[GRASS-SVN] r55407 - grass/trunk/vector/v.buffer
svn_grass at osgeo.org
Sun Mar 17 03:51:41 PDT 2013
Author: martinl
Date: 2013-03-17 03:51:40 -0700 (Sun, 17 Mar 2013)
New Revision: 55407
grass/trunk/vector/v.buffer/main.c
v.buffer: use temporary map
Modified: grass/trunk/vector/v.buffer/main.c
--- grass/trunk/vector/v.buffer/main.c 2013-03-17 10:40:28 UTC (rev 55406)
+++ grass/trunk/vector/v.buffer/main.c 2013-03-17 10:51:40 UTC (rev 55407)
@@ -186,7 +186,6 @@
struct Map_info In, Out, Buf;
struct line_pnts *Points;
struct line_cats *Cats, *BCats, *CCats;
- char bufname[GNAME_MAX];
struct GModule *module;
struct Option *in_opt, *out_opt, *type_opt, *dista_opt, *distb_opt,
*angle_opt;
@@ -385,8 +384,7 @@
CCats = Vect_new_cats_struct();
/* open tmp vector for buffers, needed for cleaning */
- sprintf(bufname, "%s_tmp_%d", out_opt->answer, getpid());
- if (0 > Vect_open_new(&Buf, bufname, 0)) {
+ if (0 > Vect_open_tmp_new(&Buf, NULL, 0)) {
G_fatal_error(_("Unable to create vector map"));
Vect_build_partial(&Buf, GV_BUILD_BASE);
@@ -875,8 +873,7 @@
Vect_spatial_index_destroy(&si);
Vect_close(&Buf);
- Vect_delete(bufname);
G_set_verbose(verbose);
if (cats_flag->answer)
