Author: hamish
Date: 2013-06-16 04:18:36 -0700 (Sun, 16 Jun 2013)
New Revision: 56732
grass/trunk/raster/r.li/r.li.patchdensity/main.c
grass/trunk/raster/r.li/r.li.patchdensity/r.li.patchdensity.html
move Rast_allocate_c_buf() after possible return, whitespace (merge from devbr6)
Modified: grass/trunk/raster/r.li/r.li.patchdensity/main.c
--- grass/trunk/raster/r.li/r.li.patchdensity/main.c 2013-06-16 11:11:37 UTC (rev 56731)
+++ grass/trunk/raster/r.li/r.li.patchdensity/main.c 2013-06-16 11:18:36 UTC (rev 56732)
@@ -68,20 +68,23 @@
double EW_DIST1, EW_DIST2, NS_DIST1, NS_DIST2;
int mask_fd = -1, *mask_buf, *mask_sup, null_count = 0;
+ G_debug(1, "begin patch_density() index");
Rast_set_c_null_value(&complete_value, 1);
Rast_get_cellhd(ad->raster, "", &hd);
- sup = Rast_allocate_c_buf();
/* open mask if needed */
if (ad->mask == 1) {
if ((mask_fd = open(ad->mask_name, O_RDONLY, 0755)) < 0)
return 0;
mask_buf = malloc(ad->cl * sizeof(int));
mask_sup = malloc(ad->cl * sizeof(int));
- /*calculate distance */
+ sup = Rast_allocate_c_buf();
+ /* calculate distance */
G_begin_distance_calculations();
/* EW Dist at North edge */
EW_DIST1 = G_distance(hd.east, hd.north, hd.west, hd.north);
@@ -93,15 +96,15 @@
NS_DIST2 = G_distance(hd.west, hd.north, hd.west, hd.south);
+ /* calculate number of patch */
- /*calculate number of patch */
for (i = 0; i < ad->rl; i++) {
buf = RLI_get_cell_raster_row(fd, i + ad->y, ad);
if (i > 0) {
sup = RLI_get_cell_raster_row(fd, i - 1 + ad->y, ad);
/* mask values */
int k;
@@ -201,5 +204,6 @@
*result = -1;
G_free(sup);
return RLI_OK;
Modified: grass/trunk/raster/r.li/r.li.patchdensity/r.li.patchdensity.html
--- grass/trunk/raster/r.li/r.li.patchdensity/r.li.patchdensity.html 2013-06-16 11:11:37 UTC (rev 56731)
+++ grass/trunk/raster/r.li/r.li.patchdensity/r.li.patchdensity.html 2013-06-16 11:18:36 UTC (rev 56732)
@@ -1,4 +1,5 @@
<h2>DESCRIPTION</h2>
<em>r.li.patchdensity</em> is a patch index for <em>r.li</em> suite.
It calculates the function:
@@ -10,10 +11,12 @@
This index is calculated using a 4 neighbour algorithm.
<h2>EXAMPLES</h2>
-To calculate patch density index on map <em>my_map</em>, using <em>my_conf</em>
-configuration file (previously defined with <em>r.li.setup</em>) and saving
-results in the raster map <em>my_out</em>, run:
+To calculate patch density index on map <em>my_map</em>, using
+<em>my_conf</em> configuration file (previously defined with
+<em>r.li.setup</em>) and saving results in the raster map
+<em>my_out</em>, run:
<div class="code"><pre>
r.li.patchdensity input=my_map conf=my_conf out=my_out
</pre></div>
@@ -34,6 +37,7 @@
d.vect forests type=boundary
</pre></div>
<h2>NOTES</h2>
A map of NULL values is considered to have zero patches. <br>
@@ -43,17 +47,22 @@
</pre></div>
after index calculation.<br>
<!-- next ??????: -->
-If raster area is 0, <em>r.li.patchdensity</em> returns -1. This is only possible
-if the raster is masked.
+If raster area is 0, <em>r.li.patchdensity</em> returns -1. This is only
+possible if the raster is masked.
<h2>SEE ALSO</h2>
<em><a href="r.li.html">r.li</A></em> package overview <br>
<em><a href="r.li.daemon.html">r.li.daemon</A></em><br>
<em><a href="r.li.setup.html">r.li.setup</A></em>
<h2>AUTHORS</h2>
Claudio Porta and Lucio Davide Spano, students of Computer Science
University of Pisa (Italy).<br>
Commission from Faunalia Pontedera (PI) (www.faunalia.it)<br>
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
