[GRASS-SVN] r57294 - grass/trunk
svn_grass at osgeo.org
Sat Jul 27 06:34:56 PDT 2013
Author: martinl
Date: 2013-07-27 06:34:56 -0700 (Sat, 27 Jul 2013)
New Revision: 57294
grass/trunk/configure
grass/trunk/configure.in
configure.in: disable pwd -W (WinGRASS)
Modified: grass/trunk/configure
--- grass/trunk/configure 2013-07-27 13:32:51 UTC (rev 57293)
+++ grass/trunk/configure 2013-07-27 13:34:56 UTC (rev 57294)
@@ -1203,14 +1203,9 @@
fi
-if test "$MINGW32" = yes ; then
- winpwd="$pwd -W"
-else
- winpwd="$pwd"
-fi
echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1214: checking for source directory" >&5
+echo "configure:1209: checking for source directory" >&5
if test -z "$srcdir" ; then
SRCDIR=`$pwd`
@@ -1221,10 +1216,9 @@
echo "$ac_t"""$SRCDIR"" 1>&6
echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1225: checking for build directory" >&5
+echo "configure:1220: checking for build directory" >&5
DSTDIR=`$pwd`
-WINDSTDIR=`$winpwd`
echo "$ac_t"""$DSTDIR"" 1>&6
@@ -1266,7 +1260,7 @@
# Set GISBASE and GRASS_BIN
-GISBASE="${WINDSTDIR}/dist.${ARCH}"
+GISBASE="${DSTDIR}/dist.${ARCH}"
GRASS_BIN="${DSTDIR}/bin.${ARCH}"
@@ -1289,7 +1283,7 @@
# Extract the first word of "svnversion", so it can be a program name with args.
set dummy svnversion; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:1293: checking for $ac_word" >&5
+echo "configure:1287: checking for $ac_word" >&5
case "$SVN_VERSION" in
@@ -1348,7 +1342,7 @@
echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1352: checking for MacOSX App" >&5
+echo "configure:1346: checking for MacOSX App" >&5
case "$enable_macosx_app" in
yes) MACOSX_APP=1 ;;
no) MACOSX_APP= ;;
@@ -1360,7 +1354,7 @@
# Check for MacOSX archs
echo $ac_n "checking for MacOSX architectures""... $ac_c" 1>&6
-echo "configure:1364: checking for MacOSX architectures" >&5
+echo "configure:1358: checking for MacOSX architectures" >&5
MACOSX_ARCHS=
@@ -1389,7 +1383,7 @@
# Check for MacOSX SDK
echo $ac_n "checking for MacOSX SDK""... $ac_c" 1>&6
-echo "configure:1393: checking for MacOSX SDK" >&5
+echo "configure:1387: checking for MacOSX SDK" >&5
MACOSX_SDK=
@@ -1399,7 +1393,7 @@
ac_safe=`echo "$with_macosx_sdk/SDKSettings.plist" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $with_macosx_sdk/SDKSettings.plist""... $ac_c" 1>&6
-echo "configure:1403: checking for $with_macosx_sdk/SDKSettings.plist" >&5
+echo "configure:1397: checking for $with_macosx_sdk/SDKSettings.plist" >&5
if test "$cross_compiling" = yes; then
{ echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -1443,7 +1437,7 @@
echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1447: checking how to build libraries" >&5
+echo "configure:1441: checking how to build libraries" >&5
# Check whether --enable-shared or --disable-shared was given.
if test "${enable_shared+set}" = set; then
enableval="$enable_shared"
@@ -2340,7 +2334,7 @@
# Done checking fortran
echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:2344: checking for additional include dirs" >&5
+echo "configure:2338: checking for additional include dirs" >&5
case "$with_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -2363,7 +2357,7 @@
# With libs option
echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:2367: checking for additional library dirs" >&5
+echo "configure:2361: checking for additional library dirs" >&5
case "$with_libs" in
{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -2397,7 +2391,7 @@
# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
# ./install, which can be erroneously created by make from ./install.sh.
echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:2401: checking for a BSD compatible install" >&5
+echo "configure:2395: checking for a BSD compatible install" >&5
if test -z "$INSTALL"; then
IFS="${IFS= }"; ac_save_IFS="$IFS"; IFS=":"
@@ -2450,7 +2444,7 @@
# Extract the first word of "flex", so it can be a program name with args.
set dummy flex; ac_word=$2
-echo "configure:2454: checking for $ac_word" >&5
+echo "configure:2448: checking for $ac_word" >&5
if test -n "$LEX"; then
ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -2481,13 +2475,13 @@
*) ac_lib=l ;;
esac
echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:2485: checking for yywrap in -l$ac_lib" >&5
+echo "configure:2479: checking for yywrap in -l$ac_lib" >&5
ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-l$ac_lib $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 2491 "configure"
+#line 2485 "configure"
#include "confdefs.h"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -2498,7 +2492,7 @@
yywrap()
; return 0; }
EOF
-if { (eval echo configure:2502: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2496: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -2523,7 +2517,7 @@
# Extract the first word of "lex", so it can be a program name with args.
set dummy lex; ac_word=$2
-echo "configure:2527: checking for $ac_word" >&5
+echo "configure:2521: checking for $ac_word" >&5
case "$LEXPATH" in
@@ -2563,7 +2557,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:2567: checking for $ac_word" >&5
+echo "configure:2561: checking for $ac_word" >&5
if test -n "$YACC"; then
ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -2594,7 +2588,7 @@
# Extract the first word of "yacc", so it can be a program name with args.
set dummy yacc; ac_word=$2
-echo "configure:2598: checking for $ac_word" >&5
+echo "configure:2592: checking for $ac_word" >&5
case "$YACCPATH" in
@@ -2632,7 +2626,7 @@
# Extract the first word of "ranlib", so it can be a program name with args.
set dummy ranlib; ac_word=$2
-echo "configure:2636: checking for $ac_word" >&5
+echo "configure:2630: checking for $ac_word" >&5
if test -n "$RANLIB"; then
ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -2661,7 +2655,7 @@
-echo "configure:2665: checking for $ac_word" >&5
+echo "configure:2659: checking for $ac_word" >&5
if test -n "$AR"; then
ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -2692,7 +2686,7 @@
-echo "configure:2696: checking for $ac_word" >&5
+echo "configure:2690: checking for $ac_word" >&5
if test -n "$ENV"; then
ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -2721,7 +2715,7 @@
# Extract the first word of "perl", so it can be a program name with args.
set dummy perl; ac_word=$2
-echo "configure:2725: checking for $ac_word" >&5
+echo "configure:2719: checking for $ac_word" >&5
case "$PERL" in
@@ -2752,7 +2746,7 @@
fi
echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:2756: checking how to run the C preprocessor" >&5
+echo "configure:2750: checking how to run the C preprocessor" >&5
# On Suns, sometimes $CPP names a directory.
if test -n "$CPP" && test -d "$CPP"; then
CPP=
@@ -2765,13 +2759,13 @@
# On the NeXT, cc -E runs the code through the compiler's parser,
# not just through cpp.
-#line 2769 "configure"
+#line 2763 "configure"
#include <assert.h>
Syntax Error
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:2775: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2769: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
@@ -2782,13 +2776,13 @@
rm -rf conftest*
CPP="${CC-cc} -E -traditional-cpp"
-#line 2786 "configure"
+#line 2780 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:2792: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2786: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2799,13 +2793,13 @@
rm -rf conftest*
CPP="${CC-cc} -nologo -E"
-#line 2803 "configure"
+#line 2797 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:2809: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2803: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2829,10 +2823,10 @@
echo "$ac_t""$CPP" 1>&6
echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:2833: checking for ANSI C header files" >&5
+echo "configure:2827: checking for ANSI C header files" >&5
-#line 2836 "configure"
+#line 2830 "configure"
#include <stdlib.h>
#include <stdarg.h>
@@ -2840,7 +2834,7 @@
#include <float.h>
EOF
-{ (eval echo configure:2844: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2838: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2857,7 +2851,7 @@
if test $ac_cv_header_stdc = yes; then
# SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 2861 "configure"
+#line 2855 "configure"
#include <string.h>
EOF
@@ -2875,7 +2869,7 @@
# ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 2879 "configure"
+#line 2873 "configure"
#include <stdlib.h>
EOF
@@ -2896,7 +2890,7 @@
else
-#line 2900 "configure"
+#line 2894 "configure"
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -2907,7 +2901,7 @@
exit (0); }
EOF
-if { (eval echo configure:2911: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:2905: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
else
@@ -2934,15 +2928,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:2938: checking for $ac_hdr" >&5
+echo "configure:2932: checking for $ac_hdr" >&5
-#line 2941 "configure"
+#line 2935 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2946: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2940: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2971,15 +2965,15 @@
do
-echo "configure:2975: checking for $ac_hdr" >&5
+echo "configure:2969: checking for $ac_hdr" >&5
-#line 2978 "configure"
+#line 2972 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2983: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2977: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3008,15 +3002,15 @@
do
-echo "configure:3012: checking for $ac_hdr" >&5
+echo "configure:3006: checking for $ac_hdr" >&5
-#line 3015 "configure"
+#line 3009 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3020: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3014: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3045,15 +3039,15 @@
do
-echo "configure:3049: checking for $ac_hdr" >&5
+echo "configure:3043: checking for $ac_hdr" >&5
-#line 3052 "configure"
+#line 3046 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3057: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3051: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3082,15 +3076,15 @@
do
-echo "configure:3086: checking for $ac_hdr" >&5
+echo "configure:3080: checking for $ac_hdr" >&5
-#line 3089 "configure"
+#line 3083 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3094: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3088: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3116,10 +3110,10 @@
done
echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:3120: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:3114: checking whether time.h and sys/time.h may both be included" >&5
-#line 3123 "configure"
+#line 3117 "configure"
#include <sys/types.h>
#include <sys/time.h>
@@ -3128,7 +3122,7 @@
struct tm *tp;
; return 0; }
EOF
-if { (eval echo configure:3132: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3126: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_header_time=yes
else
@@ -3148,10 +3142,10 @@
fi
echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:3152: checking for off_t" >&5
+echo "configure:3146: checking for off_t" >&5
-#line 3155 "configure"
+#line 3149 "configure"
#if STDC_HEADERS
@@ -3178,10 +3172,10 @@
fi
echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:3182: checking for uid_t in sys/types.h" >&5
+echo "configure:3176: checking for uid_t in sys/types.h" >&5
-#line 3185 "configure"
+#line 3179 "configure"
EOF
@@ -3209,10 +3203,10 @@
fi
echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:3213: checking return type of signal handlers" >&5
+echo "configure:3207: checking return type of signal handlers" >&5
-#line 3216 "configure"
+#line 3210 "configure"
#include <signal.h>
@@ -3229,7 +3223,7 @@
int i;
; return 0; }
EOF
-if { (eval echo configure:3233: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3227: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_type_signal=void
else
@@ -3247,10 +3241,10 @@
echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:3251: checking for Cygwin environment" >&5
+echo "configure:3245: checking for Cygwin environment" >&5
-#line 3254 "configure"
+#line 3248 "configure"
int main() {
@@ -3261,7 +3255,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:3265: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3259: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -3279,10 +3273,10 @@
for ac_func in ftime gethostname gettimeofday lseek nice time uname
do
echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:3283: checking for $ac_func" >&5
+echo "configure:3277: checking for $ac_func" >&5
-#line 3286 "configure"
+#line 3280 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char $ac_func(); below. */
@@ -3305,7 +3299,7 @@
; return 0; }
EOF
-if { (eval echo configure:3309: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3303: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_$ac_func=yes"
else
@@ -3331,10 +3325,10 @@
for ac_func in seteuid setpriority setreuid setruid
do
-echo "configure:3335: checking for $ac_func" >&5
+echo "configure:3329: checking for $ac_func" >&5
-#line 3338 "configure"
+#line 3332 "configure"
@@ -3357,7 +3351,7 @@
; return 0; }
EOF
-if { (eval echo configure:3361: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3355: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3383,10 +3377,10 @@
for ac_func in drand48
do
-echo "configure:3387: checking for $ac_func" >&5
+echo "configure:3381: checking for $ac_func" >&5
-#line 3390 "configure"
+#line 3384 "configure"
@@ -3409,7 +3403,7 @@
; return 0; }
EOF
-if { (eval echo configure:3413: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3407: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3435,10 +3429,10 @@
for ac_func in putenv setenv
do
-echo "configure:3439: checking for $ac_func" >&5
+echo "configure:3433: checking for $ac_func" >&5
-#line 3442 "configure"
+#line 3436 "configure"
@@ -3461,7 +3455,7 @@
; return 0; }
EOF
-if { (eval echo configure:3465: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3459: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3487,10 +3481,10 @@
for ac_func in nanosleep
do
-echo "configure:3491: checking for $ac_func" >&5
+echo "configure:3485: checking for $ac_func" >&5
-#line 3494 "configure"
+#line 3488 "configure"
@@ -3513,7 +3507,7 @@
; return 0; }
EOF
-if { (eval echo configure:3517: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3511: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3538,13 +3532,13 @@
if test "$cross_compiling" != "yes" ; then
echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:3542: checking whether setpgrp takes no argument" >&5
+echo "configure:3536: checking whether setpgrp takes no argument" >&5
{ echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
else
-#line 3548 "configure"
+#line 3542 "configure"
#ifdef HAVE_UNISTD_H
@@ -3564,7 +3558,7 @@
EOF
-if { (eval echo configure:3568: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3562: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
ac_cv_func_setpgrp_void=no
else
@@ -3592,16 +3586,16 @@
fi
echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:3596: checking for long long int" >&5
+echo "configure:3590: checking for long long int" >&5
-#line 3598 "configure"
+#line 3592 "configure"
int main() {
long long int x;
; return 0; }
EOF
-if { (eval echo configure:3605: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3599: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
echo "$ac_t""yes" 1>&6
@@ -3621,7 +3615,7 @@
rm -f conftest*
echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:3625: checking for W11" >&5
+echo "configure:3619: checking for W11" >&5
case "$enable_w11" in
yes|no) echo "$ac_t"""$enable_w11"" 1>&6 ;;
*) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
@@ -3649,7 +3643,7 @@
# Uses ac_ vars as temps to allow command line to override cache and checks.
# --without-x overrides everything else, but does not touch the cache.
echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:3653: checking for X" >&5
+echo "configure:3647: checking for X" >&5
# Check whether --with-x or --without-x was given.
if test "${with_x+set}" = set; then
@@ -3709,12 +3703,12 @@
# First, try using that file with no special directory specified.
-#line 3713 "configure"
+#line 3707 "configure"
#include <$x_direct_test_include>
EOF
-{ (eval echo configure:3718: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3712: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3783,14 +3777,14 @@
LIBS="-l$x_direct_test_library $LIBS"
-#line 3787 "configure"
+#line 3781 "configure"
int main() {
${x_direct_test_function}()
; return 0; }
EOF
-if { (eval echo configure:3794: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3788: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LIBS="$ac_save_LIBS"
# We can link X programs with no special library path.
@@ -3895,17 +3889,17 @@
case "`(uname -sr) 2>/dev/null`" in
"SunOS 5"*)
echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:3899: checking whether -R must be followed by a space" >&5
+echo "configure:3893: checking whether -R must be followed by a space" >&5
ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 3902 "configure"
+#line 3896 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:3909: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3903: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_nospace=yes
else
@@ -3921,14 +3915,14 @@
else
LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 3925 "configure"
+#line 3919 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:3932: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_space=yes
else
@@ -3960,13 +3954,13 @@
# libraries were built with DECnet support. And karl at cs.umb.edu says
# the Alpha needs dnet_stub (dnet does not exist).
echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:3964: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:3958: checking for dnet_ntoa in -ldnet" >&5
ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet $LIBS"
-#line 3970 "configure"
+#line 3964 "configure"
@@ -3977,7 +3971,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:3981: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3975: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3998,13 +3992,13 @@
if test $ac_cv_lib_dnet_dnet_ntoa = no; then
echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:4002: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:3996: checking for dnet_ntoa in -ldnet_stub" >&5
ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet_stub $LIBS"
-#line 4008 "configure"
+#line 4002 "configure"
@@ -4015,7 +4009,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:4019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4013: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4043,10 +4037,10 @@
# The nsl library prevents programs from opening the X display
# on Irix 5.2, according to dickey at clark.net.
echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:4047: checking for gethostbyname" >&5
+echo "configure:4041: checking for gethostbyname" >&5
-#line 4050 "configure"
+#line 4044 "configure"
which can conflict with char gethostbyname(); below. */
@@ -4069,7 +4063,7 @@
; return 0; }
EOF
-if { (eval echo configure:4073: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4067: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gethostbyname=yes"
else
@@ -4089,13 +4083,13 @@
if test $ac_cv_func_gethostbyname = no; then
echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:4093: checking for gethostbyname in -lnsl" >&5
+echo "configure:4087: checking for gethostbyname in -lnsl" >&5
ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 4099 "configure"
+#line 4093 "configure"
@@ -4106,7 +4100,7 @@
gethostbyname()
; return 0; }
EOF
-if { (eval echo configure:4110: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4104: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4135,10 +4129,10 @@
# -lsocket must be given before -lnsl if both are needed.
# We assume that if connect needs -lnsl, so does gethostbyname.
echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:4139: checking for connect" >&5
+echo "configure:4133: checking for connect" >&5
-#line 4142 "configure"
+#line 4136 "configure"
which can conflict with char connect(); below. */
@@ -4161,7 +4155,7 @@
; return 0; }
EOF
-if { (eval echo configure:4165: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4159: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_connect=yes"
else
@@ -4181,13 +4175,13 @@
if test $ac_cv_func_connect = no; then
echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:4185: checking for connect in -lsocket" >&5
+echo "configure:4179: checking for connect in -lsocket" >&5
ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 4191 "configure"
+#line 4185 "configure"
@@ -4198,7 +4192,7 @@
connect()
; return 0; }
EOF
-if { (eval echo configure:4202: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4196: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4221,10 +4215,10 @@
# gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:4225: checking for remove" >&5
+echo "configure:4219: checking for remove" >&5
-#line 4228 "configure"
+#line 4222 "configure"
which can conflict with char remove(); below. */
@@ -4247,7 +4241,7 @@
; return 0; }
EOF
-if { (eval echo configure:4251: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4245: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_remove=yes"
else
@@ -4267,13 +4261,13 @@
if test $ac_cv_func_remove = no; then
echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:4271: checking for remove in -lposix" >&5
+echo "configure:4265: checking for remove in -lposix" >&5
ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
LIBS="-lposix $LIBS"
-#line 4277 "configure"
+#line 4271 "configure"
@@ -4284,7 +4278,7 @@
remove()
; return 0; }
EOF
-if { (eval echo configure:4288: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4282: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4307,10 +4301,10 @@
# BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:4311: checking for shmat" >&5
+echo "configure:4305: checking for shmat" >&5
-#line 4314 "configure"
+#line 4308 "configure"
which can conflict with char shmat(); below. */
@@ -4333,7 +4327,7 @@
; return 0; }
EOF
-if { (eval echo configure:4337: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4331: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_shmat=yes"
else
@@ -4353,13 +4347,13 @@
if test $ac_cv_func_shmat = no; then
echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:4357: checking for shmat in -lipc" >&5
+echo "configure:4351: checking for shmat in -lipc" >&5
ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
LIBS="-lipc $LIBS"
-#line 4363 "configure"
+#line 4357 "configure"
@@ -4370,7 +4364,7 @@
shmat()
; return 0; }
EOF
-if { (eval echo configure:4374: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4368: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4402,13 +4396,13 @@
# libraries we check for below, so use a different variable.
# --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:4406: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:4400: checking for IceConnectionNumber in -lICE" >&5
ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 4412 "configure"
+#line 4406 "configure"
@@ -4419,7 +4413,7 @@
IceConnectionNumber()
; return 0; }
EOF
-if { (eval echo configure:4423: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4417: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4459,12 +4453,12 @@
LIBS=""
echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:4463: checking for library containing cuserid" >&5
+echo "configure:4457: checking for library containing cuserid" >&5
ac_func_search_save_LIBS="$LIBS"
ac_cv_search_cuserid="no"
-#line 4468 "configure"
+#line 4462 "configure"
@@ -4475,7 +4469,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:4479: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4473: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="none required"
else
@@ -4486,7 +4480,7 @@
test "$ac_cv_search_cuserid" = "no" && for i in compat; do
LIBS="-l$i $ac_func_search_save_LIBS"
-#line 4490 "configure"
+#line 4484 "configure"
@@ -4497,7 +4491,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:4501: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4495: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="-l$i"
break
@@ -4523,10 +4517,10 @@
for ac_func in asprintf
do
-echo "configure:4527: checking for $ac_func" >&5
+echo "configure:4521: checking for $ac_func" >&5
-#line 4530 "configure"
+#line 4524 "configure"
@@ -4549,7 +4543,7 @@
; return 0; }
EOF
-if { (eval echo configure:4553: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4547: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4576,10 +4570,10 @@
# Test if mathlib needs -lm flag or is included with libc
echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:4580: checking for atan" >&5
+echo "configure:4574: checking for atan" >&5
-#line 4583 "configure"
+#line 4577 "configure"
which can conflict with char atan(); below. */
@@ -4602,7 +4596,7 @@
; return 0; }
EOF
-if { (eval echo configure:4606: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4600: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_atan=yes"
else
@@ -4620,13 +4614,13 @@
echo "$ac_t""no" 1>&6
echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:4624: checking for atan in -lm" >&5
+echo "configure:4618: checking for atan in -lm" >&5
ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
LIBS="-lm $LIBS"
-#line 4630 "configure"
+#line 4624 "configure"
@@ -4637,7 +4631,7 @@
atan()
; return 0; }
EOF
-if { (eval echo configure:4641: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4635: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4664,10 +4658,10 @@
echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:4668: checking for dlsym" >&5
+echo "configure:4662: checking for dlsym" >&5
-#line 4671 "configure"
+#line 4665 "configure"
which can conflict with char dlsym(); below. */
@@ -4690,7 +4684,7 @@
; return 0; }
EOF
-if { (eval echo configure:4694: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4688: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dlsym=yes"
else
@@ -4708,13 +4702,13 @@
echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:4712: checking for dlsym in -ldl" >&5
+echo "configure:4706: checking for dlsym in -ldl" >&5
ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
LIBS="-ldl $LIBS"
-#line 4718 "configure"
+#line 4712 "configure"
@@ -4725,7 +4719,7 @@
dlsym()
; return 0; }
EOF
-if { (eval echo configure:4729: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4723: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4752,10 +4746,10 @@
echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:4756: checking for iconv" >&5
+echo "configure:4750: checking for iconv" >&5
-#line 4759 "configure"
+#line 4753 "configure"
which can conflict with char iconv(); below. */
@@ -4778,7 +4772,7 @@
; return 0; }
EOF
-if { (eval echo configure:4782: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4776: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_iconv=yes"
else
@@ -4796,13 +4790,13 @@
echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:4800: checking for iconv in -liconv" >&5
+echo "configure:4794: checking for iconv in -liconv" >&5
ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-liconv $LIBS"
-#line 4806 "configure"
+#line 4800 "configure"
@@ -4813,7 +4807,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:4817: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4811: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4832,13 +4826,13 @@
echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4836: checking for iconv in -lgiconv" >&5
+echo "configure:4830: checking for iconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-lgiconv $LIBS"
-#line 4842 "configure"
+#line 4836 "configure"
@@ -4849,7 +4843,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:4853: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4847: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4868,10 +4862,10 @@
echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:4872: checking for libiconv" >&5
+echo "configure:4866: checking for libiconv" >&5
-#line 4875 "configure"
+#line 4869 "configure"
which can conflict with char libiconv(); below. */
@@ -4894,7 +4888,7 @@
; return 0; }
EOF
-if { (eval echo configure:4898: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_libiconv=yes"
else
@@ -4912,13 +4906,13 @@
echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:4916: checking for libiconv in -liconv" >&5
+echo "configure:4910: checking for libiconv in -liconv" >&5
ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 4922 "configure"
+#line 4916 "configure"
@@ -4929,7 +4923,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:4933: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4927: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4948,13 +4942,13 @@
echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4952: checking for libiconv in -lgiconv" >&5
+echo "configure:4946: checking for libiconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 4958 "configure"
+#line 4952 "configure"
@@ -4965,7 +4959,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:4969: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4963: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5002,10 +4996,10 @@
have_socket=1
echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:5006: checking for socket" >&5
+echo "configure:5000: checking for socket" >&5
-#line 5009 "configure"
+#line 5003 "configure"
which can conflict with char socket(); below. */
@@ -5028,7 +5022,7 @@
; return 0; }
EOF
-if { (eval echo configure:5032: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5026: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_socket=yes"
else
@@ -5046,13 +5040,13 @@
echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:5050: checking for socket in -lsocket" >&5
+echo "configure:5044: checking for socket in -lsocket" >&5
ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
LIBS="-lsocket $LIBS"
-#line 5056 "configure"
+#line 5050 "configure"
@@ -5063,7 +5057,7 @@
socket()
; return 0; }
EOF
-if { (eval echo configure:5067: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5111,7 +5105,7 @@
echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:5115: checking for location of zlib includes" >&5
+echo "configure:5109: checking for location of zlib includes" >&5
case "$with_zlib_includes" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -5137,15 +5131,15 @@
do
-echo "configure:5141: checking for $ac_hdr" >&5
+echo "configure:5135: checking for $ac_hdr" >&5
-#line 5144 "configure"
+#line 5138 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5149: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5143: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5179,7 +5173,7 @@
echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:5183: checking for location of zlib library" >&5
+echo "configure:5177: checking for location of zlib library" >&5
case "$with_zlib_libs" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -5204,13 +5198,13 @@
echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:5208: checking for deflate in -lz" >&5
+echo "configure:5202: checking for deflate in -lz" >&5
ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
LIBS="-lz $LIBS"
-#line 5214 "configure"
+#line 5208 "configure"
@@ -5221,7 +5215,7 @@
deflate()
; return 0; }
EOF
-if { (eval echo configure:5225: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5219: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5269,7 +5263,7 @@
echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:5273: checking for location of External PROJ.4 includes" >&5
+echo "configure:5267: checking for location of External PROJ.4 includes" >&5
case "$with_proj_includes" in
{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -5295,15 +5289,15 @@
do
-echo "configure:5299: checking for $ac_hdr" >&5
+echo "configure:5293: checking for $ac_hdr" >&5
-#line 5302 "configure"
+#line 5296 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5307: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5301: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5340,7 +5334,7 @@
else
echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:5344: checking External PROJ.4 version" >&5
+echo "configure:5338: checking External PROJ.4 version" >&5
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -5348,7 +5342,7 @@
echo "$ac_t""unknown (cross-compiling)" 1>&6
else
-#line 5352 "configure"
+#line 5346 "configure"
#include <stdio.h>
@@ -5360,7 +5354,7 @@
EOF
-if { (eval echo configure:5364: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:5358: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
proj_ver=`cat conftestdata`
echo "$ac_t""$proj_ver" 1>&6
@@ -5385,7 +5379,7 @@
echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:5389: checking for location of External PROJ.4 library" >&5
+echo "configure:5383: checking for location of External PROJ.4 library" >&5
case "$with_proj_libs" in
{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -5410,13 +5404,13 @@
echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:5414: checking for pj_get_def in -lproj" >&5
+echo "configure:5408: checking for pj_get_def in -lproj" >&5
ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
LIBS="-lproj $LIBS"
-#line 5420 "configure"
+#line 5414 "configure"
@@ -5427,7 +5421,7 @@
pj_get_def()
; return 0; }
EOF
-if { (eval echo configure:5431: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5425: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5461,7 +5455,7 @@
echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:5465: checking for location of External PROJ.4 data files" >&5
+echo "configure:5459: checking for location of External PROJ.4 data files" >&5
case "$with_proj_share" in
{ echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -5485,14 +5479,14 @@
# LOC_CHECK_SHARE does not work when cross compiling
if test "$cross_compiling" = "yes" ; then
echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:5489: checking for epsg" >&5
+echo "configure:5483: checking for epsg" >&5
else
ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:5496: checking for $PROJSHARE/epsg" >&5
+echo "configure:5490: checking for $PROJSHARE/epsg" >&5
@@ -5524,7 +5518,7 @@
# Extract the first word of "nad2bin", so it can be a program name with args.
set dummy nad2bin; ac_word=$2
-echo "configure:5528: checking for $ac_word" >&5
+echo "configure:5522: checking for $ac_word" >&5
case "$NAD2BIN" in
@@ -5564,7 +5558,7 @@
echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:5568: checking whether to use regex" >&5
+echo "configure:5562: checking whether to use regex" >&5
echo "$ac_t"""$with_regex"" 1>&6
case "$with_regex" in
"no") USE_REGEX= ;;
@@ -5584,7 +5578,7 @@
echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:5588: checking for location of regex includes" >&5
+echo "configure:5582: checking for location of regex includes" >&5
case "$with_regex_includes" in
{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -5610,15 +5604,15 @@
do
-echo "configure:5614: checking for $ac_hdr" >&5
+echo "configure:5608: checking for $ac_hdr" >&5
-#line 5617 "configure"
+#line 5611 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5622: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5616: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5652,7 +5646,7 @@
echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:5656: checking for location of regex library" >&5
+echo "configure:5650: checking for location of regex library" >&5
case "$with_regex_libs" in
{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -5677,10 +5671,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:5681: checking for regcomp" >&5
+echo "configure:5675: checking for regcomp" >&5
-#line 5684 "configure"
+#line 5678 "configure"
which can conflict with char regcomp(); below. */
@@ -5703,7 +5697,7 @@
; return 0; }
EOF
-if { (eval echo configure:5707: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5701: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_regcomp=yes"
else
@@ -5730,13 +5724,13 @@
echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:5734: checking for regcomp in -lregex" >&5
+echo "configure:5728: checking for regcomp in -lregex" >&5
ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
LIBS="-lregex $LIBS"
-#line 5740 "configure"
+#line 5734 "configure"
@@ -5747,7 +5741,7 @@
regcomp()
; return 0; }
EOF
-if { (eval echo configure:5751: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5745: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5797,7 +5791,7 @@
echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:5801: checking whether to use Readline" >&5
+echo "configure:5795: checking whether to use Readline" >&5
echo "$ac_t"""$with_readline"" 1>&6
case "$with_readline" in
"no") USE_READLINE= ;;
@@ -5818,7 +5812,7 @@
echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:5822: checking for location of Readline includes" >&5
+echo "configure:5816: checking for location of Readline includes" >&5
case "$with_readline_includes" in
{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -5844,15 +5838,15 @@
do
-echo "configure:5848: checking for $ac_hdr" >&5
+echo "configure:5842: checking for $ac_hdr" >&5
-#line 5851 "configure"
+#line 5845 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5856: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5850: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5888,15 +5882,15 @@
do
-echo "configure:5892: checking for $ac_hdr" >&5
+echo "configure:5886: checking for $ac_hdr" >&5
-#line 5895 "configure"
+#line 5889 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5900: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5894: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5930,7 +5924,7 @@
echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:5934: checking for location of Readline library" >&5
+echo "configure:5928: checking for location of Readline library" >&5
case "$with_readline_libs" in
{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -5955,13 +5949,13 @@
echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:5959: checking for readline in -lreadline" >&5
+echo "configure:5953: checking for readline in -lreadline" >&5
ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
LIBS="-lreadline $LIBS"
-#line 5965 "configure"
+#line 5959 "configure"
@@ -5972,7 +5966,7 @@
readline()
; return 0; }
EOF
-if { (eval echo configure:5976: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6007,13 +6001,13 @@
echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:6011: checking for add_history in -lhistory" >&5
+echo "configure:6005: checking for add_history in -lhistory" >&5
ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
LIBS="-lhistory $LIBS"
-#line 6017 "configure"
+#line 6011 "configure"
@@ -6024,7 +6018,7 @@
add_history()
; return 0; }
EOF
-if { (eval echo configure:6028: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6022: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6066,7 +6060,7 @@
# GDAL option
echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:6070: checking whether to use GDAL" >&5
+echo "configure:6064: checking whether to use GDAL" >&5
GDAL_LIBS=
GDAL_CFLAGS=
@@ -6084,7 +6078,7 @@
# Extract the first word of "gdal-config", so it can be a program name with args.
set dummy gdal-config; ac_word=$2
-echo "configure:6088: checking for $ac_word" >&5
+echo "configure:6082: checking for $ac_word" >&5
case "$GDAL_CONFIG" in
@@ -6139,14 +6133,14 @@
LIBS="$LIBS $GDAL_LIBS"
CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 6143 "configure"
+#line 6137 "configure"
#include <gdal.h>
int main() {
GDALOpen("foo", GA_ReadOnly);
; return 0; }
EOF
-if { (eval echo configure:6150: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6144: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
echo "configure: failed program was:" >&5
@@ -6155,14 +6149,14 @@
LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 6159 "configure"
+#line 6153 "configure"
#include <gdal.h>
int main() {
; return 0; }
EOF
-if { (eval echo configure:6166: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6160: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
else
@@ -6194,7 +6188,7 @@
# libLAS option
echo $ac_n "checking whether to use libLAS""... $ac_c" 1>&6
-echo "configure:6198: checking whether to use libLAS" >&5
+echo "configure:6192: checking whether to use libLAS" >&5
LIBLAS_LIBS=
LIBLAS_CFLAGS=
@@ -6211,7 +6205,7 @@
# Extract the first word of "liblas-config", so it can be a program name with args.
set dummy liblas-config; ac_word=$2
-echo "configure:6215: checking for $ac_word" >&5
+echo "configure:6209: checking for $ac_word" >&5
case "$LIBLAS_CONFIG" in
@@ -6259,14 +6253,14 @@
LIBS="$LIBS $LIBLAS_LIBS"
CFLAGS="$CFLAGS $LIBLAS_CFLAGS"
-#line 6263 "configure"
+#line 6257 "configure"
#include <liblas/capi/liblas.h>
int main() {
LASReader_Create("foo");
; return 0; }
EOF
-if { (eval echo configure:6270: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6264: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
@@ -6274,14 +6268,14 @@
rm -rf conftest*
-#line 6278 "configure"
+#line 6272 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:6285: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6279: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LAS_LIBS="$LAS_LIBS"
else
@@ -6313,7 +6307,7 @@
# NetCDF option
echo $ac_n "checking whether to use NetCDF""... $ac_c" 1>&6
-echo "configure:6317: checking whether to use NetCDF" >&5
+echo "configure:6311: checking whether to use NetCDF" >&5
NETCDF_LIBS=
NETCDF_CFLAGS=
@@ -6330,7 +6324,7 @@
# Extract the first word of "nc-config", so it can be a program name with args.
set dummy nc-config; ac_word=$2
-echo "configure:6334: checking for $ac_word" >&5
+echo "configure:6328: checking for $ac_word" >&5
case "$NETCDF_CONFIG" in
@@ -6377,14 +6371,14 @@
LIBS="$LIBS $NETCDF_LIBS"
CFLAGS="$CFLAGS $NETCDF_CFLAGS"
-#line 6381 "configure"
+#line 6375 "configure"
#include <netcdf.h>
int main() {
nc_create("foo", NC_CLOBBER, NULL);
; return 0; }
EOF
-if { (eval echo configure:6388: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6382: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
@@ -6392,14 +6386,14 @@
rm -rf conftest*
-#line 6396 "configure"
+#line 6390 "configure"
#include <netcdf.h>
int main() {
; return 0; }
EOF
-if { (eval echo configure:6403: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6397: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
NETCDF_LIBS="$NETCDF_LIBS"
else
@@ -6430,7 +6424,7 @@
# GEOS option
echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:6434: checking whether to use GEOS" >&5
+echo "configure:6428: checking whether to use GEOS" >&5
GEOS_LIBS=
GEOS_CFLAGS=
@@ -6448,7 +6442,7 @@
# Extract the first word of "geos-config", so it can be a program name with args.
set dummy geos-config; ac_word=$2
-echo "configure:6452: checking for $ac_word" >&5
+echo "configure:6446: checking for $ac_word" >&5
case "$GEOS_CONFIG" in
@@ -6496,15 +6490,15 @@
do
-echo "configure:6500: checking for $ac_hdr" >&5
+echo "configure:6494: checking for $ac_hdr" >&5
-#line 6503 "configure"
+#line 6497 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6508: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6502: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6543,13 +6537,13 @@
echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:6547: checking for initGEOS in -lgeos_c" >&5
+echo "configure:6541: checking for initGEOS in -lgeos_c" >&5
ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
LIBS="-lgeos_c $LIBS"
-#line 6553 "configure"
+#line 6547 "configure"
@@ -6560,7 +6554,7 @@
initGEOS()
; return 0; }
EOF
-if { (eval echo configure:6564: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6558: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6604,7 +6598,7 @@
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:6608: checking whether to use TIFF" >&5
+echo "configure:6602: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -6624,7 +6618,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:6628: checking for location of TIFF includes" >&5
+echo "configure:6622: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -6650,15 +6644,15 @@
do
-echo "configure:6654: checking for $ac_hdr" >&5
+echo "configure:6648: checking for $ac_hdr" >&5
-#line 6657 "configure"
+#line 6651 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6662: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6656: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6692,7 +6686,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:6696: checking for location of TIFF library" >&5
+echo "configure:6690: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -6723,13 +6717,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:6727: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6721: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
LIBS="-ltiff $LIBS"
-#line 6733 "configure"
+#line 6727 "configure"
@@ -6740,7 +6734,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6744: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6759,13 +6753,13 @@
-echo "configure:6763: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6757: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
-#line 6769 "configure"
+#line 6763 "configure"
@@ -6776,7 +6770,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6780: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6774: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6795,13 +6789,13 @@
-echo "configure:6799: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6793: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 6805 "configure"
+#line 6799 "configure"
@@ -6812,7 +6806,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6816: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6810: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6831,13 +6825,13 @@
-echo "configure:6835: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6829: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 6841 "configure"
+#line 6835 "configure"
@@ -6848,7 +6842,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6852: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6846: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6867,13 +6861,13 @@
-echo "configure:6871: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6865: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $LIBS"
-#line 6877 "configure"
+#line 6871 "configure"
@@ -6884,7 +6878,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6888: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6882: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6903,13 +6897,13 @@
-echo "configure:6907: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6901: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $MATHLIB $LIBS"
-#line 6913 "configure"
+#line 6907 "configure"
@@ -6920,7 +6914,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6924: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6918: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6939,13 +6933,13 @@
-echo "configure:6943: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6937: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $ZLIB $LIBS"
-#line 6949 "configure"
+#line 6943 "configure"
@@ -6956,7 +6950,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6960: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6954: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6975,13 +6969,13 @@
-echo "configure:6979: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6973: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $ZLIB $MATHLIB $LIBS"
-#line 6985 "configure"
+#line 6979 "configure"
@@ -6992,7 +6986,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6996: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6990: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7090,7 +7084,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:7094: checking whether to use PNG" >&5
+echo "configure:7088: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -7109,7 +7103,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:7113: checking for location of PNG includes" >&5
+echo "configure:7107: checking for location of PNG includes" >&5
case "$with_png_includes" in
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -7135,15 +7129,15 @@
do
-echo "configure:7139: checking for $ac_hdr" >&5
+echo "configure:7133: checking for $ac_hdr" >&5
-#line 7142 "configure"
+#line 7136 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7147: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7141: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7177,7 +7171,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:7181: checking for location of PNG library" >&5
+echo "configure:7175: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -7202,13 +7196,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:7206: checking for png_read_image in -lpng" >&5
+echo "configure:7200: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 7212 "configure"
+#line 7206 "configure"
@@ -7219,7 +7213,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:7223: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7217: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7261,7 +7255,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:7265: checking whether to use PostgreSQL" >&5
+echo "configure:7259: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -7288,7 +7282,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:7292: checking for location of PostgreSQL includes" >&5
+echo "configure:7286: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -7314,15 +7308,15 @@
do
-echo "configure:7318: checking for $ac_hdr" >&5
+echo "configure:7312: checking for $ac_hdr" >&5
-#line 7321 "configure"
+#line 7315 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7326: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7320: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7360,7 +7354,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:7364: checking for location of PostgreSQL library" >&5
+echo "configure:7358: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -7389,13 +7383,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:7393: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7387: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 7399 "configure"
+#line 7393 "configure"
@@ -7406,7 +7400,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7410: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7404: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7425,13 +7419,13 @@
-echo "configure:7429: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7423: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 7435 "configure"
+#line 7429 "configure"
@@ -7442,7 +7436,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7440: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7461,13 +7455,13 @@
-echo "configure:7465: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7459: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 7471 "configure"
+#line 7465 "configure"
@@ -7478,7 +7472,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7482: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7476: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7497,13 +7491,13 @@
-echo "configure:7501: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7495: checking for PQsetdbLogin in -lpq" >&5
ac_save_LIBS="$LIBS"
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 7507 "configure"
+#line 7501 "configure"
#include "confdefs.h"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -7514,7 +7508,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7518: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7512: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -7571,13 +7565,13 @@
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:7575: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7569: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 7581 "configure"
+#line 7575 "configure"
@@ -7588,7 +7582,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:7592: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7586: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7610,13 +7604,13 @@
-echo "configure:7614: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7608: checking for PQcmdTuples in -lpq" >&5
-#line 7620 "configure"
+#line 7614 "configure"
@@ -7627,7 +7621,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:7631: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7625: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7670,7 +7664,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:7674: checking whether to use MySQL" >&5
+echo "configure:7668: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -7690,7 +7684,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:7694: checking for location of MySQL includes" >&5
+echo "configure:7688: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -7716,15 +7710,15 @@
do
-echo "configure:7720: checking for $ac_hdr" >&5
+echo "configure:7714: checking for $ac_hdr" >&5
-#line 7723 "configure"
+#line 7717 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7728: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7722: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7761,7 +7755,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:7765: checking for location of MySQL library" >&5
+echo "configure:7759: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -7792,13 +7786,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:7796: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7790: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 7802 "configure"
+#line 7796 "configure"
@@ -7809,7 +7803,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7813: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7807: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7828,13 +7822,13 @@
-echo "configure:7832: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7826: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 7838 "configure"
+#line 7832 "configure"
@@ -7845,7 +7839,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7849: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7843: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7864,13 +7858,13 @@
-echo "configure:7868: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7862: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 7874 "configure"
+#line 7868 "configure"
@@ -7881,7 +7875,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7885: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7879: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7900,13 +7894,13 @@
-echo "configure:7904: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7898: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 7910 "configure"
+#line 7904 "configure"
@@ -7917,7 +7911,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7921: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7915: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7936,13 +7930,13 @@
-echo "configure:7940: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7934: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 7946 "configure"
+#line 7940 "configure"
@@ -7953,7 +7947,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7957: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7951: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7972,13 +7966,13 @@
-echo "configure:7976: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7970: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 7982 "configure"
+#line 7976 "configure"
@@ -7989,7 +7983,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7993: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7987: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8008,13 +8002,13 @@
-echo "configure:8012: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8006: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 8018 "configure"
+#line 8012 "configure"
@@ -8025,7 +8019,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8029: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8023: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8044,13 +8038,13 @@
-echo "configure:8048: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8042: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 8054 "configure"
+#line 8048 "configure"
@@ -8061,7 +8055,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8065: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8059: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8151,7 +8145,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:8155: checking for $ac_word" >&5
+echo "configure:8149: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -8200,10 +8194,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:8204: checking for mysql_server_init" >&5
+echo "configure:8198: checking for mysql_server_init" >&5
-#line 8207 "configure"
+#line 8201 "configure"
which can conflict with char mysql_server_init(); below. */
@@ -8229,7 +8223,7 @@
; return 0; }
EOF
-if { (eval echo configure:8233: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8227: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -8281,7 +8275,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:8285: checking whether to use SQLite" >&5
+echo "configure:8279: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -8301,7 +8295,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:8305: checking for location of SQLite includes" >&5
+echo "configure:8299: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -8327,15 +8321,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:8331: checking for $ac_hdr" >&5
+echo "configure:8325: checking for $ac_hdr" >&5
-#line 8334 "configure"
+#line 8328 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:8339: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8333: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -8378,7 +8372,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:8382: checking for location of SQLite library" >&5
+echo "configure:8376: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -8407,13 +8401,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:8411: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8405: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 8417 "configure"
+#line 8411 "configure"
@@ -8424,7 +8418,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8428: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8422: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8443,13 +8437,13 @@
-echo "configure:8447: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8441: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 8453 "configure"
+#line 8447 "configure"
@@ -8460,7 +8454,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8464: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8458: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8479,13 +8473,13 @@
-echo "configure:8483: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8477: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 8489 "configure"
+#line 8483 "configure"
@@ -8496,7 +8490,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8500: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8494: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8515,13 +8509,13 @@
-echo "configure:8519: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8513: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 8525 "configure"
+#line 8519 "configure"
@@ -8532,7 +8526,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8536: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8530: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8601,7 +8595,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:8605: checking whether to use FFMPEG" >&5
+echo "configure:8599: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -8621,7 +8615,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:8625: checking for location of FFMPEG includes" >&5
+echo "configure:8619: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -8647,15 +8641,15 @@
do
-echo "configure:8651: checking for $ac_hdr" >&5
+echo "configure:8645: checking for $ac_hdr" >&5
-#line 8654 "configure"
+#line 8648 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8659: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8653: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8691,15 +8685,15 @@
do
-echo "configure:8695: checking for $ac_hdr" >&5
+echo "configure:8689: checking for $ac_hdr" >&5
-#line 8698 "configure"
+#line 8692 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8703: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8697: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8735,15 +8729,15 @@
do
-echo "configure:8739: checking for $ac_hdr" >&5
+echo "configure:8733: checking for $ac_hdr" >&5
-#line 8742 "configure"
+#line 8736 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8747: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8741: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8786,7 +8780,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:8790: checking for location of FFMPEG library" >&5
+echo "configure:8784: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -8813,13 +8807,13 @@
echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:8817: checking for av_free in -lavutil" >&5
+echo "configure:8811: checking for av_free in -lavutil" >&5
ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
LIBS="-lavutil $LIBS"
-#line 8823 "configure"
+#line 8817 "configure"
@@ -8830,7 +8824,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:8834: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8828: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8849,13 +8843,13 @@
-echo "configure:8853: checking for av_free in -lavutil" >&5
+echo "configure:8847: checking for av_free in -lavutil" >&5
LIBS="-lavutil $MATHLIB $LIBS"
-#line 8859 "configure"
+#line 8853 "configure"
@@ -8866,7 +8860,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:8870: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8864: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8911,13 +8905,13 @@
echo $ac_n "checking for avcodec_register in -lavcodec""... $ac_c" 1>&6
-echo "configure:8915: checking for avcodec_register in -lavcodec" >&5
+echo "configure:8909: checking for avcodec_register in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_register | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $FFMPEGLIB $LIBS"
-#line 8921 "configure"
+#line 8915 "configure"
@@ -8928,7 +8922,7 @@
avcodec_register()
; return 0; }
EOF
-if { (eval echo configure:8932: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8947,13 +8941,13 @@
-echo "configure:8951: checking for avcodec_register in -lavcodec" >&5
+echo "configure:8945: checking for avcodec_register in -lavcodec" >&5
LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 8957 "configure"
+#line 8951 "configure"
@@ -8964,7 +8958,7 @@
avcodec_register()
; return 0; }
EOF
-if { (eval echo configure:8968: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8962: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9009,13 +9003,13 @@
echo $ac_n "checking for avformat_alloc_context in -lavformat""... $ac_c" 1>&6
-echo "configure:9013: checking for avformat_alloc_context in -lavformat" >&5
+echo "configure:9007: checking for avformat_alloc_context in -lavformat" >&5
ac_lib_var=`echo avformat'_'avformat_alloc_context | sed 'y%./+-%__p_%'`
LIBS="-lavformat $FFMPEGLIB $LIBS"
-#line 9019 "configure"
+#line 9013 "configure"
@@ -9026,7 +9020,7 @@
avformat_alloc_context()
; return 0; }
EOF
-if { (eval echo configure:9030: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9024: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9045,13 +9039,13 @@
-echo "configure:9049: checking for avformat_alloc_context in -lavformat" >&5
+echo "configure:9043: checking for avformat_alloc_context in -lavformat" >&5
LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 9055 "configure"
+#line 9049 "configure"
@@ -9062,7 +9056,7 @@
; return 0; }
EOF
-if { (eval echo configure:9066: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9060: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9121,7 +9115,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:9125: checking whether to use OpenGL" >&5
+echo "configure:9119: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -9155,7 +9149,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:9159: checking for location of OpenGL includes" >&5
+echo "configure:9153: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -9181,15 +9175,15 @@
do
-echo "configure:9185: checking for $ac_hdr" >&5
+echo "configure:9179: checking for $ac_hdr" >&5
-#line 9188 "configure"
+#line 9182 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9193: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9187: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9223,7 +9217,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:9227: checking for location of OpenGL library" >&5
+echo "configure:9221: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -9252,13 +9246,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:9256: checking for glBegin in -lGL" >&5
+echo "configure:9250: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 9262 "configure"
+#line 9256 "configure"
@@ -9269,7 +9263,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9273: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9267: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9288,13 +9282,13 @@
-echo "configure:9292: checking for glBegin in -lGL" >&5
+echo "configure:9286: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 9298 "configure"
+#line 9292 "configure"
@@ -9305,7 +9299,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9309: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9303: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9324,13 +9318,13 @@
-echo "configure:9328: checking for glBegin in -lGL" >&5
+echo "configure:9322: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 9334 "configure"
+#line 9328 "configure"
@@ -9341,7 +9335,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9345: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9339: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9360,13 +9354,13 @@
-echo "configure:9364: checking for glBegin in -lGL" >&5
+echo "configure:9358: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 9370 "configure"
+#line 9364 "configure"
@@ -9377,7 +9371,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9381: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9375: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9439,13 +9433,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:9443: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9437: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 9449 "configure"
+#line 9443 "configure"
@@ -9456,7 +9450,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:9460: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9454: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9475,13 +9469,13 @@
-echo "configure:9479: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9473: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 9485 "configure"
+#line 9479 "configure"
@@ -9492,7 +9486,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:9496: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9490: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9539,10 +9533,10 @@
LIBS=" $OPENGLLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:9543: checking for glXCreatePbuffer" >&5
+echo "configure:9537: checking for glXCreatePbuffer" >&5
-#line 9546 "configure"
+#line 9540 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char glXCreatePbuffer(); below. */
@@ -9565,7 +9559,7 @@
; return 0; }
EOF
-if { (eval echo configure:9569: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9563: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -9602,10 +9596,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:9606: checking for glXCreateGLXPixmap" >&5
+echo "configure:9600: checking for glXCreateGLXPixmap" >&5
-#line 9609 "configure"
+#line 9603 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -9628,7 +9622,7 @@
; return 0; }
EOF
-if { (eval echo configure:9632: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9626: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -9671,7 +9665,7 @@
echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:9675: checking for location of OpenGL framework" >&5
+echo "configure:9669: checking for location of OpenGL framework" >&5
case "$with_opengl_framework" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -9695,15 +9689,15 @@
do
-echo "configure:9699: checking for $ac_hdr" >&5
+echo "configure:9693: checking for $ac_hdr" >&5
-#line 9702 "configure"
+#line 9696 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9707: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9701: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9739,10 +9733,10 @@
LIBS="-framework OpenGL -framework AGL -framework ApplicationServices $LIBS"
LDFLAGS="$OPENGLPATH $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:9743: checking for glBegin" >&5
+echo "configure:9737: checking for glBegin" >&5
-#line 9746 "configure"
+#line 9740 "configure"
which can conflict with char glBegin(); below. */
@@ -9765,7 +9759,7 @@
; return 0; }
EOF
-if { (eval echo configure:9769: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9763: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -9802,10 +9796,10 @@
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:9806: checking for gluBeginCurve" >&5
+echo "configure:9800: checking for gluBeginCurve" >&5
-#line 9809 "configure"
+#line 9803 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -9828,7 +9822,7 @@
; return 0; }
EOF
-if { (eval echo configure:9832: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -9876,7 +9870,7 @@
-echo "configure:9880: checking for location of OpenGL includes" >&5
+echo "configure:9874: checking for location of OpenGL includes" >&5
@@ -9902,15 +9896,15 @@
do
-echo "configure:9906: checking for $ac_hdr" >&5
+echo "configure:9900: checking for $ac_hdr" >&5
-#line 9909 "configure"
+#line 9903 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9914: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9908: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9944,7 +9938,7 @@
-echo "configure:9948: checking for location of OpenGL library" >&5
+echo "configure:9942: checking for location of OpenGL library" >&5
@@ -9969,18 +9963,18 @@
ac_save_libs="$LIBS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:9973: checking for OpenGL library" >&5
+echo "configure:9967: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 9977 "configure"
+#line 9971 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:9984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9978: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -10004,18 +9998,18 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:10008: checking for GLU library" >&5
+echo "configure:10002: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 10012 "configure"
+#line 10006 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:10019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10013: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -10064,7 +10058,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:10068: checking whether to use ODBC" >&5
+echo "configure:10062: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -10083,7 +10077,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:10087: checking for location of ODBC includes" >&5
+echo "configure:10081: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -10109,15 +10103,15 @@
do
-echo "configure:10113: checking for $ac_hdr" >&5
+echo "configure:10107: checking for $ac_hdr" >&5
-#line 10116 "configure"
+#line 10110 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10121: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10115: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10151,7 +10145,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:10155: checking for location of ODBC library" >&5
+echo "configure:10149: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -10176,13 +10170,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:10180: checking for SQLConnect in -lodbc" >&5
+echo "configure:10174: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 10186 "configure"
+#line 10180 "configure"
@@ -10193,7 +10187,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:10197: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10191: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10218,13 +10212,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:10222: checking for SQLConnect in -liodbc" >&5
+echo "configure:10216: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 10228 "configure"
+#line 10222 "configure"
@@ -10235,7 +10229,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:10239: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10233: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10260,11 +10254,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:10264: checking for ODBC library" >&5
+echo "configure:10258: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 10268 "configure"
+#line 10262 "configure"
#include <windows.h>
#include <sql.h>
@@ -10272,7 +10266,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:10276: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10270: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -10321,7 +10315,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:10325: checking whether to use FFTW" >&5
+echo "configure:10319: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -10340,7 +10334,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:10344: checking for location of FFTW includes" >&5
+echo "configure:10338: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -10366,15 +10360,15 @@
do
-echo "configure:10370: checking for $ac_hdr" >&5
+echo "configure:10364: checking for $ac_hdr" >&5
-#line 10373 "configure"
+#line 10367 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10378: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10372: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10402,15 +10396,15 @@
do
-echo "configure:10406: checking for $ac_hdr" >&5
+echo "configure:10400: checking for $ac_hdr" >&5
-#line 10409 "configure"
+#line 10403 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10414: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10408: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10438,15 +10432,15 @@
do
-echo "configure:10442: checking for $ac_hdr" >&5
+echo "configure:10436: checking for $ac_hdr" >&5
-#line 10445 "configure"
+#line 10439 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10450: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10444: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10492,7 +10486,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:10496: checking for location of FFTW library" >&5
+echo "configure:10490: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -10517,13 +10511,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:10521: checking for fftw_execute in -lfftw3" >&5
+echo "configure:10515: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 10527 "configure"
+#line 10521 "configure"
@@ -10534,7 +10528,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:10538: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10532: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10559,13 +10553,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:10563: checking for fftwnd_one in -lfftw" >&5
+echo "configure:10557: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
-#line 10569 "configure"
+#line 10563 "configure"
@@ -10576,7 +10570,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:10580: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10574: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10601,13 +10595,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:10605: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:10599: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 10611 "configure"
+#line 10605 "configure"
@@ -10618,7 +10612,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:10622: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10616: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10675,7 +10669,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:10679: checking whether to use BLAS" >&5
+echo "configure:10673: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -10696,7 +10690,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:10700: checking for location of BLAS includes" >&5
+echo "configure:10694: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -10716,7 +10710,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:10720: checking for location of BLAS library" >&5
+echo "configure:10714: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -10742,15 +10736,15 @@
do
-echo "configure:10746: checking for $ac_hdr" >&5
+echo "configure:10740: checking for $ac_hdr" >&5
-#line 10749 "configure"
+#line 10743 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10754: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10748: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10785,13 +10779,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:10789: checking for dnrm2_ in -lblas" >&5
+echo "configure:10783: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 10795 "configure"
+#line 10789 "configure"
@@ -10802,7 +10796,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:10806: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10800: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10821,13 +10815,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:10825: checking for dnrm2_ in -lblas" >&5
+echo "configure:10819: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 10831 "configure"
+#line 10825 "configure"
@@ -10838,7 +10832,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:10842: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10836: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10882,13 +10876,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:10886: checking for ATL_xerbla in -latlas" >&5
+echo "configure:10880: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 10892 "configure"
+#line 10886 "configure"
@@ -10899,7 +10893,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:10903: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10897: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10914,13 +10908,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:10918: checking for sgemm_ in -lf77blas" >&5
+echo "configure:10912: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 10924 "configure"
+#line 10918 "configure"
@@ -10931,7 +10925,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:10935: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10929: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10946,13 +10940,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:10950: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:10944: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 10956 "configure"
+#line 10950 "configure"
@@ -10963,7 +10957,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:10967: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10961: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11009,16 +11003,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:11013: checking for sgemm in $vlib_flags" >&5
+echo "configure:11007: checking for sgemm in $vlib_flags" >&5
-#line 11015 "configure"
+#line 11009 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:11022: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11016: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -11036,13 +11030,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:11040: checking for sgemm_ in -lblas" >&5
+echo "configure:11034: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 11046 "configure"
+#line 11040 "configure"
@@ -11053,7 +11047,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11057: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11051: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11068,13 +11062,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:11072: checking for dgemm_ in -ldgemm" >&5
+echo "configure:11066: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 11078 "configure"
+#line 11072 "configure"
@@ -11085,7 +11079,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:11089: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11083: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11100,13 +11094,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:11104: checking for sgemm_ in -lsgemm" >&5
+echo "configure:11098: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 11110 "configure"
+#line 11104 "configure"
@@ -11117,7 +11111,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11121: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11115: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11151,13 +11145,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:11155: checking for acosp in -lsunmath" >&5
+echo "configure:11149: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 11161 "configure"
+#line 11155 "configure"
@@ -11168,7 +11162,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:11172: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11166: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11183,13 +11177,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:11187: checking for sgemm_ in -lsunperf" >&5
+echo "configure:11181: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 11193 "configure"
+#line 11187 "configure"
@@ -11200,7 +11194,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11204: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11198: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11230,13 +11224,13 @@
# Generic BLAS library
-echo "configure:11234: checking for sgemm_ in -lblas" >&5
+echo "configure:11228: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 11240 "configure"
+#line 11234 "configure"
@@ -11247,7 +11241,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11251: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11245: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11286,7 +11280,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:11290: checking whether to use LAPACK" >&5
+echo "configure:11284: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -11311,7 +11305,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:11315: checking for location of LAPACK includes" >&5
+echo "configure:11309: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -11331,7 +11325,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:11335: checking for location of LAPACK library" >&5
+echo "configure:11329: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -11357,15 +11351,15 @@
do
-echo "configure:11361: checking for $ac_hdr" >&5
+echo "configure:11355: checking for $ac_hdr" >&5
-#line 11364 "configure"
+#line 11358 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11369: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11363: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11397,10 +11391,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:11401: checking for dsegv_" >&5
+echo "configure:11395: checking for dsegv_" >&5
-#line 11404 "configure"
+#line 11398 "configure"
which can conflict with char dsegv_(); below. */
@@ -11423,7 +11417,7 @@
; return 0; }
EOF
-if { (eval echo configure:11427: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11421: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -11450,13 +11444,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11454: checking for desgv_ in -llapack" >&5
+echo "configure:11448: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 11460 "configure"
+#line 11454 "configure"
@@ -11467,7 +11461,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:11471: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11465: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11499,13 +11493,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11503: checking for dgesv_ in -llapack" >&5
+echo "configure:11497: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 11509 "configure"
+#line 11503 "configure"
@@ -11516,7 +11510,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:11520: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11514: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11535,13 +11529,13 @@
-echo "configure:11539: checking for dgesv_ in -llapack" >&5
+echo "configure:11533: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 11545 "configure"
+#line 11539 "configure"
@@ -11552,7 +11546,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:11556: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11550: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11608,7 +11602,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:11612: checking whether to use Cairo" >&5
+echo "configure:11606: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -11640,7 +11634,7 @@
echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:11644: checking for location of cairo includes" >&5
+echo "configure:11638: checking for location of cairo includes" >&5
case "$with_cairo_includes" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -11666,15 +11660,15 @@
do
-echo "configure:11670: checking for $ac_hdr" >&5
+echo "configure:11664: checking for $ac_hdr" >&5
-#line 11673 "configure"
+#line 11667 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11678: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11672: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11710,7 +11704,7 @@
echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:11714: checking for location of cairo library" >&5
+echo "configure:11708: checking for location of cairo library" >&5
case "$with_cairo_libs" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -11730,7 +11724,7 @@
echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:11734: checking for cairo linking flags" >&5
+echo "configure:11728: checking for cairo linking flags" >&5
case "$with_cairo_ldflags" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -11746,10 +11740,10 @@
LIBS=" $CAIROLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:11750: checking for cairo_create" >&5
+echo "configure:11744: checking for cairo_create" >&5
-#line 11753 "configure"
+#line 11747 "configure"
which can conflict with char cairo_create(); below. */
@@ -11772,7 +11766,7 @@
; return 0; }
EOF
-if { (eval echo configure:11776: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11770: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -11806,10 +11800,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:11810: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:11804: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 11813 "configure"
+#line 11807 "configure"
which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below. */
@@ -11832,7 +11826,7 @@
; return 0; }
EOF
-if { (eval echo configure:11836: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11830: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
else
@@ -11865,10 +11859,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:11869: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:11863: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 11872 "configure"
+#line 11866 "configure"
which can conflict with char cairo_xlib_surface_get_xrender_format(); below. */
@@ -11891,7 +11885,7 @@
; return 0; }
EOF
-if { (eval echo configure:11895: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11889: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
else
@@ -11933,7 +11927,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:11937: checking whether to use FreeType" >&5
+echo "configure:11931: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -11952,7 +11946,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:11956: checking for location of FreeType includes" >&5
+echo "configure:11950: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -11978,15 +11972,15 @@
do
-echo "configure:11982: checking for $ac_hdr" >&5
+echo "configure:11976: checking for $ac_hdr" >&5
-#line 11985 "configure"
+#line 11979 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11990: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11984: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12020,7 +12014,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:12024: checking for location of FreeType library" >&5
+echo "configure:12018: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -12045,13 +12039,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:12049: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:12043: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 12055 "configure"
+#line 12049 "configure"
@@ -12062,7 +12056,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:12066: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12060: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12103,7 +12097,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:12107: checking whether to use NLS" >&5
+echo "configure:12101: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -12123,10 +12117,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:12127: checking for gettext" >&5
+echo "configure:12121: checking for gettext" >&5
-#line 12130 "configure"
+#line 12124 "configure"
which can conflict with char gettext(); below. */
@@ -12149,7 +12143,7 @@
; return 0; }
EOF
-if { (eval echo configure:12153: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12147: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -12167,13 +12161,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:12171: checking for gettext in -lintl" >&5
+echo "configure:12165: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 12177 "configure"
+#line 12171 "configure"
@@ -12184,7 +12178,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:12188: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12182: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12219,7 +12213,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:12223: checking whether to use C++" >&5
+echo "configure:12217: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -12235,7 +12229,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:12239: checking for $ac_word" >&5
+echo "configure:12233: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -12264,7 +12258,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:12268: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:12262: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -12275,12 +12269,12 @@
cat > conftest.$ac_ext << EOF
-#line 12279 "configure"
+#line 12273 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:12284: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12278: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -12306,19 +12300,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:12310: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:12304: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:12315: checking whether we are using GNU C++" >&5
+echo "configure:12309: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12322: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12316: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -12336,7 +12330,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:12340: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:12334: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -12364,58 +12358,7 @@
fi
fi
-for ac_declaration in \
- '#include <stdlib.h>' \
- 'extern "C" void std::exit (int) throw (); using std::exit;' \
- 'extern "C" void std::exit (int); using std::exit;' \
- 'extern "C" void exit (int) throw ();' \
- 'extern "C" void exit (int);' \
- 'void exit (int);'
-do
- cat > conftest.$ac_ext <<EOF
-#line 12378 "configure"
-#include "confdefs.h"
-#include <stdlib.h>
-$ac_declaration
-int main() {
-exit (42);
-; return 0; }
-EOF
-if { (eval echo configure:12386: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
- echo "configure: failed program was:" >&5
- cat conftest.$ac_ext >&5
- rm -rf conftest*
- continue
-fi
-rm -f conftest*
-#line 12396 "configure"
-$ac_declaration
-int main() {
-exit (42);
-; return 0; }
-EOF
-if { (eval echo configure:12403: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
- rm -rf conftest*
- break
-else
-fi
-rm -f conftest*
-done
-if test -n "$ac_declaration"; then
- echo '#ifdef __cplusplus' >>confdefs.h
- echo $ac_declaration >>confdefs.h
- echo '#endif' >>confdefs.h
-fi
-else
CXX=
CXXFLAGS=
@@ -12428,7 +12371,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:12432: checking whether to use openDWG" >&5
+echo "configure:12375: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -12448,7 +12391,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:12452: checking for location of openDGW includes" >&5
+echo "configure:12395: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -12474,15 +12417,15 @@
do
-echo "configure:12478: checking for $ac_hdr" >&5
+echo "configure:12421: checking for $ac_hdr" >&5
-#line 12481 "configure"
+#line 12424 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12486: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12429: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12516,7 +12459,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:12520: checking for location of openDWG library" >&5
+echo "configure:12463: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -12557,7 +12500,7 @@
echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:12561: checking whether to use POSIX threads" >&5
+echo "configure:12504: checking whether to use POSIX threads" >&5
echo "$ac_t"""$with_pthread"" 1>&6
case "$with_pthread" in
"no") USE_PTHREAD= ;;
@@ -12577,7 +12520,7 @@
echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:12581: checking for location of POSIX threads includes" >&5
+echo "configure:12524: checking for location of POSIX threads includes" >&5
case "$with_pthread_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -12603,15 +12546,15 @@
do
-echo "configure:12607: checking for $ac_hdr" >&5
+echo "configure:12550: checking for $ac_hdr" >&5
-#line 12610 "configure"
+#line 12553 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12615: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12558: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12645,7 +12588,7 @@
echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:12649: checking for location of POSIX threads library" >&5
+echo "configure:12592: checking for location of POSIX threads library" >&5
case "$with_pthread_libs" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -12670,10 +12613,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:12674: checking for pthread_create" >&5
+echo "configure:12617: checking for pthread_create" >&5
-#line 12677 "configure"
+#line 12620 "configure"
which can conflict with char pthread_create(); below. */
@@ -12696,7 +12639,7 @@
; return 0; }
EOF
-if { (eval echo configure:12700: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12643: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_pthread_create=yes"
else
@@ -12723,13 +12666,13 @@
echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:12727: checking for pthread_create in -lpthread" >&5
+echo "configure:12670: checking for pthread_create in -lpthread" >&5
ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lpthread $LIBS"
-#line 12733 "configure"
+#line 12676 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -12740,7 +12683,7 @@
pthread_create()
; return 0; }
EOF
-if { (eval echo configure:12744: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12687: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -12790,7 +12733,7 @@
echo $ac_n "checking whether to use OpenMP""... $ac_c" 1>&6
-echo "configure:12794: checking whether to use OpenMP" >&5
+echo "configure:12737: checking whether to use OpenMP" >&5
echo "$ac_t"""$with_openmp"" 1>&6
case "$with_openmp" in
"no") USE_OPENMP= ;;
@@ -12811,7 +12754,7 @@
echo $ac_n "checking for location of OpenMP includes""... $ac_c" 1>&6
-echo "configure:12815: checking for location of OpenMP includes" >&5
+echo "configure:12758: checking for location of OpenMP includes" >&5
case "$with_openmp_includes" in
{ echo "configure: error: *** You must supply a directory to --with-openmp-includes." 1>&2; exit 1; }
@@ -12837,15 +12780,15 @@
do
-echo "configure:12841: checking for $ac_hdr" >&5
+echo "configure:12784: checking for $ac_hdr" >&5
-#line 12844 "configure"
+#line 12787 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12849: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12792: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12883,7 +12826,7 @@
echo $ac_n "checking for location of OpenMP library""... $ac_c" 1>&6
-echo "configure:12887: checking for location of OpenMP library" >&5
+echo "configure:12830: checking for location of OpenMP library" >&5
case "$with_openmp_libs" in
{ echo "configure: error: *** You must supply a directory to --with-openmp-libs." 1>&2; exit 1; }
@@ -12908,10 +12851,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for GOMP_parallel_start""... $ac_c" 1>&6
-echo "configure:12912: checking for GOMP_parallel_start" >&5
+echo "configure:12855: checking for GOMP_parallel_start" >&5
-#line 12915 "configure"
+#line 12858 "configure"
which can conflict with char GOMP_parallel_start(); below. */
@@ -12934,7 +12877,7 @@
; return 0; }
EOF
-if { (eval echo configure:12938: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12881: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_GOMP_parallel_start=yes"
else
@@ -12961,13 +12904,13 @@
echo $ac_n "checking for GOMP_parallel_start in -lgomp""... $ac_c" 1>&6
-echo "configure:12965: checking for GOMP_parallel_start in -lgomp" >&5
+echo "configure:12908: checking for GOMP_parallel_start in -lgomp" >&5
ac_lib_var=`echo gomp'_'GOMP_parallel_start | sed 'y%./+-%__p_%'`
LIBS="-lgomp $LIBS"
-#line 12971 "configure"
+#line 12914 "configure"
@@ -12978,7 +12921,7 @@
; return 0; }
EOF
-if { (eval echo configure:12982: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12925: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13051,7 +12994,7 @@
echo $ac_n "checking whether to use OpenCL""... $ac_c" 1>&6
-echo "configure:13055: checking whether to use OpenCL" >&5
+echo "configure:12998: checking whether to use OpenCL" >&5
echo "$ac_t"""$with_opencl"" 1>&6
case "$with_opencl" in
"no") USE_OPENCL= ;;
@@ -13071,7 +13014,7 @@
echo $ac_n "checking for location of OpenCL includes""... $ac_c" 1>&6
-echo "configure:13075: checking for location of OpenCL includes" >&5
+echo "configure:13018: checking for location of OpenCL includes" >&5
case "$with_opencl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opencl-includes." 1>&2; exit 1; }
@@ -13098,15 +13041,15 @@
do
-echo "configure:13102: checking for $ac_hdr" >&5
+echo "configure:13045: checking for $ac_hdr" >&5
-#line 13105 "configure"
+#line 13048 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13110: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13053: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13146,10 +13089,10 @@
LIBS="-framework OpenCL $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for clGetPlatformInfo""... $ac_c" 1>&6
-echo "configure:13150: checking for clGetPlatformInfo" >&5
+echo "configure:13093: checking for clGetPlatformInfo" >&5
-#line 13153 "configure"
+#line 13096 "configure"
which can conflict with char clGetPlatformInfo(); below. */
@@ -13172,7 +13115,7 @@
; return 0; }
EOF
-if { (eval echo configure:13176: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13119: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_clGetPlatformInfo=yes"
else
@@ -13211,15 +13154,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13215: checking for $ac_hdr" >&5
+echo "configure:13158: checking for $ac_hdr" >&5
-#line 13218 "configure"
+#line 13161 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13223: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13166: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -13252,7 +13195,7 @@
# With OpenCL library directory
echo $ac_n "checking for location of OpenCL library""... $ac_c" 1>&6
-echo "configure:13256: checking for location of OpenCL library" >&5
+echo "configure:13199: checking for location of OpenCL library" >&5
case "$with_opencl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opencl-libs." 1>&2; exit 1; }
@@ -13276,13 +13219,13 @@
echo $ac_n "checking for clGetPlatformInfo in -lOpenCL""... $ac_c" 1>&6
-echo "configure:13280: checking for clGetPlatformInfo in -lOpenCL" >&5
+echo "configure:13223: checking for clGetPlatformInfo in -lOpenCL" >&5
ac_lib_var=`echo OpenCL'_'clGetPlatformInfo | sed 'y%./+-%__p_%'`
LIBS="-lOpenCL $LIBS"
-#line 13286 "configure"
+#line 13229 "configure"
@@ -13293,7 +13236,7 @@
clGetPlatformInfo()
; return 0; }
EOF
-if { (eval echo configure:13297: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13240: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13353,7 +13296,7 @@
fi
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:13357: checking for special C compiler options needed for large files" >&5
+echo "configure:13300: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -13361,7 +13304,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 13365 "configure"
+#line 13308 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -13377,7 +13320,7 @@
; return 0; }
EOF
-if { (eval echo configure:13381: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13324: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
@@ -13386,7 +13329,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 13390 "configure"
+#line 13333 "configure"
@@ -13402,7 +13345,7 @@
; return 0; }
EOF
-if { (eval echo configure:13406: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13349: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -13429,11 +13372,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:13433: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:13376: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 13437 "configure"
+#line 13380 "configure"
@@ -13449,14 +13392,14 @@
; return 0; }
EOF
-if { (eval echo configure:13453: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13396: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13460 "configure"
+#line 13403 "configure"
#define _FILE_OFFSET_BITS 64
@@ -13474,7 +13417,7 @@
; return 0; }
EOF
-if { (eval echo configure:13478: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13421: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -13500,11 +13443,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:13504: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:13447: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 13508 "configure"
+#line 13451 "configure"
@@ -13520,14 +13463,14 @@
; return 0; }
EOF
-if { (eval echo configure:13524: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13467: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13531 "configure"
+#line 13474 "configure"
#define _LARGE_FILES 1
@@ -13545,7 +13488,7 @@
; return 0; }
EOF
-if { (eval echo configure:13549: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13492: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -13571,25 +13514,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:13575: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13518: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 13579 "configure"
+#line 13522 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13586: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13529: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13593 "configure"
+#line 13536 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -13598,7 +13541,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13602: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13545: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -13630,25 +13573,25 @@
ac_save_cflags=${CFLAGS}
CFLAGS="$LFS_CFLAGS ${ac_save_cflags}"
-echo "configure:13634: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13577: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 13638 "configure"
+#line 13581 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13645: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13588: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13652 "configure"
+#line 13595 "configure"
#include <stdio.h>
@@ -13657,7 +13600,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13661: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13604: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
else
@@ -13687,18 +13630,18 @@
# If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:13691: checking for fseeko" >&5
+echo "configure:13634: checking for fseeko" >&5
ac_cv_func_fseeko=no
-#line 13695 "configure"
+#line 13638 "configure"
#include <stdio.h>
int main() {
return fseeko && fseeko (stdin, 0, 0);
; return 0; }
EOF
-if { (eval echo configure:13702: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13645: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_func_fseeko=yes
else
@@ -13715,10 +13658,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:13719: checking if system supports Large Files at all" >&5
+echo "configure:13662: checking if system supports Large Files at all" >&5
-#line 13722 "configure"
+#line 13665 "configure"
#include <stdio.h>
@@ -13750,7 +13693,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:13754: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13697: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -13781,7 +13724,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:13785: checking whether to use wxWidgets" >&5
+echo "configure:13728: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -13802,7 +13745,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:13806: checking for $ac_word" >&5
+echo "configure:13749: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -13850,7 +13793,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:13854: checking wxWidgets version" >&5
+echo "configure:13797: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -13873,15 +13816,15 @@
do
-echo "configure:13877: checking for $ac_hdr" >&5
+echo "configure:13820: checking for $ac_hdr" >&5
-#line 13880 "configure"
+#line 13823 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13885: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13828: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in 2013-07-27 13:32:51 UTC (rev 57293)
+++ grass/trunk/configure.in 2013-07-27 13:34:56 UTC (rev 57294)
@@ -64,11 +64,11 @@
AC_PATH_PROG(pwd, pwd, pwd)
-if test "$MINGW32" = yes ; then
- winpwd="$pwd -W"
-else
- winpwd="$pwd"
-fi
+dnl if test "$MINGW32" = yes ; then
+dnl winpwd="$pwd -W"
+dnl else
+dnl winpwd="$pwd"
+dnl fi
AC_MSG_CHECKING(for source directory)
@@ -83,7 +83,7 @@
AC_MSG_CHECKING(for build directory)
DSTDIR=`$pwd`
-WINDSTDIR=`$winpwd`
+dnl WINDSTDIR=`$winpwd`
AC_MSG_RESULT("$DSTDIR")
@@ -107,7 +107,8 @@
# Set GISBASE and GRASS_BIN
-GISBASE="${WINDSTDIR}/dist.${ARCH}"
+dnl GISBASE="${WINDSTDIR}/dist.${ARCH}
+GISBASE="${DSTDIR}/dist.${ARCH}"
GRASS_BIN="${DSTDIR}/bin.${ARCH}"
AC_SUBST(GISBASE)
