[GRASS-SVN] r56075 - grass/branches/releasebranch_6_4/scripts/v.db.update
svn_grass at osgeo.org
Thu May 2 02:29:18 PDT 2013
Author: mlennert
Date: 2013-05-02 02:29:18 -0700 (Thu, 02 May 2013)
New Revision: 56075
grass/branches/releasebranch_6_4/scripts/v.db.update/description.html
grass/branches/releasebranch_6_4/scripts/v.db.update/v.db.update
clarify difference between value and qcol options
Modified: grass/branches/releasebranch_6_4/scripts/v.db.update/description.html
--- grass/branches/releasebranch_6_4/scripts/v.db.update/description.html 2013-05-02 08:51:18 UTC (rev 56074)
+++ grass/branches/releasebranch_6_4/scripts/v.db.update/description.html 2013-05-02 09:29:18 UTC (rev 56075)
@@ -1,8 +1,8 @@
<h2>DESCRIPTION</h2>
<em>v.db.update</em> assigns a new value to a column in the
-attribute table connected to a given map. Alternatively, values can
-be copied from another column in the table.
+attribute table connected to a given map. The <em>value</em> parameter updates with a literal value. Alternatively, with the <em>qcol</em> parameter values can
+be copied from another column in the table or be the result of a combination or transformation of other columns.
<h2>NOTES</h2>
Modified: grass/branches/releasebranch_6_4/scripts/v.db.update/v.db.update
--- grass/branches/releasebranch_6_4/scripts/v.db.update/v.db.update 2013-05-02 08:51:18 UTC (rev 56074)
+++ grass/branches/releasebranch_6_4/scripts/v.db.update/v.db.update 2013-05-02 09:29:18 UTC (rev 56075)
@@ -43,14 +43,14 @@
#%option
#% key: value
#% type: string
-#% description: Value to update the column with (varchar values have to be in single quotes, e.g. 'grass')
+#% description: Literal value to update the column with
#% required : no
#%end
#%option
#% key: qcolumn
#% gisprompt: old_dbcolumn,dbcolumn,dbcolumn
#% type: string
-#% description: Column to query
+#% description: Name of other attribute column to query, can be combination of columns (e.g. col1+col2)
#% required : no
#%end
#%option
