[GRASS-SVN] r55457 - in grass-addons/grass7/raster/r.agent: libagent tests
svn_grass at osgeo.org
Tue Mar 19 09:37:46 PDT 2013
Author: mic
Date: 2013-03-19 09:37:46 -0700 (Tue, 19 Mar 2013)
New Revision: 55457
grass-addons/grass7/raster/r.agent/libagent/grassland.py
grass-addons/grass7/raster/r.agent/tests/test_grassland.py
start implementation of parsevectorlayer
Modified: grass-addons/grass7/raster/r.agent/libagent/grassland.py
--- grass-addons/grass7/raster/r.agent/libagent/grassland.py 2013-03-19 16:16:21 UTC (rev 55456)
+++ grass-addons/grass7/raster/r.agent/libagent/grassland.py 2013-03-19 16:37:46 UTC (rev 55457)
@@ -74,7 +74,25 @@
self.layers[layername].write(self.grassmapnames[layername],
overwrite=force)
- def parsevectorlayer(self, layername, grassmapname=False, force=False):
-#TODO
- return []
+ def parsevectorlayer(self, layername, grassmapname, value=1, force=False):
+ Take point information from a vector layer, mark them on the
+ layer specified and return them as a list
+ @param string name of the layer to be exported
+ @param string name of the GRASS map file to be created
+ @param int value to be set
+ @param boolean optional, whether an existing file may be overwritten
+ vectors = []
+ if grass.find_file(name = grassmapname, element = 'vector')['file']:
+ layer = grass.vector_db_select(grassmapname)['values']
+ # TODO only points are supported, ask some expert how to test this
+ # TODO indexing seems to start at "1".. verify!
+ for v in layer.values():
+ if len(v) == 4 and v[0] == v[3]:
+ x = ( v[1] - self.region["s"] ) / self.region["ewres"]
+ y = ( v[1] - self.region["s"] ) / self.region["nsres"]
+ vectors.append([x, y])
+ self.layers[layername][y][x] = value
+ return vectors
Modified: grass-addons/grass7/raster/r.agent/tests/test_grassland.py
--- grass-addons/grass7/raster/r.agent/tests/test_grassland.py 2013-03-19 16:16:21 UTC (rev 55456)
+++ grass-addons/grass7/raster/r.agent/tests/test_grassland.py 2013-03-19 16:37:46 UTC (rev 55457)
@@ -8,7 +8,9 @@
class TestGrassland(unittest.TestCase):
def setUp(self):
- self.layername = "r.agent.testmap"
+ # TODO check if there is a nicer way to do this..
+ self.layername = "r.agent.cell.testmap"
+ self.vlayername = "r.agent.vector.testmap"
self.pg = grassland.Grassland()
def test_getregion(self):
@@ -92,11 +94,20 @@
pass
def test_parsegrasslayer(self):
- # grass.vector_db_select('sites')
- pass
+ if self.vlayername:
+ if grass.find_file(name = self.vlayername,
+ element = 'vector')['file']:
+ print "We need a file to play with in this test, but it"
+ print "seems to exist already: '" + self.vlayername + "'"
+ # show error if arrived here
+ self.assertTrue(False)
+ #TODO find a way to write vector files..
def tearDown(self):
if self.layername:
grass.try_remove(grass.find_file(name = self.layername,
element = 'cell')['file'])
+ grass.try_remove(grass.find_file(name = self.vlayername,
+ element = 'vector')['file'])
