[GRASS-SVN] r56074 - grass/branches/develbranch_6/db/base
svn_grass at osgeo.org
Thu May 2 01:51:18 PDT 2013
Author: hamish
Date: 2013-05-02 01:51:18 -0700 (Thu, 02 May 2013)
New Revision: 56074
grass/branches/develbranch_6/db/base/select.c
backwards CLI compatibility: don't reorder the first option (#1503)
Modified: grass/branches/develbranch_6/db/base/select.c
--- grass/branches/develbranch_6/db/base/select.c 2013-05-02 08:19:52 UTC (rev 56073)
+++ grass/branches/develbranch_6/db/base/select.c 2013-05-02 08:51:18 UTC (rev 56074)
@@ -187,6 +187,9 @@
/* Initialize the GIS calls */
G_gisinit(argv[0]);
+ table = G_define_standard_option(G_OPT_TABLE);
+ table->guisection = _("Connection");
sql = G_define_option();
sql->key = "sql";
sql->type = TYPE_STRING;
@@ -201,9 +204,6 @@
input->description = _("Name of file with SQL select statement(s)");
input->guisection = _("Query");
- table = G_define_standard_option(G_OPT_TABLE);
- table->guisection = _("Connection");
database = G_define_standard_option(G_OPT_DATABASE);
if ((db = db_get_default_database_name()))
database->answer = (char *) db;
