[GRASS-SVN] r56559 - grass/trunk/lib/external
svn_grass at osgeo.org
Sun Jun 2 08:18:20 PDT 2013
Author: martinl
Date: 2013-06-02 08:18:19 -0700 (Sun, 02 Jun 2013)
New Revision: 56559
grass/trunk/lib/external/README.license
update readme - bwidget has been removed
Modified: grass/trunk/lib/external/README.license
--- grass/trunk/lib/external/README.license 2013-06-02 13:41:45 UTC (rev 56558)
+++ grass/trunk/lib/external/README.license 2013-06-02 15:18:19 UTC (rev 56559)
@@ -1,32 +1,19 @@
+In the following directories you will find code which was not written
+by the GRASS Development Team.
+Parts of GRASS are not copyright by the GRASS Development Team. The
+original authors hold the copyrights and you have to abide to their
+licensing terms where noted. (Keep in mind that code linking into
+GRASS can only be distributed if compatible with the GPL.)
-In the following directories you will find code which was not
-written by The GRASS Development Team.
-Parts of GRASS are not copyright by The GRASS Development Team.
-The original authors hold the copyrights and you have to abide
-to their licensing terms where noted.
-(Keep in mind that code linking into GRASS can only be distributed
-if compatible with the GPL.)
Specifically the source code below this directory is not necessarily
licensed under the GPL. Check the READMEs and source code header
comments carefully.
- * bwidget/ (LGPL 2.1)
- BWidget Tcl/Tk ToolKit 1.2.1
- Copyright (c) 1998-1999 UNIFIX.
* ccmath/ (LGPL 2.1)
CCMATH mathematics library version 2.2.1
Copyright (C) 2000 Daniel A. Atkinson
* shapelib/ (MIT/X)
Shapefile read/write functions.
Copyright (c) 2007, Frank Warmerdam
