[GRASS-SVN] r55367 - grass-addons/grass7/gui/wxpython/newgui
Wed Mar 13 11:04:31 PDT 2013
Author: rashadkm
Date: 2013-03-13 11:04:30 -0700 (Wed, 13 Mar 2013)
New Revision: 55367
Added:
   grass-addons/grass7/gui/wxpython/newgui/render2.py
test api code(copied render.py)
Added: grass-addons/grass7/gui/wxpython/newgui/render2.py
--- grass-addons/grass7/gui/wxpython/newgui/render2.py	                        (rev 0)
+++ grass-addons/grass7/gui/wxpython/newgui/render2.py	2013-03-13 18:04:30 UTC (rev 55367)
@@ -0,0 +1,1403 @@
+ at package core.render
+ at brief Rendering map layers and overlays into map composition image.
+ at todo Implement RenderManager also for other layers (see WMS
+implementation for details)
+ at todo Render classes should not care about updating statusbar (change emiting events).
+Classes:
+ - render::Layer
+ - render::MapLayer
+ - render::Overlay
+ - render::Map
+(C) 2006-2013 by the GRASS Development Team
+This program is free software under the GNU General Public License
+(>=v2). Read the file COPYING that comes with GRASS for details.
+ at author Michael Barton
+ at author Jachym Cepicky
+ at author Martin Landa <landa.martin gmail.com>
+import os
+import sys
+import glob
+import math
+import copy
+import tempfile
+import types
+import wx
+from grass.script import core as grass
+from core          import utils
+from core.ws       import RenderWMSMgr, wxUpdateProgressBar
+from core.gcmd     import GException, GError, RunCommand
+from core.debug    import Debug
+from core.settings import UserSettings
+USE_GPNMCOMP = True
+class Layer(object):
+    """!Virtual class which stores information about layers (map layers and
+    overlays) of the map composition.
+    - For map layer use MapLayer class.
+    - For overlays use Overlay class.
+    def __init__(self, ltype, cmd, Map, name = None,
+                 active = True, hidden = False, opacity = 1.0):
+        """!Create new instance
+        @todo pass cmd as tuple instead of list
+        @param ltype layer type ('raster', 'vector', 'overlay', 'command', etc.)
+        @param cmd GRASS command to render layer,
+        given as list, e.g. ['d.rast', 'map=elevation at PERMANENT']
+        @param Map render.Map instance
+        @param name layer name, e.g. 'elevation at PERMANENT' (for layer tree)
+        @param active layer is active, will be rendered only if True
+        @param hidden layer is hidden, won't be listed in Layer Manager if True
+        @param opacity layer opacity <0;1>
+        # generated file for each layer
+        if USE_GPNMCOMP or ltype == 'overlay':
+            tmpfile = tempfile.mkstemp()[1]
+            self.maskfile = tmpfile + '.pgm'
+            if ltype == 'overlay':
+                self.mapfile  = tmpfile + '.png'
+            else:
+                self.mapfile  = tmpfile + '.ppm'
+            grass.try_remove(tmpfile)
+        else:
+            self.mapfile = self.maskfile = None
+        # stores class which manages rendering instead of simple command - e. g. wms
+        self.renderMgr = None
+        self.Map = Map
+        self.type      = None
+        self.SetType(ltype)
+        self.name  = name
+        if self.type == 'command':
+            self.cmd = list()
+            for c in cmd:
+                self.cmd.append(utils.CmdToTuple(c))
+        else:
+            self.cmd = utils.CmdToTuple(cmd)
+        self.active  = active
+        self.hidden  = hidden
+        self.opacity = opacity
+        self.forceRender = True
+        Debug.msg (3, "Layer.__init__(): type=%s, cmd='%s', name=%s, " \
+                       "active=%d, opacity=%d, hidden=%d" % \
+                       (self.type, self.GetCmd(string = True), self.name, self.active,
+                        self.opacity, self.hidden))
+    def __del__(self):
+        Debug.msg (3, "Layer.__del__(): layer=%s, cmd='%s'" %
+                   (self.name, self.GetCmd(string = True)))
+    def Render(self):
+        """!Render layer to image
+        @return rendered image filename
+        @return None on error or if cmdfile is defined
+        if not self.cmd:
+            return None
+        # ignore in 2D
+        if self.type == '3d-raster':
+            return None
+        Debug.msg (3, "Layer.Render(): type=%s, name=%s" % \
+                       (self.type, self.name))
+        # prepare command for each layer
+        layertypes = utils.command2ltype.values() + ['overlay', 'command']
+        if self.type not in layertypes:
+            raise GException(_("<%(name)s>: layer type <%(type)s> is not supported") % \
+                                 {'type' : self.type, 'name' : self.name})
+        if self.mapfile:
+            os.environ["GRASS_PNGFILE"] = self.mapfile
+        # execute command
+        try:
+                read = False
+                for c in self.cmd:
+                    ret, msg = self._runCommand(c)
+                    if ret != 0:
+                        break
+                    if not read:
+                        os.environ["GRASS_PNG_READ"] = "TRUE"
+                os.environ["GRASS_PNG_READ"] = "FALSE"
+            else:
+                ret, msg = self._runCommand(self.cmd)
+            if ret != 0:
+                sys.stderr.write(_("Command '%s' failed\n") % self.GetCmd(string = True))
+                if msg:
+                    sys.stderr.write(_("Details: %s\n") % msg)
+                raise GException()
+        except GException:
+            # clean up after problems
+            for f in [self.mapfile, self.maskfile]:
+                if not f:
+                    continue
+                grass.try_remove(f)
+                f = None
+        # stop monitor
+        if self.mapfile and "GRASS_PNGFILE" in os.environ:
+            del os.environ["GRASS_PNGFILE"]
+        self.forceRender = False
+        return self.mapfile
+    def _runCommand(self, cmd):
+        """!Run command to render data
+        if self.type == 'wms':
+            ret = 0
+            msg = ''
+            self.renderMgr.Render(cmd)
+        else:
+            ret, msg = RunCommand(cmd[0],
+                                  getErrorMsg = True,
+                                  quiet = True,
+                                  **cmd[1])
+        return ret, msg
+    def GetCmd(self, string = False):
+        """!Get GRASS command as list of string.
+        @param string get command as string if True otherwise as list
+        @return command list/string
+        if string:
+                scmd = []
+                    scmd.append(utils.GetCmdString(c))
+                return ';'.join(scmd)
+            else:
+                return utils.GetCmdString(self.cmd)
+        else:
+            return self.cmd
+    def GetType(self):
+        """!Get map layer type"""
+        return self.type
+    def GetElement(self):
+        """!Get map element type"""
+        if self.type == 'raster':
+            return 'cell'
+        return self.type
+    def GetOpacity(self, float = False):
+        Get layer opacity level
+        @param float get opacity level in <0,1> otherwise <0,100>
+        @return opacity level
+        if float:
+            return self.opacity
+        return int (self.opacity * 100)
+    def GetName(self, fullyQualified = True):
+        """!Get map layer name
+        @param fullyQualified True to return fully qualified name as a
+        string 'name at mapset' otherwise directory { 'name', 'mapset' }
+        is returned
+        @return string / directory
+        if fullyQualified:
+            return self.name
+        else:
+            if '@' in self.name:
+                return { 'name' : self.name.split('@')[0],
+                         'mapset' : self.name.split('@')[1] }
+            else:
+                return { 'name' : self.name,
+                         'mapset' : '' }
+    def IsActive(self):
+        """!Check if layer is activated for rendering"""
+        return self.active
+    def SetType(self, ltype):
+        """!Set layer type"""
+        if ltype not in utils.command2ltype.values() + ['overlay', 'command']:
+            raise GException(_("Unsupported map layer type '%s'") % ltype)
+        if ltype == 'wms' and not isinstance(self.renderMgr, RenderWMSMgr):
+            self.renderMgr = RenderWMSMgr(receiver = self.Map.GetReceiver(),
+                                          layer = self,
+                                          Map = self.Map,
+                                          mapfile = self.mapfile,
+                                          maskfile = self.maskfile)
+        elif self.type == 'wms' and ltype != 'wms':
+        self.type = ltype
+    def SetName(self, name):
+        """!Set layer name"""
+        self.name = name
+    def SetActive(self, enable = True):
+        """!Active or deactive layer"""
+        self.active = bool(enable)
+    def SetHidden(self, enable = False):
+        """!Hide or show map layer in Layer Manager"""
+        self.hidden = bool(enable)
+    def SetOpacity(self, value):
+        """!Set opacity value"""
+        if value < 0:
+            value = 0.
+        elif value > 1:
+            value = 1.
+        self.opacity = float(value)
+    def SetCmd(self, cmd):
+        """!Set new command for layer"""
+            self.cmd = []
+            for c in cmd:
+        else:
+        Debug.msg(3, "Layer.SetCmd(): cmd='%s'" % self.GetCmd(string = True))
+        # for re-rendering
+    def IsDownloading(self):
+        """!Is data downloading from web server e. g. wms"""
+        if self.renderMgr is None:
+            return False
+        else:
+            return self.renderMgr.IsDownloading()
+    def AbortThread(self):
+        """!Abort running thread e. g. downloading data"""
+            return
+        else:
+            self.renderMgr.Abort()
+    def GetRenderMgr(self):
+        """!Get render manager """
+class MapLayer(Layer):
+        """!Represents map layer in the map canvas
+        @param ltype layer type ('raster', 'vector', 'command', etc.)
+        @param name layer name, e.g. 'elevation at PERMANENT' (for layer tree) or None
+        Layer.__init__(self, ltype, cmd, Map, name,
+                       active, hidden, opacity)
+    def GetMapset(self):
+        """!Get mapset of map layer
+        @return mapset name
+        @return '' on error (no name given)
+        if not self.name:
+            return ''
+        try:
+            return self.name.split('@')[1]
+        except IndexError:
+            return self.name
+class Overlay(Layer):
+    def __init__(self, id, ltype, cmd, Map,
+                 active = True, hidden = True, opacity = 1.0):
+        """!Represents overlay displayed in map canvas
+        @param id overlay id (for PseudoDC)
+        @param type overlay type ('barscale', 'legend', etc.)
+        @param cmd GRASS command to render overlay,
+        given as list, e.g. ['d.legend', 'map=elevation at PERMANENT']
+        Layer.__init__(self, 'overlay', cmd, Map, ltype,
+        self.id = id
+class Map(object):
+    def __init__(self, gisrc = None):
+        """!Map composition (stack of map layers and overlays)
+        @param gisrc alternative gisrc (used eg. by georectifier)
+        # region/extent settigns
+        self.wind      = dict() # WIND settings (wind file)
+        self.region    = dict() # region settings (g.region)
+        self.width     = 640    # map width
+        self.height    = 480    # map height
+        # list of layers
+        self.layers    = list()  # stack of available GRASS layer
+        self.overlays  = list()  # stack of available overlays
+        self.ovlookup  = dict()  # lookup dictionary for overlay items and overlays
+        # environment settings
+        self.env   = dict()
+        # path to external gisrc
+        self.gisrc = gisrc
+        # generated file for g.pnmcomp output for rendering the map
+        self.mapfile = grass.tempfile(create = False) + '.ppm'
+        # setting some initial env. variables
+        self._initGisEnv() # g.gisenv
+        self.GetWindow()
+        # receiver of events
+        self.receiver = None
+        # GRASS environment variable (for rendering)
+        self.env = {"GRASS_BACKGROUNDCOLOR" : "FFFFFF",
+               "GRASS_COMPRESSION"     : "0",
+               "GRASS_TRUECOLOR"       : "TRUE",
+               "GRASS_TRANSPARENT"     : "TRUE",
+               "GRASS_PNG_READ"        : "FALSE",
+        for k, v in self.env.iteritems():
+            os.environ[k] = v
+        # projection info
+        self.projinfo = self._projInfo()
+        # is some layer being downloaded?
+        self.downloading = False
+    def _runCommand(self, cmd, **kwargs):
+        """!Run command in environment defined by self.gisrc if
+        defined"""
+        # use external gisrc if defined
+        gisrc_orig = os.getenv("GISRC")
+        if self.gisrc:
+            os.environ["GISRC"] = self.gisrc
+        ret = cmd(**kwargs)
+        # back to original gisrc
+        if self.gisrc:
+            os.environ["GISRC"] = gisrc_orig
+        return ret
+    def _initGisEnv(self):
+        """!Stores GRASS variables (g.gisenv) to self.env variable
+        if not os.getenv("GISBASE"):
+            sys.exit(_("GISBASE not set. You must be in GRASS GIS to run this program."))
+        self.env = self._runCommand(grass.gisenv)
+    def GetProjInfo(self):
+        """!Get projection info"""
+        return self.projinfo
+    def _projInfo(self):
+        """!Return region projection and map units information
+        projinfo = dict()
+        if not grass.find_program('g.proj', ['--help']):
+            sys.exit(_("GRASS module '%s' not found. Unable to start map "
+                       "display window.") % 'g.proj')
+        ret = self._runCommand(RunCommand, prog = 'g.proj',
+                               read = True, flags = 'p')
+        if not ret:
+            return projinfo
+        for line in ret.splitlines():
+            if ':' in line:
+                key, val = map(lambda x: x.strip(), line.split(':'))
+                if key in ['units']:
+                    val = val.lower()
+                projinfo[key] = val
+            elif "XY location (unprojected)" in line:
+                projinfo['proj'] = 'xy'
+                projinfo['units'] = ''
+                break
+        return projinfo
+    def GetWindow(self):
+        """!Read WIND file and set up self.wind dictionary"""
+        # FIXME: duplicated region WIND == g.region (at least some values)
+        filename = os.path.join (self.env['GISDBASE'],
+                                 self.env['LOCATION_NAME'],
+                                 self.env['MAPSET'],
+                                 "WIND")
+        try:
+            windfile = open (filename, "r")
+        except IOError, e:
+            sys.exit(_("Error: Unable to open '%(file)s'. Reason: %(ret)s. wxGUI exited.\n") % \
+                         { 'file' : filename, 'ret' : e})
+        for line in windfile.readlines():
+            line = line.strip()
+            key, value = line.split(":", 1)
+            self.wind[key.strip()] = value.strip()
+        windfile.close()
+        return self.wind
+    def AdjustRegion(self):
+        """!Adjusts display resolution to match monitor size in
+        pixels. Maintains constant display resolution, not related to
+        computational region. Do NOT use the display resolution to set
+        computational resolution. Set computational resolution through
+        g.region.
+        mapwidth    = abs(self.region["e"] - self.region["w"])
+        mapheight   = abs(self.region['n'] - self.region['s'])
+        self.region["nsres"] =  mapheight / self.height
+        self.region["ewres"] =  mapwidth  / self.width
+        self.region['rows']  = round(mapheight / self.region["nsres"])
+        self.region['cols']  = round(mapwidth / self.region["ewres"])
+        self.region['cells'] = self.region['rows'] * self.region['cols']
+        Debug.msg (3, "Map.AdjustRegion(): %s" % self.region)
+        return self.region
+    def AlignResolution(self):
+        """!Sets display extents to even multiple of current
+        resolution defined in WIND file from SW corner. This must be
+        done manually as using the -a flag can produce incorrect
+        extents.
+        # new values to use for saving to region file
+        new = {}
+        n = s = e = w = 0.0
+        nsres = ewres = 0.0
+        # Get current values for region and display
+        reg = self.GetRegion()
+        nsres = reg['nsres']
+        ewres = reg['ewres']
+        n = float(self.region['n'])
+        s = float(self.region['s'])
+        e = float(self.region['e'])
+        w = float(self.region['w'])
+        # Calculate rows, columns, and extents
+        new['rows'] = math.fabs(round((n-s)/nsres))
+        new['cols'] = math.fabs(round((e-w)/ewres))
+        # Calculate new extents
+        new['s'] = nsres * round(s / nsres)
+        new['w'] = ewres * round(w / ewres)
+        new['n'] = new['s'] + (new['rows'] * nsres)
+        new['e'] = new['w'] + (new['cols'] * ewres)
+        return new
+    def AlignExtentFromDisplay(self):
+        """!Align region extent based on display size from center
+        point"""
+        # calculate new bounding box based on center of display
+        if self.region["ewres"] > self.region["nsres"]:
+            res = self.region["ewres"]
+        else:
+            res = self.region["nsres"]
+        Debug.msg(3, "Map.AlignExtentFromDisplay(): width=%d, height=%d, res=%f, center=%f,%f" % \
+                      (self.width, self.height, res, self.region['center_easting'],
+                       self.region['center_northing']))
+        ew = (self.width / 2) * res
+        ns = (self.height / 2) * res
+        self.region['n'] = self.region['center_northing'] + ns
+        self.region['s'] = self.region['center_northing'] - ns
+        self.region['e'] = self.region['center_easting'] + ew
+        self.region['w'] = self.region['center_easting'] - ew
+        # LL locations
+        if self.projinfo['proj'] == 'll':
+            self.region['n'] = min(self.region['n'], 90.0)
+            self.region['s'] = max(self.region['s'], -90.0)
+    def ChangeMapSize(self, (width, height)):
+        """!Change size of rendered map.
+        @param width,height map size given as tuple
+        try:
+            self.width  = int(width)
+            self.height = int(height)
+            if self.width < 1 or self.height < 1:
+                sys.stderr.write(_("Invalid map size %d,%d\n") % (self.width, self.height))
+                raise ValueError
+        except ValueError:
+            self.width  = 640
+            self.height = 480
+        Debug.msg(2, "Map.ChangeMapSize(): width=%d, height=%d" % \
+                      (self.width, self.height))
+    def GetRegion(self, rast = [], zoom = False, vect = [], regionName = None,
+                  n = None, s = None, e = None, w = None, default = False,
+                  update = False, add3d = False):
+        """!Get region settings (g.region -upgc)
+        Optionally extent, raster or vector map layer can be given.
+        @param rast list of raster maps
+        @param zoom zoom to raster map (ignore NULLs)
+        @param vect list of vector maps
+        @param regionName  named region or None
+        @param n,s,e,w force extent
+        @param default force default region settings
+        @param update if True update current display region settings
+        @param add3d add 3d region settings
+        @return region settings as dictionary, e.g. {
+        'n':'4928010', 's':'4913700', 'w':'589980',...}
+        @see GetCurrentRegion()
+        region = {}
+        tmpreg = os.getenv("GRASS_REGION")
+        if tmpreg:
+            del os.environ["GRASS_REGION"]
+        if self.gisrc:
+        # do not update & shell style output
+        cmd = {}
+        cmd['flags'] = 'ugpc'
+        if default:
+            cmd['flags'] += 'd'
+        if add3d:
+            cmd['flags'] += '3'
+        if regionName:
+            cmd['region'] = regionName
+        if n:
+            cmd['n'] = n
+        if s:
+            cmd['s'] = s
+        if e:
+            cmd['e'] = e
+        if w:
+            cmd['w'] = w
+        if rast:
+            if zoom:
+                cmd['zoom'] = rast[0]
+            else:
+                cmd['rast'] = ','.join(rast)
+        if vect:
+            cmd['vect'] = ','.join(vect)
+        ret, reg, msg = RunCommand('g.region',
+                                   read = True,
+                                   **cmd)
+        if ret != 0:
+            if rast:
+                message = _("Unable to zoom to raster map <%s>.") % rast[0] + \
+                    "\n\n" + _("Details:") + " %s" % msg
+            elif vect:
+                message = _("Unable to zoom to vector map <%s>.") % vect[0] + \
+            else:
+                message = _("Unable to get current geographic extent. "
+                            "Force quiting wxGUI. Please manually run g.region to "
+                            "fix the problem.")
+            GError(message)
+        for r in reg.splitlines():
+            key, val = r.split("=", 1)
+            try:
+                region[key] = float(val)
+                region[key] = val
+        if self.gisrc:
+        # restore region
+        if tmpreg:
+            os.environ["GRASS_REGION"] = tmpreg
+        Debug.msg (3, "Map.GetRegion(): %s" % region)
+        if update:
+            self.region = region
+        return region
+    def GetCurrentRegion(self):
+        """!Get current display region settings
+        @see GetRegion()
+    def SetRegion(self, windres = False, windres3 = False):
+        """!Render string for GRASS_REGION env. variable, so that the
+        images will be rendered from desired zoom level.
+        @param windres uses resolution from WIND file rather than
+        display (for modules that require set resolution like
+        d.rast.num)
+        @return String usable for GRASS_REGION variable or None
+        grass_region = ""
+        if windres:
+            compRegion = self.GetRegion(add3d = windres3)
+            region = copy.copy(self.region)
+            for key in ('nsres', 'ewres', 'cells'):
+                region[key] = compRegion[key]
+            if windres3:
+                for key in ('nsres3', 'ewres3', 'tbres', 'cells3',
+                            'cols3', 'rows3', 'depths'):
+                    if key in compRegion:
+        else:
+            # adjust region settings to match monitor
+            region = self.AdjustRegion()
+        # read values from wind file
+        try:
+            for key in self.wind.keys():
+                if key == 'north':
+                    grass_region += "north: %s; " % \
+                        (region['n'])
+                    continue
+                elif key == "south":
+                    grass_region += "south: %s; " % \
+                        (region['s'])
+                    continue
+                elif key == "east":
+                    grass_region += "east: %s; " % \
+                        (region['e'])
+                    continue
+                elif key == "west":
+                    grass_region += "west: %s; " % \
+                        (region['w'])
+                    continue
+                elif key == "e-w resol":
+                    grass_region += "e-w resol: %f; " % \
+                        (region['ewres'])
+                    continue
+                elif key == "n-s resol":
+                    grass_region += "n-s resol: %f; " % \
+                        (region['nsres'])
+                    continue
+                elif key == "cols":
+                    if windres:
+                        continue
+                    grass_region += 'cols: %d; ' % \
+                        region['cols']
+                    continue
+                elif key == "rows":
+                    if windres:
+                        continue
+                    grass_region += 'rows: %d; ' % \
+                        region['rows']
+                    continue
+                elif key == "n-s resol3" and windres3:
+                    grass_region += "n-s resol3: %f; " % \
+                        (region['nsres3'])
+                elif key == "e-w resol3" and windres3:
+                    grass_region += "e-w resol3: %f; " % \
+                        (region['ewres3'])
+                elif key == "t-b resol" and windres3:
+                    grass_region += "t-b resol: %f; " % \
+                        (region['tbres'])
+                elif key == "cols3" and windres3:
+                    grass_region += "cols3: %d; " % \
+                        (region['cols3'])
+                elif key == "rows3" and windres3:
+                    grass_region += "rows3: %d; " % \
+                        (region['rows3'])
+                elif key == "depths" and windres3:
+                    grass_region += "depths: %d; " % \
+                        (region['depths'])
+                else:
+                    grass_region += key + ": "  + self.wind[key] + "; "
+            Debug.msg (3, "Map.SetRegion(): %s" % grass_region)
+            return grass_region
+        except:
+            return None
+    def GetListOfLayers(self, ltype = None, mapset = None, name = None,
+                        active = None, hidden = None):
+        """!Returns list of layers of selected properties or list of
+        all layers.
+        @param ltype layer type, e.g. raster/vector/wms/overlay (value or tuple of values)
+        @param mapset all layers from given mapset (only for maplayers)
+        @param name all layers with given name
+        @param active only layers with 'active' attribute set to True or False
+        @param hidden only layers with 'hidden' attribute set to True or False
+        @return list of selected layers
+        selected = []
+        if type(ltype) == types.StringType:
+            one_type = True
+        else:
+            one_type = False
+        if one_type and ltype == 'overlay':
+            llist = self.overlays
+        else:
+            llist = self.layers
+        # ["raster", "vector", "wms", ... ]
+        for layer in llist:
+            # specified type only
+            if ltype != None:
+                if one_type and layer.type != ltype:
+                    continue
+                elif not one_type and layer.type not in ltype:
+                    continue
+            # mapset
+            if (mapset != None and ltype != 'overlay') and \
+                    layer.GetMapset() != mapset:
+                continue
+            # name
+            if name != None and layer.name != name:
+                continue
+            # hidden and active layers
+            if active != None and \
+                   hidden != None:
+                if layer.active == active and \
+                       layer.hidden == hidden:
+                    selected.append(layer)
+            # active layers
+            elif active != None:
+                if layer.active == active:
+            # hidden layers
+            elif hidden != None:
+                if layer.hidden == hidden:
+            # all layers
+            else:
+        Debug.msg (3, "Map.GetListOfLayers(): numberof=%d" % len(selected))
+        return selected
+    def _renderLayers(self, force = False, overlaysOnly = False):
+        """!Render all map layers into files
+        @param force True to force rendering
+        @param overlaysOnly True to render only overlays
+        @return list of maps, masks and opacities
+        maps = list()
+        masks = list()
+        opacities = list()
+        # render map layers
+        if overlaysOnly:
+            layers = self.overlays
+        else:
+            layers = self.layers + self.overlays
+        if self.receiver:
+            event = wxUpdateProgressBar(layer = None, map = self)
+            self.receiver.GetEventHandler().ProcessEvent(event)
+        for layer in layers:
+            # skip non-active map layers
+            if not layer or not layer.active:
+                continue
+            # render
+            if force or layer.forceRender:
+                if not layer.Render():
+                    continue
+            if layer.IsDownloading():
+                self.downloading = True
+            if self.receiver:
+                event = wxUpdateProgressBar(layer = layer, map = self)
+            # skip map layers when rendering fails
+            if not os.path.exists(layer.mapfile):
+                continue
+            # add image to compositing list
+            if layer.type != "overlay":
+                maps.append(layer.mapfile)
+                masks.append(layer.maskfile)
+                opacities.append(str(layer.opacity))
+            Debug.msg(3, "Map.Render() type=%s, layer=%s " % (layer.type, layer.name))
+        return maps, masks, opacities
+    def GetMapsMasksAndOpacities(self, force, windres):
+        Used by Render function.
+        @return maps, masks, opacities
+        return self._renderLayers(force)
+    def Render(self, force = False, windres = False):
+        """!Creates final image composite
+        This function can conditionaly use high-level tools, which
+        should be avaliable in wxPython library
+        @param force force rendering
+        @param windres use region resolution (True) otherwise display resolution
+        @return name of file with rendered image or None
+        wx.BeginBusyCursor()
+        if self.gisrc:
+        tmp_region = os.getenv("GRASS_REGION")
+        os.environ["GRASS_REGION"] = self.SetRegion(windres)
+        os.environ["GRASS_WIDTH"]  = str(self.width)
+        os.environ["GRASS_HEIGHT"] = str(self.height)
+        driver = UserSettings.Get(group = 'display', key = 'driver', subkey = 'type')
+        if driver == 'png':
+            os.environ["GRASS_RENDER_IMMEDIATE"] = "png"
+        else:
+            os.environ["GRASS_RENDER_IMMEDIATE"] = "cairo"
+        maps, masks, opacities = self.GetMapsMasksAndOpacities(force, windres)
+        # ugly hack for MSYS
+        if sys.platform != 'win32':
+            mapstr = ",".join(maps)
+            maskstr = ",".join(masks)
+        else:
+            mapstr = ""
+            for item in maps:
+                mapstr += item.replace('\\', '/')
+            mapstr = mapstr.rstrip(',')
+            maskstr = ""
+            for item in masks:
+                maskstr += item.replace('\\', '/')
+            maskstr = maskstr.rstrip(',')
+        # run g.pngcomp to get composite image
+        bgcolor = ':'.join(map(str, UserSettings.Get(group = 'display', key = 'bgcolor',
+                                                     subkey = 'color')))
+        if maps:
+            ret, msg = RunCommand('g.pnmcomp',
+                                  overwrite = True,
+                                  input = '%s' % ",".join(maps),
+                                  mask = '%s' % ",".join(masks),
+                                  opacity = '%s' % ",".join(opacities),
+                                  bgcolor = bgcolor,
+                                  width = self.width,
+                                  height = self.height,
+                                  output = self.mapfile)
+            if ret != 0:
+                print >> sys.stderr, _("ERROR: Rendering failed. Details: %s") % msg
+                wx.EndBusyCursor()
+                return None
+        Debug.msg (3, "Map.Render() force=%s file=%s" % (force, self.mapfile))
+        # back to original region
+        if tmp_region:
+            os.environ["GRASS_REGION"] = tmp_region
+        else:
+        if self.gisrc:
+        if not maps:
+            return None
+    def AddMapLayer(self, mlayer, render = False, pos = -1):
+        # opacity must be <0;1>
+        if mlayer.opacity < 0:
+            opacity = 0
+        elif mlayer.opacity > 1:
+            opacity = 1
+        # add maplayer to the list of layers
+        if pos > -1:
+            self.layers.insert(pos, mlayer)
+        else:
+            self.layers.append(mlayer)
+        Debug.msg (3, "Map.AddLayer(): layer=%s" % mlayer.name)
+        if render:
+            if not mlayer.Render():
+                raise GException(_("Unable to render map layer <%s>.") % mlayer.name)
+        return mlayer
+    def AddLayer(self, ltype, command, name = None,
+                 active = True, hidden = False, opacity = 1.0, render = False,
+                 pos = -1):
+        """!Adds generic map layer to list of layers
+        @param ltype layer type ('raster', 'vector', etc.)
+        @param command  GRASS command given as list
+        @param active layer render only if True
+        @param hidden layer not displayed in layer tree if True
+        @param opacity opacity level range from 0(transparent) - 1(not transparent)
+        @param render render an image if True
+        @param pos position in layer list (-1 for append)
+        @return new layer on success
+        @return None on failure
+        if opacity < 0:
+            opacity = 0
+        elif opacity > 1:
+            opacity = 1
+        layer = MapLayer(ltype = ltype, name = name, cmd = command, Map = self,
+                         active = active, hidden = hidden, opacity = opacity)
+        if pos > -1:
+            self.layers.insert(pos, layer)
+        else:
+            self.layers.append(layer)
+        Debug.msg (3, "Map.AddLayer(): layer=%s" % layer.name)
+        if render:
+                raise GException(_("Unable to render map layer <%s>.") % name)
+        return layer
+    def DeleteAllLayers(self, overlay = False):
+        """!Delete all layers
+        @param overlay True to delete also overlayes
+        self.layers = []
+        if overlay:
+            self.overlays = []
+    def DeleteLayer(self, layer, overlay = False):
+        """!Removes layer from list of layers
+        @param layer layer instance in layer tree
+        @param overlay delete overlay (use self.DeleteOverlay() instead)
+        @return removed layer on success or None
+        Debug.msg (3, "Map.DeleteLayer(): name=%s" % layer.name)
+        if overlay:
+            list = self.overlays
+        else:
+            list = self.layers
+        if layer in list:
+            if layer.mapfile:
+                base = os.path.split(layer.mapfile)[0]
+                mapfile = os.path.split(layer.mapfile)[1]
+                tempbase = mapfile.split('.')[0]
+                if base == '' or tempbase == '':
+                    return None
+                basefile = os.path.join(base, tempbase) + r'.*'
+                for f in glob.glob(basefile):
+                    os.remove(f)
+            list.remove(layer)
+            return layer
+        return None
+    def ReorderLayers(self, layerList):
+        """!Reorder list to match layer tree
+        @param layerList list of layers
+        self.layers = layerList
+        layerNameList = ""
+        for layer in self.layers:
+            if layer.GetName():
+                layerNameList += layer.GetName() + ','
+        Debug.msg (4, "Map.ReoderLayers(): layers=%s" % \
+                   (layerNameList))
+    def ChangeLayer(self, layer, render = False, **kargs):
+        """!Change map layer properties
+        @param layer map layer instance
+        Debug.msg (3, "Map.ChangeLayer(): layer=%s" % layer.name)
+        if 'ltype' in kargs:
+            layer.SetType(kargs['ltype']) # check type
+        print kargs['command']
+        print "yyy"
+        if 'command' in kargs:
+            layer.SetCmd(kargs['command'])
+        if 'name' in kargs:
+            layer.SetName(kargs['name'])
+        if 'active' in kargs:
+            layer.SetActive(kargs['active'])
+        if 'hidden' in kargs:
+            layer.SetHidden(kargs['hidden'])
+        if 'opacity' in kargs:
+            layer.SetOpacity(kargs['opacity'])
+        if render and not layer.Render():
+                             layer.GetName())
+        return layer
+    def ChangeOpacity(self, layer, opacity):
+        """!Changes opacity value of map layer
+        @param opacity opacity level <0;1>
+        if opacity < 0: opacity = 0
+        elif opacity > 1: opacity = 1
+        layer.opacity = opacity
+        Debug.msg (3, "Map.ChangeOpacity(): layer=%s, opacity=%f" % \
+                   (layer.name, layer.opacity))
+    def ChangeLayerActive(self, layer, active):
+        """!Enable or disable map layer
+        @param active to be rendered (True)
+        layer.active = active
+        Debug.msg (3, "Map.ChangeLayerActive(): name='%s' -> active=%d" % \
+                   (layer.name, layer.active))
+    def ChangeLayerName (self, layer, name):
+        """!Change name of the layer
+        @param name  layer name to set up
+        Debug.msg (3, "Map.ChangeLayerName(): from=%s to=%s" % \
+                   (layer.name, name))
+        layer.name =  name
+    def RemoveLayer(self, name = None, id = None):
+        """!Removes layer from layer list
+        Layer is defined by name at mapset or id.
+        @param name layer name (must be unique)
+        @param id layer index in layer list    def __init__(self, targetFile, region, bandsNum, gdalDriver, fillValue = None):
+        # delete by name
+        if name:
+            retlayer = None
+                if layer.name == name:
+                    retlayer = layer
+                    os.remove(layer.mapfile)
+                    os.remove(layer.maskfile)
+                    self.layers.remove(layer)
+                    return retlayer
+        # del by id
+        elif id != None:
+            return self.layers.pop(id)
+        return None
+    def GetLayerIndex(self, layer, overlay = False):
+        """!Get index of layer in layer list.
+        @param layer layer instace in layer tree
+        @param overlay use list of overlays instead
+        @return layer index
+        @return -1 if layer not found
+        if overlay:
+        else:
+        if layer in list:
+            return list.index(layer)
+        return -1
+    def AddOverlay(self, id, ltype, command,
+                   active = True, hidden = True, opacity = 1.0, render = False):
+        """!Adds overlay (grid, barscale, legend, etc.) to list of
+        overlays
+        @param id overlay id (PseudoDC)
+        @param ltype overlay type (barscale, legend)
+        @param command GRASS command to render overlay
+        @param active overlay activated (True) or disabled (False)
+        @param hidden overlay is not shown in layer tree (if True)
+        @param render render an image (if True)
+        Debug.msg (2, "Map.AddOverlay(): cmd=%s, render=%d" % (command, render))
+        overlay = Overlay(id = id, ltype = ltype, cmd = command, Map = self,
+        self.overlays.append(overlay)
+        if render and command != '' and not overlay.Render():
+            raise GException(_("Unable to render overlay <%s>.") %
+                             ltype)
+        return self.overlays[-1]
+    def ChangeOverlay(self, id, render = False, **kargs):
+        """!Change overlay properities
+        Add new overlay if overlay with 'id' doesn't exist.
+        @param ltype overlay ltype (barscale, legend)
+        overlay = self.GetOverlay(id, list = False)
+        if  overlay is None:
+            overlay = Overlay(id, ltype = None, cmd = None)
+            overlay.SetName(kargs['ltype']) # ltype -> overlay
+            overlay.SetCmd(kargs['command'])
+            overlay.SetActive(kargs['active'])
+            overlay.SetHidden(kargs['hidden'])
+            overlay.SetOpacity(kargs['opacity'])
+        if render and overlay.GetCmd() != [] and not overlay.Render():
+                             overlay.GetType())
+        return overlay
+    def GetOverlay(self, id, list = False):
+        """!Return overlay(s) with 'id'
+        @param list return list of overlays of True
+        otherwise suppose 'id' to be unique
+        @return list of overlays (list=True)
+        @return overlay (list=False)
+        @return None (list=False) if no overlay or more overlays found
+        ovl = []
+        for overlay in self.overlays:
+            if overlay.id == id:
+                ovl.append(overlay)
+        if not list:
+            if len(ovl) != 1:
+                return None
+            else:
+                return ovl[0]
+        return ovl
+    def DeleteOverlay(self, overlay):
+        """!Delete overlay
+        @param overlay overlay layer
+        @return removed overlay on success or None
+        return self.DeleteLayer(overlay, overlay = True)
+    def _clean(self, llist):
+            if layer.maskfile:
+                grass.try_remove(layer.maskfile)
+            if layer.mapfile:
+                grass.try_remove(layer.mapfile)
+            llist.remove(layer)
+    def Clean(self):
+        """!Clean layer stack - go trough all layers and remove them
+        from layer list.
+        Removes also mapfile and maskfile.
+        self._clean(self.layers)
+        self._clean(self.overlays)
+    def ReverseListOfLayers(self):
+        """!Reverse list of layers"""
+        return self.layers.reverse()
+    def RenderOverlays(self, force):
+        """!Render overlays only (for nviz)"""
+        for layer in self.overlays:
+                layer.Render()
+    def GetReceiver(self):
+        """!Get event receiver"""
+        return self.receiver
+    def SetReceiver(self, receiver):
+        """!Set events receiver
+        @todo  If it will be needed to change receiver, take care of running threads.
+        self.receiver = receiver
+        for l in self.overlays + self.layers:
+            if l.GetRenderMgr():
+                l.GetRenderMgr().SetReceiver(self.receiver)
+    def AbortAllThreads(self):
+        """!Abort all layers threads e. g. donwloading data"""
+        for l in self.layers + self.overlays:
+            l.AbortThread()
