[GRASS-SVN] r55465 - grass-addons/grass6/raster/r.rdfilter
svn_grass at osgeo.org
Wed Mar 20 04:53:14 PDT 2013
Author: jradinger
Date: 2013-03-20 04:53:13 -0700 (Wed, 20 Mar 2013)
New Revision: 55465
grass-addons/grass6/raster/r.rdfilter/r.rdfilter.py
stop criterion (stop points based on r.cost) implemented.
Working, but not extensively tested yet.
Modified: grass-addons/grass6/raster/r.rdfilter/r.rdfilter.py
--- grass-addons/grass6/raster/r.rdfilter/r.rdfilter.py 2013-03-20 08:19:55 UTC (rev 55464)
+++ grass-addons/grass6/raster/r.rdfilter/r.rdfilter.py 2013-03-20 11:53:13 UTC (rev 55465)
@@ -22,6 +22,13 @@
#% required: yes
#%end
#%option
+#% key: stop_points
+#% type: string
+#% gisprompt: old,vector, vector
+#% description: stop point vector for r.cost
+#% required: no
+#%end
+#%option
#% key: output
#% type: string
#% gisprompt: new,cell,raster
@@ -87,6 +94,7 @@
# Defining variables
input_map = options['input']
distance = options['distance']
+ stop_points = options['stop_points']
if options['output']:
output_map = str(options['output'])
else:
@@ -135,13 +143,23 @@
# creating "focal distance mask" (using r.cost with a specified distance as input)
- grass.run_command("r.cost",
- flags = 'n',
- overwrite = True,
- max_cost = distance,
- input = "tmp"+str(os.getpid()),
- output = "distance_mask"+str(os.getpid()),
- coordinate = coors)
+ if options['stop_points']:
+ grass.run_command("r.cost",
+ flags = 'n',
+ overwrite = True,
+ max_cost = distance,
+ stop_points = stop_points,
+ input = "tmp"+str(os.getpid()),
+ output = "distance_mask"+str(os.getpid()),
+ coordinate = coors)
+ else:
+ flags = 'n',
+ overwrite = True,
# creating "masked map" based on input
grass.mapcalc("$masked_map= if(!isnull($distance_mask),$input_map,null())",
