[GRASS-SVN] r55520 - grass/trunk/vector/v.db.select
svn_grass at osgeo.org
Tue Mar 26 03:52:48 PDT 2013
Author: mmetz
Date: 2013-03-26 03:52:48 -0700 (Tue, 26 Mar 2013)
New Revision: 55520
grass/trunk/vector/v.db.select/main.c
v.db.select: change guisection
Modified: grass/trunk/vector/v.db.select/main.c
--- grass/trunk/vector/v.db.select/main.c 2013-03-26 09:03:11 UTC (rev 55519)
+++ grass/trunk/vector/v.db.select/main.c 2013-03-26 10:52:48 UTC (rev 55520)
@@ -55,7 +55,9 @@
module->description = _("Prints vector map attributes.");
map_opt = G_define_standard_option(G_OPT_V_MAP);
field_opt = G_define_standard_option(G_OPT_V_FIELD);
+ field_opt->guisection = _("Selection");
col_opt = G_define_standard_option(G_OPT_DB_COLUMNS);
col_opt->guisection = _("Selection");
