[GRASS-SVN] r56190 - in grass-addons/grass7/raster: . r.traveltime
svn_grass at osgeo.org
Fri May 10 13:46:38 PDT 2013
Author: neteler
Date: 2013-05-10 13:46:38 -0700 (Fri, 10 May 2013)
New Revision: 56190
Added:
grass-addons/grass7/raster/r.traveltime/
grass-addons/grass7/raster/r.traveltime/r.traveltime.html
Removed:
grass-addons/grass7/raster/r.traveltime/description.html
grass-addons/grass7/raster/Makefile
grass-addons/grass7/raster/r.traveltime/Makefile
grass-addons/grass7/raster/r.traveltime/main.c
r.traveltime: attempt to port it to GRASS 7 (using http://trac.osgeo.org/grass/wiki/Grass7/RasterLib/ListOfFunctions)
Modified: grass-addons/grass7/raster/Makefile
--- grass-addons/grass7/raster/Makefile 2013-05-10 18:36:36 UTC (rev 56189)
+++ grass-addons/grass7/raster/Makefile 2013-05-10 20:46:38 UTC (rev 56190)
@@ -27,7 +27,8 @@
r.stream.slope \
r.stream.snap \
r.stream.stats \
- r.threshold
+ r.threshold \
+ r.traveltime
include $(MODULE_TOPDIR)/include/Make/Dir.make
Modified: grass-addons/grass7/raster/r.traveltime/Makefile
--- grass-addons/grass6/raster/r.traveltime/Makefile 2013-05-10 18:36:36 UTC (rev 56189)
+++ grass-addons/grass7/raster/r.traveltime/Makefile 2013-05-10 20:46:38 UTC (rev 56190)
@@ -1,12 +1,9 @@
-# Uncoment and fix MODULE_TOPDIR line OR provide MODULE_TOPDIR variable for make
-# fix this relative to include/
-# or use absolute path to the GRASS source code
-#MODULE_TOPDIR = ../..
+MODULE_TOPDIR = ../..
PGM = r.traveltime
-LIBES = $(GISLIB)
-DEPENDENCIES = $(GISDEP)
+LIBES = $(GMATHLIB) $(RASTERLIB) $(GISLIB)
+DEPENDENCIES = $(GMATHDEP) $(RASTERDEP) $(GISDEP)
include $(MODULE_TOPDIR)/include/Make/Module.make
Deleted: grass-addons/grass7/raster/r.traveltime/description.html
--- grass-addons/grass6/raster/r.traveltime/description.html 2013-05-10 18:36:36 UTC (rev 56189)
+++ grass-addons/grass7/raster/r.traveltime/description.html 2013-05-10 20:46:38 UTC (rev 56190)
@@ -1,69 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>r.traveltime</em> computes the travel time of surface runoff to an
-outlet. The program starts at the basin outlet and calculates the travel
-time at each raster cell recursively. A drainage area related threhold
-considers even surface and also channel runoff. Travel times are
-derived by assuming kinematic wave approximation.<br>
-To derive channel flow velocities an equilibrium discharge for each
-cell is calculated (Q=Area*Excess_Prcipitation, Assumption: storm
-duration >= time of concentration). This assumption may result
-in overestimated velocities. Therefor a factor is implemented to reduce
-velocities biased towards too large values.<br>
-The results can be used to derive a time-area function. This might be
-usefull for precipitation-runoff calculations (estimation of flood
-predictions) with a lumped hydrologic model (user-specified unit
-hydrograph).
-<h2>REMARKS</h2>
-The program ist restricted to SI units (meters). The algorithm is
-recursive. Maybe it will not work with extensive datasets. It is
-assumed that the minimum slope is 0.001. For smaller gradients the
-program uses this value.
-<h2>KNOWN ISSUES</h2>
-The program does not work correctly if Manning's roughness grid is
-defined as double (float expected). To define a simple uniform
-roughness distribution try: r.mapcalc 'roughness=0.1f'
-<br>
-The region has to be set one row and column larger than the elevation
-map. See the example below to see how to do that with g.region.
-<h2>EXAMPLE</h2>
-<i>This example uses the North Carolina sample dataset.</i>
-<p>
-<div class="code"><pre>
- g.region rast=elev_lid792_1m n=n+1 s=s-1 w=w-1 e=e+1 -p
- r.watershed elev_lid792_1m thresh=5000 accum=accum_5K drain=draindir_5K
- r.fill.dir elev_lid792_1m elev=elev_filled dir=elev_dir
- r.mapcalc rough=0.1f
- r.traveltime --overwrite dir=draindir_5K at user1 accu=accum_5K at user1 \
- dtm=elev_filled at user1 manningsn=rough out_x=638741.43125 \
- out_y=220269.7 threshold=1 b=1 nchannel=0.1 ep=40 fdis=1 \
- out=travel_time
-</pre></div>
-</p>
-<h2>SEE ALSO</h2>
-<em><a href="r.watershed.html">r.watershed</a>,
- <a href="r.fill.dir.html">r.fill.dir</a>
- <br>
- <br>
- <a href="http://jesbergwetter.twoday.net/stories/4845555/">http://jesbergwetter.twoday.net/stories/4845555/</a>
- <h2>REFERENCES</h2>
- <li>Kilgore, J. L. (1997): <em>Development and evaluation of a GIS-based
-spatially distributed unit hydrograph model</em>, master thesis,
-Virginia
-Polytechnic Institute and State University.</li>
-<li>Melesse, A. M., Graham, W. D. (2004):<em> Storm runoff predicition
-based on a
-spatially distributed travel time method utilizing remote sensing and
-GIS</em>, Journal of the American Water Resources Association, 8,
-863-879.</li>
-<li>Muzik, I. (1996): <em>Flood modelling with GIS-derived distributed
- unit hydrographs</em>, Hydrological Processes, 10, 1401-1409.</li>
-<h2>AUTHOR</h2>
-Kristian Foerster<br>
-<p><i>Last changed: $Date$</i>
-</p>
Modified: grass-addons/grass7/raster/r.traveltime/main.c
--- grass-addons/grass6/raster/r.traveltime/main.c 2013-05-10 18:36:36 UTC (rev 56189)
+++ grass-addons/grass7/raster/r.traveltime/main.c 2013-05-10 20:46:38 UTC (rev 56190)
@@ -27,6 +27,7 @@
#include <limits.h>
#include <float.h>
#include <grass/gis.h>
+#include <grass/raster.h>
#include <grass/glocale.h>
#include <grass/config.h>
@@ -57,8 +58,7 @@
int x_exp, y_exp;
int value;
- if (G_get_raster_row(in_dir, inrast_dir, loc_y, data_type_dir) < 0)
- G_fatal_error(_("Could not read from map"));
+ Rast_get_row(in_dir, inrast_dir, loc_y, data_type_dir);
value = ((CELL *) inrast_dir)[loc_x];
// conversions of the flow direction classification to vectors
@@ -150,16 +150,13 @@
double z1, z2;
double manningsn;
- if (G_get_raster_row(in_dir, inrast_dir, y, data_type_dir) < 0)
+ Rast_get_row(in_dir, inrast_dir, y, data_type_dir);
dir = ((CELL *) inrast_dir)[x];
- if (G_get_raster_row(in_accu, inrast_accu, y, data_type_accu) < 0)
+ Rast_get_row(in_accu, inrast_accu, y, data_type_accu);
accu = ((CELL *) inrast_accu)[x];
- if (G_get_raster_row(in_n, inrast_n, y, data_type_n) < 0)
+ Rast_get_row(in_n, inrast_n, y, data_type_n);
switch (data_type_n) {
case DCELL_TYPE:
manningsn = (double)((DCELL *) inrast_n)[x];
@@ -169,8 +166,7 @@
break;
- if (G_get_raster_row(in_dtm, inrast_dtm, y, data_type_dtm) < 0)
+ Rast_get_row(in_dtm, inrast_dtm, y, data_type_dtm);
switch (data_type_dtm) {
case CELL_TYPE:
z2 = (double)((CELL *) inrast_dtm)[x];
@@ -183,8 +179,7 @@
break;
- if (G_get_raster_row(in_dtm, inrast_dtm, y - dy, data_type_dtm) < 0)
+ Rast_get_row(in_dtm, inrast_dtm, y - dy, data_type_dtm);
case CELL_TYPE:
z1 = (double)((CELL *) inrast_dtm)[x - dx];
@@ -197,8 +192,6 @@
break;
for (i = -1; i < 2; i++) {
for (j = -1; j < 2; j++) {
if (inflow(x + i, y + j, i, j) > 0) {
@@ -251,17 +244,16 @@
*input_outlet_x, *input_outlet_y, *input_thres, *input_nc, *input_b,
*input_ep, *input_fdis;
/* initialize GIS environment */
G_gisinit(argv[0]); /* reads grass env, stores program name to G_program_name() */
/* initialize module */
module = G_define_module();
- module->description = _("Estimation of travel times/isochrones");
+ G_add_keyword(_("raster"));
+ G_add_keyword(_("hydrology"));
+ module->label = _("Estimation of travel times/isochrones.");
+ module->description =
+ _("Computes the travel time of surface runoff to an outlet");
/* Define the different options as defined in gis.h */
input_dir = G_define_standard_option(G_OPT_R_INPUT);
@@ -361,102 +353,56 @@
if (factor > 0 & factor <= 1.0)
fdis = factor;
else {
- printf("\nWARNING! Reduction factor is not valid!\n");
- exit(EXIT_FAILURE);
+ G_fatal_error("Reduction factor is not valid!");
- /* returns NULL if the map was not found in any mapset,
- * mapset name otherwise */
- mapset = G_find_cell2(map_dir, "");
- if (mapset == NULL)
- G_fatal_error(_("cell file [%s] not found"), map_dir);
+ mapset = G_find_raster2(map_dir, "");
+ mapset = G_find_raster2(map_accu, "");
+ mapset = G_find_raster2(map_dtm, "");
+ mapset = G_find_raster2(map_n, "");
- mapset = G_find_cell2(map_accu, "");
- G_fatal_error(_("cell file [%s] not found"), map_accu);
- mapset = G_find_cell2(map_dtm, "");
- G_fatal_error(_("cell file [%s] not found"), map_dtm);
- mapset = G_find_cell2(map_n, "");
- G_fatal_error(_("cell file [%s] not found"), map_n);
- if (G_legal_filename(result) < 0)
- G_fatal_error(_("[%s] is an illegal name"), result);
/* determine the inputmap type (CELL/FCELL/DCELL) */
- data_type_dir = G_raster_map_type(map_dir, mapset);
- data_type_accu = G_raster_map_type(map_accu, mapset);
- data_type_n = G_raster_map_type(map_n, mapset);
- data_type_dtm = G_raster_map_type(map_dtm, mapset);
+ data_type_dir = Rast_map_type(map_dir, mapset);
+ data_type_accu = Rast_map_type(map_accu, mapset);
+ data_type_n = Rast_map_type(map_n, mapset);
+ data_type_dtm = Rast_map_type(map_dtm, mapset);
- /* G_open_cell_old - returns file destriptor (>0) */
- if ((in_dir = G_open_cell_old(map_dir, mapset)) < 0)
- G_fatal_error(_("Cannot open cell file [%s]"), map_dir);
+ in_dir = Rast_open_old(map_dir, mapset);
+ in_accu = Rast_open_old(map_accu, mapset);
+ in_n = Rast_open_old(map_n, mapset);
+ in_dtm = Rast_open_old(map_dtm, mapset);
- if ((in_accu = G_open_cell_old(map_accu, mapset)) < 0)
- G_fatal_error(_("Cannot open cell file [%s]"), map_accu);
- if ((in_n = G_open_cell_old(map_n, mapset)) < 0)
- G_fatal_error(_("Cannot open cell file [%s]"), map_n);
- if ((in_dtm = G_open_cell_old(map_dtm, mapset)) < 0)
- G_fatal_error(_("Cannot open cell file [%s]"), map_dtm);
- /* controlling, if we can open input raster */
- if (G_get_cellhd(map_accu, mapset, &cellhd_accu) < 0)
- G_fatal_error(_("Cannot read file header of [%s]"), map_accu);
- if (G_get_cellhd(map_dir, mapset, &cellhd_dir) < 0)
- G_fatal_error(_("Cannot read file header of [%s]"), map_dir);
- if (G_get_cellhd(map_dtm, mapset, &cellhd_dtm) < 0)
- G_fatal_error(_("Cannot read file header of [%s]"), map_dtm);
- if (G_get_cellhd(map_n, mapset, &cellhd_n) < 0)
- G_fatal_error(_("Cannot read file header of [%s]"), map_n);
G_debug(3, "number of rows %d", cellhd_accu.rows);
G_debug(3, "number of rows %d", cellhd_dir.rows);
G_debug(3, "number of rows %d", cellhd_dtm.rows);
G_debug(3, "number of rows %d", cellhd_n.rows);
/* Allocate input buffer */
- inrast_accu = G_allocate_raster_buf(data_type_accu);
- inrast_dir = G_allocate_raster_buf(data_type_dir);
- inrast_n = G_allocate_raster_buf(data_type_n);
- inrast_dtm = G_allocate_raster_buf(data_type_dtm);
+ inrast_accu = Rast_allocate_buf(data_type_accu);
+ inrast_dir = Rast_allocate_buf(data_type_dir);
+ inrast_n = Rast_allocate_buf(data_type_n);
+ inrast_dtm = Rast_allocate_buf(data_type_dtm);
/* Allocate output buffer, use input map data_type */
- nrows = G_window_rows();
- ncols = G_window_cols();
- outrast = G_allocate_raster_buf(FCELL_TYPE);
+ nrows = Rast_window_rows();
+ ncols = Rast_window_cols();
+ outrast = Rast_allocate_buf(FCELL_TYPE);
/* controlling, if we can write the raster */
- if ((outfd = G_open_raster_new(result, FCELL_TYPE)) < 0)
- G_fatal_error(_("Could not open <%s>"), result);
+ outfd = Rast_open_new(result, FCELL_TYPE);
/* output array */
array_out = (double **)malloc(nrows * sizeof(double *));
- if ((NULL == array_out)) {
- printf("out of memory ... !");
+ if ((NULL == array_out))
+ G_fatal_error("Out of memory ... !");
int i, j;
for (i = 0; i < nrows; i++) {
array_out[i] = (double *)malloc(ncols * sizeof(double));
- if ((NULL == array_out[i])) {
+ if ((NULL == array_out[i]))
@@ -469,11 +415,7 @@
* terrain analysis begins here ...
- if (G_get_window(&window) < 0) {
- sprintf(map_dir, "can't read current window parameters");
- G_fatal_error(map_dir);
+ G_get_window(&window);
// map units to matrix locations
@@ -532,27 +474,20 @@
((CELL *) outrast)[col] = array_out[row][col];
/* write raster row to output raster file */
- if (G_put_raster_row(outfd, outrast, CELL_TYPE) < 0)
- G_fatal_error(_("Cannot write to <%s>"), result);
+ Rast_put_row(outfd, outrast, CELL_TYPE);
- /* memory cleanup */
- G_free(inrast_accu);
- G_free(inrast_dir);
- G_free(inrast_dtm);
- G_free(inrast_n);
- G_free(outrast);
/* closing raster files */
- G_close_cell(inrast_accu);
- G_close_cell(inrast_dir);
- G_close_cell(inrast_dtm);
- G_close_cell(inrast_n);
- G_close_cell(outfd);
+// Rast_close(inrast_accu);
+// Rast_close(inrast_dir);
+// Rast_close(inrast_dtm);
+// Rast_close(inrast_n);
+ Rast_close(in_dir);
+ Rast_close(in_accu);
+ Rast_close(in_n);
+ Rast_close(in_dtm);
+ Rast_close(outfd);
return 0;
Copied: grass-addons/grass7/raster/r.traveltime/r.traveltime.html (from rev 56189, grass-addons/grass6/raster/r.traveltime/description.html)
--- grass-addons/grass7/raster/r.traveltime/r.traveltime.html (rev 0)
+++ grass-addons/grass7/raster/r.traveltime/r.traveltime.html 2013-05-10 20:46:38 UTC (rev 56190)
@@ -0,0 +1,73 @@
+<h2>DESCRIPTION</h2>
+<em>r.traveltime</em> computes the travel time of surface runoff to an
+outlet. The program starts at the basin outlet and calculates the travel
+time at each raster cell recursively. A drainage area related threhold
+considers even surface and also channel runoff. Travel times are
+derived by assuming kinematic wave approximation.<br>
+To derive channel flow velocities an equilibrium discharge for each
+cell is calculated (Q=Area*Excess_Prcipitation, Assumption: storm
+duration >= time of concentration). This assumption may result
+in overestimated velocities. Therefor a factor is implemented to reduce
+velocities biased towards too large values.<br>
+The results can be used to derive a time-area function. This might be
+usefull for precipitation-runoff calculations (estimation of flood
+predictions) with a lumped hydrologic model (user-specified unit
+hydrograph).
+<h2>REMARKS</h2>
+The program ist restricted to SI units (meters). The algorithm is
+recursive. Maybe it will not work with extensive datasets. It is
+assumed that the minimum slope is 0.001. For smaller gradients the
+program uses this value.
+<h2>KNOWN ISSUES</h2>
+The program does not work correctly if Manning's roughness grid is
+defined as double (float expected). To define a simple uniform
+roughness distribution try: r.mapcalc 'roughness = 0.1f'
+<br>
+The region has to be set one row and column larger than the elevation
+map. See the example below to see how to do that with g.region.
+<h2>EXAMPLE</h2>
+<i>This example uses the North Carolina sample dataset.</i>
+<p>
+<div class="code"><pre>
+g.region rast=elev_lid792_1m n=n+1 s=s-1 w=w-1 e=e+1 -p
+r.watershed elev_lid792_1m thresh=5000 accum=accum_5K drain=draindir_5K
+r.fill.dir elev_lid792_1m output=elev_filled outdir=elev_dir
+r.mapcalc "rough = 0.1f"
+r.traveltime dir=draindir_5K at user1 accu=accum_5K at user1 \
+ dtm=elev_filled at user1 manningsn=rough out_x=638741.43125 \
+ out_y=220269.7 threshold=1 b=1 nchannel=0.1 ep=40 fdis=1 \
+ out=travel_time
+r.colors travel_time col=gyr
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.watershed.html">r.watershed</a>,
+<a href="r.fill.dir.html">r.fill.dir</a>
+</em>
+<br>
+<a href="http://jesbergwetter.twoday.net/stories/4845555/">http://jesbergwetter.twoday.net/stories/4845555/</a>
+<h2>REFERENCES</h2>
+<ul>
+<li>Kilgore, J. L. (1997): <em>Development and evaluation of a GIS-based
+spatially distributed unit hydrograph model</em>, master thesis,
+Virginia
+Polytechnic Institute and State University.</li>
+<li>Melesse, A. M., Graham, W. D. (2004):<em> Storm runoff predicition
+based on a
+spatially distributed travel time method utilizing remote sensing and
+GIS</em>, Journal of the American Water Resources Association, 8,
+863-879.</li>
+<li>Muzik, I. (1996): <em>Flood modelling with GIS-derived distributed
+ unit hydrographs</em>, Hydrological Processes, 10, 1401-1409.</li>
+</ul>
+<h2>AUTHOR</h2>
+Kristian Foerster<br>
+<p><i>Last changed: $Date$</i>
