[GRASS-SVN] r55458 - grass/trunk/lib/vector/rtree
svn_grass at osgeo.org
Tue Mar 19 10:29:13 PDT 2013
Author: wenzeslaus
Date: 2013-03-19 10:29:12 -0700 (Tue, 19 Mar 2013)
New Revision: 55458
grass/trunk/lib/vector/rtree/rect.c
vlib/dox: changing comments to not conflict with Markdown syntax
Modified: grass/trunk/lib/vector/rtree/rect.c
--- grass/trunk/lib/vector/rtree/rect.c 2013-03-19 16:37:46 UTC (rev 55457)
+++ grass/trunk/lib/vector/rtree/rect.c 2013-03-19 17:29:12 UTC (rev 55458)
@@ -31,7 +31,7 @@
#define MIN(a, b) ((a) < (b) ? (a) : (b))
#define MAX(a, b) ((a) > (b) ? (a) : (b))
\brief Create a new rectangle for a given tree
This method allocates a new rectangle and initializes
@@ -39,9 +39,9 @@
Hence a call to RTreeNewBoundary() is not necessary.
- \param t: The pointer to a RTree struct
+ \param t The pointer to a RTree struct
\return A new allocated RTree_Rect struct
struct RTree_Rect *RTreeAllocRect(struct RTree *t)
struct RTree_Rect *r;
@@ -56,13 +56,13 @@
return r;
\brief Delete a rectangle
This method deletes (free) the allocated memory of a rectangle.
- \param r: The pointer to the rectangle to be deleted
+ \param r The pointer to the rectangle to be deleted
void RTreeFreeRect(struct RTree_Rect *r)
assert(r);
@@ -70,17 +70,17 @@
free(r);
\brief Allocate the boundary array of a rectangle for a given tree
This method allocated the boundary coordinates array in
provided rectangle. It does not release previously allocated memory.
- \param r: The pointer to rectangle to initialize the boundary coordinates.
+ \param r The pointer to rectangle to initialize the boundary coordinates.
This is usually a rectangle that was created on the stack or
self allocated.
RectReal *RTreeAllocBoundary(struct RTree *t)
RectReal *boundary = (RectReal *)malloc(t->rectsize);
@@ -90,14 +90,14 @@
return boundary;
\brief Delete the boundary of a rectangle
This method deletes (free) the memory of the boundary of a rectangle
and sets the boundary pointer to NULL.
- \param r: The pointer to the rectangle to delete the boundary from.
+ \param r The pointer to the rectangle to delete the boundary from.
void RTreeFreeBoundary(struct RTree_Rect *r)
assert(r);
@@ -106,9 +106,9 @@
r->boundary = NULL;
\brief Initialize a rectangle to have all 0 coordinates.
void RTreeInitRect(struct RTree_Rect *r, struct RTree *t)
register int i;
@@ -117,17 +117,17 @@
r->boundary[i] = r->boundary[i + t->ndims_alloc] = (RectReal) 0;
\brief Set one dimensional coordinates of a rectangle for a given tree.
All coordinates of the rectangle will be initialized to 0 before
the x coordinates are set.
- \param t: The pointer to the RTree
- \param x_min: The lower x coordinate
- \param x_max: The higher x coordinate
+ \param t The pointer to the RTree
+ \param x_min The lower x coordinate
+ \param x_max The higher x coordinate
void RTreeSetRect1D(struct RTree_Rect *r, struct RTree *t, double x_min,
double x_max)
@@ -136,19 +136,19 @@
r->boundary[t->ndims_alloc] = (RectReal)x_max;
\brief Set two dimensional coordinates of a rectangle for a given tree.
the x and y coordinates are set.
- \param y_min: The lower y coordinate
- \param y_max: The higher y coordinate
+ \param y_min The lower y coordinate
+ \param y_max The higher y coordinate
void RTreeSetRect2D(struct RTree_Rect *r, struct RTree *t, double x_min,
double x_max, double y_min, double y_max)
@@ -159,21 +159,21 @@
r->boundary[1 + t->ndims_alloc] = (RectReal)y_max;
\brief Set three dimensional coordinates of a rectangle for a given tree.
the x,y and z coordinates are set.
- \param z_min: The lower z coordinate
- \param z_max: The higher z coordinate
+ \param z_min The lower z coordinate
+ \param z_max The higher z coordinate
void RTreeSetRect3D(struct RTree_Rect *r, struct RTree *t, double x_min,
double x_max, double y_min, double y_max, double z_min,
double z_max)
@@ -187,23 +187,23 @@
r->boundary[2 + t->ndims_alloc] = (RectReal)z_max;
\brief Set 4 dimensional coordinates of a rectangle for a given tree.
the x,y,z and t coordinates are set.
- \param t_min: The lower t coordinate
- \param t_max: The higher t coordinate
+ \param t_min The lower t coordinate
+ \param t_max The higher t coordinate
void RTreeSetRect4D(struct RTree_Rect *r, struct RTree *t, double x_min,
double z_max, double t_min, double t_max)
@@ -220,10 +220,10 @@
r->boundary[3] = (RectReal)t_min;
r->boundary[3 + t->ndims_alloc] = (RectReal)t_max;
-| Return a rect whose first low side is higher than its opposite side -
-| interpreted as an undefined rect.
+ Return a rect whose first low side is higher than its opposite side -
+ interpreted as an undefined rect.
void RTreeNullRect(struct RTree_Rect *r, struct RTree *t)
register int i;
@@ -241,10 +241,10 @@
#if 0
-| Fills in random coordinates in a rectangle.
-| The low side is guaranteed to be less than the high side.
+ Fills in random coordinates in a rectangle.
+ The low side is guaranteed to be less than the high side.
void RTreeRandomRect(struct RTree_Rect *R)
register struct RTree_Rect *r = R;
@@ -264,14 +264,14 @@
-| Fill in the boundaries for a random search rectangle.
-| Pass in a pointer to a rect that contains all the data,
-| and a pointer to the rect to be filled in.
-| Generated rect is centered randomly anywhere in the data area,
-| and has size from 0 to the size of the data area in each dimension,
-| i.e. search rect can stick out beyond data area.
+ Fill in the boundaries for a random search rectangle.
+ Pass in a pointer to a rect that contains all the data,
+ and a pointer to the rect to be filled in.
+ Generated rect is centered randomly anywhere in the data area,
+ and has size from 0 to the size of the data area in each dimension,
+ i.e. search rect can stick out beyond data area.
void RTreeSearchRect(struct RTree_Rect *Search, struct RTree_Rect *Data)
register struct RTree_Rect *search = Search, *data = Data;
@@ -301,9 +301,9 @@
#endif
-| Print out the data for a rectangle.
+ Print out the data for a rectangle.
void RTreePrintRect(struct RTree_Rect *R, int depth, struct RTree *t)
@@ -319,9 +319,9 @@
-| Calculate the n-dimensional volume of a rectangle
+ Calculate the n-dimensional volume of a rectangle
RectReal RTreeRectVolume(struct RTree_Rect *R, struct RTree *t)
@@ -341,14 +341,14 @@
-| Define the NUMDIMS-dimensional volume the unit sphere in that dimension into
-| the symbol "UnitSphereVolume"
-| Note that if the gamma function is available in the math library and if the
-| compiler supports static initialization using functions, this is
-| easily computed for any dimension. If not, the value can be precomputed and
-| taken from a table. The following code can do it either way.
+ Define the NUMDIMS-dimensional volume the unit sphere in that dimension into
+ the symbol "UnitSphereVolume"
+ Note that if the gamma function is available in the math library and if the
+ compiler supports static initialization using functions, this is
+ easily computed for any dimension. If not, the value can be precomputed and
+ taken from a table. The following code can do it either way.
#ifdef gamma
@@ -399,9 +399,9 @@
#endif
-| Calculate the n-dimensional volume of the bounding sphere of a rectangle
+ Calculate the n-dimensional volume of the bounding sphere of a rectangle
#if 0
@@ -453,9 +453,9 @@
-| Calculate the n-dimensional surface area of a rectangle
+ Calculate the n-dimensional surface area of a rectangle
RectReal RTreeRectSurfaceArea(struct RTree_Rect *r, struct RTree *t)
int i, j;
@@ -480,10 +480,10 @@
-| Calculate the n-dimensional margin of a rectangle
-| the margin is the sum of the lengths of the edges
+ Calculate the n-dimensional margin of a rectangle
+ the margin is the sum of the lengths of the edges
RectReal RTreeRectMargin(struct RTree_Rect *r, struct RTree *t)
int i;
@@ -499,9 +499,9 @@
-| Combine two rectangles, make one that includes both.
+ Combine two rectangles, make one that includes both.
void RTreeCombineRect(struct RTree_Rect *r1, struct RTree_Rect *r2,
struct RTree_Rect *r3, struct RTree *t)
@@ -536,9 +536,9 @@
-| Expand first rectangle to cover second rectangle.
+ Expand first rectangle to cover second rectangle.
int RTreeExpandRect(struct RTree_Rect *r1, struct RTree_Rect *r2,
struct RTree *t)
@@ -571,9 +571,9 @@
-| Decide whether two rectangles are identical.
+ Decide whether two rectangles are identical.
int RTreeCompareRect(struct RTree_Rect *r, struct RTree_Rect *s, struct RTree *t)
register int i, j;
@@ -591,9 +591,9 @@
-| Decide whether two rectangles overlap or touch.
+ Decide whether two rectangles overlap or touch.
int RTreeOverlap(struct RTree_Rect *r, struct RTree_Rect *s, struct RTree *t)
register int i, j;
@@ -611,9 +611,9 @@
-| Decide whether rectangle s is contained in rectangle r.
+ Decide whether rectangle s is contained in rectangle r.
int RTreeContained(struct RTree_Rect *r, struct RTree_Rect *s, struct RTree *t)
register int i, j;
@@ -638,9 +638,9 @@
-| Decide whether rectangle s fully contains rectangle r.
+ Decide whether rectangle s fully contains rectangle r.
int RTreeContains(struct RTree_Rect *r, struct RTree_Rect *s, struct RTree *t)
register int i, j;
