[GRASS-SVN] r55567 - grass/trunk/scripts/v.unpack
svn_grass at osgeo.org
Thu Mar 28 09:53:55 PDT 2013
Author: martinl
Date: 2013-03-28 09:53:54 -0700 (Thu, 28 Mar 2013)
New Revision: 55567
grass/trunk/scripts/v.unpack/v.unpack.py
v.unpack: message cosmetics (fix brackets position)
Modified: grass/trunk/scripts/v.unpack/v.unpack.py
--- grass/trunk/scripts/v.unpack/v.unpack.py 2013-03-28 16:42:46 UTC (rev 55566)
+++ grass/trunk/scripts/v.unpack/v.unpack.py 2013-03-28 16:53:54 UTC (rev 55567)
@@ -52,14 +52,17 @@
def main():
infile = options['input']
# create temporary directory
global tmp_dir
tmp_dir = grass.tempdir()
grass.debug('tmp_dir = %s' % tmp_dir)
- #check if the file exist
+ # check if the input file exists
if not os.path.exists(infile):
- grass.fatal(_("File <%s> not found" % infile))
- #copy the files to tmp dir
+ grass.fatal(_("File <%s> not found") % infile)
+ # copy the files to tmp dir
input_base = os.path.basename(infile)
shutil.copyfile(infile, os.path.join(tmp_dir, input_base))
os.chdir(tmp_dir)
@@ -68,19 +71,21 @@
data_name = tar.getnames()[0]
except:
grass.fatal(_("Pack file unreadable"))
- #set the output name
+ # set the output name
if options['output']:
map_name = options['output']
else:
map_name = data_name
# grass env
gisenv = grass.gisenv()
mset_dir = os.path.join(gisenv['GISDBASE'],
gisenv['LOCATION_NAME'],
gisenv['MAPSET'])
- new_dir = os.path.join(mset_dir,'vector',map_name)
+ new_dir = os.path.join(mset_dir, 'vector', map_name)
gfile = grass.find_file(name = map_name, element = 'vector',
mapset = '.')
overwrite = os.getenv('GRASS_OVERWRITE')
@@ -93,7 +98,7 @@
# extract data
tar.extractall()
# check projection compatibility in a rather crappy way
loc_proj = os.path.join(mset_dir, '..', 'PERMANENT', 'PROJ_INFO')
loc_proj_units = os.path.join(mset_dir, '..', 'PERMANENT', 'PROJ_UNITS')
@@ -103,30 +108,30 @@
grass.warning(_("Projection information does not match. Proceeding..."))
else:
grass.fatal(_("Projection information does not match. Aborting."))
- #new db
+ # new db
fromdb = os.path.join(new_dir, 'db.sqlite')
- #copy file
+ # copy file
shutil.copytree(data_name, new_dir)
- #exist fromdb
+ # exist fromdb
if os.path.exists(fromdb):
- #the db connection in the output mapset
+ # the db connection in the output mapset
dbconn = grassdb.db_connection()
if dbconn['database'].find('GISDBASE'):
dbstr = os.path.sep.join(dbconn['database'].split(os.path.sep)[3:])
todb = os.path.join(mset_dir, dbstr)
else:
todb = dbconn['database']
- #return all tables
+ # return all tables
list_fromtable = grass.read_command('db.tables',driver='sqlite',database=fromdb)
list_fromtable = list_fromtable.split('\n')
- #return the list of old connection for extract layer number and key
+ # return the list of old connection for extract layer number and key
dbln = open(os.path.join(new_dir,'dbln'),'r')
dbnlist = dbln.readlines()
dbln.close()
- #for each old connection
+ # for each old connection
for t in dbnlist:
- #it split the line of each connection, to found layer number and key
+ # it split the line of each connection, to found layer number and key
if len(t.split('|')) != 1:
values = t.split('|')
else:
@@ -134,40 +139,41 @@
from_table = values[1]
layer = values[0].split('/')[0]
- # We need to take care about the table name in case of several layer
+ # we need to take care about the table name in case of several layer
if options["output"]:
to_table = "%s_%s"%(map_name, layer)
else:
to_table = from_table
- grass.verbose(_("Copy table %s to table %s"%(from_table, to_table)))
+ grass.verbose(_("Coping table <%s> as table <%s>") % (from_table, to_table))
- #copy the table in the default database
+ # copy the table in the default database
ret = grass.run_command('db.copy', to_driver = dbconn['driver'],
- to_database = todb, to_table = to_table,
- from_driver = 'sqlite', from_database = fromdb,
- from_table = from_table)
+ to_database = todb, to_table = to_table,
+ from_driver = 'sqlite', from_database = fromdb,
+ from_table = from_table)
if ret != 0:
- grass.fatal(_("Unable to copy table %s to table %s"%(from_table, to_table)))
+ grass.fatal(_("Unable to copy table <%s> as table <%s>") % (from_table, to_table))
- grass.verbose(_("Connect table %s to vector %s at layer %s"%(to_table, map_name, layer)))
- #and connect the new tables with the right layer
+ grass.verbose(_("Connect table <%s> to vector map <%s> at layer <%s>") % \
+ (to_table, map_name, layer))
+ # and connect the new tables with the right layer
ret = grass.run_command('v.db.connect', flags = "o",
- driver = dbconn['driver'], database = todb,
- map = map_name, key = values[2],
- layer = layer, table = to_table)
+ driver = dbconn['driver'], database = todb,
+ map = map_name, key = values[2],
+ layer = layer, table = to_table)
if ret != 0:
- grass.fatal(_("Unable to connect table %s to vector map %s"%(to_table, map_name)))
+ grass.fatal(_("Unable to connect table <%s> to vector map <%s>") % (to_table, map_name))
- #remove
- os.remove(os.path.join(new_dir,'PROJ_INFO'))
- os.remove(os.path.join(new_dir,'PROJ_UNITS'))
+ # remove
+ os.remove(os.path.join(new_dir, 'PROJ_INFO'))
+ os.remove(os.path.join(new_dir, 'PROJ_UNITS'))
- os.remove(os.path.join(new_dir,'db.sqlite'))
+ os.remove(os.path.join(new_dir, 'db.sqlite'))
+ grass.message(_("Vector map <%s> succesfully unpacked") % map_name)
- grass.verbose(_("Vector map saved to <%s>") % map_name)
if __name__ == "__main__":
options, flags = grass.parser()
atexit.register(cleanup)
