[GRASS-SVN] r55447 - grass/trunk/lib/python/pygrass/vector
svn_grass at osgeo.org
Tue Mar 19 08:24:06 PDT 2013
Author: zarch
Date: 2013-03-19 08:24:06 -0700 (Tue, 19 Mar 2013)
New Revision: 55447
grass/trunk/lib/python/pygrass/vector/__init__.py
grass/trunk/lib/python/pygrass/vector/geometry.py
Move some geometry code from __init__ to geometry
Modified: grass/trunk/lib/python/pygrass/vector/__init__.py
--- grass/trunk/lib/python/pygrass/vector/__init__.py 2013-03-19 15:06:56 UTC (rev 55446)
+++ grass/trunk/lib/python/pygrass/vector/__init__.py 2013-03-19 15:24:06 UTC (rev 55447)
@@ -4,17 +4,16 @@
@author: pietro
-import ctypes
import grass.lib.vector as libvect
-from vector_type import VTYPE, GV_TYPE
+from vector_type import VTYPE
# import pygrass modules
from grass.pygrass.errors import GrassError, must_be_open
-import geometry
+from geometry import GEOOBJ as _GEOOBJ
+from geometry import read_line, read_next_line
from abstract import Info
from basic import Bbox
@@ -32,19 +31,7 @@
"updated_nodes": libvect.Vect_get_num_updated_nodes,
"volumes": libvect.Vect_get_num_volumes}
-_GEOOBJ = {"areas": geometry.Area,
- "dblinks": None,
- "faces": None,
- "holes": None,
- "islands": geometry.Isle,
- "kernels": None,
- "line_points": None,
- "points": geometry.Point,
- "lines": geometry.Line,
- "nodes": geometry.Node,
- "volumes": None}
# VECTOR
@@ -109,22 +96,7 @@
- v_id = self.c_mapinfo.contents.next_line
- v_id = v_id if v_id != 0 else None
- c_points = ctypes.pointer(libvect.line_pnts())
- c_cats = ctypes.pointer(libvect.line_cats())
- ftype = libvect.Vect_read_next_line(self.c_mapinfo, c_points, c_cats)
- if ftype == -2:
- raise StopIteration()
- if ftype == -1:
- raise
- #if GV_TYPE[ftype]['obj'] is not None:
- return GV_TYPE[ftype]['obj'](v_id=v_id,
- c_mapinfo=self.c_mapinfo,
- c_points=c_points,
- c_cats=c_cats,
- table=self.table,
- writable=self.writable)
+ return read_next_line(self.c_mapinfo, self.table, self.writable)
@must_be_open
def rewind(self):
@@ -206,8 +178,6 @@
geo_obj.offset = result
# VECTOR WITH TOPOLOGY
@@ -407,24 +377,7 @@
- if feature_id < 0: # Handle negative indices
- feature_id += self.__len__() + 1
- if feature_id > (self.__len__()):
- raise IndexError('Index out of range')
- if feature_id > 0:
- ftype = libvect.Vect_read_line(self.c_mapinfo, c_points,
- c_cats, feature_id)
- if GV_TYPE[ftype]['obj'] is not None:
- return GV_TYPE[ftype]['obj'](v_id=feature_id,
- c_cats=c_cats,
- table=self.table,
- else:
- raise ValueError('The index must be >0, %r given.' % feature_id)
+ return read_line(feature_id, self.c_mapinfo, self.table, self.writable)
@must_be_open
def is_empty(self):
Modified: grass/trunk/lib/python/pygrass/vector/geometry.py
--- grass/trunk/lib/python/pygrass/vector/geometry.py 2013-03-19 15:06:56 UTC (rev 55446)
+++ grass/trunk/lib/python/pygrass/vector/geometry.py 2013-03-19 15:24:06 UTC (rev 55447)
@@ -127,14 +127,10 @@
class Attrs(object):
- def __init__(self, cat, table, writable=None):
+ def __init__(self, cat, table, writable=False):
self.cat = cat
self.table = table
self.cond = "%s=%d" % (self.table.key, self.cat)
- # TODO add
- #if writable == None:
- # self.writable
- #else:
self.writable = writable
def __getitem__(self, key):
@@ -221,7 +217,7 @@
>>> attrs.keys() # doctest: +ELLIPSIS
(u'cat',
- u'NOTES')
+ u'NOTES')
return self.table.columns.names()
@@ -1019,6 +1015,7 @@
class Node(object):
pass
class Boundary(Line):
@@ -1407,3 +1404,68 @@
border = self.points()
return libvect.Vect_area_perimeter(border.c_points)
+# Define a dictionary to convert the feature type to name and or object
+GV_TYPE = {libvect.GV_POINT: {'label': 'point', 'obj': Point},
+ libvect.GV_LINE: {'label': 'line', 'obj': Line},
+ libvect.GV_BOUNDARY: {'label': 'boundary', 'obj': Boundary},
+ libvect.GV_CENTROID: {'label': 'centroid', 'obj': Centroid},
+ libvect.GV_FACE: {'label': 'face', 'obj': None},
+ libvect.GV_KERNEL: {'label': 'kernel', 'obj': None},
+ libvect.GV_AREA: {'label': 'area', 'obj': Area},
+ libvect.GV_VOLUME: {'label': 'volume', 'obj': None}, }
+GEOOBJ = {"areas": Area,
+ "dblinks": None,
+ "faces": None,
+ "holes": None,
+ "islands": Isle,
+ "kernels": None,
+ "line_points": None,
+ "points": Point,
+ "lines": Line,
+ "nodes": Node,
+ "volumes": None}
+def read_next_line(c_mapinfo, table=None, writable=False):
+ """Return the next geometry feature of a vector map."""
+ v_id = c_mapinfo.contents.next_line
+ v_id = v_id if v_id != 0 else None
+ c_points = ctypes.pointer(libvect.line_pnts())
+ c_cats = ctypes.pointer(libvect.line_cats())
+ ftype = libvect.Vect_read_next_line(c_mapinfo, c_points, c_cats)
+ if ftype == -2:
+ raise StopIteration()
+ if ftype == -1:
+ raise
+ #if GV_TYPE[ftype]['obj'] is not None:
+ return GV_TYPE[ftype]['obj'](v_id=v_id, c_mapinfo=c_mapinfo,
+ c_points=c_points, c_cats=c_cats,
+ table=table, writable=writable)
+def read_line(feature_id, c_mapinfo, table=None, writable=False):
+ """Return a geometry object given the feature id and the c_mapinfo.
+ nmax = libvect.Vect_get_num_lines(c_mapinfo)
+ if feature_id < 0: # Handle negative indices
+ feature_id += nmax + 1
+ if feature_id > nmax:
+ raise IndexError('Index out of range')
+ if feature_id > 0:
+ ftype = libvect.Vect_read_line(c_mapinfo, c_points, c_cats, feature_id)
+ if GV_TYPE[ftype]['obj'] is not None:
+ return GV_TYPE[ftype]['obj'](v_id=feature_id, c_mapinfo=c_mapinfo,
+ else:
+ raise ValueError('The index must be >0, %r given.' % feature_id)
