[GRASS-SVN] r55366 - in grass-addons/grass7/gui/wxpython: . newgui
svn_grass at osgeo.org
Wed Mar 13 11:02:02 PDT 2013
Author: rashadkm
Date: 2013-03-13 11:02:02 -0700 (Wed, 13 Mar 2013)
New Revision: 55366
Added:
grass-addons/grass7/gui/wxpython/newgui/
grass-addons/grass7/gui/wxpython/newgui/api_test.py
grass-addons/grass7/gui/wxpython/newgui/frame.py
grass-addons/grass7/gui/wxpython/newgui/gui_mapwindow.py
grass-addons/grass7/gui/wxpython/newgui/mapwindow.py
grass-addons/grass7/gui/wxpython/newgui/wxgui.py
test api code
Added: grass-addons/grass7/gui/wxpython/newgui/api_test.py
--- grass-addons/grass7/gui/wxpython/newgui/api_test.py (rev 0)
+++ grass-addons/grass7/gui/wxpython/newgui/api_test.py 2013-03-13 18:02:02 UTC (rev 55366)
@@ -0,0 +1,467 @@
+ at package api_test.py
+(C) 2006-2011 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Mohammed Rashad <rashadkm gmail.com>
+import os
+import sys
+import copy
+import tempfile
+import wx
+try:
+ import wx.lib.agw.customtreectrl as CT
+except ImportError:
+ import wx.lib.customtreectrl as CT
+import wx.lib.buttons as buttons
+try:
+ import treemixin
+ from wx.lib.mixins import treemixin
+from ctypes import *
+import grass.script as grass
+from core import globalvar
+from core.gcmd import GError, GMessage
+from mapdisp import statusbar as sb
+from mapwindow import BufferedWindow2
+from gui_core.mapdisp import MapFrameBase
+import gettext
+import core.render as render
+from core.render import Map, MapLayer
+from core.gcmd import RunCommand, GMessage
+from core.debug import Debug
+from lmgr.lmgr_layertree import LMIcons
+from gui_core.toolbars import BaseIcons
+from icons.icon import MetaIcon
+from core.utils import GetLayerNameFromCmd
+class MySingleMapFrame(MapFrameBase):
+ """! Frame with one map window.
+ It is base class for frames which needs only one map.
+ Derived class should have \c self.MapWindow or
+ it has to override GetWindow() methods.
+ @note To access maps use getters only
+ (when using class or when writing class itself).
+ def __init__(self, parent = None, giface = None, id = wx.ID_ANY, title = None,
+ style = wx.DEFAULT_FRAME_STYLE,
+ Map = Map(),
+ auimgr = None, name = None, **kwargs):
+ @param parent gui parent
+ @param id wx id
+ @param title window title
+ @param style \c wx.Frame style
+ @param Map instance of render.Map
+ @param name frame name
+ @param kwargs arguments passed to MapFrameBase
+ MapFrameBase.__init__(self, parent = parent, id = id, title = title,
+ style = style,
+ auimgr = auimgr, name = name, **kwargs)
+ self.Map = Map # instance of render.Map
+ vbox = wx.BoxSizer(wx.HORIZONTAL)
+ p = wx.Panel(self,-1)
+ #self.ltree = LayerTree(self, self.Map)
+ # initialize region values
+ self._initMap(Map = self.Map)
+ self._lmgr = LayerManager(p,self.Map)
+ self.MapWindow = BufferedWindow2(p, giface = giface, id = id, Map = self.Map)
+ vbox.Add(self._lmgr, 1, wx.EXPAND | wx.ALL, 20)
+ vbox.Add(self.MapWindow, 1, wx.EXPAND | wx.ALL, 20)
+ p.SetSizer(vbox)
+ def GetLayerByIndex(self, index):
+ return self.GetLayerManager().GetLayerByIndex(index)
+ def GetCurrentIndex(self):
+ return self.GetLayerManager().GetCurrentIndex()
+ def GetLayerManager(self):
+ return self._lmgr
+ def SetLayerManager(self, lmgr):
+ self._lmgr = lmgr
+ def AddLayer(self, layer):
+ self.GetLayerManager().AddLayer(layer)
+ def GetMap(self):
+ """!Returns map (renderer) instance"""
+ return self.Map
+ def GetWindow(self):
+ """!Returns map window"""
+ return self.MapWindow
+ def GetWindows(self):
+ """!Returns list of map windows"""
+ return [self.MapWindow]
+ def OnRender(self, event):
+ """!Re-render map composition (each map layer)
+ self.GetWindow().UpdateMap(render = True, renderVector = True)
+ # update statusbar
+ #rashad
+ #self.StatusbarUpdate()
+class LayerManager(wx.Panel):
+ def __init__(self, parent, Map, id = wx.ID_ANY, style = wx.SUNKEN_BORDER,
+ ctstyle = CT.TR_HAS_BUTTONS | CT.TR_HAS_VARIABLE_ROW_HEIGHT |
+ CT.TR_HIDE_ROOT | CT.TR_ROW_LINES | CT.TR_FULL_ROW_HIGHLIGHT |
+ CT.TR_MULTIPLE, **kwargs):
+ wx.Panel.__init__(self, parent = parent, id =id, style = style)
+ self._layerList = []
+ self._activeLayer = None
+ self._activeIndex = 0
+ self._Map = Map
+ self.ltree = LayerTree(self,Map, id = id, style = style, ctstyle = ctstyle, **kwargs)
+ self.ltree.SetSize((300,500))
+ def AddLayer(self, layer, active = True):
+ self.ltree.AddLayer(layer, True)
+ self.ltree.GetLayerByIndex(index)
+ self.ltree.GetCurrentIndex()
+class LayerTree(treemixin.DragAndDrop, CT.CustomTreeCtrl):
+ """copied from lmgr.layertree.py"""
+ def __init__(self, parent, Map, id, style, ctstyle, **kwargs):
+ if globalvar.hasAgw:
+ super(LayerTree, self).__init__(parent, id, agwStyle = ctstyle, **kwargs)
+ else:
+ super(LayerTree, self).__init__(parent, id, style = ctstyle, **kwargs)
+ #wx.Window.__init__(self, parent = parent, id =-2)
+ #self.panel = wx.Panel(self, )
+ self._Map = Map
+ self.root = self.AddRoot(_("Map Layers"))
+ self.SetPyData(self.root, (None, None))
+ il = wx.ImageList(16, 16, mask = False)
+ trart = wx.ArtProvider.GetBitmap(wx.ART_FILE_OPEN, wx.ART_OTHER, (16, 16))
+ self.folder_open = il.Add(trart)
+ trart = wx.ArtProvider.GetBitmap(wx.ART_FOLDER, wx.ART_OTHER, (16, 16))
+ self.folder = il.Add(trart)
+ bmpsize = (16, 16)
+ trgif = BaseIcons["addRast"].GetBitmap(bmpsize)
+ self.rast_icon = il.Add(trgif)
+ trgif = LMIcons["addRast3d"].GetBitmap(bmpsize)
+ self.rast3d_icon = il.Add(trgif)
+ trgif = LMIcons["addRgb"].GetBitmap(bmpsize)
+ self.rgb_icon = il.Add(trgif)
+ trgif = LMIcons["addHis"].GetBitmap(bmpsize)
+ self.his_icon = il.Add(trgif)
+ trgif = LMIcons["addShaded"].GetBitmap(bmpsize)
+ self.shaded_icon = il.Add(trgif)
+ trgif = LMIcons["addRArrow"].GetBitmap(bmpsize)
+ self.rarrow_icon = il.Add(trgif)
+ trgif = LMIcons["addRNum"].GetBitmap(bmpsize)
+ self.rnum_icon = il.Add(trgif)
+ trgif = BaseIcons["addVect"].GetBitmap(bmpsize)
+ self.vect_icon = il.Add(trgif)
+ trgif = LMIcons["addThematic"].GetBitmap(bmpsize)
+ self.theme_icon = il.Add(trgif)
+ trgif = LMIcons["addChart"].GetBitmap(bmpsize)
+ self.chart_icon = il.Add(trgif)
+ trgif = LMIcons["addGrid"].GetBitmap(bmpsize)
+ self.grid_icon = il.Add(trgif)
+ trgif = LMIcons["addGeodesic"].GetBitmap(bmpsize)
+ self.geodesic_icon = il.Add(trgif)
+ trgif = LMIcons["addRhumb"].GetBitmap(bmpsize)
+ self.rhumb_icon = il.Add(trgif)
+ trgif = LMIcons["addLabels"].GetBitmap(bmpsize)
+ self.labels_icon = il.Add(trgif)
+ trgif = LMIcons["addCmd"].GetBitmap(bmpsize)
+ self.cmd_icon = il.Add(trgif)
+ trgif = LMIcons["wsImport"].GetBitmap(bmpsize)
+ self.ws_icon = il.Add(trgif)
+ self.AssignImageList(il)
+ def AddLayer(self, layer, active = True, multiple = True, lchecked = True):
+ self._Map.AddMapLayer(layer)
+ self._layerList.append(layer)
+ self._activeIndex = len(self._layerList) - 1
+ if layer.name and not multiple:
+ # check for duplicates
+ item = self.GetFirstVisibleItem()
+ while item and item.IsOk():
+ if self.GetLayerInfo(item, key = 'type') == 'vector':
+ name = self.GetLayerInfo(item, key = 'maplayer').GetName()
+ if name == lname:
+ return
+ item = self.GetNextVisible(item)
+ self.first = True
+ # deselect active item
+ if self._activeLayer:
+ self.SelectItem(self._activeLayer, select = False)
+ Debug.msg (3, "LayerTree().AddLayer(): ltype=%s" % (layer.type))
+ if layer.type == 'command':
+ # generic command item
+ ctrl = wx.TextCtrl(self, id = wx.ID_ANY, value = '',
+ pos = wx.DefaultPosition, size = (self.GetSize()[0]-100,25),
+ # style = wx.TE_MULTILINE|wx.TE_WORDWRAP)
+ style = wx.TE_PROCESS_ENTER | wx.TE_DONTWRAP)
+ ctrl.Bind(wx.EVT_TEXT_ENTER, self.OnCmdChanged)
+ # ctrl.Bind(wx.EVT_TEXT, self.OnCmdChanged)
+ elif layer.type == 'group':
+ # group item
+ ctrl = None
+ grouptext = _('Layer group:') + str(self.groupnode)
+ self.groupnode += 1
+ else:
+ btnbmp = LMIcons["layerOptions"].GetBitmap((16,16))
+ ctrl = buttons.GenBitmapButton(self, id = wx.ID_ANY, bitmap = btnbmp, size = (24,24))
+ ctrl.SetToolTipString(_("Click to edit layer settings"))
+#rashad self.Bind(wx.EVT_BUTTON, self.OnLayerContextMenu, ctrl)
+ # add layer to the layer tree
+ if self._activeLayer and self._activeLayer != self.GetRootItem():
+ if self.GetLayerInfo(self._activeLayer, key = 'type') == 'group' \
+ and self.IsExpanded(self._activeLayer):
+ # add to group (first child of self._activeLayer) if group expanded
+ layeritem = self.PrependItem(parent = self._activeLayer,
+ text = '', ct_type = 1, wnd = ctrl)
+ else:
+ # prepend to individual layer or non-expanded group
+ if lgroup == -1:
+ # -> last child of root (loading from workspace)
+ layeritem = self.AppendItem(parentId = self.root,
+ elif lgroup > -1:
+ # -> last child of group (loading from workspace)
+ parent = self.FindItemByIndex(index = lgroup)
+ if not parent:
+ parent = self.root
+ layeritem = self.AppendItem(parentId = parent,
+ elif lgroup is None:
+ # -> previous sibling of selected layer
+ parent = self.GetItemParent(self._activeLayer)
+ layeritem = self.InsertItem(parentId = parent,
+ input = self.GetPrevSibling(self._activeLayer),
+ else: # add first layer to the layer tree (first child of root)
+ layeritem = self.PrependItem(parent = self.root, text = '', ct_type = 1, wnd = ctrl)
+ # layer is initially unchecked as inactive (beside 'command')
+ # use predefined value if given
+ if lchecked is not None:
+ checked = lchecked
+ else:
+ checked = True
+ self.forceCheck = True
+ self.CheckItem(layeritem, checked = checked)
+ # add text and icons for each layer layer.type
+ label = _('(double click to set properties)') + ' ' * 15
+ if layer.type == 'raster':
+ self.SetItemImage(layeritem, self.rast_icon)
+ self.SetItemText(layeritem, '%s %s' % (_('raster'), label))
+ elif layer.type == '3d-raster':
+ self.SetItemImage(layeritem, self.rast3d_icon)
+ self.SetItemText(layeritem, '%s %s' % (_('3D raster'), label))
+ elif layer.type == 'rgb':
+ self.SetItemImage(layeritem, self.rgb_icon)
+ self.SetItemText(layeritem, '%s %s' % (_('RGB'), label))
+ elif layer.type == 'his':
+ self.SetItemImage(layeritem, self.his_icon)
+ self.SetItemText(layeritem, '%s %s' % (_('HIS'), label))
+ elif layer.type == 'shaded':
+ self.SetItemImage(layeritem, self.shaded_icon)
+ self.SetItemText(layeritem, '%s %s' % (_('shaded relief'), label))
+ elif layer.type == 'rastnum':
+ self.SetItemImage(layeritem, self.rnum_icon)
+ self.SetItemText(layeritem, '%s %s' % (_('raster cell numbers'), label))
+ elif layer.type == 'rastarrow':
+ self.SetItemImage(layeritem, self.rarrow_icon)
+ self.SetItemText(layeritem, '%s %s' % (_('raster flow arrows'), label))
+ elif layer.type == 'vector':
+ self.SetItemImage(layeritem, self.vect_icon)
+ self.SetItemText(layeritem, '%s %s' % (_('vector'), label))
+ elif layer.type == 'thememap':
+ self.SetItemImage(layeritem, self.theme_icon)
+ self.SetItemText(layeritem, '%s %s' % (_('thematic area (choropleth) map'), label))
+ elif layer.type == 'themechart':
+ self.SetItemImage(layeritem, self.chart_icon)
+ self.SetItemText(layeritem, '%s %s' % (_('thematic charts'), label))
+ elif layer.type == 'grid':
+ self.SetItemImage(layeritem, self.grid_icon)
+ self.SetItemText(layeritem, '%s %s' % (_('grid'), label))
+ elif layer.type == 'geodesic':
+ self.SetItemImage(layeritem, self.geodesic_icon)
+ self.SetItemText(layeritem, '%s %s' % (_('geodesic line'), label))
+ elif layer.type == 'rhumb':
+ self.SetItemImage(layeritem, self.rhumb_icon)
+ self.SetItemText(layeritem, '%s %s' % (_('rhumbline'), label))
+ elif layer.type == 'labels':
+ self.SetItemImage(layeritem, self.labels_icon)
+ self.SetItemText(layeritem, '%s %s' % (_('vector labels'), label))
+ elif layer.type == 'command':
+ self.SetItemImage(layeritem, self.cmd_icon)
+ self.SetItemImage(layeritem, self.folder, CT.TreeItemIcon_Normal)
+ self.SetItemImage(layeritem, self.folder_open, CT.TreeItemIcon_Expanded)
+ self.SetItemText(layeritem, grouptext)
+ elif layer.type == 'wms':
+ self.SetItemImage(layeritem, self.ws_icon)
+ self.SetItemText(layeritem, '%s %s' % (_('wms'), label))
+ self.first = False
+ if layer.type != 'group':
+ if layer.cmd and len(layer.cmd) > 1:
+ cmd = layer.cmd
+ render = False
+ name, found = layer.name, True
+ else:
+ cmd = []
+ if layer.type == 'command' and layer.name:
+ for c in lname.split(';'):
+ cmd.append(c.split(' '))
+ render = False
+ name = None
+ if ctrl:
+ ctrlId = ctrl.GetId()
+ else:
+ ctrlId = None
+ # add a data object to hold the layer's command (does not apply to generic command layers)
+ self.SetPyData(layeritem, ({'cmd' : cmd,
+ 'type' : layer.type,
+ 'ctrl' : ctrlId,
+ 'label' : None,
+ 'maplayer' : None,
+ 'vdigit' : None,
+ 'nviz' : None,
+ 'propwin' : None},
+ None))
+ # find previous map layer instance
+ prevItem = self.GetFirstChild(self.root)[0]
+ prevMapLayer = None
+ pos = -1
+ while prevItem and prevItem.IsOk() and prevItem != layeritem:
+ if self.GetLayerInfo(prevItem, key = 'maplayer'):
+ prevMapLayer = self.GetLayerInfo(prevItem, key = 'maplayer')
+ prevItem = self.GetNextSibling(prevItem)
+ if prevMapLayer:
+ pos = self.Map.GetLayerIndex(prevMapLayer)
+ else:
+ pos = -1
+# maplayer = self.Map.AddLayer(pos = pos,
+# ltype = ltype, command = self.GetLayerInfo(prevItem, key = 'cmd'), name = name,
+# active = checked, hidden = False,
+# opacity = lopacity, render = render)
+# self.SetLayerInfo(layer, key = 'maplayer', value = maplayer)
+# # run properties dialog if no properties given
+# if len(cmd) == 0:
+# self.PropertiesDialog(layer, show = True)
+ else: # group
+ self.SetPyData(layeritem, ({'cmd' : None,
+ 'type' : ltype,
+ 'ctrl' : None,
+ 'label' : None,
+ None))
+ # select new item
+ self.SelectItem(layeritem, select = True)
+ # use predefined layer name if given
+ if layer.name:
+ if layer.type == 'group':
+ self.SetItemText(layeritem, layer.name)
+ ctrl.SetValue(layer.name)
+ else:
+ self.SetItemText(layeritem, 'ELEVATIOM at PERMANENT')
+ else:
+ self.OnRenameLayer(None)
+ return layeritem
+ if index > -1 and index < len(self._layerList):
+ return self._layerList[index]
+ return self._activeIndex
Added: grass-addons/grass7/gui/wxpython/newgui/frame.py
--- grass-addons/grass7/gui/wxpython/newgui/frame.py (rev 0)
+++ grass-addons/grass7/gui/wxpython/newgui/frame.py 2013-03-13 18:02:02 UTC (rev 55366)
@@ -0,0 +1,62 @@
+ at package frame.py
+for details.
+import os
+import sys
+import copy
+import tempfile
+import gettext
+if __name__ == "__main__":
+ sys.path.append(os.path.join(os.environ['GISBASE'], "etc", "gui", "wxpython"))
+import wx
+from api_test import MySingleMapFrame
+from core.render import MapLayer
+class MyFrame(MySingleMapFrame):
+ """!main frame
+ def __init__(self, parent = None, giface = None, title = _("GRASS UI"),
+ size = (875, 600), name = 'Frame', **kwargs):
+ @param parent (no parent is expected)
+ @param size default size
+ #self.Map = Map()
+ #self.giface = giface
+ MySingleMapFrame.__init__(self, parent = parent, title = title, size = size, name = name, **kwargs)
+ self.cmd =["d.rast", "map=aspect at PERMANENT"]
+ self.rlayer = MapLayer(ltype = 'raster', cmd = self.cmd, Map = self.GetMap(), name = "elevation")
+ self.AddLayer(self.rlayer)
+ #print self.GetLayerByIndex(0).name
+ #print self.GetCurrentIndex()
+def main():
+ gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
+ app = wx.PySimpleApp()
+ wx.InitAllImageHandlers()
+ frame = MyFrame()
+ frame.Show()
+ app.MainLoop()
+ main()
Added: grass-addons/grass7/gui/wxpython/newgui/gui_mapwindow.py
--- grass-addons/grass7/gui/wxpython/newgui/gui_mapwindow.py (rev 0)
+++ grass-addons/grass7/gui/wxpython/newgui/gui_mapwindow.py 2013-03-13 18:02:02 UTC (rev 55366)
@@ -0,0 +1,248 @@
+ at package gui_core.mapwindow
+ at brief Map display canvas - base class for buffered window.
+Classes:
+ - mapwindow::MapWindow
+(C) 2006-2012 by the GRASS Development Team
+This program is free software under the GNU General Public License
+(>=v2). Read the file COPYING that comes with GRASS for details.
+ at author Martin Landa <landa.martin gmail.com>
+ at author Michael Barton
+ at author Jachym Cepicky
+ at author Vaclav Petras <wenzeslaus gmail.com> (handlers support)
+ at author Stepan Turek <stepan.turek seznam.cz> (handlers support)
+import wx
+from core.settings import UserSettings
+from grass.script import core as grass
+class MapWindow(object):
+ """!Abstract map display window class
+ Superclass for BufferedWindow class (2D display mode), and GLWindow
+ (3D display mode).
+ Subclasses have to define
+ - _bindMouseEvents method which binds MouseEvent handlers
+ - Pixel2Cell
+ - Cell2Pixel (if it is possible)
+ def __init__(self, parent, giface, Map, frame, **kwargs):
+ self.parent = parent
+ self.Map = Map
+ self.frame = frame
+ self._giface = giface
+ self.Map.SetReceiver(self)
+ # mouse attributes -- position on the screen, begin and end of
+ # dragging, and type of drawing
+ self.mouse = {
+ 'begin': [0, 0], # screen coordinates
+ 'end' : [0, 0],
+ 'use' : "pointer",
+ 'box' : "point"
+ # last east, north coordinates, changes on mouse motion
+ self.lastEN = None
+ # stores overridden cursor
+ self._overriddenCursor = None
+ # dictionary where event types are stored as keys and lists of
+ # handlers for these types as values
+ self.handlersContainer = {
+ wx.EVT_LEFT_DOWN : [],
+ wx.EVT_LEFT_UP : [],
+ wx.EVT_LEFT_DCLICK : [],
+ wx.EVT_MIDDLE_DOWN : [],
+ wx.EVT_MIDDLE_UP : [],
+ wx.EVT_MIDDLE_DCLICK : [],
+ wx.EVT_RIGHT_DOWN : [],
+ wx.EVT_RIGHT_UP : [],
+ wx.EVT_RIGHT_DCLICK : [],
+ wx.EVT_MOTION : [],
+ wx.EVT_ENTER_WINDOW : [],
+ wx.EVT_LEAVE_WINDOW : [],
+ wx.EVT_MOUSEWHEEL : [],
+ wx.EVT_MOUSE_EVENTS : []
+ wx.CallAfter(self.InitBinding)
+ def __del__(self):
+ self.UnregisterAllHandlers()
+ def InitBinding(self):
+ """!Binds helper functions, which calls all handlers
+ registered to events with the events
+ for ev, handlers in self.handlersContainer.iteritems():
+ self.Bind(ev, self.EventTypeHandler(handlers))
+ def EventTypeHandler(self, evHandlers):
+ return lambda event:self.HandlersCaller(event, evHandlers)
+ def HandlersCaller(self, event, handlers):
+ """!Hepler function which calls all handlers registered for
+ event
+ for handler in handlers:
+ try:
+ handler(event)
+ except:
+ handlers.remove(handler)
+ GError(parent = self,
+ message=_("Error occured during calling of handler: %s \n"
+ "Handler was unregistered.") % handler.__name__)
+ event.Skip()
+ def RegisterMouseEventHandler(self, event, handler, cursor = None):
+ """!Binds event handler
+ Call event.Skip() in handler to allow default processing in MapWindow.
+ If any error occures inside of handler, the handler is removed.
+ Before handler is unregistered it is called with
+ string value "unregistered" of event parameter.
+ @code
+ # your class methods
+ def OnButton(self, event):
+ # current map display's map window
+ # expects LayerManager to be the parent
+ self.mapwin = self.parent.GetLayerTree().GetMapDisplay().GetWindow()
+ if self.mapwin.RegisterEventHandler(wx.EVT_LEFT_DOWN, self.OnMouseAction,
+ wx.StockCursor(wx.CURSOR_CROSS)):
+ self.parent.GetLayerTree().GetMapDisplay().Raise()
+ else:
+ # handle that you cannot get coordinates
+ def OnMouseAction(self, event):
+ # get real world coordinates of mouse click
+ coor = self.mapwin.Pixel2Cell(event.GetPositionTuple()[:])
+ self.text.SetLabel('Coor: ' + str(coor))
+ self.mapwin.UnregisterMouseEventHandler(wx.EVT_LEFT_DOWN, self.OnMouseAction)
+ event.Skip()
+ @endcode
+ @param event one of mouse events
+ @param handler function to handle event
+ @param cursor cursor which temporary overrides current cursor
+ @return True if successful
+ @return False if event cannot be bind
+ # inserts handler into list
+ for containerEv, handlers in self.handlersContainer.iteritems():
+ if event == containerEv:
+ handlers.append(handler)
+ self.mouse['useBeforeGenericEvent'] = self.mouse['use']
+ self.mouse['use'] = 'genericEvent'
+ if cursor:
+ self._overriddenCursor = self.GetCursor()
+ self.SetCursor(cursor)
+ return True
+ def UnregisterAllHandlers(self):
+ """!Unregisters all registered handlers
+ Before each handler is unregistered it is called with string
+ value "unregistered" of event parameter.
+ try:
+ handler("unregistered")
+ except:
+ message = _("Error occured during unregistration of handler: %s \n \
+ Handler was unregistered.") % handler.__name__)
+ def UnregisterMouseEventHandler(self, event, handler):
+ """!Unbinds event handler for event
+ Before handler is unregistered it is called with string value
+ "unregistered" of event parameter.
+ @param handler handler to unbind
+ @param event event from which handler will be unbinded
+ @return False if event cannot be unbind
+ # removes handler from list
+ if event != containerEv:
+ continue
+ try:
+ if handler in handlers:
+ else:
+ grass.warning(_("Handler: %s was not registered") \
+ % handler.__name__)
+ except:
+ Handler was unregistered") % handler.__name__)
+ # restore mouse use (previous state)
+ self.mouse['use'] = self.mouse['useBeforeGenericEvent']
+ # restore overridden cursor
+ if self._overriddenCursor:
+ self.SetCursor(self._overriddenCursor)
+ return True
+ def Pixel2Cell(self, (x, y)):
+ raise NotImplementedError()
+ def Cell2Pixel(self, (east, north)):
+ def OnMotion(self, event):
+ """!Tracks mouse motion and update statusbar
+ @see GetLastEN
+ try:
+ self.lastEN = self.Pixel2Cell(event.GetPositionTuple())
+ except (ValueError):
+ # FIXME: special case for vdigit and access to statusbarManager
+#rashad if self.frame.statusbarManager.GetMode() == 0: # Coordinates
+# updated = False
+# if hasattr(self, "digit"):
+# precision = int(UserSettings.Get(group = 'projection', key = 'format',
+# subkey = 'precision'))
+# updated = self._onMotion(self.lastEN, precision)
+# if not updated:
+# self.frame.CoordinatesChanged()
+ event.Skip()
+ def GetLastEN(self):
+ """!Returns last coordinates of mouse cursor.
+ @see OnMotion
+ return self.lastEN
Added: grass-addons/grass7/gui/wxpython/newgui/mapwindow.py
--- grass-addons/grass7/gui/wxpython/newgui/mapwindow.py (rev 0)
+++ grass-addons/grass7/gui/wxpython/newgui/mapwindow.py 2013-03-13 18:02:02 UTC (rev 55366)
@@ -0,0 +1,2173 @@
+ at package mapdisp.mapwindow
+ at brief Map display canvas - buffered window.
+Classes:
+ - mapwindow::BufferedWindow2
+ - mapwindow::GraphicsSet
+ - mapwindow::GraphicsSetItem
+ at author Stepan Turek <stepan.turek seznam.cz> (handlers support, GraphicsSet)
+import os
+import time
+import math
+import sys
+from copy import copy
+import wx
+from grass.pydispatch.signal import Signal
+from gui_core.dialogs import SavedRegion
+from core.gcmd import RunCommand, GException, GError, GMessage
+from core.events import EVT_UPDATE_MAP
+from gui_mapwindow import MapWindow
+from core.ws import EVT_UPDATE_PRGBAR
+from core.utils import GetGEventAttribsForHandler
+try:
+ import grass.lib.gis as gislib
+ haveCtypes = True
+ haveCtypes = False
+class BufferedWindow2(MapWindow, wx.Window):
+ """!A Buffered window class (2D view mode)
+ Superclass for VDigitWindow (vector digitizer).
+ When the drawing needs to change, you app needs to call the
+ UpdateMap() method. Since the drawing is stored in a bitmap, you
+ can also save the drawing to file by calling the
+ SaveToFile() method.
+ def __init__(self, parent, giface, Map, frame=None,
+ id = wx.ID_ANY, tree = None, lmgr = None, overlays = None,
+ style = wx.NO_FULL_REPAINT_ON_RESIZE, **kwargs):
+ MapWindow.__init__(self, parent = parent, giface = giface, Map = Map,
+ frame = frame, **kwargs)
+ wx.Window.__init__(self, parent = parent, id = id, style = style, **kwargs)
+ self.tree = tree
+ # flags
+ self.resize = False # indicates whether or not a resize event has taken place
+ self.dragimg = None # initialize variable for map panning
+ self.alwaysRender = False # if it always sets render to True in self.UpdateMap()
+ # variables for drawing on DC
+ self.pen = None # pen for drawing zoom boxes, etc.
+ self.polypen = None # pen for drawing polylines (measurements, profiles, etc)
+ # List of wx.Point tuples defining a polyline (geographical coordinates)
+ self.polycoords = []
+ # ID of rubber band line
+ self.lineid = None
+ # ID of poly line resulting from cumulative rubber band lines (e.g. measurement)
+ self.plineid = None
+ # Emitted when zoom of a window is changed
+ self.zoomChanged = Signal('BufferedWindow2.zoomChanged')
+ #rashad self._giface.updateMap.connect(self.UpdateMap)
+ # event bindings
+ self.Bind(wx.EVT_PAINT, self.OnPaint)
+ self.Bind(wx.EVT_SIZE, self.OnSize)
+ self.Bind(wx.EVT_IDLE, self.OnIdle)
+ self.Bind(EVT_UPDATE_MAP, self.OnUpdateMap)
+ if self.frame and hasattr(self.frame, 'OnUpdateProgress'):
+ self.Bind(EVT_UPDATE_PRGBAR, self.frame.OnUpdateProgress)
+ self._bindMouseEvents()
+ self.processMouse = True
+ # render output objects
+ self.mapfile = None # image file to be rendered
+ self.img = None # wx.Image object (self.mapfile)
+ # decoration overlays
+ self.overlays = overlays
+ # images and their PseudoDC ID's for painting and dragging
+ self.imagedict = {}
+ self.select = {} # selecting/unselecting decorations for dragging
+ self.textdict = {} # text, font, and color indexed by id
+ self.currtxtid = None # PseudoDC id for currently selected text
+ # zoom objects
+ self.zoomhistory = [] # list of past zoom extents
+ self.currzoom = 0 # current set of extents in zoom history being used
+ self.zoomtype = 1 # 1 zoom in, 0 no zoom, -1 zoom out
+ self.hitradius = 10 # distance for selecting map decorations
+ self.dialogOffset = 5 # offset for dialog (e.g. DisplayAttributesDialog)
+ # OnSize called to make sure the buffer is initialized.
+ # This might result in OnSize getting called twice on some
+ # platforms at initialization, but little harm done.
+ ### self.OnSize(None)
+ self._definePseudoDC()
+ # redraw all pdc's, pdcTmp layer is redrawn always (speed issue)
+ self.redrawAll = True
+ # will store an off screen empty bitmap for saving to file
+ self._buffer = wx.EmptyBitmap(max(1, self.Map.width), max(1, self.Map.height))
+ self.Bind(wx.EVT_ERASE_BACKGROUND, lambda x:None)
+ # vars for handling mouse clicks
+ self.dragid = -1
+ self.lastpos = (0, 0)
+ # list for registration of graphics to draw
+ self.graphicsSetList = []
+ def _definePseudoDC(self):
+ """!Define PseudoDC objects to use
+ # create PseudoDC used for background map, map decorations like scales and legends
+ self.pdc = wx.PseudoDC()
+ # used for digitization tool
+ self.pdcVector = None
+ # decorations (region box, etc.)
+ self.pdcDec = wx.PseudoDC()
+ # pseudoDC for temporal objects (select box, measurement tool, etc.)
+ self.pdcTmp = wx.PseudoDC()
+ def _bindMouseEvents(self):
+ self.Bind(wx.EVT_MOUSE_EVENTS, self.MouseActions)
+ self.Bind(wx.EVT_MOTION, self.OnMotion)
+ self.Bind(wx.EVT_CONTEXT_MENU, self.OnContextMenu)
+ def OnContextMenu(self, event):
+ """!Show Map Display context menu"""
+ if hasattr(self, "digit"):
+ event.Skip()
+ return
+ if not hasattr(self, "popupCopyCoordinates"):
+ self.popupCopyCoordinates = wx.NewId()
+ self.Bind(wx.EVT_MENU, self.OnCopyCoordinates, id = self.popupCopyCoordinates)
+ # generate popup-menu
+ menu = wx.Menu()
+ menu.Append(self.popupCopyCoordinates, _("Copy coordinates to clipboard"))
+ self.PopupMenu(menu)
+ menu.Destroy()
+ def Draw(self, pdc, img = None, drawid = None, pdctype = 'image', coords = [0, 0, 0, 0], pen = None):
+ """!Draws map and overlay decorations
+ if drawid == None:
+ if pdctype == 'image' and img:
+ drawid = self.imagedict[img]
+ elif pdctype == 'clear':
+ drawid = None
+ else:
+ drawid = wx.NewId()
+ # TODO: find better solution
+ if not pen:
+ if pdctype == 'polyline':
+ pen = self.polypen
+ else:
+ pen = self.pen
+ if img and pdctype == 'image':
+ # self.imagedict[img]['coords'] = coords
+ self.select[self.imagedict[img]['id']] = False # ?
+ pdc.BeginDrawing()
+ if drawid != 99:
+ bg = wx.TRANSPARENT_BRUSH
+ else:
+ bg = wx.Brush(self.GetBackgroundColour())
+ pdc.SetBackground(bg)
+ Debug.msg (5, "BufferedWindow2.Draw(): id=%s, pdctype = %s, coord=%s" % \
+ (drawid, pdctype, coords))
+ # set PseudoDC id
+ if drawid is not None:
+ pdc.SetId(drawid)
+ if pdctype == 'clear': # erase the display
+ bg = wx.WHITE_BRUSH
+ # bg = wx.Brush(self.GetBackgroundColour())
+ pdc.RemoveAll()
+ pdc.Clear()
+ pdc.EndDrawing()
+ self.Refresh()
+ return
+ if pdctype == 'image': # draw selected image
+ bitmap = wx.BitmapFromImage(img)
+ w,h = bitmap.GetSize()
+ pdc.DrawBitmap(bitmap, coords[0], coords[1], True) # draw the composite map
+ pdc.SetIdBounds(drawid, wx.Rect(coords[0],coords[1], w, h))
+ elif pdctype == 'box': # draw a box on top of the map
+ if pen:
+ pdc.SetBrush(wx.Brush(wx.CYAN, wx.TRANSPARENT))
+ pdc.SetPen(pen)
+ x2 = max(coords[0],coords[2])
+ x1 = min(coords[0],coords[2])
+ y2 = max(coords[1],coords[3])
+ y1 = min(coords[1],coords[3])
+ rwidth = x2-x1
+ rheight = y2-y1
+ rect = wx.Rect(x1, y1, rwidth, rheight)
+ pdc.DrawRectangleRect(rect)
+ pdc.SetIdBounds(drawid, rect)
+ elif pdctype == 'line': # draw a line on top of the map
+ if pen:
+ pdc.SetPen(pen)
+ pdc.DrawLinePoint(wx.Point(coords[0], coords[1]),wx.Point(coords[2], coords[3]))
+ pdc.SetIdBounds(drawid, wx.Rect(coords[0], coords[1], coords[2], coords[3]))
+ elif pdctype == 'polyline': # draw a polyline on top of the map
+ if pen:
+ pdc.SetPen(pen)
+ if (len(coords) < 2):
+ return
+ i = 1
+ while i < len(coords):
+ pdc.DrawLinePoint(wx.Point(coords[i-1][0], coords[i-1][1]),
+ wx.Point(coords[i][0], coords[i][1]))
+ i += 1
+ # get bounding rectangle for polyline
+ xlist = []
+ ylist = []
+ if len(coords) > 0:
+ for point in coords:
+ x,y = point
+ xlist.append(x)
+ ylist.append(y)
+ x1 = min(xlist)
+ x2 = max(xlist)
+ y1 = min(ylist)
+ y2 = max(ylist)
+ pdc.SetIdBounds(drawid, wx.Rect(x1,y1,x2,y2))
+ # self.ovlcoords[drawid] = [x1,y1,x2,y2]
+ elif pdctype == 'point': # draw point
+ if pen:
+ pdc.SetPen(pen)
+ pdc.DrawPoint(coords[0], coords[1])
+ coordsBound = (coords[0] - 5,
+ coords[1] - 5,
+ coords[0] + 5,
+ coords[1] + 5)
+ pdc.SetIdBounds(drawid, wx.Rect(coordsBound))
+ elif pdctype == 'text': # draw text on top of map
+ if not img['active']:
+ return # only draw active text
+ if 'rotation' in img:
+ rotation = float(img['rotation'])
+ else:
+ rotation = 0.0
+ w, h = self.GetFullTextExtent(img['text'])[0:2]
+ pdc.SetFont(img['font'])
+ pdc.SetTextForeground(img['color'])
+ coords, bbox = self.TextBounds(img)
+ if rotation == 0:
+ pdc.DrawText(img['text'], coords[0], coords[1])
+ else:
+ pdc.DrawRotatedText(img['text'], coords[0], coords[1], rotation)
+ pdc.SetIdBounds(drawid, bbox)
+ pdc.EndDrawing()
+ self.Refresh()
+ return drawid
+ def TextBounds(self, textinfo, relcoords = False):
+ """!Return text boundary data
+ @param textinfo text metadata (text, font, color, rotation)
+ @param coords reference point
+ @return coords of nonrotated text bbox (TL corner)
+ @return bbox of rotated text bbox (wx.Rect)
+ @return relCoords are text coord inside bbox
+ if 'rotation' in textinfo:
+ rotation = float(textinfo['rotation'])
+ else:
+ rotation = 0.0
+ coords = textinfo['coords']
+ bbox = wx.Rect(coords[0], coords[1], 0, 0)
+ relCoords = (0, 0)
+ Debug.msg (4, "BufferedWindow2.TextBounds(): text=%s, rotation=%f" % \
+ (textinfo['text'], rotation))
+ self.Update()
+ self.SetFont(textinfo['font'])
+ w, h = self.GetTextExtent(textinfo['text'])
+ if rotation == 0:
+ bbox[2], bbox[3] = w, h
+ if relcoords:
+ return coords, bbox, relCoords
+ else:
+ boxh = math.fabs(math.sin(math.radians(rotation)) * w) + h
+ boxw = math.fabs(math.cos(math.radians(rotation)) * w) + h
+ if rotation > 0 and rotation < 90:
+ bbox[1] -= boxh
+ relCoords = (0, boxh)
+ elif rotation >= 90 and rotation < 180:
+ bbox[0] -= boxw
+ bbox[1] -= boxh
+ relCoords = (boxw, boxh)
+ elif rotation >= 180 and rotation < 270:
+ bbox[0] -= boxw
+ relCoords = (boxw, 0)
+ bbox[2] = boxw
+ bbox[3] = boxh
+ bbox.Inflate(h,h)
+ if relcoords:
+ else:
+ def OnPaint(self, event):
+ """!Draw PseudoDC's to buffered paint DC
+ If self.redrawAll is False on self.pdcTmp content is re-drawn
+ Debug.msg(4, "BufferedWindow2.OnPaint(): redrawAll=%s" % self.redrawAll)
+ dc = wx.BufferedPaintDC(self, self._buffer)
+ dc.Clear()
+ # use PrepareDC to set position correctly
+ # probably does nothing, removed from wxPython 2.9
+ # self.PrepareDC(dc)
+ # create a clipping rect from our position and size
+ # and update region
+ rgn = self.GetUpdateRegion().GetBox()
+ dc.SetClippingRect(rgn)
+ switchDraw = False
+ if self.redrawAll is None:
+ switchDraw = True
+ if self.redrawAll: # redraw pdc and pdcVector
+ # draw to the dc using the calculated clipping rect
+ self.pdc.DrawToDCClipped(dc, rgn)
+ # draw vector map layer
+ # decorate with GDDC (transparency)
+ try:
+ gcdc = wx.GCDC(dc)
+ self.pdcVector.DrawToDCClipped(gcdc, rgn)
+ except NotImplementedError, e:
+ print >> sys.stderr, e
+ self.pdcVector.DrawToDCClipped(dc, rgn)
+ self.bufferLast = None
+ else: # do not redraw pdc and pdcVector
+ if self.bufferLast is None:
+ # draw to the dc
+ self.pdc.DrawToDC(dc)
+ try:
+ self.pdcVector.DrawToDC(gcdc)
+ self.pdcVector.DrawToDC(dc)
+ # store buffered image
+ # self.bufferLast = wx.BitmapFromImage(self.buffer.ConvertToImage())
+ self.bufferLast = dc.GetAsBitmap(wx.Rect(0, 0, self.Map.width, self.Map.height))
+ self.pdc.DrawBitmap(self.bufferLast, 0, 0, False)
+ # draw decorations (e.g. region box)
+ try:
+ self.pdcDec.DrawToDC(gcdc)
+ self.pdcDec.DrawToDC(dc)
+ # draw temporary object on the foreground
+ ### self.pdcTmp.DrawToDCClipped(dc, rgn)
+ self.pdcTmp.DrawToDC(dc)
+ if switchDraw:
+ self.redrawAll = False
+ def OnSize(self, event):
+ """!Scale map image so that it is the same size as the Window
+ # re-render image on idle
+ self.resize = time.clock()
+ def OnIdle(self, event):
+ """!Only re-render a composite map image from GRASS during
+ idle time instead of multiple times during resizing.
+ # use OnInternalIdle() instead ?
+ if self.resize and self.resize + 0.2 < time.clock():
+ Debug.msg(3, "BufferedWindow2.OnSize():")
+ # set size of the input image
+ self.Map.ChangeMapSize(self.GetClientSize())
+ # Make new off screen bitmap: this bitmap will always have the
+ # current drawing in it, so it can be used to save the image to
+ # a file, or whatever.
+ self._buffer.Destroy()
+ # get the image to be rendered
+ self.img = self.GetImage()
+ # update map display
+ updatemap = True
+ if self.img and self.Map.width + self.Map.height > 0: # scale image after resize
+ self.img = self.img.Scale(self.Map.width, self.Map.height)
+ if len(self.Map.GetListOfLayers()) > 0:
+ self.UpdateMap()
+ updatemap = False
+#rashad
+# # reposition checkbox in statusbar
+# self.frame.StatusbarReposition()
+# # update statusbar
+# self.frame.StatusbarUpdate()
+ if updatemap:
+ self.UpdateMap(render = True)
+ elif self.resize:
+ event.RequestMore()
+ event.Skip()
+ def SaveToFile(self, FileName, FileType, width, height):
+ """!This draws the pseudo DC to a buffer that can be saved to
+ a file.
+ @param FileName file name
+ @param FileType type of bitmap
+ @param width image width
+ @param height image height
+ busy = wx.BusyInfo(message = _("Please wait, exporting image..."),
+ parent = self)
+ wx.Yield()
+ self.Map.ChangeMapSize((width, height))
+ ibuffer = wx.EmptyBitmap(max(1, width), max(1, height))
+ self.Map.Render(force = True, windres = self.frame.GetProperty('resolution'))
+ img = self.GetImage()
+ self.pdc.RemoveAll()
+ self.Draw(self.pdc, img, drawid = 99)
+ # compute size ratio to move overlay accordingly
+ cSize = self.GetClientSizeTuple()
+ ratio = float(width) / cSize[0], float(height) / cSize[1]
+ # redraw legend, scalebar
+ for img in self.GetOverlay():
+ # draw any active and defined overlays
+ if self.imagedict[img]['layer'].IsActive():
+ id = self.imagedict[img]['id']
+ coords = int(ratio[0] * self.overlays[id].coords[0]),\
+ int(ratio[1] * self.overlays[id].coords[1])
+ self.Draw(self.pdc, img = img, drawid = id,
+ pdctype = self.overlays[id].pdcType, coords = coords)
+ # redraw text labels
+ for id in self.textdict.keys():
+ textinfo = self.textdict[id]
+ oldCoords = textinfo['coords']
+ textinfo['coords'] = ratio[0] * textinfo['coords'][0],\
+ ratio[1] * textinfo['coords'][1]
+ self.Draw(self.pdc, img = self.textdict[id], drawid = id,
+ pdctype = 'text')
+ # set back old coordinates
+ textinfo['coords'] = oldCoords
+ dc = wx.BufferedDC(None, ibuffer)
+ dc.Clear()
+ if self.pdcVector:
+ ibuffer.SaveFile(FileName, FileType)
+ busy.Destroy()
+ self.Refresh()
+ def GetOverlay(self):
+ """!Converts rendered overlay files to wx.Image
+ Updates self.imagedict
+ @return list of images
+ imgs = []
+ for overlay in self.Map.GetListOfLayers(ltype = "overlay", active = True):
+ if overlay.mapfile is not None \
+ and os.path.isfile(overlay.mapfile) and os.path.getsize(overlay.mapfile):
+ img = wx.Image(overlay.mapfile, wx.BITMAP_TYPE_ANY)
+ for key in self.imagedict.keys():
+ if self.imagedict[key]['id'] == overlay.id:
+ del self.imagedict[key]
+ self.imagedict[img] = { 'id' : overlay.id,
+ 'layer' : overlay }
+ imgs.append(img)
+ return imgs
+ def GetImage(self):
+ """!Converts redered map files to wx.Image
+ Updates self.imagedict (id=99)
+ @return wx.Image instance (map composition)
+ imgId = 99
+ if self.mapfile and self.Map.mapfile and os.path.isfile(self.Map.mapfile) and \
+ os.path.getsize(self.Map.mapfile):
+ img = wx.Image(self.Map.mapfile, wx.BITMAP_TYPE_ANY)
+ else:
+ img = None
+ if self.imagedict[key]['id'] == imgId:
+ self.imagedict[img] = { 'id': imgId }
+ return img
+ def SetAlwaysRenderEnabled(self, alwaysRender = True):
+ self.alwaysRender = alwaysRender
+ def IsAlwaysRenderEnabled(self):
+ return self.alwaysRender
+ def OnUpdateMap(self, event):
+ """!Called when this class receives core.events.gUpdateMap event.
+ kwargs, missing_args = GetGEventAttribsForHandler(self.UpdateMap, event)
+ if missing_args:
+ Debug.msg (1, "Invalid call of EVT_UPDATE_MAP event.")
+ return
+ self.UpdateMap(**kwargs)
+ def UpdateMap(self, render = True, renderVector = True):
+ """!Updates the canvas anytime there is a change to the
+ underlaying images or to the geometry of the canvas.
+ This method should not be called directly.
+ @todo change direct calling of UpdateMap method to emittig grass
+ interface updateMap signal
+ @param render re-render map composition
+ @param renderVector re-render vector map layer enabled for editing (used for digitizer)
+ start = time.clock()
+ # was if self.Map.cmdfile and ...
+ if self.IsAlwaysRenderEnabled() and self.img is None:
+ render = True
+ # render background image if needed
+ # update layer dictionary if there has been a change in layers
+ if self.tree and self.tree.reorder:
+ self.tree.ReorderLayers()
+ # reset flag for auto-rendering
+ if self.tree:
+ self.tree.rerender = False
+ try:
+ if render:
+ # update display size
+#############rashad
+ windres = True
+# if self.frame.GetProperty('resolution'):
+ # use computation region resolution for rendering
+ # windres = True
+ #else:
+ # windres = False
+ self.mapfile = self.Map.Render(force = True,
+ windres = windres)
+ else:
+ self.mapfile = self.Map.Render(force = False)
+ except GException, e:
+ GError(message = e.value)
+ self.img = self.GetImage() # id=99
+ # clear pseudoDcs
+ for pdc in (self.pdc,
+ self.pdcDec,
+ self.pdcTmp):
+ pdc.Clear()
+ pdc.RemoveAll()
+ # draw background map image to PseudoDC
+ if not self.img:
+ self.Draw(self.pdc, pdctype = 'clear')
+ else:
+ try:
+ id = self.imagedict[self.img]['id']
+ except:
+ return False
+ self.Draw(self.pdc, self.img, drawid = id)
+ # render vector map layer
+ if renderVector and hasattr(self, "digit"):
+ self._updateMap()
+ # render overlays
+ pdctype = self.overlays[id].pdcType, coords = self.overlays[id].coords)
+ pdctype = 'text', coords = [10, 10, 10, 10])
+ # optionally draw computational extent box
+ self.DrawCompRegionExtent()
+ # redraw pdcTmp if needed
+ # draw registered graphics
+ if len(self.graphicsSetList) > 0:
+ penOrig = self.pen
+ polypenOrig = self.polypen
+ for item in self.graphicsSetList:
+ try:
+ item.Draw(self.pdcTmp)
+ except:
+ message = _('Unable to draw registered graphics. '
+ 'The graphics was unregistered.'))
+ self.UnregisterGraphicsToDraw(item)
+ self.pen = penOrig
+ self.polypen = polypenOrig
+ if len(self.polycoords) > 0:
+ self.DrawLines(self.pdcTmp)
+ # clear measurement
+ if self.mouse["use"] == "measure":
+ self.ClearLines(pdc = self.pdcTmp)
+ self.mouse['use'] = 'pointer'
+ self.mouse['box'] = 'point'
+ self.mouse['end'] = [0, 0]
+ self.SetCursor(self.frame.cursors["default"])
+ stop = time.clock()
+ Debug.msg (1, "BufferedWindow2.UpdateMap(): render=%s, renderVector=%s -> time=%g" % \
+ (render, renderVector, (stop-start)))
+ return True
+ def DrawCompRegionExtent(self):
+ """!Draw computational region extent in the display
+ Display region is drawn as a blue box inside the computational region,
+ computational region inside a display region as a red box).
+ if hasattr(self, "regionCoords"):
+ compReg = self.Map.GetRegion()
+ dispReg = self.Map.GetCurrentRegion()
+ reg = None
+ if self.IsInRegion(dispReg, compReg):
+ self.polypen = wx.Pen(colour = wx.Colour(0, 0, 255, 128), width = 3, style = wx.SOLID)
+ reg = dispReg
+ else:
+ self.polypen = wx.Pen(colour = wx.Colour(255, 0, 0, 128),
+ width = 3, style = wx.SOLID)
+ reg = compReg
+ self.regionCoords = []
+ self.regionCoords.append((reg['w'], reg['n']))
+ self.regionCoords.append((reg['e'], reg['n']))
+ self.regionCoords.append((reg['e'], reg['s']))
+ self.regionCoords.append((reg['w'], reg['s']))
+ # draw region extent
+ self.DrawLines(pdc = self.pdcDec, polycoords = self.regionCoords)
+ def IsInRegion(self, region, refRegion):
+ Test if 'region' is inside of 'refRegion'
+ @param region input region
+ @param refRegion reference region (e.g. computational region)
+ @return True if region is inside of refRegion
+ @return False
+ if region['s'] >= refRegion['s'] and \
+ region['n'] <= refRegion['n'] and \
+ region['w'] >= refRegion['w'] and \
+ region['e'] <= refRegion['e']:
+ return True
+ return False
+ def EraseMap(self):
+ """!Erase map canvas
+ self.Draw(self.pdcVector, pdctype = 'clear')
+ self.Draw(self.pdcDec, pdctype = 'clear')
+ self.Draw(self.pdcTmp, pdctype = 'clear')
+ self.Map.AbortAllThreads()
+ def DragMap(self, moveto):
+ """!Drag the entire map image for panning.
+ @param moveto dx,dy
+ dc = wx.BufferedDC(wx.ClientDC(self))
+ dc.SetBackground(wx.Brush("White"))
+ dc.Clear()
+ self.dragimg = wx.DragImage(self._buffer)
+ self.dragimg.BeginDrag((0, 0), self)
+ self.dragimg.GetImageRect(moveto)
+ self.dragimg.Move(moveto)
+ self.dragimg.DoDrawImage(dc, moveto)
+ self.dragimg.EndDrag()
+ def DragItem(self, id, coords):
+ """!Drag an overlay decoration item
+ if id == 99 or id == '' or id == None: return
+ Debug.msg (5, "BufferedWindow2.DragItem(): id=%d" % id)
+ x, y = self.lastpos
+ dx = coords[0] - x
+ dy = coords[1] - y
+ self.pdc.SetBackground(wx.Brush(self.GetBackgroundColour()))
+ r = self.pdc.GetIdBounds(id)
+ if type(r) is list:
+ r = wx.Rect(r[0], r[1], r[2], r[3])
+ if id > 100: # text dragging
+ rtop = (r[0],r[1]-r[3],r[2],r[3])
+ r = r.Union(rtop)
+ rleft = (r[0]-r[2],r[1],r[2],r[3])
+ r = r.Union(rleft)
+ self.pdc.TranslateId(id, dx, dy)
+ r2 = self.pdc.GetIdBounds(id)
+ if type(r2) is list:
+ r2 = wx.Rect(r[0], r[1], r[2], r[3])
+ self.textdict[id]['bbox'] = r2
+ self.textdict[id]['coords'][0] += dx
+ self.textdict[id]['coords'][1] += dy
+ r = r.Union(r2)
+ r.Inflate(4,4)
+ self.RefreshRect(r, False)
+ self.lastpos = (coords[0], coords[1])
+ def MouseDraw(self, pdc = None, begin = None, end = None):
+ """!Mouse box or line from 'begin' to 'end'
+ If not given from self.mouse['begin'] to self.mouse['end'].
+ if not pdc:
+ return
+ if begin is None:
+ begin = self.mouse['begin']
+ if end is None:
+ end = self.mouse['end']
+ Debug.msg (5, "BufferedWindow2.MouseDraw(): use=%s, box=%s, begin=%f,%f, end=%f,%f" % \
+ (self.mouse['use'], self.mouse['box'],
+ begin[0], begin[1], end[0], end[1]))
+ if self.mouse['box'] == "box":
+ boxid = wx.ID_NEW
+ mousecoords = [begin[0], begin[1],
+ end[0], end[1]]
+ r = pdc.GetIdBounds(boxid)
+ r.Inflate(4, 4)
+ try:
+ pdc.ClearId(boxid)
+ except:
+ pass
+ pdc.SetId(boxid)
+ self.Draw(pdc, drawid = boxid, pdctype = 'box', coords = mousecoords)
+ elif self.mouse['box'] == "line":
+ self.lineid = wx.ID_NEW
+ mousecoords = [begin[0], begin[1], \
+ end[0], end[1]]
+ x1 = min(begin[0],end[0])
+ x2 = max(begin[0],end[0])
+ y1 = min(begin[1],end[1])
+ y2 = max(begin[1],end[1])
+ r = wx.Rect(x1,y1,x2-x1,y2-y1)
+ r.Inflate(4,4)
+ try:
+ pdc.ClearId(self.lineid)
+ except:
+ pass
+ pdc.SetId(self.lineid)
+ self.Draw(pdc, drawid = self.lineid, pdctype = 'line', coords = mousecoords)
+ def DrawLines(self, pdc = None, polycoords = None):
+ """!Draw polyline in PseudoDC
+ Set self.pline to wx.NEW_ID + 1
+ polycoords - list of polyline vertices, geographical coordinates
+ (if not given, self.polycoords is used)
+ if not pdc:
+ pdc = self.pdcTmp
+ if not polycoords:
+ polycoords = self.polycoords
+ if len(polycoords) > 0:
+ self.plineid = wx.ID_NEW + 1
+ # convert from EN to XY
+ coords = []
+ for p in polycoords:
+ coords.append(self.Cell2Pixel(p))
+ self.Draw(pdc, drawid = self.plineid, pdctype = 'polyline', coords = coords)
+ Debug.msg (4, "BufferedWindow2.DrawLines(): coords=%s, id=%s" % \
+ (coords, self.plineid))
+ return self.plineid
+ return -1
+ def DrawCross(self, pdc, coords, size, rotation = 0, pen = None,
+ text = None, textAlign = 'lr', textOffset = (5, 5)):
+ """!Draw cross in PseudoDC
+ @todo implement rotation
+ @param pdc PseudoDC
+ @param coords center coordinates
+ @param rotation rotate symbol
+ @param text draw also text (text, font, color, rotation)
+ @param textAlign alignment (default 'lower-right')
+ @param textOffset offset for text (from center point)
+ Debug.msg(4, "BufferedWindow2.DrawCross(): pdc=%s, coords=%s, size=%d" % \
+ (pdc, coords, size))
+ coordsCross = ((coords[0] - size, coords[1], coords[0] + size, coords[1]),
+ (coords[0], coords[1] - size, coords[0], coords[1] + size))
+ self.lineid = wx.NewId()
+ for lineCoords in coordsCross:
+ self.Draw(pdc, drawid = self.lineid, pdctype = 'line', coords = lineCoords, pen = pen)
+ if not text:
+ return self.lineid
+ if textAlign == 'ul':
+ coord = [coords[0] - textOffset[0], coords[1] - textOffset[1], 0, 0]
+ elif textAlign == 'ur':
+ coord = [coords[0] + textOffset[0], coords[1] - textOffset[1], 0, 0]
+ elif textAlign == 'lr':
+ coord = [coords[0] + textOffset[0], coords[1] + textOffset[1], 0, 0]
+ else:
+ coord = [coords[0] - textOffset[0], coords[1] + textOffset[1], 0, 0]
+ self.Draw(pdc, img = text,
+ pdctype = 'text', coords = coord, pen = pen)
+ def _computeZoomToPointAndRecenter(self, position, zoomtype):
+ """!Computes zoom parameters for recenter mode.
+ Computes begin and end parameters for Zoom() method.
+ Used for zooming by single click (not box)
+ and mouse wheel zooming (zoom and recenter mode).
+ if zoomtype > 0:
+ begin = (position[0] - self.Map.width / 4,
+ position[1] - self.Map.height / 4)
+ end = (position[0] + self.Map.width / 4,
+ position[1] + self.Map.height / 4)
+ else:
+ begin = ((self.Map.width - position[0]) / 2,
+ (self.Map.height - position[1]) / 2)
+ end = (begin[0] + self.Map.width / 2,
+ begin[1] + self.Map.height / 2)
+ return begin, end
+ def MouseActions(self, event):
+ """!Mouse motion and button click notifier
+ if not self.processMouse:
+ return
+ # zoom with mouse wheel
+ if event.GetWheelRotation() != 0:
+ self.OnMouseWheel(event)
+ # left mouse button pressed
+ elif event.LeftDown():
+ self.OnLeftDown(event)
+ # left mouse button released
+ elif event.LeftUp():
+ self.OnLeftUp(event)
+ # dragging
+ elif event.Dragging():
+ self.OnDragging(event)
+ # double click
+ elif event.ButtonDClick():
+ self.OnButtonDClick(event)
+ # middle mouse button pressed
+ elif event.MiddleDown():
+ self.OnMiddleDown(event)
+ # middle mouse button relesed
+ elif event.MiddleUp():
+ self.OnMiddleUp(event)
+ # right mouse button pressed
+ elif event.RightDown():
+ self.OnRightDown(event)
+ # right mouse button released
+ elif event.RightUp():
+ self.OnRightUp(event)
+ elif event.Entering():
+ self.OnMouseEnter(event)
+ elif event.Moving():
+ self.OnMouseMoving(event)
+ def OnMouseWheel(self, event):
+ """!Mouse wheel moved
+ zoomBehaviour = UserSettings.Get(group = 'display',
+ key = 'mouseWheelZoom',
+ subkey = 'selection')
+ if zoomBehaviour == 2:
+ event.Skip()
+ return
+ self.processMouse = False
+ current = event.GetPositionTuple()[:]
+ wheel = event.GetWheelRotation()
+ Debug.msg (5, "BufferedWindow2.MouseAction(): wheel=%d" % wheel)
+ if wheel > 0:
+ zoomtype = 1
+ else:
+ zoomtype = -1
+ if UserSettings.Get(group = 'display',
+ key = 'scrollDirection',
+ subkey = 'selection'):
+ zoomtype *= -1
+ # zoom 1/2 of the screen (TODO: settings)
+ if zoomBehaviour == 0: # zoom and recenter
+ begin, end = self._computeZoomToPointAndRecenter(position = current, zoomtype = zoomtype)
+ elif zoomBehaviour == 1: # zoom to current cursor position
+ begin = (current[0]/2, current[1]/2)
+ end = ((self.Map.width - current[0])/2 + current[0],
+ (self.Map.height - current[1])/2 + current[1])
+ # zoom
+ self.Zoom(begin, end, zoomtype)
+ # redraw map
+ self.UpdateMap()
+ #rashad self.frame.StatusbarUpdate()
+ self.Refresh()
+ def OnDragging(self, event):
+ """!Mouse dragging
+ Debug.msg (5, "BufferedWindow2.MouseAction(): Dragging")
+ previous = self.mouse['begin']
+ move = (current[0] - previous[0],
+ current[1] - previous[1])
+ digitToolbar = self.toolbar
+ else:
+ digitToolbar = None
+ # dragging or drawing box with left button
+ if self.mouse['use'] == 'pan' or \
+ event.MiddleIsDown():
+ self.DragMap(move)
+ # dragging decoration overlay item
+ elif (self.mouse['use'] == 'pointer' and
+ not digitToolbar and
+ self.dragid != None):
+ coords = event.GetPositionTuple()
+ self.DragItem(self.dragid, coords)
+ # dragging anything else - rubber band box or line
+ else:
+ if (self.mouse['use'] == 'pointer' and
+ not digitToolbar):
+ return
+ self.mouse['end'] = event.GetPositionTuple()[:]
+ if (event.LeftIsDown() and
+ not (digitToolbar and
+ digitToolbar.GetAction() in ("moveLine",) and
+ self.digit.GetDisplay().GetSelected() > 0)):
+ self.MouseDraw(pdc = self.pdcTmp)
+ def OnLeftDown(self, event):
+ """!Left mouse button pressed
+ Debug.msg (5, "BufferedWindow2.OnLeftDown(): use=%s" % \
+ self.mouse["use"])
+ self.mouse['begin'] = event.GetPositionTuple()[:]
+ if self.mouse["use"] in ["measure", "profile"]:
+ # measure or profile
+ if len(self.polycoords) == 0:
+ self.mouse['end'] = self.mouse['begin']
+ self.polycoords.append(self.Pixel2Cell(self.mouse['begin']))
+ self.ClearLines(pdc=self.pdcTmp)
+ else:
+ self.mouse['begin'] = self.mouse['end']
+ elif self.mouse['use'] in ('zoom', 'legend'):
+ pass
+ # vector digizer
+ elif self.mouse["use"] == "pointer" and \
+ hasattr(self, "digit"):
+ if event.ControlDown():
+ self.OnLeftDownUndo(event)
+ else:
+ self._onLeftDown(event)
+ elif self.mouse['use'] == 'pointer':
+ # get decoration or text id
+ idlist = []
+ self.dragid = ''
+ self.lastpos = self.mouse['begin']
+ idlist = self.pdc.FindObjects(self.lastpos[0], self.lastpos[1],
+ self.hitradius)
+ if 99 in idlist:
+ idlist.remove(99)
+ if idlist != []:
+ self.dragid = idlist[0] #drag whatever is on top
+ else:
+ pass
+ event.Skip()
+ def OnLeftUp(self, event):
+ """!Left mouse button released
+ Debug.msg (5, "BufferedWindow2.OnLeftUp(): use=%s" % \
+ if self.mouse['use'] in ["zoom", "pan"]:
+ # set region in zoom or pan
+ if self.mouse['use'] == 'zoom':
+ # set region for click (zero-width box)
+ if begin[0] - end[0] == 0 or \
+ begin[1] - end[1] == 0:
+ begin, end = self._computeZoomToPointAndRecenter(position = end, zoomtype = self.zoomtype)
+ self.Zoom(begin, end, self.zoomtype)
+ # redraw map
+###############rashad
+# elif self.mouse["use"] == "query":
+# self.frame.Query(self.mouse['end'][0], self.mouse['end'][1])
+# elif self.mouse["use"] in ["measure", "profile"]:
+# # measure or profile
+# if self.mouse["use"] == "measure":
+# self.frame.MeasureDist(self.mouse['begin'], self.mouse['end'])
+# self.polycoords.append(self.Pixel2Cell(self.mouse['end']))
+# self.ClearLines(pdc = self.pdcTmp)
+# self.DrawLines(pdc = self.pdcTmp)
+# elif self.mouse["use"] == "pointer" and \
+# not self.frame.IsStandalone() and \
+# self.frame.GetLayerManager().gcpmanagement:
+# # -> GCP manager
+# if self.frame.GetToolbar('gcpdisp'):
+# coord = self.Pixel2Cell(self.mouse['end'])
+# if self.frame.MapWindow == self.frame.SrcMapWindow:
+# coordtype = 'source'
+# else:
+# coordtype = 'target'
+# self.frame.GetLayerManager().gcpmanagement.SetGCPData(coordtype, coord, self, confirm = True)
+# self.UpdateMap(render = False, renderVector = False)
+ self._onLeftUp(event)
+ self.dragid >= 0):
+ # end drag of overlay decoration
+ if self.dragid < 99 and self.dragid in self.overlays:
+ self.overlays[self.dragid].coords = self.pdc.GetIdBounds(self.dragid)
+ elif self.dragid > 100 and self.dragid in self.textdict:
+ self.textdict[self.dragid]['bbox'] = self.pdc.GetIdBounds(self.dragid)
+ else:
+ pass
+ self.dragid = None
+#########rashad
+# elif self.mouse['use'] == 'legend':
+# self.frame.dialogs['legend'].resizeBtn.SetValue(False)
+# screenSize = self.GetClientSizeTuple()
+# self.overlays[1].ResizeLegend(self.mouse["begin"], self.mouse["end"], screenSize)
+# self.frame.MapWindow.SetCursor(self.frame.cursors["default"])
+# self.frame.MapWindow.mouse['use'] = 'pointer'
+# self.UpdateMap()
+ def OnButtonDClick(self, event):
+ """!Mouse button double click
+ Debug.msg (5, "BufferedWindow2.OnButtonDClick(): use=%s" % \
+ # measure
+ self.Refresh()
+ #self.SetCursor(self.frame.cursors["default"])
+ elif self.mouse["use"] != "profile" or \
+ (self.mouse['use'] != 'pointer' and \
+ hasattr(self, "digit")):
+ # select overlay decoration options dialog
+ clickposition = event.GetPositionTuple()[:]
+ idlist = self.pdc.FindObjects(clickposition[0], clickposition[1], self.hitradius)
+ if idlist == []:
+ return
+ # self.ovlcoords[self.dragid] = self.pdc.GetIdBounds(self.dragid)
+# if self.dragid > 100:
+# self.currtxtid = self.dragid
+# self.frame.OnAddText(None)
+# elif self.dragid == 0:
+# self.frame.AddBarscale()
+# elif self.dragid == 1:
+# self.frame.AddLegend()
+ def OnRightDown(self, event):
+ """!Right mouse button pressed
+ Debug.msg (5, "BufferedWindow2.OnRightDown(): use=%s" % \
+ self._onRightDown(event)
+ event.Skip()
+ def OnRightUp(self, event):
+ """!Right mouse button released
+ Debug.msg (5, "BufferedWindow2.OnRightUp(): use=%s" % \
+ self._onRightUp(event)
+ self.Refresh()
+ event.Skip()
+ def OnMiddleDown(self, event):
+ """!Middle mouse button pressed
+ if not event:
+ return
+ def OnMiddleUp(self, event):
+ """!Middle mouse button released
+ self.Zoom(begin, end, 0) # no zoom
+ # redraw map
+ self.frame.StatusbarUpdate()
+ def OnMouseEnter(self, event):
+ """!Mouse entered window and no mouse buttons were pressed
+# if not self.frame.IsStandalone() and \
+# if not self.frame.MapWindow == self:
+# self.frame.MapWindow = self
+# self.frame.Map = self.Map
+# self.frame.UpdateActive(self)
+# # needed for wingrass
+# self.SetFocus()
+# else:
+# event.Skip()
+ def OnMouseMoving(self, event):
+ """!Motion event and no mouse buttons were pressed
+ if self.mouse["use"] == "pointer" and \
+ self._onMouseMoving(event)
+ event.Skip()
+ def OnCopyCoordinates(self, event):
+ """!Copy coordinates to cliboard"""
+ e, n = self.GetLastEN()
+ if wx.TheClipboard.Open():
+ do = wx.TextDataObject()
+ # TODO: put delimiter in settings and apply also for Go to in statusbar
+ delim = ';'
+ do.SetText(str(e) + delim + str(n))
+ wx.TheClipboard.SetData(do)
+ wx.TheClipboard.Close()
+ def ClearLines(self, pdc = None):
+ """!Clears temporary drawn lines from PseudoDC
+ if not pdc:
+ pdc = self.pdcTmp
+ try:
+ pdc.RemoveId(self.lineid)
+ except:
+ pass
+ try:
+ pdc.ClearId(self.plineid)
+ pdc.RemoveId(self.plineid)
+ except:
+ pass
+ Debug.msg(4, "BufferedWindow2.ClearLines(): lineid=%s, plineid=%s" %
+ (self.lineid, self.plineid))
+ return True
+ """!Convert image coordinates to real word coordinates
+ @param x, y image coordinates
+ @return easting, northing
+ @return None on error
+ try:
+ x = int(x)
+ y = int(y)
+ except:
+ return None
+ if self.Map.region["ewres"] > self.Map.region["nsres"]:
+ res = self.Map.region["ewres"]
+ else:
+ res = self.Map.region["nsres"]
+ w = self.Map.region["center_easting"] - (self.Map.width / 2) * res
+ n = self.Map.region["center_northing"] + (self.Map.height / 2) * res
+ east = w + x * res
+ north = n - y * res
+ return (east, north)
+ """!Convert real word coordinates to image coordinates
+ try:
+ east = float(east)
+ north = float(north)
+ except:
+ return None
+ else:
+ x = (east - w) / res
+ y = (n - north) / res
+ return (x, y)
+ def Zoom(self, begin, end, zoomtype):
+ """!Calculates new region while (un)zoom/pan-ing
+ x1, y1 = begin
+ x2, y2 = end
+ newreg = {}
+ # threshold - too small squares do not make sense
+ # can only zoom to windows of > 5x5 screen pixels
+ if abs(x2-x1) > 5 and abs(y2-y1) > 5 and zoomtype != 0:
+ if x1 > x2:
+ x1, x2 = x2, x1
+ if y1 > y2:
+ y1, y2 = y2, y1
+ # zoom in
+ if zoomtype > 0:
+ newreg['w'], newreg['n'] = self.Pixel2Cell((x1, y1))
+ newreg['e'], newreg['s'] = self.Pixel2Cell((x2, y2))
+ # zoom out
+ elif zoomtype < 0:
+ newreg['w'], newreg['n'] = self.Pixel2Cell((-x1 * 2, -y1 * 2))
+ newreg['e'], newreg['s'] = self.Pixel2Cell((self.Map.width + 2 * \
+ (self.Map.width - x2),
+ self.Map.height + 2 * \
+ (self.Map.height - y2)))
+ # pan
+ elif zoomtype == 0:
+ dx = x1 - x2
+ dy = y1 - y2
+ if dx == 0 and dy == 0:
+ dx = x1 - self.Map.width / 2
+ dy = y1 - self.Map.height / 2
+ newreg['w'], newreg['n'] = self.Pixel2Cell((dx, dy))
+ newreg['e'], newreg['s'] = self.Pixel2Cell((self.Map.width + dx,
+ self.Map.height + dy))
+ # if new region has been calculated, set the values
+ if newreg != {}:
+ # LL locations
+ if self.Map.projinfo['proj'] == 'll':
+ self.Map.region['n'] = min(self.Map.region['n'], 90.0)
+ self.Map.region['s'] = max(self.Map.region['s'], -90.0)
+ ce = newreg['w'] + (newreg['e'] - newreg['w']) / 2
+ cn = newreg['s'] + (newreg['n'] - newreg['s']) / 2
+ # calculate new center point and display resolution
+ self.Map.region['center_easting'] = ce
+ self.Map.region['center_northing'] = cn
+ self.Map.region['ewres'] = (newreg['e'] - newreg['w']) / self.Map.width
+ self.Map.region['nsres'] = (newreg['n'] - newreg['s']) / self.Map.height
+# if not self.frame.HasProperty('alignExtent') or \
+# self.frame.GetProperty('alignExtent'):
+# self.Map.AlignExtentFromDisplay()
+# else:
+# for k in ('n', 's', 'e', 'w'):
+# self.Map.region[k] = newreg[k]
+ if hasattr(self, "digit") and \
+ hasattr(self, "moveInfo"):
+ self._zoom(None)
+ self.ZoomHistory(self.Map.region['n'], self.Map.region['s'],
+ self.Map.region['e'], self.Map.region['w'])
+ if self.redrawAll is False:
+ def ZoomBack(self):
+ """!Zoom to previous extents in zoomhistory list
+ zoom = list()
+ if len(self.zoomhistory) > 1:
+ self.zoomhistory.pop()
+ zoom = self.zoomhistory[-1]
+ # disable tool if stack is empty
+ if len(self.zoomhistory) < 2: # disable tool
+ toolbar = self.frame.GetMapToolbar()
+ toolbar.Enable('zoomBack', enable = False)
+ # zoom to selected region
+ self.Map.GetRegion(n = zoom[0], s = zoom[1],
+ e = zoom[2], w = zoom[3],
+ update = True)
+ # update map
+ self.UpdateMap()
+ self.zoomChanged.emit()
+ def ZoomHistory(self, n, s, e, w):
+ """!Manages a list of last 10 zoom extents
+ @param n,s,e,w north, south, east, west
+ @return removed history item if exists (or None)
+ removed = None
+ self.zoomhistory.append((n,s,e,w))
+ if len(self.zoomhistory) > 10:
+ removed = self.zoomhistory.pop(0)
+ if removed:
+ Debug.msg(4, "BufferedWindow2.ZoomHistory(): hist=%s, removed=%s" %
+ (self.zoomhistory, removed))
+ else:
+ Debug.msg(4, "BufferedWindow2.ZoomHistory(): hist=%s" %
+ (self.zoomhistory))
+ # update toolbar
+ enable = True
+ else:
+ enable = False
+ toolbar.Enable('zoomBack', enable)
+ return removed
+ def ResetZoomHistory(self):
+ """!Reset zoom history"""
+ self.zoomhistory = list()
+ def ZoomToMap(self, layers = None, ignoreNulls = False, render = True):
+ """!Set display extents to match selected raster
+ or vector map(s).
+ @param layers list of layers to be zoom to
+ @param ignoreNulls True to ignore null-values (valid only for rasters)
+ @param render True to re-render display
+ if not layers:
+ layers = self.tree.GetSelectedLayer(multi = True, checkedOnly = False)
+ layers = [self.tree.GetLayerInfo(layer, key = 'maplayer') for layer in layers]
+ if not layers:
+ return
+ rast = []
+ vect = []
+ updated = False
+ for l in layers:
+ # only raster/vector layers are currently supported
+ if l.type == 'raster':
+ rast.append(l.GetName())
+ elif l.type == 'vector':
+ self.toolbar.GetLayer() == l:
+ w, s, b, e, n, t = self.digit.GetDisplay().GetMapBoundingBox()
+ self.Map.GetRegion(n = n, s = s, w = w, e = e,
+ update = True)
+ updated = True
+ else:
+ vect.append(l.name)
+ elif l.type == 'rgb':
+ for rname in l.GetName().splitlines():
+ rast.append(rname)
+ if not updated:
+ self.Map.GetRegion(rast = rast,
+ vect = vect,
+ zoom = ignoreNulls,
+ update = True)
+ if render:
+ self.UpdateMap()
+ def ZoomToWind(self):
+ """!Set display geometry to match computational region
+ settings (set with g.region)
+ self.Map.region = self.Map.GetRegion()
+ self.UpdateMap()
+ def ZoomToDefault(self):
+ """!Set display geometry to match default region settings
+ self.Map.region = self.Map.GetRegion(default = True)
+ self.Map.AdjustRegion() # aling region extent to the display
+ self.UpdateMap()
+ def GoTo(self, e, n):
+ region = self.Map.GetCurrentRegion()
+ region['center_easting'], region['center_northing'] = e, n
+ dn = (region['nsres'] * region['rows']) / 2.
+ region['n'] = region['center_northing'] + dn
+ region['s'] = region['center_northing'] - dn
+ de = (region['ewres'] * region['cols']) / 2.
+ region['e'] = region['center_easting'] + de
+ region['w'] = region['center_easting'] - de
+ # add to zoom history
+ self.ZoomHistory(region['n'], region['s'],
+ region['e'], region['w'])
+ self.UpdateMap()
+ def DisplayToWind(self):
+ """!Set computational region (WIND file) to match display
+ extents
+ tmpreg = os.getenv("GRASS_REGION")
+ if tmpreg:
+ del os.environ["GRASS_REGION"]
+ # We ONLY want to set extents here. Don't mess with resolution. Leave that
+ # for user to set explicitly with g.region
+ new = self.Map.AlignResolution()
+ RunCommand('g.region',
+ parent = self,
+ overwrite = True,
+ n = new['n'],
+ s = new['s'],
+ e = new['e'],
+ w = new['w'],
+ rows = int(new['rows']),
+ cols = int(new['cols']))
+ if tmpreg:
+ os.environ["GRASS_REGION"] = tmpreg
+ def ZoomToSaved(self):
+ """!Set display geometry to match extents in
+ saved region file
+ dlg = SavedRegion(parent = self,
+ title = _("Zoom to saved region extents"),
+ loadsave = 'load')
+ if dlg.ShowModal() == wx.ID_CANCEL or not dlg.GetName():
+ dlg.Destroy()
+ return
+ if not grass.find_file(name = dlg.GetName(), element = 'windows')['name']:
+ wx.MessageBox(parent = self,
+ message = _("Region <%s> not found. Operation canceled.") % dlg.GetName(),
+ caption = _("Error"), style = wx.ICON_ERROR | wx.OK | wx.CENTRE)
+ dlg.Destroy()
+ return
+ self.Map.GetRegion(regionName = dlg.GetName(),
+ update = True)
+ dlg.Destroy()
+ self.Map.region['s'],
+ self.Map.region['w'])
+ self.UpdateMap()
+ def SaveRegion(self, display = True):
+ """!Save display extents/compulational region to named region
+ file.
+ @param display True for display extends otherwise computational region
+ if display:
+ title = _("Save display extents to region file")
+ else:
+ title = _("Save computational region to region file")
+ dlg = SavedRegion(parent = self, title = title, loadsave = 'save')
+ dlg.Destroy()
+ return
+ # test to see if it already exists and ask permission to overwrite
+ if grass.find_file(name = dlg.GetName(), element = 'windows')['name']:
+ overwrite = wx.MessageBox(parent = self,
+ message = _("Region file <%s> already exists. "
+ "Do you want to overwrite it?") % (dlg.GetName()),
+ caption = _("Warning"), style = wx.YES_NO | wx.CENTRE)
+ if overwrite != wx.YES:
+ dlg.Destroy()
+ return
+ if display:
+ self._saveDisplayRegion(dlg.GetName())
+ else:
+ self._saveCompRegion(dlg.GetName())
+ dlg.Destroy()
+ def _saveCompRegion(self, name):
+ """!Save region settings to region file
+ @param name region name
+ overwrite = True,
+ parent = self,
+ flags = 'u',
+ save = name)
+ def _saveDisplayRegion(self, name):
+ """!Save display extents to region file
+ new = self.Map.GetCurrentRegion()
+ if tmpreg:
+ overwrite = True,
+ parent = self,
+ flags = 'u',
+ n = new['n'],
+ s = new['s'],
+ e = new['e'],
+ w = new['w'],
+ cols = int(new['cols']),
+ save = name)
+ if tmpreg:
+ def Distance(self, beginpt, endpt, screen = True):
+ """!Calculates distance
+ Ctypes required for LL-locations
+ @param beginpt first point
+ @param endpt second point
+ @param screen True for screen coordinates otherwise EN
+ if screen:
+ e1, n1 = self.Pixel2Cell(beginpt)
+ e2, n2 = self.Pixel2Cell(endpt)
+ else:
+ e1, n1 = beginpt
+ e2, n2 = endpt
+ dEast = (e2 - e1)
+ dNorth = (n2 - n1)
+ if self.frame.Map.projinfo['proj'] == 'll' and haveCtypes:
+ dist = gislib.G_distance(e1, n1, e2, n2)
+ else:
+ dist = math.sqrt(math.pow((dEast), 2) + math.pow((dNorth), 2))
+ return (dist, (dEast, dNorth))
+ def GetMap(self):
+ """!Get render.Map() instance"""
+ return self.Map
+ """!Calls UpdateTools to manage connected toolbars"""
+ self.frame.UpdateTools(None)
+ MapWindow.RegisterMouseEventHandler(self, event, handler, cursor)
+ """!Sets pointer and toggles it after unregistration"""
+ MapWindow.UnregisterMouseEventHandler(self, event, handler)
+ # sets pointer mode
+ toolbar = self.frame.toolbars['map']
+ toolbar.action['id'] = vars(toolbar)["pointer"]
+ toolbar.OnTool(None)
+ self.frame.OnPointer(event = None)
+ def RegisterGraphicsToDraw(self, graphicsType, setStatusFunc = None, drawFunc = None):
+ """! Method allows to register graphics to draw.
+ @param type (string) - graphics type: "point" or "line"
+ @param setStatusFunc (function reference) - function called before drawing each item
+ Status function should be in this form: setStatusFunc(item, itemOrderNum)
+ item - passes instance of GraphicsSetItem which will be drawn
+ itemOrderNum - number of item in drawing order (from O)
+ Hidden items are also counted in drawing order.
+ @param drawFunc (function reference) - allows to define own function for drawing
+ If function is not defined DrawCross method is used for type "point"
+ or DrawLines method for type "line".
+ @return reference to GraphicsSet, which was added.
+ item = GraphicsSet(parentMapWin = self,
+ graphicsType = graphicsType,
+ setStatusFunc = setStatusFunc,
+ drawFunc = drawFunc)
+ self.graphicsSetList.append(item)
+ return item
+ def UnregisterGraphicsToDraw(self, item):
+ """!Unregisteres GraphicsSet instance
+ @param item (GraphicsSetItem) - item to unregister
+ @return True - if item was unregistered
+ @return False - if item was not found
+ if item in self.graphicsSetList:
+ self.graphicsSetList.remove(item)
+ return True
+ return False
+class GraphicsSet:
+ def __init__(self, parentMapWin, graphicsType, setStatusFunc = None, drawFunc = None):
+ """!Class, which contains instances of GraphicsSetItem and
+ draws them For description of parameters look at method
+ RegisterGraphicsToDraw in BufferedWindow2 class.
+ self.pens = {
+ "default" : wx.Pen(colour = wx.BLACK, width = 2, style = wx.SOLID),
+ "selected" : wx.Pen(colour = wx.GREEN, width = 2, style = wx.SOLID),
+ "unused" : wx.Pen(colour = wx.LIGHT_GREY, width = 2, style = wx.SOLID),
+ "highest" : wx.Pen(colour = wx.RED, width = 2, style = wx.SOLID)
+ # list contains instances of GraphicsSetItem
+ self.itemsList = []
+ self.properties = {}
+ self.graphicsType = graphicsType
+ self.parentMapWin = parentMapWin
+ self.setStatusFunc = setStatusFunc
+ if drawFunc:
+ self.drawFunc = drawFunc
+ elif self.graphicsType == "point":
+ self.properties["size"] = 5
+ self.properties["text"] = {}
+ self.properties["text"]['font'] = wx.Font(pointSize = self.properties["size"],
+ family = wx.FONTFAMILY_DEFAULT,
+ style = wx.FONTSTYLE_NORMAL,
+ weight = wx.FONTWEIGHT_NORMAL)
+ self.properties["text"]['active'] = True
+ self.drawFunc = self.parentMapWin.DrawCross
+ elif self.graphicsType == "line":
+ self.drawFunc = self.parentMapWin.DrawLines
+ def Draw(self, pdc):
+ """!Draws all containing items.
+ @param pdc - device context, where items are drawn
+ itemOrderNum = 0
+ for item in self.itemsList:
+ if self.setStatusFunc is not None:
+ self.setStatusFunc(item, itemOrderNum)
+ if item.GetPropertyVal("hide") == True:
+ itemOrderNum += 1
+ continue
+ if self.graphicsType == "point":
+ if item.GetPropertyVal("penName"):
+ self.parentMapWin.pen = self.pens[item.GetPropertyVal("penName")]
+ else:
+ self.parentMapWin.pen = self.pens["default"]
+ coords = self.parentMapWin.Cell2Pixel(item.GetCoords())
+ size = self.properties["size"]
+ self.properties["text"]['coords'] = [coords[0] + size, coords[1] + size, size, size]
+ self.properties["text"]['color'] = self.parentMapWin.pen.GetColour()
+ self.properties["text"]['text'] = item.GetPropertyVal("label")
+ self.drawFunc(pdc = pdc,
+ coords = coords,
+ text = self.properties["text"],
+ size = self.properties["size"])
+ if item.GetPropertyVal("pen"):
+ self.parentMapWin.polypen = self.pens[item.GetPropertyVal("pen")]
+ else:
+ self.parentMapWin.polypen = self.pens["default"]
+ polycoords = coords)
+ itemOrderNum += 1
+ def AddItem(self, coords, penName = None, label = None, hide = False):
+ """!Append item to the list.
+ Added item is put to the last place in drawing order.
+ Could be 'point' or 'line' according to graphicsType.
+ @param coords - list of east, north coordinates (double) of item
+ Example: point: [1023, 122]
+ line: [[10, 12],[20,40],[23, 2334]]
+ @param penName (string) - the 'default' pen is used if is not defined
+ @param label (string) - label, which will be drawn with point. It is relavant just for 'point' type.
+ @param hide (bool) - If it is True, the item is not drawn, when self.Draw is called.
+ @return (GraphicsSetItem) - added item reference
+ item = GraphicsSetItem(coords = coords, penName = penName, label = label, hide = hide)
+ self.itemsList.append(item)
+ return item
+ def DeleteItem(self, item):
+ """!Deletes item
+ @param item (GraphicsSetItem) - item to remove
+ @return True if item was removed
+ @return False if item was not found
+ try:
+ self.itemsList.remove(item)
+ except ValueError:
+ return False
+ return True
+ def GetAllItems(self):
+ """!Returns list of all containing instances of GraphicsSetItem, in order
+ as they are drawn. If you want to change order of drawing use: SetItemDrawOrder method.
+ # user can edit objects but not order in list, that is reason,
+ # why is returned shallow copy of data list it should be used
+ # SetItemDrawOrder for changing order
+ return copy(self.itemsList)
+ def GetItem(self, drawNum):
+ """!Get given item from the list.
+ @param drawNum (int) - drawing order (index) number of item
+ @return instance of GraphicsSetItem which is drawn in drawNum order
+ @return False if drawNum was out of range
+ if drawNum < len(self.itemsList) and drawNum >= 0:
+ return self.itemsList[drawNum]
+ else:
+ return False
+ def SetPropertyVal(self, propName, propVal):
+ """!Set property value
+ @param propName (string) - property name: "size", "text"
+ - both properties are relevant for "point" type
+ @param propVal - property value to be set
+ @return True - if value was set
+ @return False - if propName is not "size" or "text" or type is "line"
+ if self.properties.has_key(propName):
+ self.properties[propName] = propVal
+ return True
+ return False
+ def GetPropertyVal(self, propName):
+ """!Get property value
+ Raises KeyError if propName is not "size" or "text" or type is
+ "line"
+ @return value of property
+ return self.properties[propName]
+ raise KeyError(_("Property does not exist: %s") % (propName))
+ def AddPen(self, penName, pen):
+ """!Add pen
+ @param penName (string) - name of added pen
+ @param pen (wx.Pen) - added pen
+ @return True - if pen was added
+ @return False - if pen already exists
+ if self.pens.has_key(penName):
+ return False
+ self.pens[penName] = pen
+ return True
+ def GetPen(self, penName):
+ """!Get existing pen
+ @param penName (string) - name of pen
+ @return wx.Pen reference if is found
+ @return None if penName was not found
+ return self.pens[penName]
+ return None
+ def SetItemDrawOrder(self, item, drawNum):
+ """!Set draw order for item
+ @param drawNum (int) - drawing order of item to be set
+ @return True - if order was changed
+ @return False - if drawNum is out of range or item was not found
+ if drawNum < len(self.itemsList) and drawNum >= 0 and \
+ item in self.itemsList:
+ self.itemsList.insert(drawNum, self.itemsList.pop(self.itemsList.index(item)))
+ return True
+ return False
+ def GetItemDrawOrder(self, item):
+ """!Get draw order for given item
+ @return (int) - drawing order of item
+ @return None - if item was not found
+ try:
+ return self.itemsList.index(item)
+ return None
+class GraphicsSetItem:
+ def __init__(self, coords, penName = None, label = None, hide = False):
+ """!Could be point or line according to graphicsType in
+ GraphicsSet class
+ @param coords - list of coordinates (double) of item
+ @param penName (string) - if it is not defined 'default' pen is used
+ @param label (string) - label, which will be drawn with point. It is relevant just for 'point' type
+ @param hide (bool) - if it is True, item is not drawn
+ Hidden items are also counted in drawing order in GraphicsSet class.
+ self.coords = coords
+ self.properties = { "penName" : penName,
+ "hide" : hide,
+ "label" : label }
+ @param propName (string) - property name: "penName", "hide" or "label"
+ - property "label" is relevant just for 'point' type
+ @return False - if propName is not "penName", "hide" or "label"
+ return True
+ return False
+ Raises KeyError if propName is not "penName", "hide" or
+ "label".
+ def SetCoords(self, coords):
+ """!Set coordinates of item
+ def GetCoords(self):
+ """!Get item coordinates
+ @returns coordinates
+ return self.coords
Added: grass-addons/grass7/gui/wxpython/newgui/wxgui.py
--- grass-addons/grass7/gui/wxpython/newgui/wxgui.py (rev 0)
+++ grass-addons/grass7/gui/wxpython/newgui/wxgui.py 2013-03-13 18:02:02 UTC (rev 55366)
@@ -0,0 +1,140 @@
+ at package wxgui
+ at brief Main Python application for GRASS wxPython GUI
+Classes:
+ - wxgui::GMApp
+ - wxgui::Usage
+(C) 2006-2011 by the GRASS Development Team
+ at author Michael Barton (Arizona State University)
+ at author Jachym Cepicky (Mendel University of Agriculture)
+ at author Vaclav Petras <wenzeslaus gmail.com> (menu customization)
+import os
+import sys
+import getopt
+if __name__ == "__main__":
+ sys.path.append(os.path.join(os.getenv('GISBASE'), 'etc', 'gui', 'wxpython'))
+from core import globalvar
+import wx
+try:
+ import wx.lib.agw.advancedsplash as SC
+except ImportError:
+ SC = None
+from lmgr.frame import GMFrame
+class GMApp(wx.App):
+ def __init__(self, workspace = None):
+ """!Main GUI class.
+ @param workspace path to the workspace file
+ self.workspaceFile = workspace
+ # call parent class initializer
+ wx.App.__init__(self, False)
+ self.locale = wx.Locale(language = wx.LANGUAGE_DEFAULT)
+ def OnInit(self):
+ """!Initialize all available image handlers
+ @return True
+ if not globalvar.CheckWxVersion([2, 9]):
+ wx.InitAllImageHandlers()
+ # create splash screen
+ introImagePath = os.path.join(globalvar.ETCIMGDIR, "silesia_splash.png")
+ introImage = wx.Image(introImagePath, wx.BITMAP_TYPE_PNG)
+ introBmp = introImage.ConvertToBitmap()
+ if SC and sys.platform != 'darwin':
+ # AdvancedSplash is buggy on the Mac as of 2.8.12.1
+ # and raises annoying (though seemingly harmless) errors everytime the GUI is started
+ splash = SC.AdvancedSplash(bitmap = introBmp,
+ timeout = 2000, parent = None, id = wx.ID_ANY)
+ splash.SetText(_('Starting GRASS GUI...'))
+ splash.SetTextColour(wx.Colour(45, 52, 27))
+ splash.SetTextFont(wx.Font(pointSize = 15, family = wx.DEFAULT, style = wx.NORMAL,
+ weight = wx.BOLD))
+ splash.SetTextPosition((150, 430))
+ else:
+ wx.SplashScreen (bitmap = introBmp, splashStyle = wx.SPLASH_CENTRE_ON_SCREEN | wx.SPLASH_TIMEOUT,
+ milliseconds = 2000, parent = None, id = wx.ID_ANY)
+ wx.Yield()
+ # create and show main frame
+ mainframe = GMFrame(parent = None, id = wx.ID_ANY,
+ workspace = self.workspaceFile)
+ mainframe.Show()
+ self.SetTopWindow(mainframe)
+ return True
+class Usage(Exception):
+ def __init__(self, msg):
+ self.msg = msg
+def printHelp():
+ """!Print program help"""
+ print >> sys.stderr, "Usage:"
+ print >> sys.stderr, " python wxgui.py [options]"
+ print >> sys.stderr, "%sOptions:" % os.linesep
+ print >> sys.stderr, " -w\t--workspace file\tWorkspace file to load"
+ sys.exit(1)
+def process_opt(opts, args):
+ """!Process command-line arguments"""
+ workspaceFile = None
+ for o, a in opts:
+ if o in ("-h", "--help"):
+ printHelp()
+ if o in ("-w", "--workspace"):
+ if a != '':
+ workspaceFile = str(a)
+ else:
+ workspaceFile = args.pop(0)
+ return (workspaceFile,)
+def main(argv = None):
+ import gettext
+ gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
+ if argv is None:
+ argv = sys.argv
+ try:
+ try:
+ opts, args = getopt.getopt(argv[1:], "hw:",
+ ["help", "workspace"])
+ except getopt.error, msg:
+ raise Usage(msg)
+ except Usage, err:
+ print >> sys.stderr, err.msg
+ print >> sys.stderr, "for help use --help"
+ printHelp()
+ workspaceFile = process_opt(opts, args)[0]
+ app = GMApp(workspaceFile)
+ # suppress wxPython logs
+ q = wx.LogNull()
+ app.MainLoop()
+ sys.exit(main())
