[GRASS-SVN] r55446 - grass/trunk/vector/v.univar
svn_grass at osgeo.org
Tue Mar 19 08:06:56 PDT 2013
Author: mmetz
Date: 2013-03-19 08:06:56 -0700 (Tue, 19 Mar 2013)
New Revision: 55446
grass/trunk/vector/v.univar/main.c
v.univar: fix for SunOS 5 and Solaris 2
Modified: grass/trunk/vector/v.univar/main.c
--- grass/trunk/vector/v.univar/main.c 2013-03-19 15:02:18 UTC (rev 55445)
+++ grass/trunk/vector/v.univar/main.c 2013-03-19 15:06:56 UTC (rev 55446)
@@ -51,7 +51,7 @@
static void summary(void);
struct Option *field_opt, *where_opt, *col_opt;
-struct Flag *shell_flag, *extended, *geometry;
+struct Flag *shell_flag, *ext_flag, *geometry;
struct Map_info Map;
struct line_cats *Cats;
struct field_info *Fi;
@@ -121,9 +121,9 @@
shell_flag->key = 'g';
shell_flag->description = _("Print the stats in shell script style");
- extended = G_define_flag();
- extended->key = 'e';
- extended->description = _("Calculate extended statistics");
+ ext_flag = G_define_flag();
+ ext_flag->key = 'e';
+ ext_flag->description = _("Calculate extended statistics");
geometry = G_define_flag();
geometry->key = 'd';
@@ -162,7 +162,7 @@
"can be calculated"));
- if (extended->answer && (!(otype & GV_POINTS) || geometry->answer)) {
+ if (ext_flag->answer && (!(otype & GV_POINTS) || geometry->answer)) {
G_warning(_("Extended statistics is currently supported only for points/centroids"));
@@ -571,7 +571,7 @@
/* TODO: mode, skewness, kurtosis */
/* Not possible to calculate for point distance, since we don't collect the population */
- if (extended->answer && compatible && (otype & GV_POINTS) && !geometry->answer && count > 0) {
+ if (ext_flag->answer && compatible && (otype & GV_POINTS) && !geometry->answer && count > 0) {
double quartile_25 = 0.0, quartile_75 = 0.0, quartile_perc = 0.0;
double median = 0.0;
int qpos_25, qpos_75, qpos_perc;
