[GRASS-SVN] r55406 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Sun Mar 17 03:40:28 PDT 2013
Author: martinl
Date: 2013-03-17 03:40:28 -0700 (Sun, 17 Mar 2013)
New Revision: 55406
grass/trunk/lib/vector/Vlib/field.c
vlib: read_dblinks_ogr(): fatal error -> warning
Modified: grass/trunk/lib/vector/Vlib/field.c
--- grass/trunk/lib/vector/Vlib/field.c 2013-03-16 22:35:40 UTC (rev 55405)
+++ grass/trunk/lib/vector/Vlib/field.c 2013-03-17 10:40:28 UTC (rev 55406)
@@ -649,6 +649,7 @@
return rule;
+/* return -1 on error */
static int read_dblinks_ogr(struct Map_info *Map)
struct dblinks *dbl;
@@ -670,9 +671,11 @@
/* data source handle */
Map->fInfo.ogr.ds = OGROpen(Map->fInfo.ogr.dsn, FALSE, NULL);
- if (Map->fInfo.ogr.ds == NULL)
- G_fatal_error(_("Unable to open OGR data source '%s'"),
- Map->fInfo.ogr.dsn);
+ if (Map->fInfo.ogr.ds == NULL) {
+ G_warning(_("Unable to open OGR data source '%s'"),
+ Map->fInfo.ogr.dsn);
+ return -1;
if (Map->fInfo.ogr.layer == NULL) {
/* get layer number */
@@ -686,8 +689,9 @@
OGR_DS_Destroy(Map->fInfo.ogr.ds);
Map->fInfo.ogr.ds = NULL;
- G_fatal_error(_("Unable to open OGR layer <%s>"),
- Map->fInfo.ogr.layer_name);
+ G_warning(_("Unable to open OGR layer <%s>"),
+ Map->fInfo.ogr.layer_name);
+ return -1;
