[GRASS-SVN] r56248 - in grass/trunk: lib/init mswindows mswindows/osgeo4w
svn_grass at osgeo.org
Tue May 14 05:20:21 PDT 2013
Author: martinl
Date: 2013-05-14 05:20:20 -0700 (Tue, 14 May 2013)
New Revision: 56248
Removed:
grass/trunk/mswindows/osgeo4w/ini.bat.tmpl
grass/trunk/lib/init/grass.py
grass/trunk/mswindows/env.bat
grass/trunk/mswindows/osgeo4w/env.bat.tmpl
grass/trunk/mswindows/osgeo4w/grass.tmpl
remove GRASS_WISH, tcl/tk dependency has been removed
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2013-05-14 09:11:11 UTC (rev 56247)
+++ grass/trunk/lib/init/grass.py 2013-05-14 12:20:20 UTC (rev 56248)
@@ -175,7 +175,6 @@
%s:
GRASS_GUI %s
- GRASS_WISH %s
GRASS_HTML_BROWSER %s
GRASS_ADDON_PATH %s
GRASS_ADDON_BASE %s
@@ -200,7 +199,6 @@
_("fully qualified initial mapset directory"),
_("Environment variables relevant for startup"),
_("select GUI (text, gui)"),
- _("set wish shell name to override 'wish'"),
_("set html web browser for help pages"),
_("set additional path(s) to local GRASS modules or user scripts"),
_("set additional GISBASE for locally installed GRASS Addons"),
@@ -397,10 +395,6 @@
pager = "cat"
os.environ['GRASS_PAGER'] = pager
- # GRASS_WISH
- if not os.getenv('GRASS_WISH'):
- os.environ['GRASS_WISH'] = "wish"
# GRASS_PYTHON
if not os.getenv('GRASS_PYTHON'):
if windows:
@@ -1164,7 +1158,7 @@
# Set LD_LIBRARY_PATH (etc) to find GRASS shared libraries
path_prepend(gfile("lib"), ld_library_path_var)
-# Set GRASS_PAGER, GRASS_WISH, GRASS_PYTHON, GRASS_GNUPLOT, GRASS_PROJSHARE
+# Set GRASS_PAGER, GRASS_PYTHON, GRASS_GNUPLOT, GRASS_PROJSHARE
set_defaults()
# Set GRASS_HTML_BROWSER
Modified: grass/trunk/mswindows/env.bat
--- grass/trunk/mswindows/env.bat 2013-05-14 09:11:11 UTC (rev 56247)
+++ grass/trunk/mswindows/env.bat 2013-05-14 12:20:20 UTC (rev 56248)
@@ -1,6 +1,5 @@
rem Environmental variables for GRASS stand-alone installer
-set GRASS_WISH=%GISBASE%\extrabin\wish.exe
set GRASS_PYTHON=python
set GRASS_PROJSHARE=%GISBASE%\proj
set GRASS_HTML_BROWSER=explorer
Modified: grass/trunk/mswindows/osgeo4w/env.bat.tmpl
--- grass/trunk/mswindows/osgeo4w/env.bat.tmpl 2013-05-14 09:11:11 UTC (rev 56247)
+++ grass/trunk/mswindows/osgeo4w/env.bat.tmpl 2013-05-14 12:20:20 UTC (rev 56248)
@@ -3,7 +3,6 @@
set GISBASE=%OSGEO4W_ROOT%\apps\grass\grass- at VERSION@
set GRASS_SH=%OSGEO4W_ROOT%\apps\msys\bin\sh.exe
-set GRASS_WISH=%OSGEO4W_ROOT%\bin\wish.exe
set GRASS_PROJSHARE=%OSGEO4W_ROOT%\share\proj
Modified: grass/trunk/mswindows/osgeo4w/grass.tmpl
--- grass/trunk/mswindows/osgeo4w/grass.tmpl 2013-05-14 09:11:11 UTC (rev 56247)
+++ grass/trunk/mswindows/osgeo4w/grass.tmpl 2013-05-14 12:20:20 UTC (rev 56248)
@@ -3,13 +3,12 @@
OSGEO4W_ROOT_MSYS=@OSGEO4W_ROOT_MSYS@
GISBASE=$OSGEO4W_ROOT_MSYS/apps/grass/grass- at VERSION@
GRASS_SH=$OSGEO4W_ROOT_MSYS/apps/msys/bin/sh.exe
-GRASS_WISH=$OSGEO4W_ROOT_MSYS/bin/wish.exe
GRASS_PYTHON=$OSGEO4W_ROOT_MSYS/bin/python.exe
PYTHONHOME=$OSGEO4W_ROOT_MSYS/apps/Python27
GRASS_PROJSHARE=$OSGEO4W_ROOT_MSYS/share/proj
PATH=$OSGEO4W_ROOT_MSYS/apps/grass/grass- at VERSION@/bin:$PATH
-export $OSGEO4W_ROOT_MSYS $GISBASE $GRASS_SH $GRASS_WISH $GRASS_PYTHON $PYTHONHOME $GRASS_PROJSHARE
+export $OSGEO4W_ROOT_MSYS $GISBASE $GRASS_SH $GRASS_PYTHON $PYTHONHOME $GRASS_PROJSHARE
export $PATH
$GRASS_PYTHON "$GISBASE/etc/grass at POSTFIX@.py" "$@"
Deleted: grass/trunk/mswindows/osgeo4w/ini.bat.tmpl
--- grass/trunk/mswindows/osgeo4w/ini.bat.tmpl 2013-05-14 09:11:11 UTC (rev 56247)
+++ grass/trunk/mswindows/osgeo4w/ini.bat.tmpl 2013-05-14 12:20:20 UTC (rev 56248)
@@ -1,7 +0,0 @@
-set GISBASE=%OSGEO4W_ROOT%\apps\grass\grass-7.0.0svn
-set WINGISBASE=%OSGEO4W_ROOT%\apps\grass\grass-7.0.0svn
-set GRASS_SH=%OSGEO4W_ROOT%\apps\msys\bin\sh.exe
-set GRASS_PYTHON=%OSGEO4W_ROOT%\bin\python.exe
-set GRASS_PROJSHARE=%OSGEO4W_ROOT%\share\proj
-set GRASS_HTML_BROWSER=%PROGRAMFILES%\Internet Explorer\iexplore.exe
