[GRASS-SVN] r56656 - grass/branches/releasebranch_6_4/doc
svn_grass at osgeo.org
Sun Jun 9 09:36:06 PDT 2013
Author: neteler
Date: 2013-06-09 09:36:05 -0700 (Sun, 09 Jun 2013)
New Revision: 56656
grass/branches/releasebranch_6_4/doc/howto_release.txt
howto_release.txt: Check that autoconf scripts are up-to-date (to do only in RC cycle)
Modified: grass/branches/releasebranch_6_4/doc/howto_release.txt
--- grass/branches/releasebranch_6_4/doc/howto_release.txt 2013-06-09 16:26:23 UTC (rev 56655)
+++ grass/branches/releasebranch_6_4/doc/howto_release.txt 2013-06-09 16:36:05 UTC (rev 56656)
@@ -21,6 +21,18 @@
( cd doc/raster/r.example/ ; make )
( cd doc/vector/v.example/ ; make )
still compile; fix otherwise
+ - Check that autoconf scripts are up-to-date (to do only in RC cycle!):
+ rm -f config.guess config.sub
+ wget http://git.savannah.gnu.org/cgit/config.git/plain/config.guess
+ wget http://git.savannah.gnu.org/cgit/config.git/plain/config.sub
+ svn diff config.guess config.sub
+ autoconf-2.13
+ # check and submit to SVN:
+ svn ci -m"config.guess + config.sub: updated from http://git.savannah.gnu.org/cgit/config.git/plain/" config.guess config.sub configure
+ # test by running ./configure
- make distclean
- cleanup rubbish:
