[GRASS-SVN] r55477 - grass/trunk/lib/vector
svn_grass at osgeo.org
Thu Mar 21 04:06:12 PDT 2013
Author: wenzeslaus
Date: 2013-03-21 04:06:12 -0700 (Thu, 21 Mar 2013)
New Revision: 55477
grass/trunk/lib/vector/vectorlib_lists.dox
vlib/dox: improving lists of funs and structs page sectioning
Modified: grass/trunk/lib/vector/vectorlib_lists.dox
--- grass/trunk/lib/vector/vectorlib_lists.dox 2013-03-21 11:02:33 UTC (rev 55476)
+++ grass/trunk/lib/vector/vectorlib_lists.dox 2013-03-21 11:06:12 UTC (rev 55477)
@@ -4,18 +4,18 @@
\tableofcontents
-\section vlibStructures Vector library data structures
+\section vlibStructures List of vector library data structures
All data structure used by the vector library are defined in
-include/vect/dig_structs.h. See the list bellow:
+include/vect/dig_structs.h. See the lists bellow.
-Major:
+\subsection vlibStructuresMajor Major
- \ref Map_info
- \ref Plus_head
- \ref dig_head
-Supporting:
+\subsection vlibStructuresSupporting Supporting
- \ref bound_box
- \ref gvfile
@@ -23,39 +23,39 @@
- \ref Coor_info
- \ref spatial_index
-Format-related:
+\subsection vlibStructuresFormat-related Format-related
- \ref Format_info
- \ref Format_info_ogr
-DB-related:
+\subsection vlibStructuresDB-related DB-related
- \ref field_info
- \ref dblinks
-Geometry-related:
+\subsection vlibStructuresGeometry-related Geometry-related
- \ref line_pnts
-Category-related:
+\subsection vlibStructuresCategory-related Category-related
- \ref line_cats
- \ref cat_list
- \ref Cat_index
-Topology-related:
+\subsection vlibStructuresTopology-related Topology-related
- \ref P_node
- \ref P_line
- \ref P_area
- \ref P_isle
-Misc:
+\subsection vlibStructuresMisc Misc
- \ref ilist
- \ref varray
-Obsolete:
+\subsection vlibStructuresObsolete Obsolete
- \ref site_att
- \ref recycle
@@ -79,7 +79,7 @@
The Vect_*() functions are the programmer's API for GRASS vector
programming. The programmer should use only routines with this prefix.
-\section vlibArea Vector area functions
+\subsection vlibArea Vector area functions
- Vect_get_area_area()
@@ -104,7 +104,7 @@
- Vect_point_in_area()
-\section vlibArray Vector array functions
+\subsection vlibArray Vector array functions
- Vect_new_varray()
@@ -115,7 +115,7 @@
- Vect_set_varray_from_db()
-\section vlibBox Vector bounding box functions
+\subsection vlibBox Vector bounding box functions
- Vect_box_copy()
@@ -138,34 +138,36 @@
- Vect_region_box()
-\section vlibBreakLines Vector break lines functions
+\subsection vlibBreakLines Vector break lines functions
- Vect_break_lines()
- Vect_break_lines_list()
-\section vlibBreakPolygons Vector break polygons functions
+\subsection vlibBreakPolygons Vector break polygons functions
- Vect_break_polygons()
-\section vlibBridges Vector bridges functions
+\subsection vlibBridges Vector bridges functions
- Vect_chtype_bridges()
- Vect_remove_bridges()
-\section vlibBuffer Vector buffer functions
+\subsection vlibBuffer Vector buffer functions
- Vect_line_buffer()
- Vect_line_parallel()
-\section vlibBuild Vector build functions
+\subsection vlibBuild Vector build functions
+\subsubsection vlibBuildMain Main build functions
- Vect_build()
- Vect_build_partial()
@@ -185,7 +187,7 @@
- Vect_topo_dump()
-\subsection vlibBuildNat Vector build (native) functions
+\subsubsection vlibBuildNat Native build functions
- Vect_attach_centroids()
@@ -200,12 +202,12 @@
- Vect_isle_find_area()
-\subsection vlibBuildOgr Vector build (OGR) functions
+\subsubsection vlibBuildOgr OGR build functions
- Vect_build_ogr()
-\section vlibCats Vector categories functions
+\subsection vlibCats Vector categories functions
- Vect_array_to_cat_list()
@@ -240,52 +242,17 @@
- Vect_str_to_cat_list()
-\section vlibCindex Vector category index functions
+\subsection vlibCleanNodes Vector clean nodes functions
-(note: vector layer is historically called "field")
- - Vect_cidx_dump()
- - Vect_cidx_find_next()
- - Vect_cidx_find_all()
- - Vect_cidx_get_cat_by_index()
- - Vect_cidx_get_field_index()
- - Vect_cidx_get_field_number()
- - Vect_cidx_get_num_cats_by_index()
- - Vect_cidx_get_num_fields()
- - Vect_cidx_get_num_types_by_index()
- - Vect_cidx_get_num_unique_cats_by_index()
- - Vect_cidx_get_type_count()
- - Vect_cidx_get_type_count_by_index()
- - Vect_cidx_open()
- - Vect_cidx_save()
- - Vect_set_category_index_update()
-\section vlibCleanNodes Vector clean nodes functions
- Vect_clean_small_angles_at_nodes()
-\section vlibClose Vector close functions
+\subsection vlibClose Vector close functions
- Vect_close()
-\section vlibConstraint Vector constraint functions
+\subsection vlibConstraint Vector constraint functions
- Vect_get_constraint_box()
@@ -305,7 +272,7 @@
- Vect_select_dangles()
-\section vlibDbcolumns Vector dbcolumns functions
+\subsection vlibDbcolumns Vector dbcolumns functions
- Vect_get_column_names()
@@ -314,14 +281,14 @@
- Vect_get_column_types()
-\section vlibError Vector error functions
+\subsection vlibError Vector error functions
- Vect_get_fatal_error()
- Vect_set_fatal_error()
-\section vlibField Vector field functions
+\subsection vlibField Vector layer (field) functions
@@ -356,7 +323,7 @@
- Vect_write_dblinks()
-\section vlibFind Vector find functions
+\subsection vlibFind Vector find functions
- Vect_find_area()
@@ -369,7 +336,7 @@
- Vect_find_node()
-\section vlibGraph Vector graph functions
+\subsection vlibGraph Vector graph functions
- Vect_graph_add_edge()
@@ -382,7 +349,7 @@
- Vect_graph_shortest_path()
-\section vlibHeader Vector header functions
+\subsection vlibHeader Vector header functions
- Vect_get_comment()
@@ -441,7 +408,7 @@
- Vect_write_header()
-\section vlibHist Vector history functions
+\subsection vlibHist Vector history functions
- Vect_hist_command()
@@ -454,12 +421,12 @@
- Vect_hist_write()
-\section vlibInitHead Vector header functions
+\subsection vlibInitHead Vector header functions
- Vect_copy_head_data()
-\section vlibIntersect Vector intersection functions
+\subsection vlibIntersect Vector intersection functions
- Vect_line_check_intersection()
@@ -468,19 +435,19 @@
- Vect_segment_intersection()
-\section vlibLegalVname Vector valid map name functions
+\subsection vlibLegalVname Vector valid map name functions
- Vect_check_input_output_name()
- Vect_legal_filename()
-\section vlibLevel Vector level functions
+\subsection vlibLevel Vector level functions
- Vect_level()
-\section vlibLevelTwo Vector topological (level 2) functions
+\subsection vlibLevelTwo Vector topological (level 2) functions
- Vect_get_centroid_area()
@@ -521,7 +488,7 @@
- Vect_set_release_support()
-\section vlibLine Vector feature functions
+\subsection vlibLine Vector feature functions
- Vect_append_point()
@@ -566,7 +533,7 @@
- Vect_reset_line()
-\section vlibList Vector list functions
+\subsection vlibList Vector list functions
- Vect_destroy_list()
@@ -601,7 +568,7 @@
- Vect_val_in_boxlist()
-\section vlibMap Vector map functions
+\subsection vlibMap Vector map functions
- Vect_copy()
@@ -618,12 +585,12 @@
- Vect_rename()
-\section vlibMergeLines Vector merge line functions
+\subsection vlibMergeLines Vector merge line functions
- Vect_merge_lines()
-\section vlibNet Vector network functions
+\subsection vlibNet Vector network functions
- Vect_net_build_graph()
@@ -638,7 +605,7 @@
- Vect_net_shortest_path_coor()
-\section vlibOpen Vector open functions
+\subsection vlibOpen Vector open functions
- Vect_coor_info()
@@ -664,14 +631,14 @@
- Vect_set_open_level()
-\section vlibOverlay Vector overlay functions
+\subsection vlibOverlay Vector overlay functions
- Vect_overlay()
- Vect_overlay_str_to_operator()
-\section vlibVpoly Vector polygon functions
+\subsection vlibVpoly Vector polygon functions
- Vect_find_poly_centroid()
@@ -686,13 +653,13 @@
- Vect_get_point_in_poly_isl()
-\section vlibRead Vector read functions
+\subsection vlibRead Vector read functions
-\subsection vlibread1_2 Level 1 and 2
+\subsubsection vlibread1_2 Level 1 and 2
- Vect_read_next_line()
-\subsection vlibRead2 Level 2 only
+\subsubsection vlibRead2 Level 2 only
- Vect_area_alive()
@@ -705,24 +672,26 @@
- Vect_read_line()
-\section vlibRemoveAreas Vector remove areas functions
+\subsection vlibRemoveAreas Vector remove functions
+\subsubsection vlibRemoveAreas Vector remove areas functions
- Vect_remove_small_areas()
-\section vlibRemoveDuplicates Vector remove duplicates functions
+\subsubsection vlibRemoveDuplicates Vector remove duplicates functions
- Vect_line_check_duplicate()
- Vect_remove_duplicates()
-\section vlibRewind Vector rewind functions
+\subsection vlibRewind Vector rewind functions
- Vect_rewind()
-\section vlibSelect Vector select functions
+\subsection vlibSelect Vector select functions
- Vect_select_areas_by_box()
@@ -737,8 +706,11 @@
- Vect_select_nodes_by_box()
-\section vlibSindex Vector spatial index functions
+\subsection vlibIndex Vector index functions
+\subsubsection vlibSindex Vector spatial index functions
- Vect_spatial_index_add_item()
- Vect_spatial_index_del_item()
@@ -750,36 +722,71 @@
- Vect_spatial_index_select()
-\section vlibSnap Vector snap functions
+\subsection vlibCindex Vector category index functions
+(note: vector layer is historically called "field")
+ - Vect_cidx_dump()
+ - Vect_cidx_find_next()
+ - Vect_cidx_find_all()
+ - Vect_cidx_get_cat_by_index()
+ - Vect_cidx_get_field_index()
+ - Vect_cidx_get_field_number()
+ - Vect_cidx_get_num_cats_by_index()
+ - Vect_cidx_get_num_fields()
+ - Vect_cidx_get_num_types_by_index()
+ - Vect_cidx_get_num_unique_cats_by_index()
+ - Vect_cidx_get_type_count()
+ - Vect_cidx_get_type_count_by_index()
+ - Vect_cidx_open()
+ - Vect_cidx_save()
+ - Vect_set_category_index_update()
+\subsection vlibSnap Vector snap functions
- Vect_snap_lines()
- Vect_snap_lines_list()
-\section vlibTinFuns Vector TIN functions
+\subsection vlibTinFuns Vector TIN functions
- Vect_tin_get_z()
-\section vlibType Vector type option functions
+\subsection vlibType Vector type option functions
- Vect_option_to_types()
-\section vlibDelete Vector delete functions
+\subsection vlibDelete Vector delete functions
-\subsection vlibDelete2 Level 2 only
+\subsubsection vlibDelete2 Level 2 only
- Vect_delete_line()
-\section vlibWrite Vector write functions
+\subsection vlibWrite Vector write functions
-\subsection vlibWrite1_2 Level 1 and 2
+\subsubsection vlibWrite1_2 Level 1 and 2
- Vect_write_line()
-\subsection vlibWrite2 Level 2 only
+\subsubsection vlibWrite2 Level 2 only
- Vect_rewrite_line()
@@ -811,7 +818,7 @@
- Vect_sfa_is_line_closed()
-\section vlibGeosFn Vector GEOS functions
+\subsection vlibGeosFn Vector GEOS functions
Note: The functions are available only if GRASS is compiled with
<tt>--with-geos</tt> switch.
@@ -826,7 +833,7 @@
- Vect_get_isle_points_geos()
-\section vlibPgFn Vector PostgreSQL/PostGIS functions
+\subsection vlibPgFn Vector PostgreSQL/PostGIS functions
<tt>--with-postgres</tt> switch.
@@ -855,6 +862,7 @@
- V1_rewrite_line_pg(), V2_rewrite_line_sfa() called by Vect_rewrite_line()
- - V2_write_area_pg(), see <tt>v.out.postgis</tt> for implementation issues
+ - V2_write_area_pg(), see \gmod{v.out.postgis} for implementation issues
