[GRASS-SVN] r55566 - grass/trunk/scripts/v.pack
svn_grass at osgeo.org
Thu Mar 28 09:42:46 PDT 2013
Author: martinl
Date: 2013-03-28 09:42:46 -0700 (Thu, 28 Mar 2013)
New Revision: 55566
grass/trunk/scripts/v.pack/v.pack.py
v.pack: only native format supported
cosmetics
Modified: grass/trunk/scripts/v.pack/v.pack.py
--- grass/trunk/scripts/v.pack/v.pack.py 2013-03-27 21:42:23 UTC (rev 55565)
+++ grass/trunk/scripts/v.pack/v.pack.py 2013-03-28 16:42:46 UTC (rev 55566)
@@ -46,61 +46,74 @@
def main():
infile = options['input']
compression_off = flags['c']
- #search if file exist
+ # check if vector map exist
gfile = grass.find_file(infile, element = 'vector')
if not gfile['name']:
grass.fatal(_("Vector map <%s> not found") % infile)
- #split the name if there is the mapset name
+ # check if input vector map is in native format
+ if vector.vector_info(gfile['fullname'])['format'] != 'native':
+ grass.fatal(_("Unable to pack vector map <%s>. Only native format supported.") % \
+ gfile['fullname'])
+ # split the name if there is the mapset name
if infile.find('@'):
- infile = infile.split('@')[0]
- #output name
+ infile = infile.split('@')[0]
+ # output name
if options['output']:
outfile = options['output']
else:
outfile = infile + '.pack'
- #check if exists the output file
+ # check if exists the output file
if os.path.exists(outfile):
if os.getenv('GRASS_OVERWRITE'):
grass.warning(_("Pack file <%s> already exists and will be overwritten") % outfile)
grass.try_remove(outfile)
else:
grass.fatal(_("option <output>: <%s> exists.") % outfile)
+ # prepare for packing
grass.verbose(_("Packing <%s>...") % (gfile['fullname']))
basedir = os.path.sep.join(gfile['file'].split(os.path.sep)[:-2])
olddir = os.getcwd()
- #check if exist a db connection for the vector
+ # check if exist a db connection for the vector
db_vect = vector.vector_db(gfile['fullname'])
- #db not exist and skip the db copy
sqlitedb = None
if not db_vect:
grass.verbose(_('There is not database connected with vector map <%s>') % gfile['fullname'])
else:
- # for each layer connection save a table
+ # for each layer connection save a table in sqlite database
for i, dbconn in db_vect.iteritems():
sqlitedb = os.path.join(basedir, 'vector', infile, 'db.sqlite')
cptable = grass.run_command('db.copy', from_driver = dbconn['driver'],
- from_database = dbconn['database'], from_table = dbconn['table'],
- to_driver = 'sqlite', to_database = sqlitedb,
- to_table = dbconn['table'])
+ from_database = dbconn['database'], from_table = dbconn['table'],
+ to_driver = 'sqlite', to_database = sqlitedb,
+ to_table = dbconn['table'])
# write tar file, optional compression
if compression_off:
tar = tarfile.open(name = outfile, mode = 'w:')
else:
tar = tarfile.open(name = outfile, mode = 'w:gz')
- tar.add(os.path.join(basedir,'vector',infile),infile)
+ tar.add(os.path.join(basedir,'vector', infile), infile)
+ # add to the tar file the PROJ files to check when unpack file
gisenv = grass.gisenv()
- #add to the tar file the PROJ files to check when unpack file
for support in ['INFO', 'UNITS']:
path = os.path.join(gisenv['GISDBASE'], gisenv['LOCATION_NAME'],
'PERMANENT', 'PROJ_' + support)
if os.path.exists(path):
- tar.add(path,os.path.join(infile,'PROJ_' + support))
+ tar.add(path,os.path.join(infile,'PROJ_' + support))
tar.close()
- #remove the db from the vector directory #ONLY THE DB FOR THE COPY NOT DB OF GRASS
+ # remove the db from the vector directory (ONLY THE DB FOR THE COPY NOT DB OF GRASS)
if db_vect and sqlitedb:
os.remove(sqlitedb)
grass.message(_("Pack file <%s> created") % os.path.join(olddir, outfile))
if __name__ == "__main__":
