[GRASS-SVN] r56193 - in grass/trunk/raster: r.sun r.sunmask
svn_grass at osgeo.org
Sat May 11 01:46:25 PDT 2013
Author: neteler
Date: 2013-05-11 01:46:25 -0700 (Sat, 11 May 2013)
New Revision: 56193
grass/trunk/raster/r.sun/r.sun.html
grass/trunk/raster/r.sunmask/r.sunmask.html
refer to r.sunhours
Modified: grass/trunk/raster/r.sun/r.sun.html
--- grass/trunk/raster/r.sun/r.sun.html 2013-05-11 08:37:20 UTC (rev 56192)
+++ grass/trunk/raster/r.sun/r.sun.html 2013-05-11 08:46:25 UTC (rev 56193)
@@ -100,7 +100,7 @@
calculations with the <i>step</i> option. The default value of <i>step</i> is
0.5 hour. Larger steps (e.g. 1.0-2.0) can speed-up calculations but produce
less reliable (and more jagged) results. As the sun moves through approx.
-15° of the sky in an hour, the default <i>step</i> of half an hour will
+15° of the sky in an hour, the default <i>step</i> of half an hour will
produce 7.5° steps in the data. For relatively smooth output with the
sun placed for every degree of movement in the sky you should set the
<i>step</i> to 4 minutes or less. <i>step</i><tt>=0.05</tt> is equivalent
@@ -296,6 +296,7 @@
<em>
<a href="r.horizon.html">r.horizon</a>,
<a href="r.slope.aspect.html">r.slope.aspect</a>,
+<a href="r.sunhours.html">r.sunhours</a>,
<a href="r.sunmask.html">r.sunmask</a>,
<a href="g.proj.html">g.proj</a>,
<a href="r.null.html">r.null</a>,
Modified: grass/trunk/raster/r.sunmask/r.sunmask.html
--- grass/trunk/raster/r.sunmask/r.sunmask.html 2013-05-11 08:37:20 UTC (rev 56192)
+++ grass/trunk/raster/r.sunmask/r.sunmask.html 2013-05-11 08:46:25 UTC (rev 56193)
@@ -102,6 +102,7 @@
<em>
<a href="g.region.html">g.region</a>,
<a href="r.sun.html">r.sun</a>,
</em>
