[GRASS-SVN] r55476 - grass/trunk/lib/vector
svn_grass at osgeo.org
Thu Mar 21 04:02:34 PDT 2013
Author: wenzeslaus
Date: 2013-03-21 04:02:33 -0700 (Thu, 21 Mar 2013)
New Revision: 55476
Added:
grass/trunk/lib/vector/vectorlib_lists.dox
grass/trunk/lib/vector/vectorlib.dox
vlib/dox: moving lists of funs and structs to a separate page
Modified: grass/trunk/lib/vector/vectorlib.dox
--- grass/trunk/lib/vector/vectorlib.dox 2013-03-21 09:39:59 UTC (rev 55475)
+++ grass/trunk/lib/vector/vectorlib.dox 2013-03-21 11:02:33 UTC (rev 55476)
@@ -12,6 +12,7 @@
- \subpage vlibAscii
- \subpage vlibTin
- \subpage vlibFAQ
+- \subpage vlibLists
\par Data providers for external formats
- \subpage vlibOgr
@@ -308,62 +309,6 @@
(maintained with <tt>db.connect</tt> command at user level).
-\section vlibStructures Vector library data structures
-All data structure used by the vector library are defined in
-include/vect/dig_structs.h. See the list bellow:
-Major:
-- \ref Map_info
-- \ref Plus_head
-- \ref dig_head
-Supporting:
-- \ref bound_box
-- \ref gvfile
-- \ref Port_info
-- \ref Coor_info
-- \ref spatial_index
-Format-related:
-- \ref Format_info
-- \ref Format_info_ogr
-DB-related:
-- \ref field_info
-- \ref dblinks
-Geometry-related:
-- \ref line_pnts
-Category-related:
-- \ref line_cats
-- \ref cat_list
-- \ref Cat_index
-Topology-related:
-- \ref P_node
-- \ref P_line
-- \ref P_area
-- \ref P_isle
-Misc:
-- \ref ilist
-- \ref varray
-Obsolete:
-- \ref site_att
-- \ref recycle
\section vlibGeometry Vector library feature geometry
\subsection vlibFeatureTypes Feature types
@@ -388,802 +333,6 @@
volumetric figures.
-\section vlibFunc List of vector library functions
-The vector library provides the GRASS programmer with routines to
-process vector data. The routines in the vector library are presented
-in functional groupings, rather than in alphabetical order. The order
-of presentation will, it is hoped, provide better understanding of how
-the library is to be used, as well as show the interrelationships
-among the various routines. Note that a good way to understand how to
-use these routines is to look at the source code for GRASS modules
-which use them.
-Note: All routines start with one of following prefixes Vect_, V1_,
-V2_ or dig_. To avoid name conficts, programmers should not create
-variables or routines in their own modules which use this prefix.
-The Vect_*() functions are the programmer's API for GRASS vector
-programming. The programmer should use only routines with this prefix.
-\section vlibArea Vector area functions
- - Vect_get_area_area()
- - Vect_get_area_boundaries()
- - Vect_get_area_centroid()
- - Vect_get_area_isle()
- - Vect_get_area_num_isles()
- - Vect_area_perimeter()
- - Vect_get_area_points()
- - Vect_get_isle_area()
- - Vect_get_isle_boundaries()
- - Vect_get_isle_points()
- - Vect_point_in_area()
-\section vlibArray Vector array functions
- - Vect_new_varray()
- - Vect_set_varray_from_cat_list()
- - Vect_set_varray_from_cat_string()
- - Vect_set_varray_from_db()
-\section vlibBox Vector bounding box functions
- - Vect_box_copy()
- - Vect_box_clip()
- - Vect_box_extend()
- - Vect_box_overlap()
- - Vect_get_area_box()
- - Vect_get_isle_box()
- - Vect_get_line_box()
- - Vect_get_map_box()
- - Vect_point_in_box()
- - Vect_region_box()
-\section vlibBreakLines Vector break lines functions
- - Vect_break_lines()
- - Vect_break_lines_list()
-\section vlibBreakPolygons Vector break polygons functions
- - Vect_break_polygons()
-\section vlibBridges Vector bridges functions
- - Vect_chtype_bridges()
- - Vect_remove_bridges()
-\section vlibBuffer Vector buffer functions
- - Vect_line_buffer()
- - Vect_line_parallel()
-\section vlibBuild Vector build functions
- - Vect_build()
- - Vect_build_partial()
- - Vect_get_built()
- - Vect_build_sidx_from_topo()
- - Vect_build_sidx()
- - Vect_save_sidx()
- - Vect_save_topo()
- - Vect_sidx_dump()
- - Vect_topo_dump()
-\subsection vlibBuildNat Vector build (native) functions
- - Vect_attach_centroids()
- - Vect_attach_isle()
- - Vect_attach_isles()
- - Vect_build_line_area()
- - Vect_build_nat()
- - Vect_isle_find_area()
-\subsection vlibBuildOgr Vector build (OGR) functions
- - Vect_build_ogr()
-\section vlibCats Vector categories functions
- - Vect_array_to_cat_list()
- - Vect_cat_del()
- - Vect_cat_get()
- - Vect_cat_in_array()
- - Vect_cat_in_cat_list()
- - Vect_cat_set()
- - Vect_destroy_cat_list()
- - Vect_destroy_cats_struct()
- - Vect_field_cat_del()
- - Vect_get_area_cats()
- - Vect_get_area_cat()
- - Vect_get_line_cat()
- - Vect_new_cat_list()
- - Vect_new_cats_struct()
- - Vect_reset_cats()
- - Vect_str_to_cat_list()
-\section vlibCindex Vector category index functions
-(note: vector layer is historically called "field")
- - Vect_cidx_dump()
- - Vect_cidx_find_next()
- - Vect_cidx_find_all()
- - Vect_cidx_get_cat_by_index()
- - Vect_cidx_get_field_index()
- - Vect_cidx_get_field_number()
- - Vect_cidx_get_num_cats_by_index()
- - Vect_cidx_get_num_fields()
- - Vect_cidx_get_num_types_by_index()
- - Vect_cidx_get_num_unique_cats_by_index()
- - Vect_cidx_get_type_count()
- - Vect_cidx_get_type_count_by_index()
- - Vect_cidx_open()
- - Vect_cidx_save()
- - Vect_set_category_index_update()
-\section vlibCleanNodes Vector clean nodes functions
- - Vect_clean_small_angles_at_nodes()
-\section vlibClose Vector close functions
- - Vect_close()
-\section vlibConstraint Vector constraint functions
- - Vect_get_constraint_box()
- - Vect_remove_constraints()
- - Vect_set_constraint_region()
- - Vect_set_constraint_type()
-\section vlibDangles Vector dangles functions
- - Vect_chtype_dangles()
- - Vect_remove_dangles()
- - Vect_select_dangles()
-\section vlibDbcolumns Vector dbcolumns functions
- - Vect_get_column_names()
- - Vect_get_column_names_types()
- - Vect_get_column_types()
-\section vlibError Vector error functions
- - Vect_get_fatal_error()
- - Vect_set_fatal_error()
-\section vlibField Vector field functions
- - Vect_add_dblink()
- - Vect_check_dblink()
- - Vect_default_field_info()
- - Vect_get_dblink()
- - Vect_get_field()
- - Vect_get_field_by_name()
- - Vect_map_add_dblink()
- - Vect_map_check_dblink()
- - Vect_map_del_dblink()
- - Vect_new_dblinks_struct()
- - Vect_read_dblinks()
- - Vect_reset_dblinks()
- - Vect_set_db_updated()
- - Vect_subst_var()
- - Vect_write_dblinks()
-\section vlibFind Vector find functions
- - Vect_find_area()
- - Vect_find_island()
- - Vect_find_line()
- - Vect_find_line_list()
- - Vect_find_node()
-\section vlibGraph Vector graph functions
- - Vect_graph_add_edge()
- - Vect_graph_build()
- - Vect_graph_init()
- - Vect_graph_set_node_costs()
- - Vect_graph_shortest_path()
-\section vlibHeader Vector header functions
- - Vect_get_comment()
- - Vect_get_date()
- - Vect_get_full_name()
- - Vect_get_map_date()
- - Vect_get_map_name()
- - Vect_get_mapset()
- - Vect_get_name()
- - Vect_get_organization()
- - Vect_get_person()
- - Vect_get_proj()
- - Vect_get_proj_name()
- - Vect_get_scale()
- - Vect_get_thresh()
- - Vect_get_zone()
- - Vect_is_3d()
- - Vect_print_header()
- - Vect_read_header()
- - Vect_set_comment()
- - Vect_set_date()
- - Vect_set_map_date()
- - Vect_set_map_name()
- - Vect_set_organization()
- - Vect_set_person()
- - Vect_set_scale()
- - Vect_set_thresh()
- - Vect_set_zone()
- - Vect_write_header()
-\section vlibHist Vector history functions
- - Vect_hist_command()
- - Vect_hist_copy()
- - Vect_hist_read()
- - Vect_hist_rewind()
- - Vect_hist_write()
-\section vlibInitHead Vector header functions
- - Vect_copy_head_data()
-\section vlibIntersect Vector intersection functions
- - Vect_line_check_intersection()
- - Vect_line_intersection()
- - Vect_segment_intersection()
-\section vlibLegalVname Vector valid map name functions
- - Vect_check_input_output_name()
- - Vect_legal_filename()
-\section vlibLevel Vector level functions
- - Vect_level()
-\section vlibLevelTwo Vector topological (level 2) functions
- - Vect_get_centroid_area()
- - Vect_get_line_areas()
- - Vect_get_line_nodes()
- - Vect_get_node_coor()
- - Vect_get_node_line()
- - Vect_get_node_line_angle()
- - Vect_get_node_n_lines()
- - Vect_get_num_areas()
- - Vect_get_num_dblinks()
- - Vect_get_num_faces()
- - Vect_get_num_islands()
- - Vect_get_num_lines()
- - Vect_get_num_nodes()
- - Vect_get_num_primitives()
- - Vect_get_num_updated_lines()
- - Vect_get_num_updated_nodes()
- - Vect_get_updated_line()
- - Vect_get_updated_node()
- - Vect_set_release_support()
-\section vlibLine Vector feature functions
- - Vect_append_point()
- - Vect_append_points()
- - Vect_copy_pnts_to_xyz()
- - Vect_copy_xyz_to_pnts()
- - Vect_destroy_line_struct()
- - Vect_get_num_line_points()
- - Vect_line_box()
- - Vect_line_delete_point()
- - Vect_line_distance()
- - Vect_line_geodesic_length()
- - Vect_line_get_point()
- - Vect_line_insert_point()
- - Vect_line_length()
- - Vect_line_prune()
- - Vect_line_prune_thresh()
- - Vect_line_reverse()
- - Vect_line_segment()
- - Vect_new_line_struct()
- - Vect_point_on_line()
- - Vect_points_distance()
- - Vect_reset_line()
-\section vlibList Vector list functions
- - Vect_destroy_list()
- - Vect_list_append()
- - Vect_list_append_list()
- - Vect_list_delete()
- - Vect_list_delete_list()
- - Vect_new_list()
- - Vect_reset_list()
- - Vect_val_in_list()
- - Vect_destroy_boxlist()
- - Vect_boxlist_append()
- - Vect_boxlist_append_boxlist()
- - Vect_boxlist_delete()
- - Vect_boxlist_delete_boxlist()
- - Vect_new_boxlist()
- - Vect_reset_boxlist()
- - Vect_val_in_boxlist()
-\section vlibMap Vector map functions
- - Vect_copy()
- - Vect_copy_map_lines()
- - Vect_copy_table()
- - Vect_copy_table_by_cats()
- - Vect_copy_tables()
- - Vect_delete()
- - Vect_rename()
-\section vlibMergeLines Vector merge line functions
- - Vect_merge_lines()
-\section vlibNet Vector network functions
- - Vect_net_build_graph()
- - Vect_net_get_line_cost()
- - Vect_net_get_node_cost()
- - Vect_net_nearest_nodes()
- - Vect_net_shortest_path()
- - Vect_net_shortest_path_coor()
-\section vlibOpen Vector open functions
- - Vect_coor_info()
- - Vect_maptype_info()
- - Vect_maptype()
- - Vect_open_new()
- - Vect__open_old()
- - Vect_open_old()
- - Vect_open_old_head()
- - Vect_open_sidx()
- - Vect_open_topo()
- - Vect_open_update()
- - Vect_open_update_head()
- - Vect_set_open_level()
-\section vlibOverlay Vector overlay functions
- - Vect_overlay()
- - Vect_overlay_str_to_operator()
-\section vlibVpoly Vector polygon functions
- - Vect_find_poly_centroid()
- - Vect_get_point_in_area()
- - Vect_point_in_area_outer_ring()
- - Vect_point_in_island()
- - Vect_get_point_in_poly()
- - Vect_get_point_in_poly_isl()
-\section vlibRead Vector read functions
-\subsection vlibread1_2 Level 1 and 2
- - Vect_read_next_line()
-\subsection vlibRead2 Level 2 only
- - Vect_area_alive()
- - Vect_isle_alive()
- - Vect_line_alive()
- - Vect_node_alive()
- - Vect_read_line()
-\section vlibRemoveAreas Vector remove areas functions
- - Vect_remove_small_areas()
-\section vlibRemoveDuplicates Vector remove duplicates functions
- - Vect_line_check_duplicate()
- - Vect_remove_duplicates()
-\section vlibRewind Vector rewind functions
- - Vect_rewind()
-\section vlibSelect Vector select functions
- - Vect_select_areas_by_box()
- - Vect_select_areas_by_polygon()
- - Vect_select_isles_by_box()
- - Vect_select_lines_by_box()
- - Vect_select_lines_by_polygon()
- - Vect_select_nodes_by_box()
-\section vlibSindex Vector spatial index functions
- - Vect_spatial_index_add_item()
- - Vect_spatial_index_del_item()
- - Vect_spatial_index_destroy()
- - Vect_spatial_index_init()
- - Vect_spatial_index_select()
-\section vlibSnap Vector snap functions
- - Vect_snap_lines()
- - Vect_snap_lines_list()
-\section vlibTinFuns Vector TIN functions
- - Vect_tin_get_z()
-\section vlibType Vector type option functions
- - Vect_option_to_types()
-\section vlibDelete Vector delete functions
-\subsection vlibDelete2 Level 2 only
- - Vect_delete_line()
-\section vlibWrite Vector write functions
-\subsection vlibWrite1_2 Level 1 and 2
- - Vect_write_line()
-\subsection vlibWrite2 Level 2 only
- - Vect_rewrite_line()
-\subsection vlibAsciiFn Vector ASCII functions
- - Vect_read_ascii()
- - Vect_read_ascii_head()
- - Vect_write_ascii()
- - Vect_write_ascii_head()
-\subsection vlibSFAFn Vector Simple Feature Access API
-Functions from GRASS Simple Feature API (in progress, incomplete).
- - Vect_sfa_get_line_type()
- - Vect_sfa_check_line_type()
- - Vect_sfa_line_dimension()
- - Vect_sfa_line_geometry_type()
- - Vect_sfa_line_astext()
- - Vect_sfa_is_line_simple()
- - Vect_sfa_is_line_closed()
-\section vlibGeosFn Vector GEOS functions
-Note: The functions are available only if GRASS is compiled with
-<tt>--with-geos</tt> switch.
- - Vect_read_line_geos()
- - Vect_read_area_geos()
- - Vect_line_to_geos()
- - Vect_get_area_points_geos()
- - Vect_get_isle_points_geos()
-\section vlibPgFn Vector PostgreSQL/PostGIS functions
-<tt>--with-postgres</tt> switch.
- - Vect_open_topo_pg()
- - Vect_build_pg()
-(For internal use only)
- - V1_open_old_pg(), V2_open_old_pg() called by Vect_open_old()
- - V1_open_new_pg(), V2_open_new_pg() called by Vect_open_new()
- - V1_rewind_pg(), V2_rewind_pg() called by Vect_rewind()
- - V1_close_pg(), V2_close_pg() called by Vect_close()
- - V1_read_line_pg(), V2_read_line_pg() called by Vect_read_line()
- - V1_read_next_line_pg(), V2_read_next_line_pg() called by Vect_read_next_line()
- - V1_delete_line_pg(), V2_delete_line_sfa() called by Vect_delete_line()
- - V1_write_line_pg(), V2_write_line_pg() called by Vect_write_line()
- - V1_rewrite_line_pg(), V2_rewrite_line_sfa() called by Vect_rewrite_line()
- - V2_write_area_pg(), see <tt>v.out.postgis</tt> for implementation issues
\section vlibAuthors Authors
- Radim Blazek (vector architecture) <radim.blazek gmail.com>
Added: grass/trunk/lib/vector/vectorlib_lists.dox
--- grass/trunk/lib/vector/vectorlib_lists.dox (rev 0)
+++ grass/trunk/lib/vector/vectorlib_lists.dox 2013-03-21 11:02:33 UTC (rev 55476)
@@ -0,0 +1,860 @@
+/*! \page vlibLists Vector Library Stuctures and Functions
+by GRASS Development Team (http://grass.osgeo.org)
+\tableofcontents
+\section vlibStructures Vector library data structures
+All data structure used by the vector library are defined in
+include/vect/dig_structs.h. See the list bellow:
+Major:
+- \ref Map_info
+- \ref Plus_head
+- \ref dig_head
+Supporting:
+- \ref bound_box
+- \ref gvfile
+- \ref Port_info
+- \ref Coor_info
+- \ref spatial_index
+Format-related:
+- \ref Format_info
+- \ref Format_info_ogr
+DB-related:
+- \ref field_info
+- \ref dblinks
+Geometry-related:
+- \ref line_pnts
+Category-related:
+- \ref line_cats
+- \ref cat_list
+- \ref Cat_index
+Topology-related:
+- \ref P_node
+- \ref P_line
+- \ref P_area
+- \ref P_isle
+Misc:
+- \ref ilist
+- \ref varray
+Obsolete:
+- \ref site_att
+- \ref recycle
+\section vlibFunc List of vector library functions
+The vector library provides the GRASS programmer with routines to
+process vector data. The routines in the vector library are presented
+in functional groupings, rather than in alphabetical order. The order
+of presentation will, it is hoped, provide better understanding of how
+the library is to be used, as well as show the interrelationships
+among the various routines. Note that a good way to understand how to
+use these routines is to look at the source code for GRASS modules
+which use them.
+Note: All routines start with one of following prefixes Vect_, V1_,
+V2_ or dig_. To avoid name conficts, programmers should not create
+variables or routines in their own modules which use this prefix.
+The Vect_*() functions are the programmer's API for GRASS vector
+programming. The programmer should use only routines with this prefix.
+\section vlibArea Vector area functions
+ - Vect_get_area_area()
+ - Vect_get_area_boundaries()
+ - Vect_get_area_centroid()
+ - Vect_get_area_isle()
+ - Vect_get_area_num_isles()
+ - Vect_area_perimeter()
+ - Vect_get_area_points()
+ - Vect_get_isle_area()
+ - Vect_get_isle_boundaries()
+ - Vect_get_isle_points()
+ - Vect_point_in_area()
+\section vlibArray Vector array functions
+ - Vect_new_varray()
+ - Vect_set_varray_from_cat_list()
+ - Vect_set_varray_from_cat_string()
+ - Vect_set_varray_from_db()
+\section vlibBox Vector bounding box functions
+ - Vect_box_copy()
+ - Vect_box_clip()
+ - Vect_box_extend()
+ - Vect_box_overlap()
+ - Vect_get_area_box()
+ - Vect_get_isle_box()
+ - Vect_get_line_box()
+ - Vect_get_map_box()
+ - Vect_point_in_box()
+ - Vect_region_box()
+\section vlibBreakLines Vector break lines functions
+ - Vect_break_lines()
+ - Vect_break_lines_list()
+\section vlibBreakPolygons Vector break polygons functions
+ - Vect_break_polygons()
+\section vlibBridges Vector bridges functions
+ - Vect_chtype_bridges()
+ - Vect_remove_bridges()
+\section vlibBuffer Vector buffer functions
+ - Vect_line_buffer()
+ - Vect_line_parallel()
+\section vlibBuild Vector build functions
+ - Vect_build()
+ - Vect_build_partial()
+ - Vect_get_built()
+ - Vect_build_sidx_from_topo()
+ - Vect_build_sidx()
+ - Vect_save_sidx()
+ - Vect_save_topo()
+ - Vect_sidx_dump()
+ - Vect_topo_dump()
+\subsection vlibBuildNat Vector build (native) functions
+ - Vect_attach_centroids()
+ - Vect_attach_isle()
+ - Vect_attach_isles()
+ - Vect_build_line_area()
+ - Vect_build_nat()
+ - Vect_isle_find_area()
+\subsection vlibBuildOgr Vector build (OGR) functions
+ - Vect_build_ogr()
+\section vlibCats Vector categories functions
+ - Vect_array_to_cat_list()
+ - Vect_cat_del()
+ - Vect_cat_get()
+ - Vect_cat_in_array()
+ - Vect_cat_in_cat_list()
+ - Vect_cat_set()
+ - Vect_destroy_cat_list()
+ - Vect_destroy_cats_struct()
+ - Vect_field_cat_del()
+ - Vect_get_area_cats()
+ - Vect_get_area_cat()
+ - Vect_get_line_cat()
+ - Vect_new_cat_list()
+ - Vect_new_cats_struct()
+ - Vect_reset_cats()
+ - Vect_str_to_cat_list()
+\section vlibCindex Vector category index functions
+(note: vector layer is historically called "field")
+ - Vect_cidx_dump()
+ - Vect_cidx_find_next()
+ - Vect_cidx_find_all()
+ - Vect_cidx_get_cat_by_index()
+ - Vect_cidx_get_field_index()
+ - Vect_cidx_get_field_number()
+ - Vect_cidx_get_num_cats_by_index()
+ - Vect_cidx_get_num_fields()
+ - Vect_cidx_get_num_types_by_index()
+ - Vect_cidx_get_num_unique_cats_by_index()
+ - Vect_cidx_get_type_count()
+ - Vect_cidx_get_type_count_by_index()
+ - Vect_cidx_open()
+ - Vect_cidx_save()
+ - Vect_set_category_index_update()
+\section vlibCleanNodes Vector clean nodes functions
+ - Vect_clean_small_angles_at_nodes()
+\section vlibClose Vector close functions
+ - Vect_close()
+\section vlibConstraint Vector constraint functions
+ - Vect_get_constraint_box()
+ - Vect_remove_constraints()
+ - Vect_set_constraint_region()
+ - Vect_set_constraint_type()
+\section vlibDangles Vector dangles functions
+ - Vect_chtype_dangles()
+ - Vect_remove_dangles()
+ - Vect_select_dangles()
+\section vlibDbcolumns Vector dbcolumns functions
+ - Vect_get_column_names()
+ - Vect_get_column_names_types()
+ - Vect_get_column_types()
+\section vlibError Vector error functions
+ - Vect_get_fatal_error()
+ - Vect_set_fatal_error()
+\section vlibField Vector field functions
+ - Vect_add_dblink()
+ - Vect_check_dblink()
+ - Vect_default_field_info()
+ - Vect_get_dblink()
+ - Vect_get_field()
+ - Vect_get_field_by_name()
+ - Vect_map_add_dblink()
+ - Vect_map_check_dblink()
+ - Vect_map_del_dblink()
+ - Vect_new_dblinks_struct()
+ - Vect_read_dblinks()
+ - Vect_reset_dblinks()
+ - Vect_set_db_updated()
+ - Vect_subst_var()
+ - Vect_write_dblinks()
+\section vlibFind Vector find functions
+ - Vect_find_area()
+ - Vect_find_island()
+ - Vect_find_line()
+ - Vect_find_line_list()
+ - Vect_find_node()
+\section vlibGraph Vector graph functions
+ - Vect_graph_add_edge()
+ - Vect_graph_build()
+ - Vect_graph_init()
+ - Vect_graph_set_node_costs()
+ - Vect_graph_shortest_path()
+\section vlibHeader Vector header functions
+ - Vect_get_comment()
+ - Vect_get_date()
+ - Vect_get_full_name()
+ - Vect_get_map_date()
+ - Vect_get_map_name()
+ - Vect_get_mapset()
+ - Vect_get_name()
+ - Vect_get_organization()
+ - Vect_get_person()
+ - Vect_get_proj()
+ - Vect_get_proj_name()
+ - Vect_get_scale()
+ - Vect_get_thresh()
+ - Vect_get_zone()
+ - Vect_is_3d()
+ - Vect_print_header()
+ - Vect_read_header()
+ - Vect_set_comment()
+ - Vect_set_date()
+ - Vect_set_map_date()
+ - Vect_set_map_name()
+ - Vect_set_organization()
+ - Vect_set_person()
+ - Vect_set_scale()
+ - Vect_set_thresh()
+ - Vect_set_zone()
+ - Vect_write_header()
+\section vlibHist Vector history functions
+ - Vect_hist_command()
+ - Vect_hist_copy()
+ - Vect_hist_read()
+ - Vect_hist_rewind()
+ - Vect_hist_write()
+\section vlibInitHead Vector header functions
+ - Vect_copy_head_data()
+\section vlibIntersect Vector intersection functions
+ - Vect_line_check_intersection()
+ - Vect_line_intersection()
+ - Vect_segment_intersection()
+\section vlibLegalVname Vector valid map name functions
+ - Vect_check_input_output_name()
+ - Vect_legal_filename()
+\section vlibLevel Vector level functions
+ - Vect_level()
+\section vlibLevelTwo Vector topological (level 2) functions
+ - Vect_get_centroid_area()
+ - Vect_get_line_areas()
+ - Vect_get_line_nodes()
+ - Vect_get_node_coor()
+ - Vect_get_node_line()
+ - Vect_get_node_line_angle()
+ - Vect_get_node_n_lines()
+ - Vect_get_num_areas()
+ - Vect_get_num_dblinks()
+ - Vect_get_num_faces()
+ - Vect_get_num_islands()
+ - Vect_get_num_lines()
+ - Vect_get_num_nodes()
+ - Vect_get_num_primitives()
+ - Vect_get_num_updated_lines()
+ - Vect_get_num_updated_nodes()
+ - Vect_get_updated_line()
+ - Vect_get_updated_node()
+ - Vect_set_release_support()
+\section vlibLine Vector feature functions
+ - Vect_append_point()
+ - Vect_append_points()
+ - Vect_copy_pnts_to_xyz()
+ - Vect_copy_xyz_to_pnts()
+ - Vect_destroy_line_struct()
+ - Vect_get_num_line_points()
+ - Vect_line_box()
+ - Vect_line_delete_point()
+ - Vect_line_distance()
+ - Vect_line_geodesic_length()
+ - Vect_line_get_point()
+ - Vect_line_insert_point()
+ - Vect_line_length()
+ - Vect_line_prune()
+ - Vect_line_prune_thresh()
+ - Vect_line_reverse()
+ - Vect_line_segment()
+ - Vect_new_line_struct()
+ - Vect_point_on_line()
+ - Vect_points_distance()
+ - Vect_reset_line()
+\section vlibList Vector list functions
+ - Vect_destroy_list()
+ - Vect_list_append()
+ - Vect_list_append_list()
+ - Vect_list_delete()
+ - Vect_list_delete_list()
+ - Vect_new_list()
+ - Vect_reset_list()
+ - Vect_val_in_list()
+ - Vect_destroy_boxlist()
+ - Vect_boxlist_append()
+ - Vect_boxlist_append_boxlist()
+ - Vect_boxlist_delete()
+ - Vect_boxlist_delete_boxlist()
+ - Vect_new_boxlist()
+ - Vect_reset_boxlist()
+ - Vect_val_in_boxlist()
+\section vlibMap Vector map functions
+ - Vect_copy()
+ - Vect_copy_map_lines()
+ - Vect_copy_table()
+ - Vect_copy_table_by_cats()
+ - Vect_copy_tables()
+ - Vect_delete()
+ - Vect_rename()
+\section vlibMergeLines Vector merge line functions
+ - Vect_merge_lines()
+\section vlibNet Vector network functions
+ - Vect_net_build_graph()
+ - Vect_net_get_line_cost()
+ - Vect_net_get_node_cost()
+ - Vect_net_nearest_nodes()
+ - Vect_net_shortest_path()
+ - Vect_net_shortest_path_coor()
+\section vlibOpen Vector open functions
+ - Vect_coor_info()
+ - Vect_maptype_info()
+ - Vect_maptype()
+ - Vect_open_new()
+ - Vect__open_old()
+ - Vect_open_old()
+ - Vect_open_old_head()
+ - Vect_open_sidx()
+ - Vect_open_topo()
+ - Vect_open_update()
+ - Vect_open_update_head()
+ - Vect_set_open_level()
+\section vlibOverlay Vector overlay functions
+ - Vect_overlay()
+ - Vect_overlay_str_to_operator()
+\section vlibVpoly Vector polygon functions
+ - Vect_find_poly_centroid()
+ - Vect_get_point_in_area()
+ - Vect_point_in_area_outer_ring()
+ - Vect_point_in_island()
+ - Vect_get_point_in_poly()
+ - Vect_get_point_in_poly_isl()
+\section vlibRead Vector read functions
+\subsection vlibread1_2 Level 1 and 2
+ - Vect_read_next_line()
+\subsection vlibRead2 Level 2 only
+ - Vect_area_alive()
+ - Vect_isle_alive()
+ - Vect_line_alive()
+ - Vect_node_alive()
+ - Vect_read_line()
+\section vlibRemoveAreas Vector remove areas functions
+ - Vect_remove_small_areas()
+\section vlibRemoveDuplicates Vector remove duplicates functions
+ - Vect_line_check_duplicate()
+ - Vect_remove_duplicates()
+\section vlibRewind Vector rewind functions
+ - Vect_rewind()
+\section vlibSelect Vector select functions
+ - Vect_select_areas_by_box()
+ - Vect_select_areas_by_polygon()
+ - Vect_select_isles_by_box()
+ - Vect_select_lines_by_box()
+ - Vect_select_lines_by_polygon()
+ - Vect_select_nodes_by_box()
+\section vlibSindex Vector spatial index functions
+ - Vect_spatial_index_add_item()
+ - Vect_spatial_index_del_item()
+ - Vect_spatial_index_destroy()
+ - Vect_spatial_index_init()
+ - Vect_spatial_index_select()
+\section vlibSnap Vector snap functions
+ - Vect_snap_lines()
+ - Vect_snap_lines_list()
+\section vlibTinFuns Vector TIN functions
+ - Vect_tin_get_z()
+\section vlibType Vector type option functions
+ - Vect_option_to_types()
+\section vlibDelete Vector delete functions
+\subsection vlibDelete2 Level 2 only
+ - Vect_delete_line()
+\section vlibWrite Vector write functions
+\subsection vlibWrite1_2 Level 1 and 2
+ - Vect_write_line()
+\subsection vlibWrite2 Level 2 only
+ - Vect_rewrite_line()
+\subsection vlibAsciiFn Vector ASCII functions
+ - Vect_read_ascii()
+ - Vect_read_ascii_head()
+ - Vect_write_ascii()
+ - Vect_write_ascii_head()
+\subsection vlibSFAFn Vector Simple Feature Access API
+Functions from GRASS Simple Feature API (in progress, incomplete).
+ - Vect_sfa_get_line_type()
+ - Vect_sfa_check_line_type()
+ - Vect_sfa_line_dimension()
+ - Vect_sfa_line_geometry_type()
+ - Vect_sfa_line_astext()
+ - Vect_sfa_is_line_simple()
+ - Vect_sfa_is_line_closed()
+\section vlibGeosFn Vector GEOS functions
+Note: The functions are available only if GRASS is compiled with
+<tt>--with-geos</tt> switch.
+ - Vect_read_line_geos()
+ - Vect_read_area_geos()
+ - Vect_line_to_geos()
+ - Vect_get_area_points_geos()
+ - Vect_get_isle_points_geos()
+\section vlibPgFn Vector PostgreSQL/PostGIS functions
+<tt>--with-postgres</tt> switch.
+ - Vect_open_topo_pg()
+ - Vect_build_pg()
+(For internal use only)
+ - V1_open_old_pg(), V2_open_old_pg() called by Vect_open_old()
+ - V1_open_new_pg(), V2_open_new_pg() called by Vect_open_new()
+ - V1_rewind_pg(), V2_rewind_pg() called by Vect_rewind()
+ - V1_close_pg(), V2_close_pg() called by Vect_close()
+ - V1_read_line_pg(), V2_read_line_pg() called by Vect_read_line()
+ - V1_read_next_line_pg(), V2_read_next_line_pg() called by Vect_read_next_line()
+ - V1_delete_line_pg(), V2_delete_line_sfa() called by Vect_delete_line()
+ - V1_write_line_pg(), V2_write_line_pg() called by Vect_write_line()
+ - V1_rewrite_line_pg(), V2_rewrite_line_sfa() called by Vect_rewrite_line()
+ - V2_write_area_pg(), see <tt>v.out.postgis</tt> for implementation issues
