[GRASS-SVN] r55521 - grass/trunk
svn_grass at osgeo.org
Tue Mar 26 04:40:12 PDT 2013
Author: mmetz
Date: 2013-03-26 04:40:12 -0700 (Tue, 26 Mar 2013)
New Revision: 55521
grass/trunk/aclocal.m4
grass/trunk/configure
fix FreeBSD support
Modified: grass/trunk/aclocal.m4
--- grass/trunk/aclocal.m4 2013-03-26 10:52:48 UTC (rev 55520)
+++ grass/trunk/aclocal.m4 2013-03-26 11:40:12 UTC (rev 55521)
@@ -556,13 +556,15 @@
LD_LIBRARY_PATH_VAR="LD_LIBRARY_PATH"
*-freebsd*)
- # NOTE: only FreeBSD 4+ is supported
+ # NOTE: only FreeBSD 4+ is supported
# FreeBSD 3.* and greater have ELF.
SHLIB_CFLAGS="-fPIC"
- SHLIB_LD="ld -Bshareable -x"
+ #SHLIB_LD="ld -Bshareable -x"
+ SHLIB_LD="${CC} -shared"
SHLIB_SUFFIX=".so"
LDFLAGS="-export-dynamic"
- LD_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
+ #LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
+ LD_SEARCH_FLAGS='-Wl,-rpath-link,${LIB_RUNTIME_DIR}'
# TODO: add optional pthread support with any combination of:
# CFLAGS="$CFLAGS -pthread"
# LDFLAGS="$LDFLAGS -lpthread"
Modified: grass/trunk/configure
--- grass/trunk/configure 2013-03-26 10:52:48 UTC (rev 55520)
+++ grass/trunk/configure 2013-03-26 11:40:12 UTC (rev 55521)
@@ -1566,13 +1566,15 @@
*-freebsd*)
SHLIB_SUFFIX=".so"
@@ -2294,7 +2296,7 @@
# Done checking fortran
echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:2298: checking for additional include dirs" >&5
+echo "configure:2300: checking for additional include dirs" >&5
case "$with_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -2317,7 +2319,7 @@
# With libs option
echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:2321: checking for additional library dirs" >&5
+echo "configure:2323: checking for additional library dirs" >&5
case "$with_libs" in
{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -2351,7 +2353,7 @@
# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
# ./install, which can be erroneously created by make from ./install.sh.
echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:2355: checking for a BSD compatible install" >&5
+echo "configure:2357: checking for a BSD compatible install" >&5
if test -z "$INSTALL"; then
IFS="${IFS= }"; ac_save_IFS="$IFS"; IFS=":"
@@ -2404,7 +2406,7 @@
# Extract the first word of "flex", so it can be a program name with args.
set dummy flex; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:2408: checking for $ac_word" >&5
+echo "configure:2410: checking for $ac_word" >&5
if test -n "$LEX"; then
ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -2435,13 +2437,13 @@
*) ac_lib=l ;;
esac
echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:2439: checking for yywrap in -l$ac_lib" >&5
+echo "configure:2441: checking for yywrap in -l$ac_lib" >&5
ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-l$ac_lib $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 2445 "configure"
+#line 2447 "configure"
#include "confdefs.h"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -2452,7 +2454,7 @@
yywrap()
; return 0; }
EOF
-if { (eval echo configure:2456: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2458: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -2477,7 +2479,7 @@
# Extract the first word of "lex", so it can be a program name with args.
set dummy lex; ac_word=$2
-echo "configure:2481: checking for $ac_word" >&5
+echo "configure:2483: checking for $ac_word" >&5
case "$LEXPATH" in
@@ -2517,7 +2519,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:2521: checking for $ac_word" >&5
+echo "configure:2523: checking for $ac_word" >&5
if test -n "$YACC"; then
ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -2548,7 +2550,7 @@
# Extract the first word of "yacc", so it can be a program name with args.
set dummy yacc; ac_word=$2
-echo "configure:2552: checking for $ac_word" >&5
+echo "configure:2554: checking for $ac_word" >&5
case "$YACCPATH" in
@@ -2586,7 +2588,7 @@
# Extract the first word of "ranlib", so it can be a program name with args.
set dummy ranlib; ac_word=$2
-echo "configure:2590: checking for $ac_word" >&5
+echo "configure:2592: checking for $ac_word" >&5
if test -n "$RANLIB"; then
ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -2615,7 +2617,7 @@
-echo "configure:2619: checking for $ac_word" >&5
+echo "configure:2621: checking for $ac_word" >&5
if test -n "$AR"; then
ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -2646,7 +2648,7 @@
-echo "configure:2650: checking for $ac_word" >&5
+echo "configure:2652: checking for $ac_word" >&5
if test -n "$ENV"; then
ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -2675,7 +2677,7 @@
# Extract the first word of "perl", so it can be a program name with args.
set dummy perl; ac_word=$2
-echo "configure:2679: checking for $ac_word" >&5
+echo "configure:2681: checking for $ac_word" >&5
case "$PERL" in
@@ -2706,7 +2708,7 @@
fi
echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:2710: checking how to run the C preprocessor" >&5
+echo "configure:2712: checking how to run the C preprocessor" >&5
# On Suns, sometimes $CPP names a directory.
if test -n "$CPP" && test -d "$CPP"; then
CPP=
@@ -2719,13 +2721,13 @@
# On the NeXT, cc -E runs the code through the compiler's parser,
# not just through cpp.
-#line 2723 "configure"
+#line 2725 "configure"
#include <assert.h>
Syntax Error
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:2729: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2731: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
@@ -2736,13 +2738,13 @@
rm -rf conftest*
CPP="${CC-cc} -E -traditional-cpp"
-#line 2740 "configure"
+#line 2742 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:2746: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2748: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2753,13 +2755,13 @@
rm -rf conftest*
CPP="${CC-cc} -nologo -E"
-#line 2757 "configure"
+#line 2759 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:2763: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2765: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2783,10 +2785,10 @@
echo "$ac_t""$CPP" 1>&6
echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:2787: checking for ANSI C header files" >&5
+echo "configure:2789: checking for ANSI C header files" >&5
-#line 2790 "configure"
+#line 2792 "configure"
#include <stdlib.h>
#include <stdarg.h>
@@ -2794,7 +2796,7 @@
#include <float.h>
EOF
-{ (eval echo configure:2798: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2800: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2811,7 +2813,7 @@
if test $ac_cv_header_stdc = yes; then
# SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 2815 "configure"
+#line 2817 "configure"
#include <string.h>
EOF
@@ -2829,7 +2831,7 @@
# ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 2833 "configure"
+#line 2835 "configure"
#include <stdlib.h>
EOF
@@ -2850,7 +2852,7 @@
else
-#line 2854 "configure"
+#line 2856 "configure"
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -2861,7 +2863,7 @@
exit (0); }
EOF
-if { (eval echo configure:2865: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:2867: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
else
@@ -2888,15 +2890,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:2892: checking for $ac_hdr" >&5
+echo "configure:2894: checking for $ac_hdr" >&5
-#line 2895 "configure"
+#line 2897 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2900: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2902: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2925,15 +2927,15 @@
do
-echo "configure:2929: checking for $ac_hdr" >&5
+echo "configure:2931: checking for $ac_hdr" >&5
-#line 2932 "configure"
+#line 2934 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2937: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2939: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2962,15 +2964,15 @@
do
-echo "configure:2966: checking for $ac_hdr" >&5
+echo "configure:2968: checking for $ac_hdr" >&5
-#line 2969 "configure"
+#line 2971 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2974: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2976: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2999,15 +3001,15 @@
do
-echo "configure:3003: checking for $ac_hdr" >&5
+echo "configure:3005: checking for $ac_hdr" >&5
-#line 3006 "configure"
+#line 3008 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3011: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3013: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3036,15 +3038,15 @@
do
-echo "configure:3040: checking for $ac_hdr" >&5
+echo "configure:3042: checking for $ac_hdr" >&5
-#line 3043 "configure"
+#line 3045 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3048: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3050: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3070,10 +3072,10 @@
done
echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:3074: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:3076: checking whether time.h and sys/time.h may both be included" >&5
-#line 3077 "configure"
+#line 3079 "configure"
#include <sys/types.h>
#include <sys/time.h>
@@ -3082,7 +3084,7 @@
struct tm *tp;
; return 0; }
EOF
-if { (eval echo configure:3086: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3088: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_header_time=yes
else
@@ -3102,10 +3104,10 @@
fi
echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:3106: checking for off_t" >&5
+echo "configure:3108: checking for off_t" >&5
-#line 3109 "configure"
+#line 3111 "configure"
#if STDC_HEADERS
@@ -3132,10 +3134,10 @@
fi
echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:3136: checking for uid_t in sys/types.h" >&5
+echo "configure:3138: checking for uid_t in sys/types.h" >&5
-#line 3139 "configure"
+#line 3141 "configure"
EOF
@@ -3163,10 +3165,10 @@
fi
echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:3167: checking return type of signal handlers" >&5
+echo "configure:3169: checking return type of signal handlers" >&5
-#line 3170 "configure"
+#line 3172 "configure"
#include <signal.h>
@@ -3183,7 +3185,7 @@
int i;
; return 0; }
EOF
-if { (eval echo configure:3187: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3189: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_type_signal=void
else
@@ -3201,10 +3203,10 @@
echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:3205: checking for Cygwin environment" >&5
+echo "configure:3207: checking for Cygwin environment" >&5
-#line 3208 "configure"
+#line 3210 "configure"
int main() {
@@ -3215,7 +3217,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:3219: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3221: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -3233,10 +3235,10 @@
for ac_func in ftime gethostname gettimeofday lseek nice time uname
do
echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:3237: checking for $ac_func" >&5
+echo "configure:3239: checking for $ac_func" >&5
-#line 3240 "configure"
+#line 3242 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char $ac_func(); below. */
@@ -3259,7 +3261,7 @@
; return 0; }
EOF
-if { (eval echo configure:3263: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3265: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_$ac_func=yes"
else
@@ -3285,10 +3287,10 @@
for ac_func in seteuid setpriority setreuid setruid
do
-echo "configure:3289: checking for $ac_func" >&5
+echo "configure:3291: checking for $ac_func" >&5
-#line 3292 "configure"
+#line 3294 "configure"
@@ -3311,7 +3313,7 @@
; return 0; }
EOF
-if { (eval echo configure:3315: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3317: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3337,10 +3339,10 @@
for ac_func in drand48
do
-echo "configure:3341: checking for $ac_func" >&5
+echo "configure:3343: checking for $ac_func" >&5
-#line 3344 "configure"
+#line 3346 "configure"
@@ -3363,7 +3365,7 @@
; return 0; }
EOF
-if { (eval echo configure:3367: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3369: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3389,10 +3391,10 @@
for ac_func in putenv setenv
do
-echo "configure:3393: checking for $ac_func" >&5
+echo "configure:3395: checking for $ac_func" >&5
-#line 3396 "configure"
+#line 3398 "configure"
@@ -3415,7 +3417,7 @@
; return 0; }
EOF
-if { (eval echo configure:3419: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3421: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3441,10 +3443,10 @@
for ac_func in nanosleep
do
-echo "configure:3445: checking for $ac_func" >&5
+echo "configure:3447: checking for $ac_func" >&5
-#line 3448 "configure"
+#line 3450 "configure"
@@ -3467,7 +3469,7 @@
; return 0; }
EOF
-if { (eval echo configure:3471: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3473: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3492,13 +3494,13 @@
if test "$cross_compiling" != "yes" ; then
echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:3496: checking whether setpgrp takes no argument" >&5
+echo "configure:3498: checking whether setpgrp takes no argument" >&5
if test "$cross_compiling" = yes; then
{ echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
else
-#line 3502 "configure"
+#line 3504 "configure"
#ifdef HAVE_UNISTD_H
@@ -3518,7 +3520,7 @@
EOF
-if { (eval echo configure:3522: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3524: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
ac_cv_func_setpgrp_void=no
else
@@ -3546,16 +3548,16 @@
fi
echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:3550: checking for long long int" >&5
+echo "configure:3552: checking for long long int" >&5
-#line 3552 "configure"
+#line 3554 "configure"
int main() {
long long int x;
; return 0; }
EOF
-if { (eval echo configure:3559: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3561: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
echo "$ac_t""yes" 1>&6
@@ -3575,7 +3577,7 @@
rm -f conftest*
echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:3579: checking for W11" >&5
+echo "configure:3581: checking for W11" >&5
case "$enable_w11" in
yes|no) echo "$ac_t"""$enable_w11"" 1>&6 ;;
*) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
@@ -3603,7 +3605,7 @@
# Uses ac_ vars as temps to allow command line to override cache and checks.
# --without-x overrides everything else, but does not touch the cache.
echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:3607: checking for X" >&5
+echo "configure:3609: checking for X" >&5
# Check whether --with-x or --without-x was given.
if test "${with_x+set}" = set; then
@@ -3663,12 +3665,12 @@
# First, try using that file with no special directory specified.
-#line 3667 "configure"
+#line 3669 "configure"
#include <$x_direct_test_include>
EOF
-{ (eval echo configure:3672: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3674: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3737,14 +3739,14 @@
LIBS="-l$x_direct_test_library $LIBS"
-#line 3741 "configure"
+#line 3743 "configure"
int main() {
${x_direct_test_function}()
; return 0; }
EOF
-if { (eval echo configure:3748: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3750: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LIBS="$ac_save_LIBS"
# We can link X programs with no special library path.
@@ -3849,17 +3851,17 @@
case "`(uname -sr) 2>/dev/null`" in
"SunOS 5"*)
echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:3853: checking whether -R must be followed by a space" >&5
+echo "configure:3855: checking whether -R must be followed by a space" >&5
ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 3856 "configure"
+#line 3858 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:3863: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3865: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_nospace=yes
else
@@ -3875,14 +3877,14 @@
else
LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 3879 "configure"
+#line 3881 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:3886: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3888: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_space=yes
else
@@ -3914,13 +3916,13 @@
# libraries were built with DECnet support. And karl at cs.umb.edu says
# the Alpha needs dnet_stub (dnet does not exist).
echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:3918: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:3920: checking for dnet_ntoa in -ldnet" >&5
ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet $LIBS"
-#line 3924 "configure"
+#line 3926 "configure"
@@ -3931,7 +3933,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:3935: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3937: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3952,13 +3954,13 @@
if test $ac_cv_lib_dnet_dnet_ntoa = no; then
echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:3956: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:3958: checking for dnet_ntoa in -ldnet_stub" >&5
ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet_stub $LIBS"
-#line 3962 "configure"
+#line 3964 "configure"
@@ -3969,7 +3971,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:3973: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3975: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3997,10 +3999,10 @@
# The nsl library prevents programs from opening the X display
# on Irix 5.2, according to dickey at clark.net.
echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:4001: checking for gethostbyname" >&5
+echo "configure:4003: checking for gethostbyname" >&5
-#line 4004 "configure"
+#line 4006 "configure"
which can conflict with char gethostbyname(); below. */
@@ -4023,7 +4025,7 @@
; return 0; }
EOF
-if { (eval echo configure:4027: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4029: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gethostbyname=yes"
else
@@ -4043,13 +4045,13 @@
if test $ac_cv_func_gethostbyname = no; then
echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:4047: checking for gethostbyname in -lnsl" >&5
+echo "configure:4049: checking for gethostbyname in -lnsl" >&5
ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 4053 "configure"
+#line 4055 "configure"
@@ -4060,7 +4062,7 @@
gethostbyname()
; return 0; }
EOF
-if { (eval echo configure:4064: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4066: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4089,10 +4091,10 @@
# -lsocket must be given before -lnsl if both are needed.
# We assume that if connect needs -lnsl, so does gethostbyname.
echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:4093: checking for connect" >&5
+echo "configure:4095: checking for connect" >&5
-#line 4096 "configure"
+#line 4098 "configure"
which can conflict with char connect(); below. */
@@ -4115,7 +4117,7 @@
; return 0; }
EOF
-if { (eval echo configure:4119: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4121: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_connect=yes"
else
@@ -4135,13 +4137,13 @@
if test $ac_cv_func_connect = no; then
echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:4139: checking for connect in -lsocket" >&5
+echo "configure:4141: checking for connect in -lsocket" >&5
ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 4145 "configure"
+#line 4147 "configure"
@@ -4152,7 +4154,7 @@
connect()
; return 0; }
EOF
-if { (eval echo configure:4156: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4158: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4175,10 +4177,10 @@
# gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:4179: checking for remove" >&5
+echo "configure:4181: checking for remove" >&5
-#line 4182 "configure"
+#line 4184 "configure"
which can conflict with char remove(); below. */
@@ -4201,7 +4203,7 @@
; return 0; }
EOF
-if { (eval echo configure:4205: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4207: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_remove=yes"
else
@@ -4221,13 +4223,13 @@
if test $ac_cv_func_remove = no; then
echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:4225: checking for remove in -lposix" >&5
+echo "configure:4227: checking for remove in -lposix" >&5
ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
LIBS="-lposix $LIBS"
-#line 4231 "configure"
+#line 4233 "configure"
@@ -4238,7 +4240,7 @@
remove()
; return 0; }
EOF
-if { (eval echo configure:4242: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4244: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4261,10 +4263,10 @@
# BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:4265: checking for shmat" >&5
+echo "configure:4267: checking for shmat" >&5
-#line 4268 "configure"
+#line 4270 "configure"
which can conflict with char shmat(); below. */
@@ -4287,7 +4289,7 @@
; return 0; }
EOF
-if { (eval echo configure:4291: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4293: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_shmat=yes"
else
@@ -4307,13 +4309,13 @@
if test $ac_cv_func_shmat = no; then
echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:4311: checking for shmat in -lipc" >&5
+echo "configure:4313: checking for shmat in -lipc" >&5
ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
LIBS="-lipc $LIBS"
-#line 4317 "configure"
+#line 4319 "configure"
@@ -4324,7 +4326,7 @@
shmat()
; return 0; }
EOF
-if { (eval echo configure:4328: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4330: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4356,13 +4358,13 @@
# libraries we check for below, so use a different variable.
# --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:4360: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:4362: checking for IceConnectionNumber in -lICE" >&5
ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 4366 "configure"
+#line 4368 "configure"
@@ -4373,7 +4375,7 @@
IceConnectionNumber()
; return 0; }
EOF
-if { (eval echo configure:4377: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4379: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4413,12 +4415,12 @@
LIBS=""
echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:4417: checking for library containing cuserid" >&5
+echo "configure:4419: checking for library containing cuserid" >&5
ac_func_search_save_LIBS="$LIBS"
ac_cv_search_cuserid="no"
-#line 4422 "configure"
+#line 4424 "configure"
@@ -4429,7 +4431,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:4433: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4435: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="none required"
else
@@ -4440,7 +4442,7 @@
test "$ac_cv_search_cuserid" = "no" && for i in compat; do
LIBS="-l$i $ac_func_search_save_LIBS"
-#line 4444 "configure"
+#line 4446 "configure"
@@ -4451,7 +4453,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:4455: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4457: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="-l$i"
break
@@ -4477,10 +4479,10 @@
for ac_func in asprintf
do
-echo "configure:4481: checking for $ac_func" >&5
+echo "configure:4483: checking for $ac_func" >&5
-#line 4484 "configure"
+#line 4486 "configure"
@@ -4503,7 +4505,7 @@
; return 0; }
EOF
-if { (eval echo configure:4507: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4509: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4530,10 +4532,10 @@
# Test if mathlib needs -lm flag or is included with libc
echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:4534: checking for atan" >&5
+echo "configure:4536: checking for atan" >&5
-#line 4537 "configure"
+#line 4539 "configure"
which can conflict with char atan(); below. */
@@ -4556,7 +4558,7 @@
; return 0; }
EOF
-if { (eval echo configure:4560: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4562: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_atan=yes"
else
@@ -4574,13 +4576,13 @@
echo "$ac_t""no" 1>&6
echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:4578: checking for atan in -lm" >&5
+echo "configure:4580: checking for atan in -lm" >&5
ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
LIBS="-lm $LIBS"
-#line 4584 "configure"
+#line 4586 "configure"
@@ -4591,7 +4593,7 @@
atan()
; return 0; }
EOF
-if { (eval echo configure:4595: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4597: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4618,10 +4620,10 @@
echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:4622: checking for dlsym" >&5
+echo "configure:4624: checking for dlsym" >&5
-#line 4625 "configure"
+#line 4627 "configure"
which can conflict with char dlsym(); below. */
@@ -4644,7 +4646,7 @@
; return 0; }
EOF
-if { (eval echo configure:4648: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4650: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dlsym=yes"
else
@@ -4662,13 +4664,13 @@
echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:4666: checking for dlsym in -ldl" >&5
+echo "configure:4668: checking for dlsym in -ldl" >&5
ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
LIBS="-ldl $LIBS"
-#line 4672 "configure"
+#line 4674 "configure"
@@ -4679,7 +4681,7 @@
dlsym()
; return 0; }
EOF
-if { (eval echo configure:4683: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4685: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4706,10 +4708,10 @@
echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:4710: checking for iconv" >&5
+echo "configure:4712: checking for iconv" >&5
-#line 4713 "configure"
+#line 4715 "configure"
which can conflict with char iconv(); below. */
@@ -4732,7 +4734,7 @@
; return 0; }
EOF
-if { (eval echo configure:4736: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_iconv=yes"
else
@@ -4750,13 +4752,13 @@
echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:4754: checking for iconv in -liconv" >&5
+echo "configure:4756: checking for iconv in -liconv" >&5
ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-liconv $LIBS"
-#line 4760 "configure"
+#line 4762 "configure"
@@ -4767,7 +4769,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:4771: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4773: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4786,13 +4788,13 @@
echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4790: checking for iconv in -lgiconv" >&5
+echo "configure:4792: checking for iconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-lgiconv $LIBS"
-#line 4796 "configure"
+#line 4798 "configure"
@@ -4803,7 +4805,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:4807: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4809: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4822,10 +4824,10 @@
echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:4826: checking for libiconv" >&5
+echo "configure:4828: checking for libiconv" >&5
-#line 4829 "configure"
+#line 4831 "configure"
which can conflict with char libiconv(); below. */
@@ -4848,7 +4850,7 @@
; return 0; }
EOF
-if { (eval echo configure:4852: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4854: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_libiconv=yes"
else
@@ -4866,13 +4868,13 @@
echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:4870: checking for libiconv in -liconv" >&5
+echo "configure:4872: checking for libiconv in -liconv" >&5
ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 4876 "configure"
+#line 4878 "configure"
@@ -4883,7 +4885,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:4887: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4889: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4902,13 +4904,13 @@
echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4906: checking for libiconv in -lgiconv" >&5
+echo "configure:4908: checking for libiconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 4912 "configure"
+#line 4914 "configure"
@@ -4919,7 +4921,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:4923: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4925: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4956,10 +4958,10 @@
have_socket=1
echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:4960: checking for socket" >&5
+echo "configure:4962: checking for socket" >&5
-#line 4963 "configure"
+#line 4965 "configure"
which can conflict with char socket(); below. */
@@ -4982,7 +4984,7 @@
; return 0; }
EOF
-if { (eval echo configure:4986: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4988: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_socket=yes"
else
@@ -5000,13 +5002,13 @@
echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:5004: checking for socket in -lsocket" >&5
+echo "configure:5006: checking for socket in -lsocket" >&5
ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
LIBS="-lsocket $LIBS"
-#line 5010 "configure"
+#line 5012 "configure"
@@ -5017,7 +5019,7 @@
socket()
; return 0; }
EOF
-if { (eval echo configure:5021: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5023: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5065,7 +5067,7 @@
echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:5069: checking for location of zlib includes" >&5
+echo "configure:5071: checking for location of zlib includes" >&5
case "$with_zlib_includes" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -5091,15 +5093,15 @@
do
-echo "configure:5095: checking for $ac_hdr" >&5
+echo "configure:5097: checking for $ac_hdr" >&5
-#line 5098 "configure"
+#line 5100 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5103: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5105: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5133,7 +5135,7 @@
echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:5137: checking for location of zlib library" >&5
+echo "configure:5139: checking for location of zlib library" >&5
case "$with_zlib_libs" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -5158,13 +5160,13 @@
echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:5162: checking for deflate in -lz" >&5
+echo "configure:5164: checking for deflate in -lz" >&5
ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
LIBS="-lz $LIBS"
-#line 5168 "configure"
+#line 5170 "configure"
@@ -5175,7 +5177,7 @@
deflate()
; return 0; }
EOF
-if { (eval echo configure:5179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5181: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5223,7 +5225,7 @@
echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:5227: checking for location of External PROJ.4 includes" >&5
+echo "configure:5229: checking for location of External PROJ.4 includes" >&5
case "$with_proj_includes" in
{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -5249,15 +5251,15 @@
do
-echo "configure:5253: checking for $ac_hdr" >&5
+echo "configure:5255: checking for $ac_hdr" >&5
-#line 5256 "configure"
+#line 5258 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5261: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5263: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5294,7 +5296,7 @@
else
echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:5298: checking External PROJ.4 version" >&5
+echo "configure:5300: checking External PROJ.4 version" >&5
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -5302,7 +5304,7 @@
echo "$ac_t""unknown (cross-compiling)" 1>&6
else
-#line 5306 "configure"
+#line 5308 "configure"
#include <stdio.h>
@@ -5314,7 +5316,7 @@
EOF
-if { (eval echo configure:5318: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:5320: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
proj_ver=`cat conftestdata`
echo "$ac_t""$proj_ver" 1>&6
@@ -5339,7 +5341,7 @@
echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:5343: checking for location of External PROJ.4 library" >&5
+echo "configure:5345: checking for location of External PROJ.4 library" >&5
case "$with_proj_libs" in
{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -5364,13 +5366,13 @@
echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:5368: checking for pj_get_def in -lproj" >&5
+echo "configure:5370: checking for pj_get_def in -lproj" >&5
ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
LIBS="-lproj $LIBS"
-#line 5374 "configure"
+#line 5376 "configure"
@@ -5381,7 +5383,7 @@
pj_get_def()
; return 0; }
EOF
-if { (eval echo configure:5385: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5387: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5415,7 +5417,7 @@
echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:5419: checking for location of External PROJ.4 data files" >&5
+echo "configure:5421: checking for location of External PROJ.4 data files" >&5
case "$with_proj_share" in
{ echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -5439,14 +5441,14 @@
# LOC_CHECK_SHARE does not work when cross compiling
if test "$cross_compiling" = "yes" ; then
echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:5443: checking for epsg" >&5
+echo "configure:5445: checking for epsg" >&5
else
ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:5450: checking for $PROJSHARE/epsg" >&5
+echo "configure:5452: checking for $PROJSHARE/epsg" >&5
{ echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -5478,7 +5480,7 @@
# Extract the first word of "nad2bin", so it can be a program name with args.
set dummy nad2bin; ac_word=$2
-echo "configure:5482: checking for $ac_word" >&5
+echo "configure:5484: checking for $ac_word" >&5
case "$NAD2BIN" in
@@ -5518,7 +5520,7 @@
echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:5522: checking whether to use regex" >&5
+echo "configure:5524: checking whether to use regex" >&5
echo "$ac_t"""$with_regex"" 1>&6
case "$with_regex" in
"no") USE_REGEX= ;;
@@ -5538,7 +5540,7 @@
echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:5542: checking for location of regex includes" >&5
+echo "configure:5544: checking for location of regex includes" >&5
case "$with_regex_includes" in
{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -5564,15 +5566,15 @@
do
-echo "configure:5568: checking for $ac_hdr" >&5
+echo "configure:5570: checking for $ac_hdr" >&5
-#line 5571 "configure"
+#line 5573 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5576: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5578: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5606,7 +5608,7 @@
echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:5610: checking for location of regex library" >&5
+echo "configure:5612: checking for location of regex library" >&5
case "$with_regex_libs" in
{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -5631,10 +5633,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:5635: checking for regcomp" >&5
+echo "configure:5637: checking for regcomp" >&5
-#line 5638 "configure"
+#line 5640 "configure"
which can conflict with char regcomp(); below. */
@@ -5657,7 +5659,7 @@
; return 0; }
EOF
-if { (eval echo configure:5661: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5663: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_regcomp=yes"
else
@@ -5684,13 +5686,13 @@
echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:5688: checking for regcomp in -lregex" >&5
+echo "configure:5690: checking for regcomp in -lregex" >&5
ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
LIBS="-lregex $LIBS"
-#line 5694 "configure"
+#line 5696 "configure"
@@ -5701,7 +5703,7 @@
regcomp()
; return 0; }
EOF
-if { (eval echo configure:5705: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5707: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5751,7 +5753,7 @@
echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:5755: checking whether to use Readline" >&5
+echo "configure:5757: checking whether to use Readline" >&5
echo "$ac_t"""$with_readline"" 1>&6
case "$with_readline" in
"no") USE_READLINE= ;;
@@ -5772,7 +5774,7 @@
echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:5776: checking for location of Readline includes" >&5
+echo "configure:5778: checking for location of Readline includes" >&5
case "$with_readline_includes" in
{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -5798,15 +5800,15 @@
do
-echo "configure:5802: checking for $ac_hdr" >&5
+echo "configure:5804: checking for $ac_hdr" >&5
-#line 5805 "configure"
+#line 5807 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5810: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5812: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5842,15 +5844,15 @@
do
-echo "configure:5846: checking for $ac_hdr" >&5
+echo "configure:5848: checking for $ac_hdr" >&5
-#line 5849 "configure"
+#line 5851 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5854: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5856: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5884,7 +5886,7 @@
echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:5888: checking for location of Readline library" >&5
+echo "configure:5890: checking for location of Readline library" >&5
case "$with_readline_libs" in
{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -5909,13 +5911,13 @@
echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:5913: checking for readline in -lreadline" >&5
+echo "configure:5915: checking for readline in -lreadline" >&5
ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
LIBS="-lreadline $LIBS"
-#line 5919 "configure"
+#line 5921 "configure"
@@ -5926,7 +5928,7 @@
readline()
; return 0; }
EOF
-if { (eval echo configure:5930: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5932: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5961,13 +5963,13 @@
echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:5965: checking for add_history in -lhistory" >&5
+echo "configure:5967: checking for add_history in -lhistory" >&5
ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
LIBS="-lhistory $LIBS"
-#line 5971 "configure"
+#line 5973 "configure"
@@ -5978,7 +5980,7 @@
add_history()
; return 0; }
EOF
-if { (eval echo configure:5982: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6020,7 +6022,7 @@
# GDAL option
echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:6024: checking whether to use GDAL" >&5
+echo "configure:6026: checking whether to use GDAL" >&5
GDAL_LIBS=
GDAL_CFLAGS=
@@ -6038,7 +6040,7 @@
# Extract the first word of "gdal-config", so it can be a program name with args.
set dummy gdal-config; ac_word=$2
-echo "configure:6042: checking for $ac_word" >&5
+echo "configure:6044: checking for $ac_word" >&5
case "$GDAL_CONFIG" in
@@ -6093,14 +6095,14 @@
LIBS="$LIBS $GDAL_LIBS"
CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 6097 "configure"
+#line 6099 "configure"
#include <gdal.h>
int main() {
GDALOpen("foo", GA_ReadOnly);
; return 0; }
EOF
-if { (eval echo configure:6104: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6106: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
echo "configure: failed program was:" >&5
@@ -6109,14 +6111,14 @@
LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 6113 "configure"
+#line 6115 "configure"
#include <gdal.h>
int main() {
; return 0; }
EOF
-if { (eval echo configure:6120: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6122: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
else
@@ -6148,7 +6150,7 @@
# libLAS option
echo $ac_n "checking whether to use libLAS""... $ac_c" 1>&6
-echo "configure:6152: checking whether to use libLAS" >&5
+echo "configure:6154: checking whether to use libLAS" >&5
LIBLAS_LIBS=
LIBLAS_CFLAGS=
@@ -6165,7 +6167,7 @@
# Extract the first word of "liblas-config", so it can be a program name with args.
set dummy liblas-config; ac_word=$2
-echo "configure:6169: checking for $ac_word" >&5
+echo "configure:6171: checking for $ac_word" >&5
case "$LIBLAS_CONFIG" in
@@ -6213,14 +6215,14 @@
LIBS="$LIBS $LIBLAS_LIBS"
CFLAGS="$CFLAGS $LIBLAS_CFLAGS"
-#line 6217 "configure"
+#line 6219 "configure"
#include <liblas/capi/liblas.h>
int main() {
LASReader_Create("foo");
; return 0; }
EOF
-if { (eval echo configure:6224: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6226: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
@@ -6228,14 +6230,14 @@
rm -rf conftest*
-#line 6232 "configure"
+#line 6234 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:6239: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6241: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LAS_LIBS="$LAS_LIBS"
else
@@ -6267,7 +6269,7 @@
# NetCDF option
echo $ac_n "checking whether to use NetCDF""... $ac_c" 1>&6
-echo "configure:6271: checking whether to use NetCDF" >&5
+echo "configure:6273: checking whether to use NetCDF" >&5
NETCDF_LIBS=
NETCDF_CFLAGS=
@@ -6284,7 +6286,7 @@
# Extract the first word of "nc-config", so it can be a program name with args.
set dummy nc-config; ac_word=$2
-echo "configure:6288: checking for $ac_word" >&5
+echo "configure:6290: checking for $ac_word" >&5
case "$NETCDF_CONFIG" in
@@ -6331,14 +6333,14 @@
LIBS="$LIBS $NETCDF_LIBS"
CFLAGS="$CFLAGS $NETCDF_CFLAGS"
-#line 6335 "configure"
+#line 6337 "configure"
#include <netcdf.h>
int main() {
nc_create("foo", NC_CLOBBER, NULL);
; return 0; }
EOF
-if { (eval echo configure:6342: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6344: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
@@ -6346,14 +6348,14 @@
rm -rf conftest*
-#line 6350 "configure"
+#line 6352 "configure"
#include <netcdf.h>
int main() {
; return 0; }
EOF
-if { (eval echo configure:6357: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6359: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
NETCDF_LIBS="$NETCDF_LIBS"
else
@@ -6384,7 +6386,7 @@
# GEOS option
echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:6388: checking whether to use GEOS" >&5
+echo "configure:6390: checking whether to use GEOS" >&5
GEOS_LIBS=
GEOS_CFLAGS=
@@ -6402,7 +6404,7 @@
# Extract the first word of "geos-config", so it can be a program name with args.
set dummy geos-config; ac_word=$2
-echo "configure:6406: checking for $ac_word" >&5
+echo "configure:6408: checking for $ac_word" >&5
case "$GEOS_CONFIG" in
@@ -6450,15 +6452,15 @@
do
-echo "configure:6454: checking for $ac_hdr" >&5
+echo "configure:6456: checking for $ac_hdr" >&5
-#line 6457 "configure"
+#line 6459 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6462: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6464: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6497,13 +6499,13 @@
echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:6501: checking for initGEOS in -lgeos_c" >&5
+echo "configure:6503: checking for initGEOS in -lgeos_c" >&5
ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
LIBS="-lgeos_c $LIBS"
-#line 6507 "configure"
+#line 6509 "configure"
@@ -6514,7 +6516,7 @@
initGEOS()
; return 0; }
EOF
-if { (eval echo configure:6518: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6520: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6558,7 +6560,7 @@
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:6562: checking whether to use TIFF" >&5
+echo "configure:6564: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -6578,7 +6580,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:6582: checking for location of TIFF includes" >&5
+echo "configure:6584: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -6604,15 +6606,15 @@
do
-echo "configure:6608: checking for $ac_hdr" >&5
+echo "configure:6610: checking for $ac_hdr" >&5
-#line 6611 "configure"
+#line 6613 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6616: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6618: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6646,7 +6648,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:6650: checking for location of TIFF library" >&5
+echo "configure:6652: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -6677,13 +6679,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:6681: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6683: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
LIBS="-ltiff $LIBS"
-#line 6687 "configure"
+#line 6689 "configure"
@@ -6694,7 +6696,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6698: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6700: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6713,13 +6715,13 @@
-echo "configure:6717: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6719: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
-#line 6723 "configure"
+#line 6725 "configure"
@@ -6730,7 +6732,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6734: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6736: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6749,13 +6751,13 @@
-echo "configure:6753: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6755: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 6759 "configure"
+#line 6761 "configure"
@@ -6766,7 +6768,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6770: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6772: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6785,13 +6787,13 @@
-echo "configure:6789: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6791: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 6795 "configure"
+#line 6797 "configure"
@@ -6802,7 +6804,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6806: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6808: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6821,13 +6823,13 @@
-echo "configure:6825: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6827: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $LIBS"
-#line 6831 "configure"
+#line 6833 "configure"
@@ -6838,7 +6840,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6842: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6844: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6857,13 +6859,13 @@
-echo "configure:6861: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6863: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $MATHLIB $LIBS"
-#line 6867 "configure"
+#line 6869 "configure"
@@ -6874,7 +6876,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6878: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6880: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6893,13 +6895,13 @@
-echo "configure:6897: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6899: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $ZLIB $LIBS"
-#line 6903 "configure"
+#line 6905 "configure"
@@ -6910,7 +6912,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6914: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6916: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6929,13 +6931,13 @@
-echo "configure:6933: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6935: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $ZLIB $MATHLIB $LIBS"
-#line 6939 "configure"
+#line 6941 "configure"
@@ -6946,7 +6948,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6952: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7044,7 +7046,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:7048: checking whether to use PNG" >&5
+echo "configure:7050: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -7063,7 +7065,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:7067: checking for location of PNG includes" >&5
+echo "configure:7069: checking for location of PNG includes" >&5
case "$with_png_includes" in
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -7089,15 +7091,15 @@
do
-echo "configure:7093: checking for $ac_hdr" >&5
+echo "configure:7095: checking for $ac_hdr" >&5
-#line 7096 "configure"
+#line 7098 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7101: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7103: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7131,7 +7133,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:7135: checking for location of PNG library" >&5
+echo "configure:7137: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -7156,13 +7158,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:7160: checking for png_read_image in -lpng" >&5
+echo "configure:7162: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 7166 "configure"
+#line 7168 "configure"
@@ -7173,7 +7175,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:7177: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7215,7 +7217,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:7219: checking whether to use PostgreSQL" >&5
+echo "configure:7221: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -7242,7 +7244,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:7246: checking for location of PostgreSQL includes" >&5
+echo "configure:7248: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -7268,15 +7270,15 @@
do
-echo "configure:7272: checking for $ac_hdr" >&5
+echo "configure:7274: checking for $ac_hdr" >&5
-#line 7275 "configure"
+#line 7277 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7280: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7282: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7314,7 +7316,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:7318: checking for location of PostgreSQL library" >&5
+echo "configure:7320: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -7343,13 +7345,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:7347: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7349: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 7353 "configure"
+#line 7355 "configure"
@@ -7360,7 +7362,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7364: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7366: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7379,13 +7381,13 @@
-echo "configure:7383: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7385: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 7389 "configure"
+#line 7391 "configure"
@@ -7396,7 +7398,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7400: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7402: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7415,13 +7417,13 @@
-echo "configure:7419: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7421: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 7425 "configure"
+#line 7427 "configure"
@@ -7432,7 +7434,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7436: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7438: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7451,13 +7453,13 @@
-echo "configure:7455: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7457: checking for PQsetdbLogin in -lpq" >&5
ac_save_LIBS="$LIBS"
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 7461 "configure"
+#line 7463 "configure"
#include "confdefs.h"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -7468,7 +7470,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7472: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7474: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -7525,13 +7527,13 @@
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:7529: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7531: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 7535 "configure"
+#line 7537 "configure"
@@ -7542,7 +7544,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:7546: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7548: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7564,13 +7566,13 @@
-echo "configure:7568: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7570: checking for PQcmdTuples in -lpq" >&5
-#line 7574 "configure"
+#line 7576 "configure"
@@ -7581,7 +7583,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:7585: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7587: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7624,7 +7626,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:7628: checking whether to use MySQL" >&5
+echo "configure:7630: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -7644,7 +7646,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:7648: checking for location of MySQL includes" >&5
+echo "configure:7650: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -7670,15 +7672,15 @@
do
-echo "configure:7674: checking for $ac_hdr" >&5
+echo "configure:7676: checking for $ac_hdr" >&5
-#line 7677 "configure"
+#line 7679 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7682: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7684: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -7715,7 +7717,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:7719: checking for location of MySQL library" >&5
+echo "configure:7721: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -7746,13 +7748,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:7750: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7752: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 7756 "configure"
+#line 7758 "configure"
@@ -7763,7 +7765,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7767: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7769: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7782,13 +7784,13 @@
-echo "configure:7786: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7788: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 7792 "configure"
+#line 7794 "configure"
@@ -7799,7 +7801,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7803: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7805: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7818,13 +7820,13 @@
-echo "configure:7822: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7824: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 7828 "configure"
+#line 7830 "configure"
@@ -7835,7 +7837,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7839: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7841: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7854,13 +7856,13 @@
-echo "configure:7858: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7860: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 7864 "configure"
+#line 7866 "configure"
@@ -7871,7 +7873,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7875: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7877: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7890,13 +7892,13 @@
-echo "configure:7894: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7896: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 7900 "configure"
+#line 7902 "configure"
@@ -7907,7 +7909,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7911: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7913: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7926,13 +7928,13 @@
-echo "configure:7930: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7932: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 7936 "configure"
+#line 7938 "configure"
@@ -7943,7 +7945,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7947: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7949: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7962,13 +7964,13 @@
-echo "configure:7966: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7968: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 7972 "configure"
+#line 7974 "configure"
@@ -7979,7 +7981,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7983: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7985: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7998,13 +8000,13 @@
-echo "configure:8002: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8004: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 8008 "configure"
+#line 8010 "configure"
@@ -8015,7 +8017,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8021: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8105,7 +8107,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:8109: checking for $ac_word" >&5
+echo "configure:8111: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -8154,10 +8156,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:8158: checking for mysql_server_init" >&5
+echo "configure:8160: checking for mysql_server_init" >&5
-#line 8161 "configure"
+#line 8163 "configure"
which can conflict with char mysql_server_init(); below. */
@@ -8183,7 +8185,7 @@
; return 0; }
EOF
-if { (eval echo configure:8187: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8189: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -8235,7 +8237,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:8239: checking whether to use SQLite" >&5
+echo "configure:8241: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -8255,7 +8257,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:8259: checking for location of SQLite includes" >&5
+echo "configure:8261: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -8281,15 +8283,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:8285: checking for $ac_hdr" >&5
+echo "configure:8287: checking for $ac_hdr" >&5
-#line 8288 "configure"
+#line 8290 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8293: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8295: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8332,7 +8334,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:8336: checking for location of SQLite library" >&5
+echo "configure:8338: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -8361,13 +8363,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:8365: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8367: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 8371 "configure"
+#line 8373 "configure"
@@ -8378,7 +8380,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8382: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8384: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8397,13 +8399,13 @@
-echo "configure:8401: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8403: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 8407 "configure"
+#line 8409 "configure"
@@ -8414,7 +8416,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8418: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8420: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8433,13 +8435,13 @@
-echo "configure:8437: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8439: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 8443 "configure"
+#line 8445 "configure"
@@ -8450,7 +8452,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8454: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8456: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8469,13 +8471,13 @@
-echo "configure:8473: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8475: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 8479 "configure"
+#line 8481 "configure"
@@ -8486,7 +8488,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8490: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8492: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8555,7 +8557,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:8559: checking whether to use FFMPEG" >&5
+echo "configure:8561: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -8575,7 +8577,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:8579: checking for location of FFMPEG includes" >&5
+echo "configure:8581: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -8601,15 +8603,15 @@
do
-echo "configure:8605: checking for $ac_hdr" >&5
+echo "configure:8607: checking for $ac_hdr" >&5
-#line 8608 "configure"
+#line 8610 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8613: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8615: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8645,15 +8647,15 @@
do
-echo "configure:8649: checking for $ac_hdr" >&5
+echo "configure:8651: checking for $ac_hdr" >&5
-#line 8652 "configure"
+#line 8654 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8657: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8659: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8689,15 +8691,15 @@
do
-echo "configure:8693: checking for $ac_hdr" >&5
+echo "configure:8695: checking for $ac_hdr" >&5
-#line 8696 "configure"
+#line 8698 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8701: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8703: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8740,7 +8742,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:8744: checking for location of FFMPEG library" >&5
+echo "configure:8746: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -8767,13 +8769,13 @@
echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:8771: checking for av_free in -lavutil" >&5
+echo "configure:8773: checking for av_free in -lavutil" >&5
ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
LIBS="-lavutil $LIBS"
-#line 8777 "configure"
+#line 8779 "configure"
@@ -8784,7 +8786,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:8788: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8790: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8803,13 +8805,13 @@
-echo "configure:8807: checking for av_free in -lavutil" >&5
+echo "configure:8809: checking for av_free in -lavutil" >&5
LIBS="-lavutil $MATHLIB $LIBS"
-#line 8813 "configure"
+#line 8815 "configure"
@@ -8820,7 +8822,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:8824: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8865,13 +8867,13 @@
echo $ac_n "checking for avcodec_register in -lavcodec""... $ac_c" 1>&6
-echo "configure:8869: checking for avcodec_register in -lavcodec" >&5
+echo "configure:8871: checking for avcodec_register in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_register | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $FFMPEGLIB $LIBS"
-#line 8875 "configure"
+#line 8877 "configure"
@@ -8882,7 +8884,7 @@
avcodec_register()
; return 0; }
EOF
-if { (eval echo configure:8886: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8888: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8901,13 +8903,13 @@
-echo "configure:8905: checking for avcodec_register in -lavcodec" >&5
+echo "configure:8907: checking for avcodec_register in -lavcodec" >&5
LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 8911 "configure"
+#line 8913 "configure"
@@ -8918,7 +8920,7 @@
avcodec_register()
; return 0; }
EOF
-if { (eval echo configure:8922: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8924: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8963,13 +8965,13 @@
echo $ac_n "checking for avformat_alloc_context in -lavformat""... $ac_c" 1>&6
-echo "configure:8967: checking for avformat_alloc_context in -lavformat" >&5
+echo "configure:8969: checking for avformat_alloc_context in -lavformat" >&5
ac_lib_var=`echo avformat'_'avformat_alloc_context | sed 'y%./+-%__p_%'`
LIBS="-lavformat $FFMPEGLIB $LIBS"
-#line 8973 "configure"
+#line 8975 "configure"
@@ -8980,7 +8982,7 @@
avformat_alloc_context()
; return 0; }
EOF
-if { (eval echo configure:8984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8986: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8999,13 +9001,13 @@
-echo "configure:9003: checking for avformat_alloc_context in -lavformat" >&5
+echo "configure:9005: checking for avformat_alloc_context in -lavformat" >&5
LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 9009 "configure"
+#line 9011 "configure"
@@ -9016,7 +9018,7 @@
; return 0; }
EOF
-if { (eval echo configure:9020: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9022: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9075,7 +9077,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:9079: checking whether to use OpenGL" >&5
+echo "configure:9081: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -9109,7 +9111,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:9113: checking for location of OpenGL includes" >&5
+echo "configure:9115: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -9135,15 +9137,15 @@
do
-echo "configure:9139: checking for $ac_hdr" >&5
+echo "configure:9141: checking for $ac_hdr" >&5
-#line 9142 "configure"
+#line 9144 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9147: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9149: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9177,7 +9179,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:9181: checking for location of OpenGL library" >&5
+echo "configure:9183: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -9206,13 +9208,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:9210: checking for glBegin in -lGL" >&5
+echo "configure:9212: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 9216 "configure"
+#line 9218 "configure"
@@ -9223,7 +9225,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9227: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9229: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9242,13 +9244,13 @@
-echo "configure:9246: checking for glBegin in -lGL" >&5
+echo "configure:9248: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 9252 "configure"
+#line 9254 "configure"
@@ -9259,7 +9261,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9263: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9265: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9278,13 +9280,13 @@
-echo "configure:9282: checking for glBegin in -lGL" >&5
+echo "configure:9284: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 9288 "configure"
+#line 9290 "configure"
@@ -9295,7 +9297,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9299: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9301: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9314,13 +9316,13 @@
-echo "configure:9318: checking for glBegin in -lGL" >&5
+echo "configure:9320: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 9324 "configure"
+#line 9326 "configure"
@@ -9331,7 +9333,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9335: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9337: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9393,13 +9395,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:9397: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9399: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 9403 "configure"
+#line 9405 "configure"
@@ -9410,7 +9412,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:9414: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9416: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9429,13 +9431,13 @@
-echo "configure:9433: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9435: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 9439 "configure"
+#line 9441 "configure"
@@ -9446,7 +9448,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:9450: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9452: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9493,10 +9495,10 @@
LIBS=" $OPENGLLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:9497: checking for glXCreatePbuffer" >&5
+echo "configure:9499: checking for glXCreatePbuffer" >&5
-#line 9500 "configure"
+#line 9502 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char glXCreatePbuffer(); below. */
@@ -9519,7 +9521,7 @@
; return 0; }
EOF
-if { (eval echo configure:9523: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9525: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -9556,10 +9558,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:9560: checking for glXCreateGLXPixmap" >&5
+echo "configure:9562: checking for glXCreateGLXPixmap" >&5
-#line 9563 "configure"
+#line 9565 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -9582,7 +9584,7 @@
; return 0; }
EOF
-if { (eval echo configure:9586: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9588: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -9625,7 +9627,7 @@
echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:9629: checking for location of OpenGL framework" >&5
+echo "configure:9631: checking for location of OpenGL framework" >&5
case "$with_opengl_framework" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -9649,15 +9651,15 @@
do
-echo "configure:9653: checking for $ac_hdr" >&5
+echo "configure:9655: checking for $ac_hdr" >&5
-#line 9656 "configure"
+#line 9658 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9661: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9663: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9693,10 +9695,10 @@
LIBS="-framework OpenGL -framework AGL -framework ApplicationServices $LIBS"
LDFLAGS="$OPENGLPATH $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:9697: checking for glBegin" >&5
+echo "configure:9699: checking for glBegin" >&5
-#line 9700 "configure"
+#line 9702 "configure"
which can conflict with char glBegin(); below. */
@@ -9719,7 +9721,7 @@
; return 0; }
EOF
-if { (eval echo configure:9723: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9725: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -9756,10 +9758,10 @@
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:9760: checking for gluBeginCurve" >&5
+echo "configure:9762: checking for gluBeginCurve" >&5
-#line 9763 "configure"
+#line 9765 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -9782,7 +9784,7 @@
; return 0; }
EOF
-if { (eval echo configure:9786: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9788: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -9830,7 +9832,7 @@
-echo "configure:9834: checking for location of OpenGL includes" >&5
+echo "configure:9836: checking for location of OpenGL includes" >&5
@@ -9856,15 +9858,15 @@
do
-echo "configure:9860: checking for $ac_hdr" >&5
+echo "configure:9862: checking for $ac_hdr" >&5
-#line 9863 "configure"
+#line 9865 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9868: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9870: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9898,7 +9900,7 @@
-echo "configure:9902: checking for location of OpenGL library" >&5
+echo "configure:9904: checking for location of OpenGL library" >&5
@@ -9923,18 +9925,18 @@
ac_save_libs="$LIBS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:9927: checking for OpenGL library" >&5
+echo "configure:9929: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 9931 "configure"
+#line 9933 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:9938: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9940: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -9958,18 +9960,18 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:9962: checking for GLU library" >&5
+echo "configure:9964: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 9966 "configure"
+#line 9968 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:9973: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9975: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -10018,7 +10020,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:10022: checking whether to use ODBC" >&5
+echo "configure:10024: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -10037,7 +10039,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:10041: checking for location of ODBC includes" >&5
+echo "configure:10043: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -10063,15 +10065,15 @@
do
-echo "configure:10067: checking for $ac_hdr" >&5
+echo "configure:10069: checking for $ac_hdr" >&5
-#line 10070 "configure"
+#line 10072 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10075: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10077: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10105,7 +10107,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:10109: checking for location of ODBC library" >&5
+echo "configure:10111: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -10130,13 +10132,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:10134: checking for SQLConnect in -lodbc" >&5
+echo "configure:10136: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 10140 "configure"
+#line 10142 "configure"
@@ -10147,7 +10149,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:10151: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10153: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10172,13 +10174,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:10176: checking for SQLConnect in -liodbc" >&5
+echo "configure:10178: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 10182 "configure"
+#line 10184 "configure"
@@ -10189,7 +10191,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:10193: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10195: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10214,11 +10216,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:10218: checking for ODBC library" >&5
+echo "configure:10220: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 10222 "configure"
+#line 10224 "configure"
#include <windows.h>
#include <sql.h>
@@ -10226,7 +10228,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:10230: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10232: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -10275,7 +10277,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:10279: checking whether to use FFTW" >&5
+echo "configure:10281: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -10294,7 +10296,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:10298: checking for location of FFTW includes" >&5
+echo "configure:10300: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -10320,15 +10322,15 @@
do
-echo "configure:10324: checking for $ac_hdr" >&5
+echo "configure:10326: checking for $ac_hdr" >&5
-#line 10327 "configure"
+#line 10329 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10332: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10334: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10356,15 +10358,15 @@
do
-echo "configure:10360: checking for $ac_hdr" >&5
+echo "configure:10362: checking for $ac_hdr" >&5
-#line 10363 "configure"
+#line 10365 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10368: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10370: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10392,15 +10394,15 @@
do
-echo "configure:10396: checking for $ac_hdr" >&5
+echo "configure:10398: checking for $ac_hdr" >&5
-#line 10399 "configure"
+#line 10401 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10404: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10406: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10446,7 +10448,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:10450: checking for location of FFTW library" >&5
+echo "configure:10452: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -10471,13 +10473,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:10475: checking for fftw_execute in -lfftw3" >&5
+echo "configure:10477: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 10481 "configure"
+#line 10483 "configure"
@@ -10488,7 +10490,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:10492: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10494: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10513,13 +10515,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:10517: checking for fftwnd_one in -lfftw" >&5
+echo "configure:10519: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
-#line 10523 "configure"
+#line 10525 "configure"
@@ -10530,7 +10532,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:10534: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10536: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10555,13 +10557,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:10559: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:10561: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 10565 "configure"
+#line 10567 "configure"
@@ -10572,7 +10574,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:10576: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10578: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10629,7 +10631,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:10633: checking whether to use BLAS" >&5
+echo "configure:10635: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -10650,7 +10652,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:10654: checking for location of BLAS includes" >&5
+echo "configure:10656: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -10670,7 +10672,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:10674: checking for location of BLAS library" >&5
+echo "configure:10676: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -10696,15 +10698,15 @@
do
-echo "configure:10700: checking for $ac_hdr" >&5
+echo "configure:10702: checking for $ac_hdr" >&5
-#line 10703 "configure"
+#line 10705 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10708: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10710: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10739,13 +10741,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:10743: checking for dnrm2_ in -lblas" >&5
+echo "configure:10745: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 10749 "configure"
+#line 10751 "configure"
@@ -10756,7 +10758,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:10760: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10762: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10775,13 +10777,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:10779: checking for dnrm2_ in -lblas" >&5
+echo "configure:10781: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 10785 "configure"
+#line 10787 "configure"
@@ -10792,7 +10794,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:10796: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10798: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10836,13 +10838,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:10840: checking for ATL_xerbla in -latlas" >&5
+echo "configure:10842: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 10846 "configure"
+#line 10848 "configure"
@@ -10853,7 +10855,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:10857: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10868,13 +10870,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:10872: checking for sgemm_ in -lf77blas" >&5
+echo "configure:10874: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 10878 "configure"
+#line 10880 "configure"
@@ -10885,7 +10887,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:10889: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10891: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10900,13 +10902,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:10904: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:10906: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 10910 "configure"
+#line 10912 "configure"
@@ -10917,7 +10919,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:10921: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10923: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10963,16 +10965,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:10967: checking for sgemm in $vlib_flags" >&5
+echo "configure:10969: checking for sgemm in $vlib_flags" >&5
-#line 10969 "configure"
+#line 10971 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:10976: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10978: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -10990,13 +10992,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:10994: checking for sgemm_ in -lblas" >&5
+echo "configure:10996: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 11000 "configure"
+#line 11002 "configure"
@@ -11007,7 +11009,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11011: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11013: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11022,13 +11024,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:11026: checking for dgemm_ in -ldgemm" >&5
+echo "configure:11028: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 11032 "configure"
+#line 11034 "configure"
@@ -11039,7 +11041,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:11043: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11045: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11054,13 +11056,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:11058: checking for sgemm_ in -lsgemm" >&5
+echo "configure:11060: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 11064 "configure"
+#line 11066 "configure"
@@ -11071,7 +11073,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11077: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11105,13 +11107,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:11109: checking for acosp in -lsunmath" >&5
+echo "configure:11111: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 11115 "configure"
+#line 11117 "configure"
@@ -11122,7 +11124,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:11126: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11128: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11137,13 +11139,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:11141: checking for sgemm_ in -lsunperf" >&5
+echo "configure:11143: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 11147 "configure"
+#line 11149 "configure"
@@ -11154,7 +11156,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11158: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11160: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11184,13 +11186,13 @@
# Generic BLAS library
-echo "configure:11188: checking for sgemm_ in -lblas" >&5
+echo "configure:11190: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 11194 "configure"
+#line 11196 "configure"
@@ -11201,7 +11203,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11205: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11207: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11240,7 +11242,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:11244: checking whether to use LAPACK" >&5
+echo "configure:11246: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -11265,7 +11267,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:11269: checking for location of LAPACK includes" >&5
+echo "configure:11271: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -11285,7 +11287,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:11289: checking for location of LAPACK library" >&5
+echo "configure:11291: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -11311,15 +11313,15 @@
do
-echo "configure:11315: checking for $ac_hdr" >&5
+echo "configure:11317: checking for $ac_hdr" >&5
-#line 11318 "configure"
+#line 11320 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11323: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11325: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11351,10 +11353,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:11355: checking for dsegv_" >&5
+echo "configure:11357: checking for dsegv_" >&5
-#line 11358 "configure"
+#line 11360 "configure"
which can conflict with char dsegv_(); below. */
@@ -11377,7 +11379,7 @@
; return 0; }
EOF
-if { (eval echo configure:11381: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11383: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -11404,13 +11406,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11408: checking for desgv_ in -llapack" >&5
+echo "configure:11410: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 11414 "configure"
+#line 11416 "configure"
@@ -11421,7 +11423,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:11425: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11427: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11453,13 +11455,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11457: checking for dgesv_ in -llapack" >&5
+echo "configure:11459: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 11463 "configure"
+#line 11465 "configure"
@@ -11470,7 +11472,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:11474: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11476: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11489,13 +11491,13 @@
-echo "configure:11493: checking for dgesv_ in -llapack" >&5
+echo "configure:11495: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 11499 "configure"
+#line 11501 "configure"
@@ -11506,7 +11508,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:11510: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11512: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11562,7 +11564,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:11566: checking whether to use Cairo" >&5
+echo "configure:11568: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -11594,7 +11596,7 @@
echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:11598: checking for location of cairo includes" >&5
+echo "configure:11600: checking for location of cairo includes" >&5
case "$with_cairo_includes" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -11620,15 +11622,15 @@
do
-echo "configure:11624: checking for $ac_hdr" >&5
+echo "configure:11626: checking for $ac_hdr" >&5
-#line 11627 "configure"
+#line 11629 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11632: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11634: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11664,7 +11666,7 @@
echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:11668: checking for location of cairo library" >&5
+echo "configure:11670: checking for location of cairo library" >&5
case "$with_cairo_libs" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -11684,7 +11686,7 @@
echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:11688: checking for cairo linking flags" >&5
+echo "configure:11690: checking for cairo linking flags" >&5
case "$with_cairo_ldflags" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -11700,10 +11702,10 @@
LIBS=" $CAIROLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:11704: checking for cairo_create" >&5
+echo "configure:11706: checking for cairo_create" >&5
-#line 11707 "configure"
+#line 11709 "configure"
which can conflict with char cairo_create(); below. */
@@ -11726,7 +11728,7 @@
; return 0; }
EOF
-if { (eval echo configure:11730: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11732: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -11760,10 +11762,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:11764: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:11766: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 11767 "configure"
+#line 11769 "configure"
which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below. */
@@ -11786,7 +11788,7 @@
; return 0; }
EOF
-if { (eval echo configure:11790: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11792: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
else
@@ -11819,10 +11821,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:11823: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:11825: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 11826 "configure"
+#line 11828 "configure"
which can conflict with char cairo_xlib_surface_get_xrender_format(); below. */
@@ -11845,7 +11847,7 @@
; return 0; }
EOF
-if { (eval echo configure:11849: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11851: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
else
@@ -11887,7 +11889,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:11891: checking whether to use FreeType" >&5
+echo "configure:11893: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -11906,7 +11908,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:11910: checking for location of FreeType includes" >&5
+echo "configure:11912: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -11932,15 +11934,15 @@
do
-echo "configure:11936: checking for $ac_hdr" >&5
+echo "configure:11938: checking for $ac_hdr" >&5
-#line 11939 "configure"
+#line 11941 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11944: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11946: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11974,7 +11976,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:11978: checking for location of FreeType library" >&5
+echo "configure:11980: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -11999,13 +12001,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:12003: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:12005: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 12009 "configure"
+#line 12011 "configure"
@@ -12016,7 +12018,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:12020: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12022: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12057,7 +12059,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:12061: checking whether to use NLS" >&5
+echo "configure:12063: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -12077,10 +12079,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:12081: checking for gettext" >&5
+echo "configure:12083: checking for gettext" >&5
-#line 12084 "configure"
+#line 12086 "configure"
which can conflict with char gettext(); below. */
@@ -12103,7 +12105,7 @@
; return 0; }
EOF
-if { (eval echo configure:12107: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12109: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -12121,13 +12123,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:12125: checking for gettext in -lintl" >&5
+echo "configure:12127: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 12131 "configure"
+#line 12133 "configure"
@@ -12138,7 +12140,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:12142: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12144: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12173,7 +12175,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:12177: checking whether to use C++" >&5
+echo "configure:12179: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -12189,7 +12191,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:12193: checking for $ac_word" >&5
+echo "configure:12195: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -12218,7 +12220,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:12222: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:12224: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -12229,12 +12231,12 @@
cat > conftest.$ac_ext << EOF
-#line 12233 "configure"
+#line 12235 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:12238: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12240: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -12260,19 +12262,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:12264: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:12266: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:12269: checking whether we are using GNU C++" >&5
+echo "configure:12271: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12276: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12278: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -12290,7 +12292,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:12294: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:12296: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -12328,7 +12330,7 @@
'void exit (int);'
do
-#line 12332 "configure"
+#line 12334 "configure"
#include <stdlib.h>
$ac_declaration
@@ -12336,7 +12338,7 @@
exit (42);
; return 0; }
EOF
-if { (eval echo configure:12340: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12342: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
echo "configure: failed program was:" >&5
@@ -12346,14 +12348,14 @@
fi
rm -f conftest*
cat > conftest.$ac_ext <<EOF
-#line 12350 "configure"
+#line 12352 "configure"
#include "confdefs.h"
$ac_declaration
int main() {
exit (42);
; return 0; }
EOF
-if { (eval echo configure:12357: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12359: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
break
else
@@ -12382,7 +12384,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:12386: checking whether to use openDWG" >&5
+echo "configure:12388: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -12402,7 +12404,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:12406: checking for location of openDGW includes" >&5
+echo "configure:12408: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -12428,15 +12430,15 @@
do
-echo "configure:12432: checking for $ac_hdr" >&5
+echo "configure:12434: checking for $ac_hdr" >&5
-#line 12435 "configure"
+#line 12437 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12440: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12442: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12470,7 +12472,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:12474: checking for location of openDWG library" >&5
+echo "configure:12476: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -12511,7 +12513,7 @@
echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:12515: checking whether to use POSIX threads" >&5
+echo "configure:12517: checking whether to use POSIX threads" >&5
echo "$ac_t"""$with_pthread"" 1>&6
case "$with_pthread" in
"no") USE_PTHREAD= ;;
@@ -12531,7 +12533,7 @@
echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:12535: checking for location of POSIX threads includes" >&5
+echo "configure:12537: checking for location of POSIX threads includes" >&5
case "$with_pthread_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -12557,15 +12559,15 @@
do
-echo "configure:12561: checking for $ac_hdr" >&5
+echo "configure:12563: checking for $ac_hdr" >&5
-#line 12564 "configure"
+#line 12566 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:12569: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12571: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -12599,7 +12601,7 @@
echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:12603: checking for location of POSIX threads library" >&5
+echo "configure:12605: checking for location of POSIX threads library" >&5
case "$with_pthread_libs" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -12624,10 +12626,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:12628: checking for pthread_create" >&5
+echo "configure:12630: checking for pthread_create" >&5
-#line 12631 "configure"
+#line 12633 "configure"
which can conflict with char pthread_create(); below. */
@@ -12650,7 +12652,7 @@
; return 0; }
EOF
-if { (eval echo configure:12654: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12656: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_pthread_create=yes"
else
@@ -12677,13 +12679,13 @@
echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:12681: checking for pthread_create in -lpthread" >&5
+echo "configure:12683: checking for pthread_create in -lpthread" >&5
ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lpthread $LIBS"
-#line 12687 "configure"
+#line 12689 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -12694,7 +12696,7 @@
pthread_create()
; return 0; }
EOF
-if { (eval echo configure:12698: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12700: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -12744,7 +12746,7 @@
echo $ac_n "checking whether to use OpenMP""... $ac_c" 1>&6
-echo "configure:12748: checking whether to use OpenMP" >&5
+echo "configure:12750: checking whether to use OpenMP" >&5
echo "$ac_t"""$with_openmp"" 1>&6
case "$with_openmp" in
"no") USE_OPENMP= ;;
@@ -12765,7 +12767,7 @@
echo $ac_n "checking for location of OpenMP includes""... $ac_c" 1>&6
-echo "configure:12769: checking for location of OpenMP includes" >&5
+echo "configure:12771: checking for location of OpenMP includes" >&5
case "$with_openmp_includes" in
{ echo "configure: error: *** You must supply a directory to --with-openmp-includes." 1>&2; exit 1; }
@@ -12791,15 +12793,15 @@
do
-echo "configure:12795: checking for $ac_hdr" >&5
+echo "configure:12797: checking for $ac_hdr" >&5
-#line 12798 "configure"
+#line 12800 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12803: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12805: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12837,7 +12839,7 @@
echo $ac_n "checking for location of OpenMP library""... $ac_c" 1>&6
-echo "configure:12841: checking for location of OpenMP library" >&5
+echo "configure:12843: checking for location of OpenMP library" >&5
case "$with_gomp_libs" in
{ echo "configure: error: *** You must supply a directory to --with-gomp-libs." 1>&2; exit 1; }
@@ -12862,10 +12864,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for GOMP_parallel_start""... $ac_c" 1>&6
-echo "configure:12866: checking for GOMP_parallel_start" >&5
+echo "configure:12868: checking for GOMP_parallel_start" >&5
-#line 12869 "configure"
+#line 12871 "configure"
which can conflict with char GOMP_parallel_start(); below. */
@@ -12888,7 +12890,7 @@
; return 0; }
EOF
-if { (eval echo configure:12892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12894: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_GOMP_parallel_start=yes"
else
@@ -12915,13 +12917,13 @@
echo $ac_n "checking for GOMP_parallel_start in -lgomp""... $ac_c" 1>&6
-echo "configure:12919: checking for GOMP_parallel_start in -lgomp" >&5
+echo "configure:12921: checking for GOMP_parallel_start in -lgomp" >&5
ac_lib_var=`echo gomp'_'GOMP_parallel_start | sed 'y%./+-%__p_%'`
LIBS="-lgomp $LIBS"
-#line 12925 "configure"
+#line 12927 "configure"
@@ -12932,7 +12934,7 @@
; return 0; }
EOF
-if { (eval echo configure:12936: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12938: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13011,7 +13013,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:13015: checking for special C compiler options needed for large files" >&5
+echo "configure:13017: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -13019,7 +13021,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 13023 "configure"
+#line 13025 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -13035,7 +13037,7 @@
; return 0; }
EOF
-if { (eval echo configure:13039: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13041: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
@@ -13044,7 +13046,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 13048 "configure"
+#line 13050 "configure"
@@ -13060,7 +13062,7 @@
; return 0; }
EOF
-if { (eval echo configure:13064: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13066: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -13080,11 +13082,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:13084: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:13086: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 13088 "configure"
+#line 13090 "configure"
@@ -13100,14 +13102,14 @@
; return 0; }
EOF
-if { (eval echo configure:13104: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13106: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
cat conftest.$ac_ext >&5
rm -rf conftest*
-#line 13111 "configure"
+#line 13113 "configure"
#define _FILE_OFFSET_BITS 64
@@ -13125,7 +13127,7 @@
; return 0; }
EOF
-if { (eval echo configure:13129: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13131: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -13144,11 +13146,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:13148: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:13150: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 13152 "configure"
+#line 13154 "configure"
@@ -13164,14 +13166,14 @@
; return 0; }
EOF
-if { (eval echo configure:13168: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13170: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13175 "configure"
+#line 13177 "configure"
#define _LARGE_FILES 1
@@ -13189,7 +13191,7 @@
; return 0; }
EOF
-if { (eval echo configure:13193: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13195: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -13208,25 +13210,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:13212: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13214: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 13216 "configure"
+#line 13218 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13223: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13225: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13230 "configure"
+#line 13232 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -13235,7 +13237,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13239: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13241: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -13256,25 +13258,25 @@
fi
-echo "configure:13260: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13262: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 13264 "configure"
+#line 13266 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13271: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13273: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13278 "configure"
+#line 13280 "configure"
#include <stdio.h>
@@ -13283,7 +13285,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13287: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13289: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
else
@@ -13306,18 +13308,18 @@
# If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:13310: checking for fseeko" >&5
+echo "configure:13312: checking for fseeko" >&5
ac_cv_func_fseeko=no
-#line 13314 "configure"
+#line 13316 "configure"
#include <stdio.h>
int main() {
return fseeko && fseeko (stdin, 0, 0);
; return 0; }
EOF
-if { (eval echo configure:13321: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13323: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_func_fseeko=yes
else
@@ -13334,10 +13336,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:13338: checking if system supports Large Files at all" >&5
+echo "configure:13340: checking if system supports Large Files at all" >&5
-#line 13341 "configure"
+#line 13343 "configure"
#include <stdio.h>
@@ -13369,7 +13371,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:13373: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13375: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -13398,7 +13400,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:13402: checking whether to use wxWidgets" >&5
+echo "configure:13404: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -13419,7 +13421,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:13423: checking for $ac_word" >&5
+echo "configure:13425: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -13467,7 +13469,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:13471: checking wxWidgets version" >&5
+echo "configure:13473: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -13490,15 +13492,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13494: checking for $ac_hdr" >&5
+echo "configure:13496: checking for $ac_hdr" >&5
-#line 13497 "configure"
+#line 13499 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13502: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13504: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
