[GRASS-SVN] r56733 - grass/trunk/lib/python/pygrass/modules/interface
svn_grass at osgeo.org
Sun Jun 16 10:01:47 PDT 2013
Author: wenzeslaus
Date: 2013-06-16 10:01:47 -0700 (Sun, 16 Jun 2013)
New Revision: 56733
grass/trunk/lib/python/pygrass/modules/interface/parameter.py
pygrass: use keydescvalues only when defined
Modified: grass/trunk/lib/python/pygrass/modules/interface/parameter.py
--- grass/trunk/lib/python/pygrass/modules/interface/parameter.py 2013-06-16 11:18:36 UTC (rev 56732)
+++ grass/trunk/lib/python/pygrass/modules/interface/parameter.py 2013-06-16 17:01:47 UTC (rev 56733)
@@ -139,7 +139,8 @@
vals = ', '.join([repr(val) for val in self.values])
else:
vals = False
- keydescvals = "\n (%s)" % ', '.join(self.keydescvalues)
+ if self.keydescvalues:
+ keydescvals = "\n (%s)" % ', '.join(self.keydescvalues)
return DOC['param'].format(name=self.name,
default=repr(self.default) + ', ' if self.default else '',
required='required, ' if self.required else 'optional, ',
