configure"
@@ -7784,7 +7778,7 @@
 add_history()
 ; return 0; }
 EOF
-if { (eval echo configure:7788: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7782: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7826,7 +7820,7 @@
 # GDAL option
 echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:7830: checking whether to use GDAL" >&5
+echo "configure:7824: checking whether to use GDAL" >&5
 GDAL_LIBS=
 GDAL_CFLAGS=
@@ -7844,7 +7838,7 @@
   # Extract the first word of "gdal-config", so it can be a program name with args.
 set dummy gdal-config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:7848: checking for $ac_word" >&5
+echo "configure:7842: checking for $ac_word" >&5
 case "$GDAL_CONFIG" in
@@ -7899,14 +7893,14 @@
   LIBS="$LIBS $GDAL_LIBS"
   CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 7903 "configure"
+#line 7897 "configure"
 #include <gdal.h>
 int main() {
 GDALOpen("foo", GA_ReadOnly);
 ; return 0; }
 EOF
-if { (eval echo configure:7910: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7904: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
   echo "configure: failed program was:" >&5
@@ -7915,14 +7909,14 @@
   LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 7919 "configure"
+#line 7913 "configure"
 #include <gdal.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:7926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7920: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
 else
@@ -7954,7 +7948,7 @@
 # GEOS option
 echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:7958: checking whether to use GEOS" >&5
+echo "configure:7952: checking whether to use GEOS" >&5
 GEOS_LIBS=
 GGEOS_CFLAGS=
@@ -7972,7 +7966,7 @@
   # Extract the first word of "geos-config", so it can be a program name with args.
 set dummy geos-config; ac_word=$2
-echo "configure:7976: checking for $ac_word" >&5
+echo "configure:7970: checking for $ac_word" >&5
 case "$GEOS_CONFIG" in
@@ -8020,15 +8014,15 @@
 do
-echo "configure:8024: checking for $ac_hdr" >&5
+echo "configure:8018: checking for $ac_hdr" >&5
-#line 8027 "configure"
+#line 8021 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:8032: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8026: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -8067,13 +8061,13 @@
 echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:8071: checking for initGEOS in -lgeos_c" >&5
+echo "configure:8065: checking for initGEOS in -lgeos_c" >&5
 ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lgeos_c  $LIBS"
-#line 8077 "configure"
+#line 8071 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -8084,7 +8078,7 @@
 initGEOS()
 ; return 0; }
 EOF
-if { (eval echo configure:8088: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8082: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -8128,7 +8122,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:8132: checking whether to use TIFF" >&5
+echo "configure:8126: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -8148,7 +8142,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:8152: checking for location of TIFF includes" >&5
+echo "configure:8146: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -8174,15 +8168,15 @@
 do
-echo "configure:8178: checking for $ac_hdr" >&5
+echo "configure:8172: checking for $ac_hdr" >&5
-#line 8181 "configure"
+#line 8175 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8186: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8180: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8216,7 +8210,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:8220: checking for location of TIFF library" >&5
+echo "configure:8214: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -8247,13 +8241,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:8251: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8245: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 LIBS="-ltiff  $LIBS"
-#line 8257 "configure"
+#line 8251 "configure"
@@ -8264,7 +8258,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8268: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8262: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8283,13 +8277,13 @@
-echo "configure:8287: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8281: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 8293 "configure"
+#line 8287 "configure"
@@ -8300,7 +8294,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8304: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8298: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8319,13 +8313,13 @@
-echo "configure:8323: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8317: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
-#line 8329 "configure"
+#line 8323 "configure"
@@ -8336,7 +8330,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8340: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8334: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8355,13 +8349,13 @@
-echo "configure:8359: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8353: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 8365 "configure"
+#line 8359 "configure"
@@ -8372,7 +8366,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8376: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8370: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8391,13 +8385,13 @@
-echo "configure:8395: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8389: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $LIBS"
-#line 8401 "configure"
+#line 8395 "configure"
@@ -8408,7 +8402,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8412: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8406: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8427,13 +8421,13 @@
-echo "configure:8431: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8425: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $MATHLIB $LIBS"
-#line 8437 "configure"
+#line 8431 "configure"
@@ -8444,7 +8438,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8448: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8442: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8463,13 +8457,13 @@
-echo "configure:8467: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8461: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $ZLIB $LIBS"
-#line 8473 "configure"
+#line 8467 "configure"
@@ -8480,7 +8474,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8484: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8478: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8499,13 +8493,13 @@
-echo "configure:8503: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8497: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $ZLIB $MATHLIB $LIBS"
-#line 8509 "configure"
+#line 8503 "configure"
@@ -8516,7 +8510,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8520: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8514: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8614,7 +8608,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8618: checking whether to use PNG" >&5
+echo "configure:8612: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -8633,7 +8627,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8637: checking for location of PNG includes" >&5
+echo "configure:8631: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8659,15 +8653,15 @@
 do
-echo "configure:8663: checking for $ac_hdr" >&5
+echo "configure:8657: checking for $ac_hdr" >&5
-#line 8666 "configure"
+#line 8660 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8671: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8665: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8701,7 +8695,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8705: checking for location of PNG library" >&5
+echo "configure:8699: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8726,13 +8720,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8730: checking for png_read_image in -lpng" >&5
+echo "configure:8724: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8736 "configure"
+#line 8730 "configure"
@@ -8743,7 +8737,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:8747: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8741: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8785,7 +8779,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:8789: checking whether to use PostgreSQL" >&5
+echo "configure:8783: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -8812,7 +8806,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:8816: checking for location of PostgreSQL includes" >&5
+echo "configure:8810: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -8838,15 +8832,15 @@
 do
-echo "configure:8842: checking for $ac_hdr" >&5
+echo "configure:8836: checking for $ac_hdr" >&5
-#line 8845 "configure"
+#line 8839 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8850: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8844: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8884,7 +8878,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:8888: checking for location of PostgreSQL library" >&5
+echo "configure:8882: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -8913,13 +8907,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:8917: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8911: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 8923 "configure"
+#line 8917 "configure"
@@ -8930,7 +8924,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:8934: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8928: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8949,13 +8943,13 @@
-echo "configure:8953: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8947: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 8959 "configure"
+#line 8953 "configure"
@@ -8966,7 +8960,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:8970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8985,13 +8979,13 @@
-echo "configure:8989: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8983: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 8995 "configure"
+#line 8989 "configure"
@@ -9002,7 +8996,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9006: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9000: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9021,13 +9015,13 @@
-echo "configure:9025: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9019: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9031 "configure"
+#line 9025 "configure"
@@ -9038,7 +9032,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9042: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9036: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9095,13 +9089,13 @@
 ac_save_ldflags="$LDFLAGS"
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9099: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9093: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9105 "configure"
+#line 9099 "configure"
@@ -9112,7 +9106,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9110: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9134,13 +9128,13 @@
-echo "configure:9138: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9132: checking for PQcmdTuples in -lpq" >&5
-#line 9144 "configure"
+#line 9138 "configure"
@@ -9151,7 +9145,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9155: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9149: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9194,7 +9188,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9198: checking whether to use MySQL" >&5
+echo "configure:9192: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -9214,7 +9208,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9218: checking for location of MySQL includes" >&5
+echo "configure:9212: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9240,15 +9234,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:9244: checking for $ac_hdr" >&5
+echo "configure:9238: checking for $ac_hdr" >&5
-#line 9247 "configure"
+#line 9241 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9252: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9246: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9285,7 +9279,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9289: checking for location of MySQL library" >&5
+echo "configure:9283: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9316,13 +9310,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9320: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9314: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 9326 "configure"
+#line 9320 "configure"
@@ -9333,7 +9327,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9337: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9331: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9352,13 +9346,13 @@
-echo "configure:9356: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9350: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9362 "configure"
+#line 9356 "configure"
@@ -9369,7 +9363,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9373: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9367: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9388,13 +9382,13 @@
-echo "configure:9392: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9386: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9398 "configure"
+#line 9392 "configure"
@@ -9405,7 +9399,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9409: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9403: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9424,13 +9418,13 @@
-echo "configure:9428: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9422: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9434 "configure"
+#line 9428 "configure"
@@ -9441,7 +9435,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9445: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9439: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9460,13 +9454,13 @@
-echo "configure:9464: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9458: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9470 "configure"
+#line 9464 "configure"
@@ -9477,7 +9471,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9481: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9475: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9496,13 +9490,13 @@
-echo "configure:9500: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9494: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9506 "configure"
+#line 9500 "configure"
@@ -9513,7 +9507,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9517: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9511: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9532,13 +9526,13 @@
-echo "configure:9536: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9530: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 9542 "configure"
+#line 9536 "configure"
@@ -9549,7 +9543,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9553: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9547: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9568,13 +9562,13 @@
-echo "configure:9572: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9566: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 9578 "configure"
+#line 9572 "configure"
@@ -9585,7 +9579,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9589: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9583: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9675,7 +9669,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
-echo "configure:9679: checking for $ac_word" >&5
+echo "configure:9673: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -9716,10 +9710,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:9720: checking for mysql_server_init" >&5
+echo "configure:9714: checking for mysql_server_init" >&5
-#line 9723 "configure"
+#line 9717 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char mysql_server_init(); below.  */
@@ -9742,7 +9736,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9746: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9740: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -9780,7 +9774,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:9784: checking whether to use SQLite" >&5
+echo "configure:9778: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -9800,7 +9794,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:9804: checking for location of SQLite includes" >&5
+echo "configure:9798: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -9826,15 +9820,15 @@
 do
-echo "configure:9830: checking for $ac_hdr" >&5
+echo "configure:9824: checking for $ac_hdr" >&5
-#line 9833 "configure"
+#line 9827 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9838: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9832: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9877,7 +9871,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:9881: checking for location of SQLite library" >&5
+echo "configure:9875: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -9906,13 +9900,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:9910: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9904: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 9916 "configure"
+#line 9910 "configure"
@@ -9923,7 +9917,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:9927: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9921: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9942,13 +9936,13 @@
-echo "configure:9946: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9940: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 9952 "configure"
+#line 9946 "configure"
@@ -9959,7 +9953,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:9963: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9957: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9978,13 +9972,13 @@
-echo "configure:9982: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9976: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 9988 "configure"
+#line 9982 "configure"
@@ -9995,7 +9989,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:9999: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9993: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10014,13 +10008,13 @@
-echo "configure:10018: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10012: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 10024 "configure"
+#line 10018 "configure"
@@ -10031,7 +10025,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10035: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10029: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10100,7 +10094,7 @@
 echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10104: checking whether to use FFMPEG" >&5
+echo "configure:10098: checking whether to use FFMPEG" >&5
 echo "$ac_t"""$with_ffmpeg"" 1>&6
 case "$with_ffmpeg" in
 	"no")	USE_FFMPEG=	;;
@@ -10120,7 +10114,7 @@
 echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10124: checking for location of FFMPEG includes" >&5
+echo "configure:10118: checking for location of FFMPEG includes" >&5
 case "$with_ffmpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10146,15 +10140,15 @@
 do
-echo "configure:10150: checking for $ac_hdr" >&5
+echo "configure:10144: checking for $ac_hdr" >&5
-#line 10153 "configure"
+#line 10147 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10158: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10152: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10190,15 +10184,15 @@
 do
-echo "configure:10194: checking for $ac_hdr" >&5
+echo "configure:10188: checking for $ac_hdr" >&5
-#line 10197 "configure"
+#line 10191 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10202: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10196: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10234,15 +10228,15 @@
 do
-echo "configure:10238: checking for $ac_hdr" >&5
+echo "configure:10232: checking for $ac_hdr" >&5
-#line 10241 "configure"
+#line 10235 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10246: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10240: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10285,7 +10279,7 @@
 echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10289: checking for location of FFMPEG library" >&5
+echo "configure:10283: checking for location of FFMPEG library" >&5
 case "$with_ffmpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10312,13 +10306,13 @@
 echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10316: checking for av_free in -lavutil" >&5
+echo "configure:10310: checking for av_free in -lavutil" >&5
 ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
 LIBS="-lavutil  $LIBS"
-#line 10322 "configure"
+#line 10316 "configure"
@@ -10329,7 +10323,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10333: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10327: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10348,13 +10342,13 @@
-echo "configure:10352: checking for av_free in -lavutil" >&5
+echo "configure:10346: checking for av_free in -lavutil" >&5
 LIBS="-lavutil $MATHLIB $LIBS"
-#line 10358 "configure"
+#line 10352 "configure"
@@ -10365,7 +10359,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10369: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10363: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10410,13 +10404,13 @@
 echo $ac_n "checking for avcodec_register in -lavcodec""... $ac_c" 1>&6
-echo "configure:10414: checking for avcodec_register in -lavcodec" >&5
+echo "configure:10408: checking for avcodec_register in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_register | sed 'y%./+-%__p_%'`
 LIBS="-lavcodec $FFMPEGLIB  $LIBS"
-#line 10420 "configure"
+#line 10414 "configure"
@@ -10427,7 +10421,7 @@
 avcodec_register()
 ; return 0; }
 EOF
-if { (eval echo configure:10431: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10425: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10446,13 +10440,13 @@
-echo "configure:10450: checking for avcodec_register in -lavcodec" >&5
+echo "configure:10444: checking for avcodec_register in -lavcodec" >&5
 LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10456 "configure"
+#line 10450 "configure"
@@ -10463,7 +10457,7 @@
 avcodec_register()
 ; return 0; }
 EOF
-if { (eval echo configure:10467: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10461: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10508,13 +10502,13 @@
 echo $ac_n "checking for avformat_alloc_context in -lavformat""... $ac_c" 1>&6
-echo "configure:10512: checking for avformat_alloc_context in -lavformat" >&5
+echo "configure:10506: checking for avformat_alloc_context in -lavformat" >&5
 ac_lib_var=`echo avformat'_'avformat_alloc_context | sed 'y%./+-%__p_%'`
 LIBS="-lavformat $FFMPEGLIB  $LIBS"
-#line 10518 "configure"
+#line 10512 "configure"
@@ -10525,7 +10519,7 @@
 avformat_alloc_context()
 ; return 0; }
 EOF
-if { (eval echo configure:10529: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10523: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10544,13 +10538,13 @@
-echo "configure:10548: checking for avformat_alloc_context in -lavformat" >&5
+echo "configure:10542: checking for avformat_alloc_context in -lavformat" >&5
 LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10554 "configure"
+#line 10548 "configure"
@@ -10561,7 +10555,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10565: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10559: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10620,7 +10614,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10624: checking whether to use OpenGL" >&5
+echo "configure:10618: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -10654,7 +10648,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:10658: checking for location of OpenGL includes" >&5
+echo "configure:10652: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -10680,15 +10674,15 @@
 do
-echo "configure:10684: checking for $ac_hdr" >&5
+echo "configure:10678: checking for $ac_hdr" >&5
-#line 10687 "configure"
+#line 10681 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10692: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10686: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10725,15 +10719,15 @@
 do
-echo "configure:10729: checking for $ac_hdr" >&5
+echo "configure:10723: checking for $ac_hdr" >&5
-#line 10732 "configure"
+#line 10726 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10737: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10731: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10767,7 +10761,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:10771: checking for location of OpenGL library" >&5
+echo "configure:10765: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -10788,7 +10782,7 @@
 echo $ac_n "checking for location of Xmu library""... $ac_c" 1>&6
-echo "configure:10792: checking for location of Xmu library" >&5
+echo "configure:10786: checking for location of Xmu library" >&5
 case "$with_Xmu_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-Xmu-libs." 1>&2; exit 1; }
@@ -10817,13 +10811,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:10821: checking for glBegin in -lGL" >&5
+echo "configure:10815: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 10827 "configure"
+#line 10821 "configure"
@@ -10834,7 +10828,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10838: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10832: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10853,13 +10847,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:10857: checking for glBegin in -lGL" >&5
+echo "configure:10851: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 10863 "configure"
+#line 10857 "configure"
@@ -10870,7 +10864,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10874: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10889,13 +10883,13 @@
-echo "configure:10893: checking for glBegin in -lGL" >&5
+echo "configure:10887: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 10899 "configure"
+#line 10893 "configure"
@@ -10906,7 +10900,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10910: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10904: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10925,13 +10919,13 @@
-echo "configure:10929: checking for glBegin in -lGL" >&5
+echo "configure:10923: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 10935 "configure"
+#line 10929 "configure"
@@ -10942,7 +10936,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10946: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10940: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11004,13 +10998,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11008: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11002: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11014 "configure"
+#line 11008 "configure"
@@ -11021,7 +11015,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11025: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11040,13 +11034,13 @@
-echo "configure:11044: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11038: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11050 "configure"
+#line 11044 "configure"
@@ -11057,7 +11051,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11055: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11101,10 +11095,10 @@
 LDFLAGS="$LDFLAGS $OPENGLLIB"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11105: checking for glXCreatePbuffer" >&5
+echo "configure:11099: checking for glXCreatePbuffer" >&5
-#line 11108 "configure"
+#line 11102 "configure"
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -11127,7 +11121,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11131: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11125: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -11149,10 +11143,10 @@
 fi
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11153: checking for glXCreateGLXPixmap" >&5
+echo "configure:11147: checking for glXCreateGLXPixmap" >&5
-#line 11156 "configure"
+#line 11150 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -11175,7 +11169,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11173: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -11214,7 +11208,7 @@
-echo "configure:11218: checking for location of OpenGL includes" >&5
+echo "configure:11212: checking for location of OpenGL includes" >&5
@@ -11240,15 +11234,15 @@
 do
-echo "configure:11244: checking for $ac_hdr" >&5
+echo "configure:11238: checking for $ac_hdr" >&5
-#line 11247 "configure"
+#line 11241 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11252: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11246: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11283,10 +11277,10 @@
 LDFLAGS="$with_opengl_libs $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11287: checking for glBegin" >&5
+echo "configure:11281: checking for glBegin" >&5
-#line 11290 "configure"
+#line 11284 "configure"
     which can conflict with char glBegin(); below.  */
@@ -11309,7 +11303,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11313: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11307: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -11324,10 +11318,10 @@
   echo "$ac_t""yes" 1>&6
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11328: checking for gluBeginCurve" >&5
+echo "configure:11322: checking for gluBeginCurve" >&5
-#line 11331 "configure"
+#line 11325 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -11350,7 +11344,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11354: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11348: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -11394,7 +11388,7 @@
-echo "configure:11398: checking for location of OpenGL includes" >&5
+echo "configure:11392: checking for location of OpenGL includes" >&5
@@ -11420,15 +11414,15 @@
 do
-echo "configure:11424: checking for $ac_hdr" >&5
+echo "configure:11418: checking for $ac_hdr" >&5
-#line 11427 "configure"
+#line 11421 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11432: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11426: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11462,7 +11456,7 @@
-echo "configure:11466: checking for location of OpenGL library" >&5
+echo "configure:11460: checking for location of OpenGL library" >&5
@@ -11487,18 +11481,18 @@
 ac_save_libs="$LIBS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11491: checking for OpenGL library" >&5
+echo "configure:11485: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 11495 "configure"
+#line 11489 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:11502: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11496: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -11522,18 +11516,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11526: checking for GLU library" >&5
+echo "configure:11520: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 11530 "configure"
+#line 11524 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:11537: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11531: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -11582,7 +11576,7 @@
 echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:11586: checking whether to use Tcl/Tk" >&5
+echo "configure:11580: checking whether to use Tcl/Tk" >&5
 echo "$ac_t"""$with_tcltk"" 1>&6
 case "$with_tcltk" in
 	"no")	USE_TCLTK=	;;
@@ -11602,7 +11596,7 @@
 echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:11606: checking for location of Tcl/Tk includes" >&5
+echo "configure:11600: checking for location of Tcl/Tk includes" >&5
 case "$with_tcltk_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -11628,15 +11622,15 @@
 do
-echo "configure:11632: checking for $ac_hdr" >&5
+echo "configure:11626: checking for $ac_hdr" >&5
-#line 11635 "configure"
+#line 11629 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11640: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11634: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11673,15 +11667,15 @@
 do
-echo "configure:11677: checking for $ac_hdr" >&5
+echo "configure:11671: checking for $ac_hdr" >&5
-#line 11680 "configure"
+#line 11674 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11685: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11679: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11714,7 +11708,7 @@
 # Tcl/Tk version checks
 echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:11718: checking Tcl version" >&5
+echo "configure:11712: checking Tcl version" >&5
 CPPFLAGS="$TCLINCDIR $CPPFLAGS"
 if test "$cross_compiling" = yes; then
@@ -11722,7 +11716,7 @@
 else
-#line 11726 "configure"
+#line 11720 "configure"
 #include <stdio.h>
@@ -11734,7 +11728,7 @@
 EOF
-if { (eval echo configure:11738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11732: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tcl_ver=`cat conftestdata`
     echo "$ac_t""$tcl_ver" 1>&6
@@ -11752,7 +11746,7 @@
 echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:11756: checking Tk version" >&5
+echo "configure:11750: checking Tk version" >&5
 CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -11760,7 +11754,7 @@
 else
-#line 11764 "configure"
+#line 11758 "configure"
 #include <stdio.h>
@@ -11772,7 +11766,7 @@
 EOF
-if { (eval echo configure:11776: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11770: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tk_ver=`cat conftestdata`
     echo "$ac_t""$tk_ver" 1>&6
@@ -11803,7 +11797,7 @@
 echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:11807: checking for location of Tcl/Tk library" >&5
+echo "configure:11801: checking for location of Tcl/Tk library" >&5
 case "$with_tcltk_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -11843,13 +11837,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:11847: checking for Tcl_Init in -ltcl" >&5
+echo "configure:11841: checking for Tcl_Init in -ltcl" >&5
 ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl $MATHLIB $LIBS"
-#line 11853 "configure"
+#line 11847 "configure"
@@ -11860,7 +11854,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11864: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11858: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11879,13 +11873,13 @@
-echo "configure:11883: checking for Tcl_Init in -ltcl" >&5
+echo "configure:11877: checking for Tcl_Init in -ltcl" >&5
 LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 11889 "configure"
+#line 11883 "configure"
@@ -11896,7 +11890,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11900: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11894: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11923,13 +11917,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:11927: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:11921: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 11933 "configure"
+#line 11927 "configure"
@@ -11940,7 +11934,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11944: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11938: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11959,13 +11953,13 @@
-echo "configure:11963: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:11957: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 11969 "configure"
+#line 11963 "configure"
@@ -11976,7 +11970,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11980: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11974: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12003,13 +11997,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:12007: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:12001: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 12013 "configure"
+#line 12007 "configure"
@@ -12020,7 +12014,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:12024: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12018: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12039,13 +12033,13 @@
-echo "configure:12043: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:12037: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 12049 "configure"
+#line 12043 "configure"
@@ -12056,7 +12050,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:12060: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12054: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12134,13 +12128,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:12138: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12132: checking for Tk_MainWindow in -ltk" >&5
 ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 12144 "configure"
+#line 12138 "configure"
@@ -12151,7 +12145,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12155: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12149: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12170,13 +12164,13 @@
-echo "configure:12174: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12168: checking for Tk_MainWindow in -ltk" >&5
 LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12180 "configure"
+#line 12174 "configure"
@@ -12187,7 +12181,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12191: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12185: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12214,13 +12208,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:12218: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12212: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 12224 "configure"
+#line 12218 "configure"
@@ -12231,7 +12225,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12235: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12229: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12250,13 +12244,13 @@
-echo "configure:12254: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12248: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12260 "configure"
+#line 12254 "configure"
@@ -12267,7 +12261,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12271: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12265: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12294,13 +12288,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:12298: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12292: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 12304 "configure"
+#line 12298 "configure"
@@ -12311,7 +12305,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12315: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12309: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12330,13 +12324,13 @@
-echo "configure:12334: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12328: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12340 "configure"
+#line 12334 "configure"
@@ -12347,7 +12341,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12351: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12345: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12437,13 +12431,13 @@
   do
     # add only if in MACOSX_ARCHS
     echo $ac_n "checking for Tcl_Init in -l$tlib""... $ac_c" 1>&6
-echo "configure:12441: checking for Tcl_Init in -l$tlib" >&5
+echo "configure:12435: checking for Tcl_Init in -l$tlib" >&5
 ac_lib_var=`echo $tlib'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-l$tlib -arch $a $MACOSX_SDK $TCLTKLIBPATH $LIBS"
-#line 12447 "configure"
+#line 12441 "configure"
@@ -12454,7 +12448,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:12458: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12452: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12503,7 +12497,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:12507: checking whether to use ODBC" >&5
+echo "configure:12501: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -12522,7 +12516,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:12526: checking for location of ODBC includes" >&5
+echo "configure:12520: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -12548,15 +12542,15 @@
 do
-echo "configure:12552: checking for $ac_hdr" >&5
+echo "configure:12546: checking for $ac_hdr" >&5
-#line 12555 "configure"
+#line 12549 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12560: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12554: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12590,7 +12584,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:12594: checking for location of ODBC library" >&5
+echo "configure:12588: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12615,13 +12609,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12619: checking for SQLConnect in -lodbc" >&5
+echo "configure:12613: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 12625 "configure"
+#line 12619 "configure"
@@ -12632,7 +12626,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12636: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12630: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12657,13 +12651,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12661: checking for SQLConnect in -liodbc" >&5
+echo "configure:12655: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 12667 "configure"
+#line 12661 "configure"
@@ -12674,7 +12668,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12678: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12672: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12699,11 +12693,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12703: checking for ODBC library" >&5
+echo "configure:12697: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 12707 "configure"
+#line 12701 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -12711,7 +12705,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:12715: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12709: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -12760,7 +12754,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12764: checking whether to use FFTW" >&5
+echo "configure:12758: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -12779,7 +12773,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12783: checking for location of FFTW includes" >&5
+echo "configure:12777: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12805,15 +12799,15 @@
 do
-echo "configure:12809: checking for $ac_hdr" >&5
+echo "configure:12803: checking for $ac_hdr" >&5
-#line 12812 "configure"
+#line 12806 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12817: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12811: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12841,15 +12835,15 @@
 do
-echo "configure:12845: checking for $ac_hdr" >&5
+echo "configure:12839: checking for $ac_hdr" >&5
 cat > conftest.$ac_ext <<EOF
-#line 12848 "configure"
+#line 12842 "configure"
 #include "confdefs.h"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12853: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12847: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12877,15 +12871,15 @@
 do
-echo "configure:12881: checking for $ac_hdr" >&5
+echo "configure:12875: checking for $ac_hdr" >&5
-#line 12884 "configure"
+#line 12878 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12889: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12883: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12931,7 +12925,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12935: checking for location of FFTW library" >&5
+echo "configure:12929: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12956,13 +12950,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12960: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12954: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12966 "configure"
+#line 12960 "configure"
@@ -12973,7 +12967,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:12977: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12998,13 +12992,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:13002: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12996: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 13008 "configure"
+#line 13002 "configure"
@@ -13015,7 +13009,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:13019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13013: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13040,13 +13034,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:13044: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:13038: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 13050 "configure"
+#line 13044 "configure"
@@ -13057,7 +13051,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:13061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13055: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13114,7 +13108,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:13118: checking whether to use BLAS" >&5
+echo "configure:13112: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -13135,7 +13129,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:13139: checking for location of BLAS includes" >&5
+echo "configure:13133: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -13155,7 +13149,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:13159: checking for location of BLAS library" >&5
+echo "configure:13153: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -13181,15 +13175,15 @@
 do
-echo "configure:13185: checking for $ac_hdr" >&5
+echo "configure:13179: checking for $ac_hdr" >&5
-#line 13188 "configure"
+#line 13182 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13193: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13187: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -13224,13 +13218,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:13228: checking for dnrm2_ in -lblas" >&5
+echo "configure:13222: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 13234 "configure"
+#line 13228 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -13241,7 +13235,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:13245: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13239: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -13260,13 +13254,13 @@
-echo "configure:13264: checking for dnrm2_ in -lblas" >&5
+echo "configure:13258: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 13270 "configure"
+#line 13264 "configure"
@@ -13277,7 +13271,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:13281: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13275: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13321,13 +13315,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:13325: checking for ATL_xerbla in -latlas" >&5
+echo "configure:13319: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 13331 "configure"
+#line 13325 "configure"
@@ -13338,7 +13332,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:13342: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13336: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13353,13 +13347,13 @@
 if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:13357: checking for sgemm_ in -lf77blas" >&5
+echo "configure:13351: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 13363 "configure"
+#line 13357 "configure"
@@ -13370,7 +13364,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13374: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13368: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13385,13 +13379,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:13389: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:13383: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 13395 "configure"
+#line 13389 "configure"
@@ -13402,7 +13396,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:13406: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13400: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13448,16 +13442,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:13452: checking for sgemm in $vlib_flags" >&5
+echo "configure:13446: checking for sgemm in $vlib_flags" >&5
-#line 13454 "configure"
+#line 13448 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:13461: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13455: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -13475,13 +13469,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:13479: checking for sgemm_ in -lblas" >&5
+echo "configure:13473: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 13485 "configure"
+#line 13479 "configure"
@@ -13492,7 +13486,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13496: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13490: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13507,13 +13501,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:13511: checking for dgemm_ in -ldgemm" >&5
+echo "configure:13505: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 13517 "configure"
+#line 13511 "configure"
@@ -13524,7 +13518,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13528: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13522: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13539,13 +13533,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:13543: checking for sgemm_ in -lsgemm" >&5
+echo "configure:13537: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 13549 "configure"
+#line 13543 "configure"
@@ -13556,7 +13550,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13560: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13554: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13590,13 +13584,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:13594: checking for acosp in -lsunmath" >&5
+echo "configure:13588: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 13600 "configure"
+#line 13594 "configure"
@@ -13607,7 +13601,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:13611: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13605: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13622,13 +13616,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13626: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13620: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 13632 "configure"
+#line 13626 "configure"
@@ -13639,7 +13633,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13643: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13637: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13669,13 +13663,13 @@
 # Generic BLAS library
-echo "configure:13673: checking for sgemm_ in -lblas" >&5
+echo "configure:13667: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 13679 "configure"
+#line 13673 "configure"
@@ -13686,7 +13680,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13690: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13684: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13725,7 +13719,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13729: checking whether to use LAPACK" >&5
+echo "configure:13723: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -13750,7 +13744,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13754: checking for location of LAPACK includes" >&5
+echo "configure:13748: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13770,7 +13764,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13774: checking for location of LAPACK library" >&5
+echo "configure:13768: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13796,15 +13790,15 @@
 do
-echo "configure:13800: checking for $ac_hdr" >&5
+echo "configure:13794: checking for $ac_hdr" >&5
-#line 13803 "configure"
+#line 13797 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13808: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13802: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13836,10 +13830,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13840: checking for dsegv_" >&5
+echo "configure:13834: checking for dsegv_" >&5
-#line 13843 "configure"
+#line 13837 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -13862,7 +13856,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13866: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13860: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -13889,13 +13883,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13893: checking for desgv_ in -llapack" >&5
+echo "configure:13887: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 13899 "configure"
+#line 13893 "configure"
@@ -13906,7 +13900,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13910: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13904: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13938,13 +13932,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13942: checking for dgesv_ in -llapack" >&5
+echo "configure:13936: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 13948 "configure"
+#line 13942 "configure"
@@ -13955,7 +13949,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13959: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13953: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13974,13 +13968,13 @@
-echo "configure:13978: checking for dgesv_ in -llapack" >&5
+echo "configure:13972: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13984 "configure"
+#line 13978 "configure"
@@ -13991,7 +13985,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13995: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13989: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14047,7 +14041,7 @@
 echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:14051: checking whether to use Motif" >&5
+echo "configure:14045: checking whether to use Motif" >&5
 echo "$ac_t"""$with_motif"" 1>&6
 case "$with_motif" in
 	"no")	USE_MOTIF=	;;
@@ -14066,7 +14060,7 @@
 echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:14070: checking for location of Motif includes" >&5
+echo "configure:14064: checking for location of Motif includes" >&5
 case "$with_motif_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -14092,15 +14086,15 @@
 do
-echo "configure:14096: checking for $ac_hdr" >&5
+echo "configure:14090: checking for $ac_hdr" >&5
-#line 14099 "configure"
+#line 14093 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14104: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14098: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14134,7 +14128,7 @@
 echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:14138: checking for location of Motif library" >&5
+echo "configure:14132: checking for location of Motif library" >&5
 case "$with_motif_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -14159,13 +14153,13 @@
 echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:14163: checking for XmStringCreate in -lXm" >&5
+echo "configure:14157: checking for XmStringCreate in -lXm" >&5
 ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
 LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS  $LIBS"
-#line 14169 "configure"
+#line 14163 "configure"
@@ -14176,7 +14170,7 @@
 XmStringCreate()
 ; return 0; }
 EOF
-if { (eval echo configure:14180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14174: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14217,7 +14211,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:14221: checking whether to use Cairo" >&5
+echo "configure:14215: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -14249,7 +14243,7 @@
 echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:14253: checking for location of cairo includes" >&5
+echo "configure:14247: checking for location of cairo includes" >&5
 case "$with_cairo_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -14275,15 +14269,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:14279: checking for $ac_hdr" >&5
+echo "configure:14273: checking for $ac_hdr" >&5
-#line 14282 "configure"
+#line 14276 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14287: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14281: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14319,7 +14313,7 @@
 echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:14323: checking for location of cairo library" >&5
+echo "configure:14317: checking for location of cairo library" >&5
 case "$with_cairo_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -14339,7 +14333,7 @@
 echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:14343: checking for cairo linking flags" >&5
+echo "configure:14337: checking for cairo linking flags" >&5
 case "$with_cairo_ldflags" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -14355,10 +14349,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:14359: checking for cairo_create" >&5
+echo "configure:14353: checking for cairo_create" >&5
-#line 14362 "configure"
+#line 14356 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -14381,7 +14375,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14385: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14379: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -14415,10 +14409,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:14419: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:14413: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 14422 "configure"
+#line 14416 "configure"
     which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below.  */
@@ -14441,7 +14435,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14445: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14439: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
 else
@@ -14474,10 +14468,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:14478: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:14472: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 14481 "configure"
+#line 14475 "configure"
     which can conflict with char cairo_xlib_surface_get_xrender_format(); below.  */
@@ -14500,7 +14494,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14504: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14498: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
 else
@@ -14542,7 +14536,7 @@
 echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:14546: checking whether to use GLw" >&5
+echo "configure:14540: checking whether to use GLw" >&5
 echo "$ac_t"""$with_glw"" 1>&6
 case "$with_glw" in
 	"no")	USE_GLW=	;;
@@ -14561,7 +14555,7 @@
 echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:14565: checking for location of GLw includes" >&5
+echo "configure:14559: checking for location of GLw includes" >&5
 case "$with_glw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -14587,15 +14581,15 @@
 do
-echo "configure:14591: checking for $ac_hdr" >&5
+echo "configure:14585: checking for $ac_hdr" >&5
-#line 14594 "configure"
+#line 14588 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14599: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14593: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14623,15 +14617,15 @@
 do
-echo "configure:14627: checking for $ac_hdr" >&5
+echo "configure:14621: checking for $ac_hdr" >&5
-#line 14630 "configure"
+#line 14624 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14635: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14629: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14671,7 +14665,7 @@
 echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:14675: checking for location of GLw library" >&5
+echo "configure:14669: checking for location of GLw library" >&5
 case "$with_glw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -14696,13 +14690,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14700: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:14694: checking for GLwCreateMDrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14706 "configure"
+#line 14700 "configure"
@@ -14713,7 +14707,7 @@
 GLwCreateMDrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14717: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14711: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14738,13 +14732,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14742: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:14736: checking for GLwCreateM1DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14748 "configure"
+#line 14742 "configure"
@@ -14755,7 +14749,7 @@
 GLwCreateM1DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14759: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14753: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14780,13 +14774,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14784: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:14778: checking for GLwCreateM2DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14790 "configure"
+#line 14784 "configure"
@@ -14797,7 +14791,7 @@
 GLwCreateM2DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14801: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14795: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14822,13 +14816,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14826: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:14820: checking for GLwCreateMDrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14832 "configure"
+#line 14826 "configure"
@@ -14839,7 +14833,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14843: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14837: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14864,13 +14858,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14868: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:14862: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14874 "configure"
+#line 14868 "configure"
@@ -14881,7 +14875,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14885: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14879: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14906,13 +14900,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14910: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:14904: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14916 "configure"
+#line 14910 "configure"
@@ -14923,7 +14917,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14927: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14921: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14950,13 +14944,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:14954: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14948: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14960 "configure"
+#line 14954 "configure"
@@ -14967,7 +14961,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14965: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14986,13 +14980,13 @@
-echo "configure:14990: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14984: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14996 "configure"
+#line 14990 "configure"
@@ -15003,7 +14997,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15007: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15001: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15030,13 +15024,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:15034: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:15028: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 15040 "configure"
+#line 15034 "configure"
@@ -15047,7 +15041,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15051: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15045: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15066,13 +15060,13 @@
-echo "configure:15070: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:15064: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 15076 "configure"
+#line 15070 "configure"
@@ -15083,7 +15077,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15087: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15081: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15196,7 +15190,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:15200: checking whether to use FreeType" >&5
+echo "configure:15194: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -15215,7 +15209,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:15219: checking for location of FreeType includes" >&5
+echo "configure:15213: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -15241,15 +15235,15 @@
 do
-echo "configure:15245: checking for $ac_hdr" >&5
+echo "configure:15239: checking for $ac_hdr" >&5
-#line 15248 "configure"
+#line 15242 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15253: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15247: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15283,7 +15277,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:15287: checking for location of FreeType library" >&5
+echo "configure:15281: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -15308,13 +15302,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:15312: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:15306: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 15318 "configure"
+#line 15312 "configure"
@@ -15325,7 +15319,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:15329: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15323: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15366,7 +15360,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:15370: checking whether to use NLS" >&5
+echo "configure:15364: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -15386,10 +15380,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:15390: checking for gettext" >&5
+echo "configure:15384: checking for gettext" >&5
-#line 15393 "configure"
+#line 15387 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char gettext(); below.  */
@@ -15412,7 +15406,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15416: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15410: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -15430,13 +15424,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:15434: checking for gettext in -lintl" >&5
+echo "configure:15428: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 15440 "configure"
+#line 15434 "configure"
@@ -15447,7 +15441,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:15451: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15445: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15482,7 +15476,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:15486: checking whether to use C++" >&5
+echo "configure:15480: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -15498,7 +15492,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:15502: checking for $ac_word" >&5
+echo "configure:15496: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -15527,7 +15521,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:15531: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:15525: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -15538,12 +15532,12 @@
 cat > conftest.$ac_ext << EOF
-#line 15542 "configure"
+#line 15536 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:15547: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15541: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -15569,19 +15563,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:15573: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:15567: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:15578: checking whether we are using GNU C++" >&5
+echo "configure:15572: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15585: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15579: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -15599,7 +15593,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:15603: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:15597: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -15627,58 +15621,7 @@
   fi
 fi
-for ac_declaration in \
-   '#include <stdlib.h>' \
-   'extern "C" void std::exit (int) throw (); using std::exit;' \
-   'extern "C" void std::exit (int); using std::exit;' \
-   'extern "C" void exit (int) throw ();' \
-   'extern "C" void exit (int);' \
-   'void exit (int);'
-do
-  cat > conftest.$ac_ext <<EOF
-#line 15641 "configure"
-#include "confdefs.h"
-#include <stdlib.h>
-$ac_declaration
-int main() {
-exit (42);
-; return 0; }
-EOF
-if { (eval echo configure:15649: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
-  echo "configure: failed program was:" >&5
-  cat conftest.$ac_ext >&5
-  rm -rf conftest*
-  continue
-fi
-rm -f conftest*
-#line 15659 "configure"
-$ac_declaration
-int main() {
-exit (42);
-; return 0; }
-EOF
-if { (eval echo configure:15666: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
-  rm -rf conftest*
-  break
-else
-fi
-rm -f conftest*
-done
-if test -n "$ac_declaration"; then
-  echo '#ifdef __cplusplus' >>confdefs.h
-  echo $ac_declaration      >>confdefs.h
-  echo '#endif'             >>confdefs.h
-fi
-else
 	CXX=
 	CXXFLAGS=
@@ -15691,7 +15634,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:15695: checking whether to use openDWG" >&5
+echo "configure:15638: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -15711,7 +15654,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:15715: checking for location of openDGW includes" >&5
+echo "configure:15658: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -15737,15 +15680,15 @@
 do
-echo "configure:15741: checking for $ac_hdr" >&5
+echo "configure:15684: checking for $ac_hdr" >&5
-#line 15744 "configure"
+#line 15687 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15749: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15692: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15779,7 +15722,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:15783: checking for location of openDWG library" >&5
+echo "configure:15726: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -15826,7 +15769,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:15830: checking for special C compiler options needed for large files" >&5
+echo "configure:15773: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -15834,7 +15777,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 15838 "configure"
+#line 15781 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -15850,7 +15793,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15854: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15797: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -15859,7 +15802,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 15863 "configure"
+#line 15806 "configure"
@@ -15875,7 +15818,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15879: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15822: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -15895,11 +15838,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:15899: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:15842: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 15903 "configure"
+#line 15846 "configure"
@@ -15915,14 +15858,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15919: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15862: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15926 "configure"
+#line 15869 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -15940,7 +15883,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15944: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15887: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -15959,11 +15902,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:15963: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:15906: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 15967 "configure"
+#line 15910 "configure"
@@ -15979,14 +15922,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15983: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15926: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15990 "configure"
+#line 15933 "configure"
 #define _LARGE_FILES 1
@@ -16004,7 +15947,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:16008: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15951: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -16023,25 +15966,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:16027: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:15970: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 16031 "configure"
+#line 15974 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:16038: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15981: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 16045 "configure"
+#line 15988 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -16050,7 +15993,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:16054: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15997: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -16071,10 +16014,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:16075: checking if system supports Large Files at all" >&5
+echo "configure:16018: checking if system supports Large Files at all" >&5
-#line 16078 "configure"
+#line 16021 "configure"
 #include <stdio.h>
@@ -16106,7 +16049,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:16110: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16053: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -16135,7 +16078,7 @@
 # Python check
 echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:16139: checking whether to use Python" >&5
+echo "configure:16082: checking whether to use Python" >&5
 PYTHONINC=
 PYTHONCFLAGS=
@@ -16155,7 +16098,7 @@
   # Extract the first word of "python-config", so it can be a program name with args.
 set dummy python-config; ac_word=$2
-echo "configure:16159: checking for $ac_word" >&5
+echo "configure:16102: checking for $ac_word" >&5
 case "$PY_CONFIG" in
@@ -16197,15 +16140,15 @@
 do
-echo "configure:16201: checking for $ac_hdr" >&5
+echo "configure:16144: checking for $ac_hdr" >&5
-#line 16204 "configure"
+#line 16147 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:16209: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16152: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -16275,7 +16218,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:16279: checking whether to use wxWidgets" >&5
+echo "configure:16222: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -16296,7 +16239,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:16300: checking for $ac_word" >&5
+echo "configure:16243: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -16344,7 +16287,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:16348: checking wxWidgets version" >&5
+echo "configure:16291: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -16367,15 +16310,15 @@
 do
-echo "configure:16371: checking for $ac_hdr" >&5
+echo "configure:16314: checking for $ac_hdr" >&5
-#line 16374 "configure"
+#line 16317 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:16379: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16322: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
Modified: grass/branches/develbranch_6/configure.in
--- grass/branches/develbranch_6/configure.in	2013-07-27 11:19:06 UTC (rev 57292)
+++ grass/branches/develbranch_6/configure.in	2013-07-27 13:32:51 UTC (rev 57293)
@@ -64,11 +64,11 @@
 AC_PATH_PROG(pwd, pwd, pwd)
-if test "$MINGW32" = yes ; then
-  winpwd="$pwd -W"
-else
-  winpwd="$pwd"
-fi
+dnl if test "$MINGW32" = yes ; then
+dnl   winpwd="$pwd -W"
+dnl else
+dnl   winpwd="$pwd"
+dnl fi
 AC_MSG_CHECKING(for source directory)
@@ -83,7 +83,7 @@
 AC_MSG_CHECKING(for build directory)
 DSTDIR=`$pwd`
-WINDSTDIR=`$winpwd`
+dnl WINDSTDIR=`$winpwd`
 AC_MSG_RESULT("$DSTDIR")
@@ -107,7 +107,8 @@
 # Set GISBASE and GRASS_BIN
-GISBASE="${WINDSTDIR}/dist.${ARCH}"
+dnl GISBASE="${WINDSTDIR}/dist.${ARCH}
+GISBASE="${DSTDIR}/dist.${ARCH}"
 GRASS_BIN="${DSTDIR}/bin.${ARCH}"
 AC_SUBST(GISBASE)
