[GRASS-SVN] r55572 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Thu Mar 28 13:05:15 PDT 2013
Author: martinl
Date: 2013-03-28 13:05:15 -0700 (Thu, 28 Mar 2013)
New Revision: 55572
grass/trunk/lib/vector/Vlib/copy.c
vlib: Vect_copy_lines_field(): fix copying areas (simple features output) - skip isles (work in progress)
Modified: grass/trunk/lib/vector/Vlib/copy.c
--- grass/trunk/lib/vector/Vlib/copy.c 2013-03-28 19:36:16 UTC (rev 55571)
+++ grass/trunk/lib/vector/Vlib/copy.c 2013-03-28 20:05:15 UTC (rev 55572)
@@ -5,7 +5,7 @@
Higher level functions for reading/writing/manipulating vectors.
- (C) 2001-2009, 2012 by the GRASS Development Team
+ (C) 2001-2009, 2012-2013 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
@@ -36,6 +36,7 @@
static int copy_lines_1(struct Map_info *, int, struct Map_info *);
static int copy_lines_2(struct Map_info *, int, int, struct Map_info *);
static int copy_nodes(const struct Map_info *, struct Map_info *);
+static int is_isle(const struct Map_info *, int);
static int copy_areas(const struct Map_info *, int, struct Map_info *);
@@ -325,6 +326,45 @@
+ \brief Check if area forms an isle
+ Check for areas that are part of isles which in turn are inside
+ another area.
+ \param Map pointer to Map_info struct
+ \param area area id
+ \return TRUE if area forms an isle otherwise FALSE
+int is_isle(const struct Map_info *Map, int area)
+ int i, line, left, right, isle, is_isle;
+ struct ilist *List;
+ List = Vect_new_list();
+ Vect_get_area_boundaries(Map, area, List);
+ is_isle = FALSE;
+ /* do we need to check all boundaries ? */
+ for (i = 0; i < List->n_values && !is_isle; i++) {
+ line = abs(List->value[i]);
+ if (1 != Vect_get_line_areas(Map, line, &left, &right))
+ continue;
+ isle = abs(left == area ? right : left);
+ if (Vect_get_isle_area(Map, isle) > 0)
+ is_isle = TRUE;
+ G_debug(3, "is_isle(): area %d skip? -> %s", area, is_isle ? "yes" : "no");
+ Vect_destroy_list(List);
+ return is_isle;
\brief Copy areas as polygons (OGR/PostGIS simple features access only)
\param In input vector map
@@ -354,19 +394,21 @@
for (area = 1; area <= nareas; area++) {
G_debug(3, "area = %d", area);
G_percent(area, nareas, 3);
- /* get outer ring (area) geometry */
- Vect_get_area_points(In, area, Points);
/* get area category */
cat = Vect_get_area_cat(In, area, field);
if (cat < 0) {
- G_warning(_("No category defined for area %d. "
- "Area not exported."),
- area);
+ /* no category - check if area forms an isle */
+ if (!is_isle(In, area))
+ G_warning(_("No category defined for area %d. "
+ "Area not exported."),
+ area);
continue;
- G_debug(3, " -> cat %d", cat);
+ /* get outer ring (area) geometry */
+ Vect_get_area_points(In, area, Points);
Vect_reset_cats(Cats);
Vect_cat_set(Cats, field, cat);
@@ -381,7 +423,7 @@
IPoints[i] = Vect_new_line_struct();
nisles_alloc = nisles;
- G_debug(3, " -> nisles=%d", nisles);
+ G_debug(3, "\tcat=%d, nisles=%d", cat, nisles);
for (i = 0; i < nisles; i++) {
isle = Vect_get_area_isle(In, area, i);
Vect_get_isle_points(In, isle, IPoints[i]);
