[GRASS-SVN] r56201 - grass/trunk/vector/v.random
svn_grass at osgeo.org
Sat May 11 08:09:34 PDT 2013
Author: martinl
Date: 2013-05-11 08:09:34 -0700 (Sat, 11 May 2013)
New Revision: 56201
grass/trunk/vector/v.random/main.c
v.random: use standard error handlers
Modified: grass/trunk/vector/v.random/main.c
--- grass/trunk/vector/v.random/main.c 2013-05-11 15:08:27 UTC (rev 56200)
+++ grass/trunk/vector/v.random/main.c 2013-05-11 15:09:34 UTC (rev 56201)
@@ -153,7 +153,7 @@
output = parm.output->answer;
n = atoi(parm.nsites->answer);
- b = (flag.drand48->answer == '\0') ? 0 : 1;
+ b = flag.drand48->answer ? TRUE : FALSE;
if(parm.seed->answer)
seed = atoi(parm.seed->answer);
@@ -165,6 +165,7 @@
/* create new vector map */
if (-1 == Vect_open_new(&Out, output, flag.z->answer ? WITH_Z : WITHOUT_Z))
G_fatal_error(_("Unable to create vector map <%s>"), output);
+ Vect_set_error_handler_io(NULL, &Out);
/* Do we need to write random values into attribute table? */
if (parm.zcol->answer) {
@@ -173,14 +174,15 @@
db_start_driver_open_database(Fi->driver,
Vect_subst_var(Fi->database, &Out));
if (driver == NULL) {
- Vect_delete(parm.output->answer);
G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
Vect_subst_var(Fi->database, &Out), Fi->driver);
+ db_set_error_handler_driver(driver);
db_begin_transaction(driver);
db_init_string(&sql);
- sprintf(buf, "create table %s (cat integer, %s %s)", Fi->table,
+ sprintf(buf, "create table %s (%s integer, %s %s)", Fi->table, GV_KEY_COLUMN,
parm.zcol->answer, parm.ztype->answer);
db_set_string(&sql, buf);
Vect_map_add_dblink(&Out, 1, NULL, Fi->table, GV_KEY_COLUMN, Fi->database,
@@ -189,9 +191,6 @@
/* Create table */
G_debug(3, db_get_string(&sql));
if (db_execute_immediate(driver, &sql) != DB_OK) {
- db_close_database(driver);
- db_shutdown_driver(driver);
G_fatal_error(_("Unable to create table: %s"),
@@ -200,9 +199,6 @@
if (db_grant_on_table
(driver, Fi->table, DB_PRIV_SELECT,
DB_GROUP | DB_PUBLIC) != DB_OK) {
G_fatal_error(_("Unable to grant privileges on table <%s>"),
Fi->table);
@@ -210,16 +206,10 @@
/* OK. Let's check what type of column user has created */
db_set_string(&sql, Fi->table);
if (db_describe_table(driver, &sql, &table) != DB_OK) {
G_fatal_error(_("Unable to describe table <%s>"), Fi->table);
if (db_get_table_number_of_columns(table) != 2) {
G_fatal_error(_("Table should contain only two columns"));
@@ -230,9 +220,6 @@
if (type == DB_SQL_TYPE_REAL || type == DB_SQL_TYPE_DOUBLE_PRECISION)
usefloat = 1;
if (usefloat < 0) {
G_fatal_error(_("You have created unsupported column type. This module supports only INTEGER"
" and DOUBLE PRECISION column types."));
@@ -299,9 +286,6 @@
G_fatal_error(_("Cannot insert new row: %s"),
