[GRASS-SVN] r56200 - in grass/trunk: include/defs lib/db/dbmi_client
svn_grass at osgeo.org
Sat May 11 08:08:27 PDT 2013
Author: martinl
Date: 2013-05-11 08:08:27 -0700 (Sat, 11 May 2013)
New Revision: 56200
Added:
grass/trunk/lib/db/dbmi_client/handler.c
grass/trunk/include/defs/dbmi.h
dbmi: add db_set_error_handler_driver()
Modified: grass/trunk/include/defs/dbmi.h
--- grass/trunk/include/defs/dbmi.h 2013-05-11 13:37:39 UTC (rev 56199)
+++ grass/trunk/include/defs/dbmi.h 2013-05-11 15:08:27 UTC (rev 56200)
@@ -331,6 +331,7 @@
int db_set_default_connection(void);
void db_set_error_who(const char *);
int db_set_handle(dbHandle *, const char *, const char *);
+void db_set_error_handler_driver(dbDriver *);
int db_set_index_column_name(dbIndex *, int,
const char *);
int db_set_index_name(dbIndex *, const char *);
Added: grass/trunk/lib/db/dbmi_client/handler.c
--- grass/trunk/lib/db/dbmi_client/handler.c (rev 0)
+++ grass/trunk/lib/db/dbmi_client/handler.c 2013-05-11 15:08:27 UTC (rev 56200)
@@ -0,0 +1,42 @@
+ \file lib/db/dbmi_client/handler.c
+ \brief DBMI Library (client) - standard error handlers
+ (C) 2013 by the GRASS Development Team
+ This program is free software under the GNU General Public License
+ (>=v2). Read the file COPYING that comes with GRASS for details.
+ \author Martin Landa <landa.martin gmail.com>
+#include <grass/gis.h>
+#include <grass/dbmi.h>
+static void error_handler_driver(void *p)
+ dbDriver *driver;
+ driver = (dbDriver *) p;
+ db_close_database(driver);
+ db_shutdown_driver(driver);
+ \brief Define standard error handler for open database connection
+ This handler:
+ - close database connection
+ - shutdown db driver
+ Note: It's recommended to call this routine after
+ db_start_driver_open_database().
+ \param driver DB driver
+void db_set_error_handler_driver(dbDriver *driver)
+ G_add_error_handler(error_handler_driver, driver);
Property changes on: grass/trunk/lib/db/dbmi_client/handler.c
___________________________________________________________________
Added: svn:mime-type
+ text/x-csrc
Added: svn:eol-style
+ native
