[GRASS-SVN] r55464 - in grass/trunk/include: . defs
svn_grass at osgeo.org
Wed Mar 20 01:19:56 PDT 2013
Author: huhabla
Date: 2013-03-20 01:19:55 -0700 (Wed, 20 Mar 2013)
New Revision: 55464
grass/trunk/include/defs/raster3d.h
grass/trunk/include/raster3d.h
Committed correct header files for the 3D raster library
Modified: grass/trunk/include/defs/raster3d.h
--- grass/trunk/include/defs/raster3d.h 2013-03-20 01:58:48 UTC (rev 55463)
+++ grass/trunk/include/defs/raster3d.h 2013-03-20 08:19:55 UTC (rev 55464)
@@ -48,12 +48,8 @@
/* fpcompress.c */
void Rast3d_fpcompress_print_binary(char *, int);
void Rast3d_fpcompress_dissect_xdr_double(unsigned char *);
-int Rast3d_fpcompress_write_xdr_nums(int, char *, int, int, char *, int, int, int);
-int Rast3d_fpcompress_write_xdr_floats(int, char *, int, int, char *, int, int);
-int Rast3d_fpcompress_write_xdr_double(int, char *, int, int, char *, int, int);
+int Rast3d_fpcompress_write_xdr_nums(int, char *, int, int, char *, int);
int Rast3d_fpcompress_read_xdr_nums(int, char *, int, int, int, char *, int);
-int Rast3d_fpcompress_read_xdr_floats(int, char *, int, int, int, char *);
-int Rast3d_fpcompress_read_xdr_doubles(int, char *, int, int, int, char *);
/* alloc.c */
void *Rast3d_malloc(int);
@@ -78,8 +74,8 @@
int Rast3d_write_colors(const char *, const char *, struct Colors *);
/* defaults.c */
-void Rast3d_set_compression_mode(int, int, int, int);
-void Rast3d_get_compression_mode(int *, int *, int *, int *);
+void Rast3d_set_compression_mode(int, int);
+void Rast3d_get_compression_mode(int *, int *);
void Rast3d_set_cache_size(int);
int Rast3d_get_cache_size(void);
void Rast3d_set_cache_limit(int);
@@ -177,7 +173,7 @@
void Rast3d_set_null_value(void *, int, int);
/* open2.c */
-void *Rast3d_open_new_param(const char *, int , int, RASTER3D_Region *, int, int, int, int, int, int, int);
+void *Rast3d_open_new_param(const char *, int , int, RASTER3D_Region *, int, int, int, int, int, int);
/* open.c */
void *Rast3d_open_cell_old_no_header(const char *, const char *);
void *Rast3d_open_cell_old(const char *, const char *, RASTER3D_Region *, int, int);
@@ -186,7 +182,7 @@
/* param.c */
void Rast3d_set_standard3d_input_params(void);
-int Rast3d_get_standard3d_params(int *, int *, int *, int *, int *, int *, int *,
+int Rast3d_get_standard3d_params(int *, int *, int *, int *, int *,
int *, int *, int *, int *, int *);
void Rast3d_set_window_params(void);
char *Rast3d_get_window_params(void);
@@ -255,18 +251,18 @@
int Rast3d_read_header(RASTER3D_Map *, int *, int *, double *, double *, double *,
double *, double *, double *, int *, int *, int *,
double *, double *, double *, int *, int *, int *, int *,
- int *, int *, int *, int *, int *, int *, int *, char **, int *);
+ int *, int *, int *, int *, int *, int *, int *, char **, int *, int *);
int Rast3d_write_header(RASTER3D_Map *, int, int, double, double, double, double,
double, double, int, int, int, double, double, double,
int, int, int, int, int, int, int, int, int, int, int,
- char *, int);
+ char *, int, int);
int Rast3d_rewrite_header(RASTER3D_Map * map);
int Rast3d_cache_size_encode(int, int);
int Rast3d__compute_cache_size(RASTER3D_Map *, int);
int Rast3d_fill_header(RASTER3D_Map *, int, int, int, int, int, int, int, int, int,
int, int, int, int, int, int, int, double, double, double,
double, double, double, int, int, int, double, double,
- double, char *, int);
+ double, char *, int, int);
/* headerinfo.c */
void Rast3d_get_coords_map(RASTER3D_Map *, int *, int *, int *);
void Rast3d_get_coords_map_window(RASTER3D_Map *, int *, int *, int *);
Modified: grass/trunk/include/raster3d.h
--- grass/trunk/include/raster3d.h 2013-03-20 01:58:48 UTC (rev 55463)
+++ grass/trunk/include/raster3d.h 2013-03-20 08:19:55 UTC (rev 55464)
@@ -4,17 +4,16 @@
#include <grass/gis.h>
#include <grass/raster.h>
+#define RASTER3D_MAP_VERSION 2 /* Second version of the raster 3D map layout.
+ * Old maps withput version information are
+ * defined as version == 1 when reading the header.
#define RASTER3D_TILE_SAME_AS_FILE 2
#define RASTER3D_NO_COMPRESSION 0
#define RASTER3D_COMPRESSION 1
-#define RASTER3D_USE_LZW 1
-#define RASTER3D_NO_LZW 0
-#define RASTER3D_USE_RLE 1
-#define RASTER3D_NO_RLE 0
#define RASTER3D_MAX_PRECISION -1
#define RASTER3D_NO_CACHE 0
@@ -72,6 +71,7 @@
typedef struct RASTER3D_Map
+ int version; /* The version of the raster 3D map layout */
char *fileName;
char *tempName;
@@ -110,10 +110,10 @@
/* data concering the compression */
int precision; /* RASTER3D_MAX_PRECISION or, 0 .. 23 for float,
0 .. 52 for double */
- int compression; /* RASTER3D_NO_COMPRESSION or RASTER3D_USE_COMPRESSION */
- int useLzw; /* RASTER3D_USE_LZW or RASTER3D_NO_LZW */
- int useRle; /* RASTER3D_USE_RLE or RASTER3D_NO_RLE */
- int useXdr; /* RASTER3D_USE_XDR or RASTER3D_NO_XDR */
+ int compression; /* RASTER3D_NO_COMPRESSION or RASTER3D_COMPRESSION */
+ int useLzw; /* RASTER3D_USE_LZW or RASTER3D_NO_LZW !!! only kept for backward compatibility */
+ int useRle; /* RASTER3D_USE_RLE or RASTER3D_NO_RLE !!! only kept for backward compatibility */
+ int useXdr; /* RASTER3D_USE_XDR or RASTER3D_NO_XDR !!! only kept for backward compatibility */
/* pointer to first tile in file */
int offset;
@@ -158,7 +158,7 @@
int useCache; /* 1 if cache is used */
void *cache; /* pointer to cache structure */
- int cacheFD; /* file discriptor of cache file -- write mode only */
+ int cacheFD; /* file descriptor of cache file -- write mode only */
char *cacheFileName; /* filename of cache file -- write mode only */
long cachePosLast; /* position of last entry in cache file -- write */
/* mode only */
