[GRASS-SVN] r56801 - in grass-addons/grass7: display/d.mon2 general/g.cloud gui/wxpython/newgui raster/r.hazard.flood vector/v.concave.hull vector/v.ply.rectify
svn_grass at osgeo.org
Wed Jun 19 07:54:50 PDT 2013
Author: annakrat
Date: 2013-06-19 07:54:50 -0700 (Wed, 19 Jun 2013)
New Revision: 56801
grass-addons/grass7/display/d.mon2/d.mon2.py
grass-addons/grass7/general/g.cloud/g.cloud.py
grass-addons/grass7/gui/wxpython/newgui/render2.py
grass-addons/grass7/raster/r.hazard.flood/r.hazard.flood.py
grass-addons/grass7/vector/v.concave.hull/v.concave.hull.py
grass-addons/grass7/vector/v.ply.rectify/v.ply.rectify.py
reflect change in find_program usage (see r56800)
Modified: grass-addons/grass7/display/d.mon2/d.mon2.py
--- grass-addons/grass7/display/d.mon2/d.mon2.py 2013-06-19 14:51:56 UTC (rev 56800)
+++ grass-addons/grass7/display/d.mon2/d.mon2.py 2013-06-19 14:54:50 UTC (rev 56801)
@@ -116,7 +116,7 @@
## rest of this won't work, as parent can't inherit from the child..
## (unless we do some ugly g.gisenv)
## ... any ideas? end by running grass.call(['bash'])?
- if not grass.find_program(handler, ['--help']):
+ if not grass.find_program(handler):
grass.fatal(_("'%s' not found.") % handler)
os.environ['GRASS_PNGFILE'] = img_tmp
Modified: grass-addons/grass7/general/g.cloud/g.cloud.py
--- grass-addons/grass7/general/g.cloud/g.cloud.py 2013-06-19 14:51:56 UTC (rev 56800)
+++ grass-addons/grass7/general/g.cloud/g.cloud.py 2013-06-19 14:54:50 UTC (rev 56801)
@@ -247,7 +247,7 @@
grass.fatal(_('$GISBASE not defined'))
return 0
# check ssh
- if not grass.find_program('ssh', ['-V']):
+ if not grass.find_program('ssh'):
grass.fatal(_("%s required. Please install '%s' first.") % ('ssh', 'ssh'))
return 0
# parse the grassdata, location e mapset
Modified: grass-addons/grass7/gui/wxpython/newgui/render2.py
--- grass-addons/grass7/gui/wxpython/newgui/render2.py 2013-06-19 14:51:56 UTC (rev 56800)
+++ grass-addons/grass7/gui/wxpython/newgui/render2.py 2013-06-19 14:54:50 UTC (rev 56801)
@@ -453,7 +453,7 @@
"""!Return region projection and map units information
projinfo = dict()
- if not grass.find_program('g.proj', ['--help']):
+ if not grass.find_program('g.proj'):
sys.exit(_("GRASS module '%s' not found. Unable to start map "
"display window.") % 'g.proj')
Modified: grass-addons/grass7/raster/r.hazard.flood/r.hazard.flood.py
--- grass-addons/grass7/raster/r.hazard.flood/r.hazard.flood.py 2013-06-19 14:51:56 UTC (rev 56800)
+++ grass-addons/grass7/raster/r.hazard.flood/r.hazard.flood.py 2013-06-19 14:54:50 UTC (rev 56801)
@@ -62,7 +62,7 @@
def main():
#### check for r.area
- if not grass.find_program('r.area', ['help']):
+ if not grass.find_program('r.area'):
grass.fatal(_("'r.area' program not found, install it first:") +
"\n" +
"g.extension r.area")
Modified: grass-addons/grass7/vector/v.concave.hull/v.concave.hull.py
--- grass-addons/grass7/vector/v.concave.hull/v.concave.hull.py 2013-06-19 14:51:56 UTC (rev 56800)
+++ grass-addons/grass7/vector/v.concave.hull/v.concave.hull.py 2013-06-19 14:54:50 UTC (rev 56801)
@@ -48,7 +48,7 @@
inf = file(infile, 'r')
outf = file(outfile, 'w')
- if grass.find_program('sort', ['-n']):
+ if grass.find_program('sort'):
grass.run_command('sort', flags = 'n', stdin = inf, stdout = outf)
else:
# FIXME: we need a large-file sorting function
Modified: grass-addons/grass7/vector/v.ply.rectify/v.ply.rectify.py
--- grass-addons/grass7/vector/v.ply.rectify/v.ply.rectify.py 2013-06-19 14:51:56 UTC (rev 56800)
+++ grass-addons/grass7/vector/v.ply.rectify/v.ply.rectify.py 2013-06-19 14:54:50 UTC (rev 56801)
@@ -49,9 +49,9 @@
currmapset = grass.gisenv()['MAPSET']
#### check for v.in.ply, v.out.ply
- if not grass.find_program("v.in.ply", ['help']):
+ if not grass.find_program("v.in.ply"):
grass.fatal(_("The GRASS addon v.in.ply was not found, please install it first.\n"))
- if not grass.find_program("v.out.ply", ['help']):
+ if not grass.find_program("v.out.ply"):
grass.fatal(_("The GRASS addon v.out.ply was not found, please install it first.\n"))
# import input PLY file
