[GRASS-SVN] r56247 - in grass-addons/grass7: imagery/i.eb.h_sebal95 imagery/i.spec.unmix raster raster/r.area raster/r.convergence raster/r.stream.basins raster/r.stream.channel raster/r.stream.distance raster/r.stream.order raster/r.stream.segment raster/r.stream.slope raster/r.stream.snap raster/r.stream.stats
Tue May 14 02:11:11 PDT 2013
Author: neteler
Date: 2013-05-14 02:11:11 -0700 (Tue, 14 May 2013)
New Revision: 56247
   grass-addons/grass7/imagery/i.eb.h_sebal95/main.c
   grass-addons/grass7/imagery/i.spec.unmix/main.c
   grass-addons/grass7/raster/Makefile
   grass-addons/grass7/raster/r.area/main.c
   grass-addons/grass7/raster/r.convergence/main.c
   grass-addons/grass7/raster/r.stream.basins/main.c
   grass-addons/grass7/raster/r.stream.channel/main.c
   grass-addons/grass7/raster/r.stream.distance/main.c
   grass-addons/grass7/raster/r.stream.order/main.c
   grass-addons/grass7/raster/r.stream.segment/main.c
   grass-addons/grass7/raster/r.stream.slope/main.c
   grass-addons/grass7/raster/r.stream.snap/main.c
   grass-addons/grass7/raster/r.stream.stats/main.c
various G_add_keyword() fixes
Modified: grass-addons/grass7/imagery/i.eb.h_sebal95/main.c
--- grass-addons/grass7/imagery/i.eb.h_sebal95/main.c	2013-05-14 08:58:43 UTC (rev 56246)
+++ grass-addons/grass7/imagery/i.eb.h_sebal95/main.c	2013-05-14 09:11:11 UTC (rev 56247)
@@ -86,6 +86,8 @@
     G_gisinit(argv[0]);
     module = G_define_module();
+    G_add_keyword(_("imagery"));
+    G_add_keyword(_("heat flux"));
     module->description = _("Sensible Heat Flux iteration SEBAL 95");
     /* Define different options */
Modified: grass-addons/grass7/imagery/i.spec.unmix/main.c
--- grass-addons/grass7/imagery/i.spec.unmix/main.c	2013-05-14 08:58:43 UTC (rev 56246)
+++ grass-addons/grass7/imagery/i.spec.unmix/main.c	2013-05-14 09:11:11 UTC (rev 56247)
@@ -89,15 +89,15 @@
     /* initialize GIS engine */
     G_gisinit(argv[0]);
-    module->keywords = _("imagery, spectral unmixing");
+    G_add_keyword(_("spectral unmixing"));
 	_("Perfroms Spectral mixture analysis of satellite/aerial images");
     parm.group = G_define_standard_option(G_OPT_I_GROUP);
     parm.matrixfile = G_define_standard_option(G_OPT_F_INPUT);
     parm.matrixfile->key = "matrix";
     parm.matrixfile->type = TYPE_STRING;
Modified: grass-addons/grass7/raster/Makefile
--- grass-addons/grass7/raster/Makefile	2013-05-14 08:58:43 UTC (rev 56246)
+++ grass-addons/grass7/raster/Makefile	2013-05-14 09:11:11 UTC (rev 56247)
@@ -16,7 +16,6 @@
 	r.mcda.output \
 	r.mcda.roughset \
 	r.modis \
-	r.regression.multi \
 	r.regression.series \
 	r.stream.basins \
 	r.stream.channel \
Modified: grass-addons/grass7/raster/r.area/main.c
--- grass-addons/grass7/raster/r.area/main.c	2013-05-14 08:58:43 UTC (rev 56246)
+++ grass-addons/grass7/raster/r.area/main.c	2013-05-14 09:11:11 UTC (rev 56247)
@@ -3,7 +3,7 @@
  * MODULE:       r.area
  * AUTHOR(S):    Jarek Jasiewicz <jarekj amu.edu.pl>
  * PURPOSE:      Calculate area of clumped areas. Remove areas smaller than
- *                                                       given treshold.
+ *                                                       given threshold.
  * COPYRIGHT:    (C) 1999-2010 by the GRASS Development Team
@@ -45,6 +45,13 @@
     G_gisinit(argv[0]);
+    module = G_define_module();
+    G_add_keyword(_("raster"));
+    G_add_keyword(_("statistics"));
+    G_add_keyword(_("area"));
+    module->description =
+        _("Calculates area of clumped areas and remove areas smaller than given threshold.");
     input = G_define_standard_option(G_OPT_R_INPUT);
     input->description = _("Map created with r.clump");
Modified: grass-addons/grass7/raster/r.convergence/main.c
--- grass-addons/grass7/raster/r.convergence/main.c	2013-05-14 08:58:43 UTC (rev 56246)
+++ grass-addons/grass7/raster/r.convergence/main.c	2013-05-14 09:11:11 UTC (rev 56247)
@@ -1,17 +1,17 @@
- * MODULE:			 r.convergence
+ * MODULE:		r.convergence
  * AUTHOR(S):		Jarek Jasiewicz jarekj amu.edu.pl
- * 							Original convergence index in SAGA GIS sofware: Olaf Conrad
+ * 			Original convergence index in SAGA GIS sofware: Olaf Conrad
- * PURPOSE:			Calculate convergence index (parameter defining the local convergence of the relief)
+ * PURPOSE:		Calculate convergence index (parameter defining the local convergence of the relief)
-* COPYRIGHT:		 (C) 2002,2010 by the GRASS Development Team
+* COPYRIGHT:		(C) 2002,2010 by the GRASS Development Team
-*								 This program is free software under the GNU General Public
-*								 License (>=v2). Read the file COPYING that comes with GRASS
+*		 This program is free software under the GNU General Public
+*		 License (>=v2). Read the file COPYING that comes with GRASS
 *								 for details.
@@ -21,6 +21,7 @@
 int main(int argc, char **argv)
+    struct GModule *module;
     struct Option *map_dem,
 	*map_slope,
 	*map_aspect, *par_window, *par_method, *par_differnce, *map_output;
@@ -37,6 +38,12 @@
     G_gisinit(argv[0]);
+    G_add_keyword(_("terrain"));
+        _("Calculate convergence index.");
     map_dem = G_define_standard_option(G_OPT_R_INPUT);
     map_dem->description = _("Digital elevation model map");
Modified: grass-addons/grass7/raster/r.stream.basins/main.c
--- grass-addons/grass7/raster/r.stream.basins/main.c	2013-05-14 08:58:43 UTC (rev 56246)
+++ grass-addons/grass7/raster/r.stream.basins/main.c	2013-05-14 09:11:11 UTC (rev 56247)
@@ -1,4 +1,3 @@
  * MODULE:       r.stream.basins
@@ -47,6 +46,8 @@
     module->description = _("Delineate basins according user' input. \
 	Input can be stream network, point file with outlets or outlet coordinates");
+    G_add_keyword(_("hydrology"));
     G_add_keyword("basins creation");
     in_dir_opt = G_define_standard_option(G_OPT_R_INPUT);	/* input directon file */
Modified: grass-addons/grass7/raster/r.stream.channel/main.c
--- grass-addons/grass7/raster/r.stream.channel/main.c	2013-05-14 08:58:43 UTC (rev 56246)
+++ grass-addons/grass7/raster/r.stream.channel/main.c	2013-05-14 09:11:11 UTC (rev 56247)
@@ -58,6 +58,8 @@
     G_add_keyword("Horton statisctics");
 	_("Calculate local parameters for individual streams");
     G_add_keyword("Stream parameters");
     G_add_keyword("Stream gradient");
     G_add_keyword("Stream curvature");
Modified: grass-addons/grass7/raster/r.stream.distance/main.c
--- grass-addons/grass7/raster/r.stream.distance/main.c	2013-05-14 08:58:43 UTC (rev 56246)
+++ grass-addons/grass7/raster/r.stream.distance/main.c	2013-05-14 09:11:11 UTC (rev 56247)
@@ -51,6 +51,8 @@
     and outlets according user' input. It can work in stream mode where target are streams and outlets mode \
     where targets are outlets");
     G_add_keyword("watercourse distance");
     G_add_keyword("relative elevation");
Modified: grass-addons/grass7/raster/r.stream.order/main.c
--- grass-addons/grass7/raster/r.stream.order/main.c	2013-05-14 08:58:43 UTC (rev 56246)
+++ grass-addons/grass7/raster/r.stream.order/main.c	2013-05-14 09:11:11 UTC (rev 56247)
@@ -72,11 +72,13 @@
 	_("Calculate Strahler's and more streams hierarchy. Basic module for topological analysis of drainage network");
-    G_add_keyword("Strahler Stream Order");
-    G_add_keyword("Hack Streams");
+    G_add_keyword("Strahler stream order");
+    G_add_keyword("Hack streams");
     G_add_keyword("Stream network topology");
     G_add_keyword("Stream network geometry");
-    G_add_keyword("Nework vectorisation");
+    G_add_keyword("Network vectorisation");
     for (i = 0; i < input_size; ++i) {
 	opt_input[i] = G_define_standard_option(G_OPT_R_INPUT);
Modified: grass-addons/grass7/raster/r.stream.segment/main.c
--- grass-addons/grass7/raster/r.stream.segment/main.c	2013-05-14 08:58:43 UTC (rev 56246)
+++ grass-addons/grass7/raster/r.stream.segment/main.c	2013-05-14 09:11:11 UTC (rev 56247)
@@ -54,6 +54,8 @@
 	_("Divide network into near strigh-line segments and calculate its order");
     G_add_keyword("Stream divide");
     G_add_keyword("Stream direction");
Modified: grass-addons/grass7/raster/r.stream.slope/main.c
--- grass-addons/grass7/raster/r.stream.slope/main.c	2013-05-14 08:58:43 UTC (rev 56246)
+++ grass-addons/grass7/raster/r.stream.slope/main.c	2013-05-14 09:11:11 UTC (rev 56247)
@@ -4,15 +4,15 @@
  * MODULE:       r.stream.slope
- * PURPOSE:      Suplementary module for r.stream.distance for slope subsystem,
- * 							 calculate local downsteam elevation change
- * 							 and local downstream minimum and maximum curvature
+ * PURPOSE:      Supplementary module for r.stream.distance for slope subsystem,
+ * 		 calculate local downstream elevation change
+ * 		 and local downstream minimum and maximum curvature
- * COPYRIGHT:    (C) 2002,2010 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2002, 2010 by the GRASS Development Team
- *   	    	 	  License (>=v2). Read the file COPYING that comes with GRASS
- *   	    	 	  for details.
+ *   	    	 License (>=v2). Read the file COPYING that comes with GRASS
+ *   	         for details.
 #include <stdio.h>
@@ -69,6 +69,9 @@
     G_gisinit(argv[0]);
+    G_add_keyword("Stream local parameters");
     module->description = _("Calculate local parameters for slope subsystem");
Modified: grass-addons/grass7/raster/r.stream.snap/main.c
--- grass-addons/grass7/raster/r.stream.snap/main.c	2013-05-14 08:58:43 UTC (rev 56246)
+++ grass-addons/grass7/raster/r.stream.snap/main.c	2013-05-14 09:11:11 UTC (rev 56247)
@@ -46,6 +46,8 @@
     in_points_opt = G_define_standard_option(G_OPT_V_INPUT);
Modified: grass-addons/grass7/raster/r.stream.stats/main.c
--- grass-addons/grass7/raster/r.stream.stats/main.c	2013-05-14 08:58:43 UTC (rev 56246)
+++ grass-addons/grass7/raster/r.stream.stats/main.c	2013-05-14 09:11:11 UTC (rev 56247)
@@ -50,9 +50,11 @@
 	_("Calculate Horton's statistics for Strahler and Horton ordered networks created with r.stream.");
     G_add_keyword("Horton's statistics");
-    G_add_keyword("Bifuracation ratio");
-    G_add_keyword("Drainege density");
+    G_add_keyword("Bifurcation ratio");
+    G_add_keyword("Drainage density");
     G_add_keyword("Catchment statistics");
     in_stm_opt = G_define_standard_option(G_OPT_R_INPUT);
