[GRASS-SVN] r56734 - grass/trunk/scripts/v.unpack
svn_grass at osgeo.org
Sun Jun 16 10:20:06 PDT 2013
Author: lucadelu
Date: 2013-06-16 10:20:05 -0700 (Sun, 16 Jun 2013)
New Revision: 56734
grass/trunk/scripts/v.unpack/v.unpack.py
v.unpack: try to fix problem when dbf or sqlite directory is missing
Modified: grass/trunk/scripts/v.unpack/v.unpack.py
--- grass/trunk/scripts/v.unpack/v.unpack.py 2013-06-16 17:01:47 UTC (rev 56733)
+++ grass/trunk/scripts/v.unpack/v.unpack.py 2013-06-16 17:20:05 UTC (rev 56734)
@@ -129,6 +129,11 @@
dbln = open(os.path.join(new_dir,'dbln'),'r')
dbnlist = dbln.readlines()
dbln.close()
+ # check if dbf or sqlite directory exists
+ if dbconn['driver'] == 'dbf' and not os.path.exists(os.path.join(mset_dir, 'dbf')):
+ os.mkdir(os.path.join(mset_dir, 'dbf'))
+ elif dbconn['driver'] == 'sqlite' and not os.path.exists(os.path.join(mset_dir, 'sqlite')):
+ os.mkdir(os.path.join(mset_dir, 'sqlite'))
# for each old connection
for t in dbnlist:
# it split the line of each connection, to found layer number and key
@@ -136,7 +141,7 @@
values = t.split('|')
else:
values = t.split(' ')
from_table = values[1]
layer = values[0].split('/')[0]
# we need to take care about the table name in case of several layer
@@ -144,9 +149,9 @@
to_table = "%s_%s"%(map_name, layer)
else:
to_table = from_table
grass.verbose(_("Coping table <%s> as table <%s>") % (from_table, to_table))
# copy the table in the default database
ret = grass.run_command('db.copy', to_driver = dbconn['driver'],
to_database = todb, to_table = to_table,
