[GRASS-SVN] r56803 - in grass/trunk: raster/r.univar vector/v.vect.stats
Wed Jun 19 08:22:59 PDT 2013
Author: neteler
Date: 2013-06-19 08:22:59 -0700 (Wed, 19 Jun 2013)
New Revision: 56803
   grass/trunk/raster/r.univar/r.univar_main.c
   grass/trunk/vector/v.vect.stats/main.c
keywords added
Modified: grass/trunk/raster/r.univar/r.univar_main.c
--- grass/trunk/raster/r.univar/r.univar_main.c	2013-06-19 15:22:29 UTC (rev 56802)
+++ grass/trunk/raster/r.univar/r.univar_main.c	2013-06-19 15:22:59 UTC (rev 56803)
@@ -99,6 +99,8 @@
     module = G_define_module();
     G_add_keyword(_("raster"));
     G_add_keyword(_("statistics"));
+    G_add_keyword(_("univariate statistics"));
+    G_add_keyword(_("zonal statistics"));
     module->description =
 	_("Calculates univariate statistics from the non-null cells of a raster map.");
Modified: grass/trunk/vector/v.vect.stats/main.c
--- grass/trunk/vector/v.vect.stats/main.c	2013-06-19 15:22:29 UTC (rev 56802)
+++ grass/trunk/vector/v.vect.stats/main.c	2013-06-19 15:22:59 UTC (rev 56803)
@@ -128,6 +128,8 @@
     G_add_keyword(_("vector"));
     G_add_keyword(_("attribute table"));
     G_add_keyword(_("database"));
     module->description = _("Count points in areas, calculate statistics from point attributes.");
     point_opt = G_define_standard_option(G_OPT_V_INPUT);
