[GRASS-SVN] r56655 - grass/branches/develbranch_6
svn_grass at osgeo.org
Sun Jun 9 09:26:23 PDT 2013
Author: neteler
Date: 2013-06-09 09:26:23 -0700 (Sun, 09 Jun 2013)
New Revision: 56655
grass/branches/develbranch_6/config.guess
grass/branches/develbranch_6/config.sub
grass/branches/develbranch_6/configure
config.guess + config.sub: updated from http://git.savannah.gnu.org/cgit/config.git/plain/
Modified: grass/branches/develbranch_6/config.guess
--- grass/branches/develbranch_6/config.guess 2013-06-09 16:25:37 UTC (rev 56654)
+++ grass/branches/develbranch_6/config.guess 2013-06-09 16:26:23 UTC (rev 56655)
@@ -1,14 +1,12 @@
#! /bin/sh
# Attempt to guess a canonical system name.
-# Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999,
-# 2000, 2001, 2002, 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010,
-# 2011, 2012 Free Software Foundation, Inc.
+# Copyright 1992-2013 Free Software Foundation, Inc.
-timestamp='2012-09-25'
+timestamp='2013-05-16'
# This file is free software; you can redistribute it and/or modify it
# under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2 of the License, or
+# the Free Software Foundation; either version 3 of the License, or
# (at your option) any later version.
# This program is distributed in the hope that it will be useful, but
@@ -22,20 +20,18 @@
# As a special exception to the GNU General Public License, if you
# distribute this file as part of a program that contains a
# configuration script generated by Autoconf, you may include it under
-# the same distribution terms that you use for the rest of that program.
-# Originally written by Per Bothner. Please send patches (context
-# diff format) to <config-patches at gnu.org> and include a ChangeLog
-# entry.
+# the same distribution terms that you use for the rest of that
+# program. This Exception is an additional permission under section 7
+# of the GNU General Public License, version 3 ("GPLv3").
-# This script attempts to guess a canonical system name similar to
-# config.sub. If it succeeds, it prints the system name on stdout, and
-# exits with 0. Otherwise, it exits with 1.
+# Originally written by Per Bothner.
# You can get the latest version of this script from:
# http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.guess;hb=HEAD
+# Please send patches with a ChangeLog entry to config-patches at gnu.org.
me=`echo "$0" | sed -e 's,.*/,,'`
usage="\
@@ -54,9 +50,7 @@
GNU config.guess ($timestamp)
-Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000,
-2001, 2002, 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012
-Free Software Foundation, Inc.
+Copyright 1992-2013 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE."
@@ -138,6 +132,27 @@
UNAME_SYSTEM=`(uname -s) 2>/dev/null` || UNAME_SYSTEM=unknown
UNAME_VERSION=`(uname -v) 2>/dev/null` || UNAME_VERSION=unknown
+case "${UNAME_SYSTEM}" in
+Linux|GNU|GNU/*)
+ # If the system lacks a compiler, then just pick glibc.
+ # We could probably try harder.
+ LIBC=gnu
+ eval $set_cc_for_build
+ cat <<-EOF > $dummy.c
+ #include <features.h>
+ #if defined(__UCLIBC__)
+ LIBC=uclibc
+ #elif defined(__dietlibc__)
+ LIBC=dietlibc
+ #else
+ LIBC=gnu
+ #endif
+ EOF
+ eval `$CC_FOR_BUILD -E $dummy.c 2>/dev/null | grep '^LIBC'`
+esac
# Note: order is significant - the case branches are not exclusive.
case "${UNAME_MACHINE}:${UNAME_SYSTEM}:${UNAME_RELEASE}:${UNAME_VERSION}" in
@@ -859,21 +874,21 @@
exit ;;
*:GNU:*:*)
# the GNU system
- echo `echo ${UNAME_MACHINE}|sed -e 's,[-/].*$,,'`-unknown-gnu`echo ${UNAME_RELEASE}|sed -e 's,/.*$,,'`
+ echo `echo ${UNAME_MACHINE}|sed -e 's,[-/].*$,,'`-unknown-${LIBC}`echo ${UNAME_RELEASE}|sed -e 's,/.*$,,'`
exit ;;
*:GNU/*:*:*)
# other systems with GNU libc and userland
- echo ${UNAME_MACHINE}-unknown-`echo ${UNAME_SYSTEM} | sed 's,^[^/]*/,,' | tr '[A-Z]' '[a-z]'``echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'`-gnu
+ echo ${UNAME_MACHINE}-unknown-`echo ${UNAME_SYSTEM} | sed 's,^[^/]*/,,' | tr '[A-Z]' '[a-z]'``echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'`-${LIBC}
exit ;;
i*86:Minix:*:*)
echo ${UNAME_MACHINE}-pc-minix
exit ;;
aarch64:Linux:*:*)
- echo ${UNAME_MACHINE}-unknown-linux-gnu
+ echo ${UNAME_MACHINE}-unknown-linux-${LIBC}
exit ;;
aarch64_be:Linux:*:*)
UNAME_MACHINE=aarch64_be
exit ;;
alpha:Linux:*:*)
case `sed -n '/^cpu model/s/^.*: \(.*\)/\1/p' < /proc/cpuinfo` in
@@ -886,59 +901,54 @@
EV68*) UNAME_MACHINE=alphaev68 ;;
esac
objdump --private-headers /bin/sh | grep -q ld.so.1
- if test "$?" = 0 ; then LIBC="libc1" ; else LIBC="" ; fi
- echo ${UNAME_MACHINE}-unknown-linux-gnu${LIBC}
+ if test "$?" = 0 ; then LIBC="gnulibc1" ; fi
exit ;;
+ arc:Linux:*:* | arceb:Linux:*:*)
+ exit ;;
arm*:Linux:*:*)
if echo __ARM_EABI__ | $CC_FOR_BUILD -E - 2>/dev/null \
| grep -q __ARM_EABI__
then
else
if echo __ARM_PCS_VFP | $CC_FOR_BUILD -E - 2>/dev/null \
| grep -q __ARM_PCS_VFP
then
- echo ${UNAME_MACHINE}-unknown-linux-gnueabi
+ echo ${UNAME_MACHINE}-unknown-linux-${LIBC}eabi
else
- echo ${UNAME_MACHINE}-unknown-linux-gnueabihf
+ echo ${UNAME_MACHINE}-unknown-linux-${LIBC}eabihf
fi
fi
exit ;;
avr32*:Linux:*:*)
exit ;;
cris:Linux:*:*)
- echo ${UNAME_MACHINE}-axis-linux-gnu
+ echo ${UNAME_MACHINE}-axis-linux-${LIBC}
exit ;;
crisv32:Linux:*:*)
exit ;;
frv:Linux:*:*)
exit ;;
hexagon:Linux:*:*)
exit ;;
i*86:Linux:*:*)
- LIBC=gnu
- eval $set_cc_for_build
- sed 's/^ //' << EOF >$dummy.c
- #ifdef __dietlibc__
- LIBC=dietlibc
- #endif
-EOF
- eval `$CC_FOR_BUILD -E $dummy.c 2>/dev/null | grep '^LIBC'`
- echo "${UNAME_MACHINE}-pc-linux-${LIBC}"
+ echo ${UNAME_MACHINE}-pc-linux-${LIBC}
exit ;;
ia64:Linux:*:*)
exit ;;
m32r*:Linux:*:*)
exit ;;
m68*:Linux:*:*)
exit ;;
mips:Linux:*:* | mips64:Linux:*:*)
@@ -957,54 +967,63 @@
#endif
EOF
eval `$CC_FOR_BUILD -E $dummy.c 2>/dev/null | grep '^CPU'`
- test x"${CPU}" != x && { echo "${CPU}-unknown-linux-gnu"; exit; }
+ test x"${CPU}" != x && { echo "${CPU}-unknown-linux-${LIBC}"; exit; }
+ or1k:Linux:*:*)
+ exit ;;
or32:Linux:*:*)
exit ;;
padre:Linux:*:*)
- echo sparc-unknown-linux-gnu
+ echo sparc-unknown-linux-${LIBC}
exit ;;
parisc64:Linux:*:* | hppa64:Linux:*:*)
- echo hppa64-unknown-linux-gnu
+ echo hppa64-unknown-linux-${LIBC}
exit ;;
parisc:Linux:*:* | hppa:Linux:*:*)
# Look for CPU level
case `grep '^cpu[^a-z]*:' /proc/cpuinfo 2>/dev/null | cut -d' ' -f2` in
- PA7*) echo hppa1.1-unknown-linux-gnu ;;
- PA8*) echo hppa2.0-unknown-linux-gnu ;;
- *) echo hppa-unknown-linux-gnu ;;
+ PA7*) echo hppa1.1-unknown-linux-${LIBC} ;;
+ PA8*) echo hppa2.0-unknown-linux-${LIBC} ;;
+ *) echo hppa-unknown-linux-${LIBC} ;;
esac
exit ;;
ppc64:Linux:*:*)
- echo powerpc64-unknown-linux-gnu
+ echo powerpc64-unknown-linux-${LIBC}
exit ;;
ppc:Linux:*:*)
- echo powerpc-unknown-linux-gnu
+ echo powerpc-unknown-linux-${LIBC}
exit ;;
+ ppc64le:Linux:*:*)
+ echo powerpc64le-unknown-linux-${LIBC}
+ exit ;;
+ ppcle:Linux:*:*)
+ echo powerpcle-unknown-linux-${LIBC}
+ exit ;;
s390:Linux:*:* | s390x:Linux:*:*)
- echo ${UNAME_MACHINE}-ibm-linux
+ echo ${UNAME_MACHINE}-ibm-linux-${LIBC}
exit ;;
sh64*:Linux:*:*)
exit ;;
sh*:Linux:*:*)
exit ;;
sparc:Linux:*:* | sparc64:Linux:*:*)
exit ;;
tile*:Linux:*:*)
exit ;;
vax:Linux:*:*)
- echo ${UNAME_MACHINE}-dec-linux-gnu
+ echo ${UNAME_MACHINE}-dec-linux-${LIBC}
exit ;;
x86_64:Linux:*:*)
exit ;;
xtensa*:Linux:*:*)
exit ;;
i*86:DYNIX/ptx:4*:*)
# ptx 4.0 does uname -s correctly, with DYNIX/ptx in there.
@@ -1237,19 +1256,21 @@
exit ;;
*:Darwin:*:*)
UNAME_PROCESSOR=`uname -p` || UNAME_PROCESSOR=unknown
- case $UNAME_PROCESSOR in
- i386)
- if [ "$CC_FOR_BUILD" != 'no_compiler_found' ]; then
- if (echo '#ifdef __LP64__'; echo IS_64BIT_ARCH; echo '#endif') | \
- (CCOPTS= $CC_FOR_BUILD -E - 2>/dev/null) | \
- grep IS_64BIT_ARCH >/dev/null
- then
- UNAME_PROCESSOR="x86_64"
- fi
- fi ;;
- unknown) UNAME_PROCESSOR=powerpc ;;
- esac
+ if test "$UNAME_PROCESSOR" = unknown ; then
+ UNAME_PROCESSOR=powerpc
+ fi
+ if [ "$CC_FOR_BUILD" != 'no_compiler_found' ]; then
+ if (echo '#ifdef __LP64__'; echo IS_64BIT_ARCH; echo '#endif') | \
+ (CCOPTS= $CC_FOR_BUILD -E - 2>/dev/null) | \
+ grep IS_64BIT_ARCH >/dev/null
+ then
+ case $UNAME_PROCESSOR in
+ i386) UNAME_PROCESSOR=x86_64 ;;
+ powerpc) UNAME_PROCESSOR=powerpc64 ;;
+ esac
+ fi
+ fi
echo ${UNAME_PROCESSOR}-apple-darwin${UNAME_RELEASE}
exit ;;
*:procnto*:*:* | *:QNX:[0123456789]*:*)
Modified: grass/branches/develbranch_6/config.sub
--- grass/branches/develbranch_6/config.sub 2013-06-09 16:25:37 UTC (rev 56654)
+++ grass/branches/develbranch_6/config.sub 2013-06-09 16:26:23 UTC (rev 56655)
@@ -1,24 +1,18 @@
#! /bin/sh
# Configuration validation subroutine script.
-timestamp='2012-10-10'
+timestamp='2013-04-24'
-# This file is (in principle) common to ALL GNU software.
-# The presence of a machine in this file suggests that SOME GNU software
-# can handle that machine. It does not imply ALL GNU software can.
-# This file is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
+# This file is free software; you can redistribute it and/or modify it
+# under the terms of the GNU General Public License as published by
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
+# This program is distributed in the hope that it will be useful, but
+# WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+# General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program; if not, see <http://www.gnu.org/licenses/>.
@@ -26,11 +20,12 @@
-# Please send patches to <config-patches at gnu.org>. Submit a context
-# diff and a properly formatted GNU ChangeLog entry.
# Configuration subroutine to validate and canonicalize a configuration type.
# Supply the specified configuration type as an argument.
@@ -73,9 +68,7 @@
version="\
GNU config.sub ($timestamp)
@@ -259,7 +252,7 @@
| alpha | alphaev[4-8] | alphaev56 | alphaev6[78] | alphapca5[67] \
| alpha64 | alpha64ev[4-8] | alpha64ev56 | alpha64ev6[78] | alpha64pca5[67] \
| am33_2.0 \
- | arc \
+ | arc | arceb \
| arm | arm[bl]e | arme[lb] | armv[2-8] | armv[3-8][lb] | armv7[arm] \
| avr | avr32 \
| be32 | be64 \
@@ -293,16 +286,17 @@
| mipsisa64r2 | mipsisa64r2el \
| mipsisa64sb1 | mipsisa64sb1el \
| mipsisa64sr71k | mipsisa64sr71kel \
+ | mipsr5900 | mipsr5900el \
| mipstx39 | mipstx39el \
| mn10200 | mn10300 \
| moxie \
| mt \
| msp430 \
| nds32 | nds32le | nds32be \
- | nios | nios2 \
+ | nios | nios2 | nios2eb | nios2el \
| ns16k | ns32k \
| open8 \
- | or32 \
+ | or1k | or32 \
| pdp10 | pdp11 | pj | pjl \
| powerpc | powerpc64 | powerpc64le | powerpcle \
| pyramid \
@@ -372,7 +366,7 @@
| aarch64-* | aarch64_be-* \
| alpha-* | alphaev[4-8]-* | alphaev56-* | alphaev6[78]-* \
| alpha64-* | alpha64ev[4-8]-* | alpha64ev56-* | alpha64ev6[78]-* \
- | alphapca5[67]-* | alpha64pca5[67]-* | arc-* \
+ | alphapca5[67]-* | alpha64pca5[67]-* | arc-* | arceb-* \
| arm-* | armbe-* | armle-* | armeb-* | armv*-* \
| avr-* | avr32-* \
| be32-* | be64-* \
@@ -410,12 +404,13 @@
| mipsisa64r2-* | mipsisa64r2el-* \
| mipsisa64sb1-* | mipsisa64sb1el-* \
| mipsisa64sr71k-* | mipsisa64sr71kel-* \
+ | mipsr5900-* | mipsr5900el-* \
| mipstx39-* | mipstx39el-* \
| mmix-* \
| mt-* \
| msp430-* \
| nds32-* | nds32le-* | nds32be-* \
- | nios-* | nios2-* \
+ | nios-* | nios2-* | nios2eb-* | nios2el-* \
| none-* | np1-* | ns16k-* | ns32k-* \
| open8-* \
| orion-* \
@@ -1026,7 +1021,11 @@
basic_machine=i586-unknown
os=-pw32
- rdos)
+ rdos | rdos64)
+ basic_machine=x86_64-pc
+ os=-rdos
+ rdos32)
basic_machine=i386-pc
os=-rdos
@@ -1353,7 +1352,7 @@
-gnu* | -bsd* | -mach* | -minix* | -genix* | -ultrix* | -irix* \
| -*vms* | -sco* | -esix* | -isc* | -aix* | -cnk* | -sunos | -sunos[34]*\
| -hpux* | -unos* | -osf* | -luna* | -dgux* | -auroraux* | -solaris* \
- | -sym* | -kopensolaris* \
+ | -sym* | -kopensolaris* | -plan9* \
| -amigaos* | -amigados* | -msdos* | -newsos* | -unicos* | -aof* \
| -aos* | -aros* \
| -nindy* | -vxsim* | -vxworks* | -ebmon* | -hms* | -mvs* \
@@ -1499,9 +1498,6 @@
-aros*)
os=-aros
- -kaos*)
- os=-kaos
-zvmoe)
os=-zvmoe
@@ -1593,6 +1589,9 @@
mips*-*)
os=-elf
+ or1k-*)
+ os=-elf
or32-*)
os=-coff
Modified: grass/branches/develbranch_6/configure
--- grass/branches/develbranch_6/configure 2013-06-09 16:25:37 UTC (rev 56654)
+++ grass/branches/develbranch_6/configure 2013-06-09 16:26:23 UTC (rev 56655)
@@ -15627,7 +15627,58 @@
fi
fi
+for ac_declaration in \
+ '#include <stdlib.h>' \
+ 'extern "C" void std::exit (int) throw (); using std::exit;' \
+ 'extern "C" void std::exit (int); using std::exit;' \
+ 'extern "C" void exit (int) throw ();' \
+ 'extern "C" void exit (int);' \
+ 'void exit (int);'
+do
+ cat > conftest.$ac_ext <<EOF
+#line 15641 "configure"
+#include "confdefs.h"
+#include <stdlib.h>
+$ac_declaration
+int main() {
+exit (42);
+; return 0; }
+EOF
+if { (eval echo configure:15649: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
+ echo "configure: failed program was:" >&5
+ cat conftest.$ac_ext >&5
+ rm -rf conftest*
+ continue
+fi
+rm -f conftest*
+#line 15659 "configure"
+$ac_declaration
+int main() {
+exit (42);
+; return 0; }
+EOF
+if { (eval echo configure:15666: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+ rm -rf conftest*
+ break
+else
+fi
+rm -f conftest*
+done
+if test -n "$ac_declaration"; then
+ echo '#ifdef __cplusplus' >>confdefs.h
+ echo $ac_declaration >>confdefs.h
+ echo '#endif' >>confdefs.h
+fi
+else
CXX=
CXXFLAGS=
@@ -15640,7 +15691,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:15644: checking whether to use openDWG" >&5
+echo "configure:15695: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -15660,7 +15711,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:15664: checking for location of openDGW includes" >&5
+echo "configure:15715: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -15686,15 +15737,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:15690: checking for $ac_hdr" >&5
+echo "configure:15741: checking for $ac_hdr" >&5
-#line 15693 "configure"
+#line 15744 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:15698: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15749: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -15728,7 +15779,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:15732: checking for location of openDWG library" >&5
+echo "configure:15783: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -15775,7 +15826,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:15779: checking for special C compiler options needed for large files" >&5
+echo "configure:15830: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -15783,7 +15834,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 15787 "configure"
+#line 15838 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -15799,7 +15850,7 @@
; return 0; }
EOF
-if { (eval echo configure:15803: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15854: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
@@ -15808,7 +15859,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 15812 "configure"
+#line 15863 "configure"
@@ -15824,7 +15875,7 @@
; return 0; }
EOF
-if { (eval echo configure:15828: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15879: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -15844,11 +15895,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:15848: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:15899: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 15852 "configure"
+#line 15903 "configure"
@@ -15864,14 +15915,14 @@
; return 0; }
EOF
-if { (eval echo configure:15868: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15919: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15875 "configure"
+#line 15926 "configure"
#define _FILE_OFFSET_BITS 64
@@ -15889,7 +15940,7 @@
; return 0; }
EOF
-if { (eval echo configure:15893: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15944: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -15908,11 +15959,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:15912: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:15963: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 15916 "configure"
+#line 15967 "configure"
@@ -15928,14 +15979,14 @@
; return 0; }
EOF
-if { (eval echo configure:15932: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15983: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15939 "configure"
+#line 15990 "configure"
#define _LARGE_FILES 1
@@ -15953,7 +16004,7 @@
; return 0; }
EOF
-if { (eval echo configure:15957: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16008: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -15972,25 +16023,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:15976: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:16027: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 15980 "configure"
+#line 16031 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:15987: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16038: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15994 "configure"
+#line 16045 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -15999,7 +16050,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:16003: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16054: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -16020,10 +16071,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:16024: checking if system supports Large Files at all" >&5
+echo "configure:16075: checking if system supports Large Files at all" >&5
-#line 16027 "configure"
+#line 16078 "configure"
#include <stdio.h>
@@ -16055,7 +16106,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:16059: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16110: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -16084,7 +16135,7 @@
# Python check
echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:16088: checking whether to use Python" >&5
+echo "configure:16139: checking whether to use Python" >&5
PYTHONINC=
PYTHONCFLAGS=
@@ -16104,7 +16155,7 @@
# Extract the first word of "python-config", so it can be a program name with args.
set dummy python-config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:16108: checking for $ac_word" >&5
+echo "configure:16159: checking for $ac_word" >&5
case "$PY_CONFIG" in
@@ -16146,15 +16197,15 @@
do
-echo "configure:16150: checking for $ac_hdr" >&5
+echo "configure:16201: checking for $ac_hdr" >&5
-#line 16153 "configure"
+#line 16204 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:16158: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16209: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -16224,7 +16275,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:16228: checking whether to use wxWidgets" >&5
+echo "configure:16279: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -16245,7 +16296,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
-echo "configure:16249: checking for $ac_word" >&5
+echo "configure:16300: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -16293,7 +16344,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:16297: checking wxWidgets version" >&5
+echo "configure:16348: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -16316,15 +16367,15 @@
do
-echo "configure:16320: checking for $ac_hdr" >&5
+echo "configure:16371: checking for $ac_hdr" >&5
-#line 16323 "configure"
+#line 16374 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:16328: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16379: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
