[GRASS-SVN] r56191 - in grass/trunk: lib/python/temporal temporal/t.rast.import
svn_grass at osgeo.org
Fri May 10 15:22:14 PDT 2013
Author: huhabla
Date: 2013-05-10 15:22:14 -0700 (Fri, 10 May 2013)
New Revision: 56191
Added:
grass/trunk/temporal/t.rast.import/test.t.rast.import.relative.sh
grass/trunk/lib/python/temporal/stds_export.py
grass/trunk/lib/python/temporal/stds_import.py
grass/trunk/temporal/t.rast.import/test.t.rast.import.sh
Correct handling of relative time in stds import and export implemented.
Modified: grass/trunk/lib/python/temporal/stds_export.py
--- grass/trunk/lib/python/temporal/stds_export.py 2013-05-10 20:46:38 UTC (rev 56190)
+++ grass/trunk/lib/python/temporal/stds_export.py 2013-05-10 22:22:14 UTC (rev 56191)
@@ -317,6 +317,8 @@
string += "%s=%s\n" % ("format", format_)
string += "%s=%s\n" % ("temporal_type", sp.get_temporal_type())
string += "%s=%s\n" % ("semantic_type", sp.get_semantic_type())
+ if sp.is_time_relative():
+ string += "%s=%s\n" % ("relative_time_unit", sp.get_relative_time_unit())
string += "%s=%s\n" % ("number_of_maps", sp.metadata.get_number_of_maps())
north, south, east, west, top, bottom = sp.get_spatial_extent()
string += "%s=%s\n" % ("north", north)
Modified: grass/trunk/lib/python/temporal/stds_import.py
--- grass/trunk/lib/python/temporal/stds_import.py 2013-05-10 20:46:38 UTC (rev 56190)
+++ grass/trunk/lib/python/temporal/stds_import.py 2013-05-10 22:22:14 UTC (rev 56191)
@@ -374,6 +374,14 @@
temporal_type = init["temporal_type"]
semantic_type = init["semantic_type"]
+ relative_time_unit = None
+ if temporal_type == "relative":
+ if "relative_time_unit" not in init:
+ core.fatal(_("Key word %s not found in init file.") %("relative_time_unit"))
+ relative_time_unit = init["relative_time_unit"]
+ sp.set_relative_time_unit(relative_time_unit)
core.verbose(_("Create space time %s dataset.") %
sp.get_new_map_instance(None).get_type())
@@ -387,7 +395,7 @@
register_maps_in_space_time_dataset(
type=sp.get_new_map_instance(None).get_type(),
name=output, file=list_file_name, start="file",
- end="file", dbif=None, fs=fs)
+ end="file", unit=relative_time_unit, dbif=None, fs=fs)
os.chdir(old_cwd)
except:
Added: grass/trunk/temporal/t.rast.import/test.t.rast.import.relative.sh
--- grass/trunk/temporal/t.rast.import/test.t.rast.import.relative.sh (rev 0)
+++ grass/trunk/temporal/t.rast.import/test.t.rast.import.relative.sh 2013-05-10 22:22:14 UTC (rev 56191)
@@ -0,0 +1,84 @@
+#!/bin/sh
+# Test the import of space time raster datasets with relative time
+export GRASS_OVERWRITE=1
+# We need to set a specific region in the
+# @preprocess step of this test. We generate
+# raster with r.mapcalc and create a space time raster datasets
+# The region setting should work for UTM and LL test locations
+g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
+mkdir test
+r.mapcalc expr="prec_1 = rand(0, 550)"
+r.mapcalc expr="prec_2 = rand(0, 450)"
+r.mapcalc expr="prec_3 = rand(0, 320)"
+r.mapcalc expr="prec_4 = rand(0, 510)"
+r.mapcalc expr="prec_5 = rand(0, 300)"
+r.mapcalc expr="prec_6 = rand(0, 650)"
+n1=`g.tempfile pid=1 -d`
+cat > "${n1}" << EOF
+prec_1|1|2
+prec_2|2|3
+prec_3|3|4
+prec_4|4|5
+prec_5|5|6
+prec_6|6|7
+EOF
+eval `g.gisenv`
+t.create type=strds temporaltype=relative output=precip_rel \
+ title="A test with input files" descr="A test with input files"
+# The first @test
+t.register -i type=rast input=precip_rel file="${n1}" unit="years"
+t.rast.export input=precip_rel output=strds_export.tar.bz2 compression=bzip2 format=GTiff workdir=test
+t.rast.export input=precip_rel output=strds_export.tar.gz compression=gzip format=GTiff workdir=test
+t.rast.export input=precip_rel output=strds_export.tar compression=no format=GTiff workdir=test
+t.rast.export input=precip_rel output=strds_export_pack.tar compression=no format=pack workdir=test
+t.rast.export input=precip_rel output=strds_export_pack.tar.gz compression=gzip format=pack workdir=test
+t.rast.export input=precip_rel output=strds_export_pack.tar.bz2 compression=bzip2 format=pack workdir=test
+# Checking different flags
+t.rast.import --o input=strds_export.tar.bz2 output=precip_rel extrdir=test\
+ -oe title="A test" description="Description of a test"
+ -loe title="A test" description="Description of a test"
+ title="A test" description="Description of a test"
+ -l title="A test" description="Description of a test"
+# Import using different compression and formats
+t.rast.import --o input=strds_export.tar.gz output=precip_rel extrdir=test\
+r.info prec_1
+t.rast.import --o input=strds_export.tar output=precip_rel extrdir=test\
+r.info prec_1
+t.rast.import --o input=strds_export_pack.tar output=precip_rel extrdir=test\
+r.info prec_1
+t.rast.import --o input=strds_export_pack.tar.gz output=precip_rel extrdir=test\
+r.info prec_1
+t.rast.import --o input=strds_export_pack.tar.bz2 output=precip_rel extrdir=test\
+r.info prec_1
+# Cleaning up
+t.unregister type=rast maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+t.remove type=strds input=precip_rel
+g.remove rast=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+rm -rf test
+rm strds_export.tar.bz2
+rm strds_export.tar.gz
+rm strds_export_pack.tar
+rm strds_export_pack.tar.gz
+rm strds_export_pack.tar.bz2
Property changes on: grass/trunk/temporal/t.rast.import/test.t.rast.import.relative.sh
___________________________________________________________________
Added: svn:executable
Modified: grass/trunk/temporal/t.rast.import/test.t.rast.import.sh
--- grass/trunk/temporal/t.rast.import/test.t.rast.import.sh 2013-05-10 20:46:38 UTC (rev 56190)
+++ grass/trunk/temporal/t.rast.import/test.t.rast.import.sh 2013-05-10 22:22:14 UTC (rev 56191)
@@ -1,6 +1,8 @@
#!/bin/sh
@@ -9,12 +11,12 @@
mkdir test
-r.mapcalc --o expr="prec_1 = rand(0, 550)"
-r.mapcalc --o expr="prec_2 = rand(0, 450)"
-r.mapcalc --o expr="prec_3 = rand(0, 320)"
-r.mapcalc --o expr="prec_4 = rand(0, 510)"
-r.mapcalc --o expr="prec_5 = rand(0, 300)"
-r.mapcalc --o expr="prec_6 = rand(0, 650)"
@@ -29,10 +31,10 @@
eval `g.gisenv`
-t.create --o type=strds temporaltype=absolute output=precip_abs1 title="A test with input files" descr="A test with input files"
+t.create type=strds temporaltype=absolute output=precip_abs1 title="A test with input files" descr="A test with input files"
# The first @test
-t.register -i type=rast input=precip_abs1 file="${n1}" start="2001-01-01" increment="1 months"
+t.register -i type=rast input=precip_abs1 file="${n1}"
t.rast.export input=precip_abs1 output=strds_export.tar.bz2 compression=bzip2 format=GTiff workdir=test
t.rast.export input=precip_abs1 output=strds_export.tar.gz compression=gzip format=GTiff workdir=test
