[GRASS-SVN] r55565 - in grass/trunk: raster/r.tile raster3d/r3.retile
svn_grass at osgeo.org
Wed Mar 27 14:42:23 PDT 2013
Author: neteler
Date: 2013-03-27 14:42:23 -0700 (Wed, 27 Mar 2013)
New Revision: 55565
grass/trunk/raster/r.tile/r.tile.html
grass/trunk/raster3d/r3.retile/r3.retile.html
r.tile: +description, +example
Modified: grass/trunk/raster/r.tile/r.tile.html
--- grass/trunk/raster/r.tile/r.tile.html 2013-03-27 21:18:11 UTC (rev 55564)
+++ grass/trunk/raster/r.tile/r.tile.html 2013-03-27 21:42:23 UTC (rev 55565)
@@ -1,11 +1,38 @@
<h2>DESCRIPTION</h2>
+<em>r.tile</em> retiles an existing raster map with user defined
+x and y tile size.
<h2>NOTES</h2>
+<em>r.tile</em> generates a separate raster for each tile.
+This is equivalent to running <em>g.region</em> along with
+<em>r.resample</em> in a double loop.
+<p>
+The module can be used to split a large raster map into smaller
+tiles, e.g. for further parallelized analysis on a cluster.
+<h2>EXAMPLE</h2>
+Retiling example for the North Carolina DEM:
+<div class="code"><pre>
+g.region rast=elevation -p
+# rows: 1350
+# cols: 1500
+r.tile input=elevation output=elev_tile width=135 height=150
+</pre></div>
+creates 108 tiles with the prefix <em>elev_tile</em> (named:
+elev_tile-000-000, elev_tile-000-001, elev_tile-000-002, ...).
<h2>SEE ALSO</h2>
-<em><a href="g.region.html">g.region</a></em>,
-<em><a href="r3.retile.html">r3.retile</a></em>,
+<em>
+<a href="g.region.html">g.region</a>,
+<a href="r3.retile.html">r3.retile</a>
+</em>
<h2>AUTHOR</h2>
Modified: grass/trunk/raster3d/r3.retile/r3.retile.html
--- grass/trunk/raster3d/r3.retile/r3.retile.html 2013-03-27 21:18:11 UTC (rev 55564)
+++ grass/trunk/raster3d/r3.retile/r3.retile.html 2013-03-27 21:42:23 UTC (rev 55565)
@@ -1,7 +1,7 @@
-Writes a copy of an existing 3D raster map with a user defined
-number of tiles in x, y and z direction.
+<em>r3.retile</em> writes a copy of an existing 3D raster map with
+a user defined number of tiles in x, y and z direction.
The precision and the type of the original 3D raster map are used for
the new retiled 3D raster map.
@@ -9,8 +9,9 @@
<em>
<a href="r3.info.html">r3.cross.rast</a>,
-<em><a href="r3.out.ascii.html">r3.out.ascii</a>,
+<a href="r3.out.ascii.html">r3.out.ascii</a>,
+<a href="r3.retile.html">r.tile</a>
</em>
<h2>AUTHOR</h2>
