[GRASS-SVN] r56802 - grass/trunk/vector/v.colors
svn_grass at osgeo.org
Wed Jun 19 08:22:29 PDT 2013
Author: neteler
Date: 2013-06-19 08:22:29 -0700 (Wed, 19 Jun 2013)
New Revision: 56802
grass/trunk/vector/v.colors/thumbnails.py
sync with raster/r.colors/thumbnails.py
Modified: grass/trunk/vector/v.colors/thumbnails.py
--- grass/trunk/vector/v.colors/thumbnails.py 2013-06-19 14:54:50 UTC (rev 56801)
+++ grass/trunk/vector/v.colors/thumbnails.py 2013-06-19 15:22:29 UTC (rev 56802)
@@ -1,4 +1,16 @@
#!/usr/bin/env python
+# thumbnails.py: Create thumbnail sample images of the various GRASS color rules
+# AUTHOR: Python version by Glynn Clements
+# Earlier Bourne script version by Hamish Bowman,
+# http://grasswiki.osgeo.org/wiki/Talk:Color_tables
+# (C) 2009-2013 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
import sys
import os
@@ -102,7 +114,7 @@
# skip comments
continue
records.append(line.split())
- records = [record for record in records if record[0] != 'nv']
+ records = [record for record in records if record[0] != 'nv' and record[0] != 'default']
relative = False
absolute = False
for record in records:
@@ -122,7 +134,7 @@
maxval = min(maxval, 2500000)
grad = tmp_grad_abs
grass.mapcalc("$grad = if(row()==1, float($min), float($max))",
- grad = tmp_grad_abs, min = minval, max = maxval, quiet = True)
+ grad = tmp_grad_abs, min = minval, max = maxval, quiet = True)
else:
grad = tmp_grad_rel
@@ -134,7 +146,8 @@
else:
lines, cols = None, None
grass.run_command("r.colors", map = grad, color = table, quiet = True)
- grass.run_command("d.colortable", flags = 'n', map = grad, lines = lines, cols = cols, quiet = True)
+ grass.run_command("d.colortable", flags = 'n', map = grad,
+ lines = lines, cols = cols, quiet = True)
outfile = os.path.join(output_dir, "Colortable_%s.png" % table)
convert_and_rotate(tmp_img, outfile, discrete)
