[GRASS-SVN] r56257 - grass/branches/develbranch_6/gui/wxpython/location_wizard
Wed May 15 03:53:43 PDT 2013
Author: hamish
Date: 2013-05-15 03:53:42 -0700 (Wed, 15 May 2013)
New Revision: 56257
   grass/branches/develbranch_6/gui/wxpython/location_wizard/wizard.py
mostly cosmetic sync with trunk for easier diffs
Modified: grass/branches/develbranch_6/gui/wxpython/location_wizard/wizard.py
--- grass/branches/develbranch_6/gui/wxpython/location_wizard/wizard.py	2013-05-15 08:11:11 UTC (rev 56256)
+++ grass/branches/develbranch_6/gui/wxpython/location_wizard/wizard.py	2013-05-15 10:53:42 UTC (rev 56257)
@@ -28,7 +28,7 @@
 @author Michael Barton
 @author Jachym Cepicky
- at author Martin Landa <landa.martin gmail.com>
+ at author Martin Landa <landa.martin gmail.com>
 import os
 import locale
@@ -747,7 +747,7 @@
             paramSBSizer.Fit(self.panel)
             self.panel.SetSizer(self.prjParamSizer)
-        if event.GetDirection():
+        if event.GetDirection():
             self.prjParamSizer.Clear(True)
             self.paramSBox.SetLabel(_(" Enter parameters for %s projection ") % self.projdesc)
             self.pparam = dict()
@@ -762,7 +762,7 @@
                 # default values
                 if param['type'] == 'bool':
                     param['value'] = 0
-                elif param['type'] == 'zone':
+                elif param['type'] == 'zone':
                     param['value'] = 30
                     param['desc'] += ' (1-60)'
                 else:
@@ -1043,10 +1043,10 @@
                        wx.ALL, border = 5, pos = (3, 1), span = (1, 4))
         # events
-        self.ellipselist.Bind(wx.EVT_LIST_ITEM_SELECTED,    self.OnItemSelected)
+        self.ellipselist.Bind(wx.EVT_LIST_ITEM_SELECTED, self.OnItemSelected)
         self.tellipse.Bind(wx.EVT_TEXT, self.OnText)
         self.tellipse.Bind(wx.EVT_TEXT_ENTER, self.OnText)
-        self.searchb.Bind(wx.EVT_TEXT_ENTER,    self.OnSearch)
+        self.searchb.Bind(wx.EVT_TEXT_ENTER, self.OnSearch)
         self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnEnterPage)
         self.Bind(wiz.EVT_WIZARD_PAGE_CHANGING, self.OnPageChanging)
@@ -1182,12 +1182,12 @@
     for setting coordinate system parameters"""
     def __init__(self, wizard, parent):
-        TitledPage.__init__(self, wizard, _("Select WKT file"))
+        TitledPage.__init__(self, wizard, _("Select WKT or PRJ file"))
         self.wktfile = ''
         # create controls
-        self.lfile= self.MakeLabel(_("WKT file:"))
+        self.lfile= self.MakeLabel(_("WKT or PRJ file:"))
         self.tfile = self.MakeTextCtrl(size = (300,-1))
         self.bbrowse = self.MakeButton(_("Browse"))
@@ -1239,8 +1239,11 @@
     def OnBrowse(self, event):
         """!Choose file"""
         dlg = wx.FileDialog(self,
-                            _("Select WKT file"),
-                            os.getcwd(), "", "*.*", wx.OPEN)
+                            message = _("Select WKT or PRJ file"),
+                            defaultDir = os.getcwd(),
+                            wildcard = "PRJ files (*.prj)|*.prj|Files (*.*)|*.*",
+                            style = wx.OPEN)
         if dlg.ShowModal() == wx.ID_OK:
             path = dlg.GetPath()
             self.tfile.SetValue(path)
@@ -1398,7 +1401,7 @@
             self.tcode.SetValue('')
             self.searchb.SetValue('')
             self.OnBrowseCodes(None)
-        else:
+        else:
             try:
                 self.epsgcode, self.epsgdesc, self.epsgparams = \
                         self.epsglist.Search(index=[0,1,2], pattern=value)
@@ -1847,7 +1850,7 @@
                 self.grassdatabase = self.startpage.grassdatabase
                 self.georeffile = self.filepage.georeffile
                 # FIXME here was code for setting default region, what for is this if:
-                # if self.altdb == False:
+                # if self.altdb == False:
             else: # -> error
                 self.wizard.Destroy()
