[GRASS-SVN] r56258 - grass/branches/releasebranch_6_4/gui/wxpython/location_wizard
svn_grass at osgeo.org
Wed May 15 03:55:29 PDT 2013
Author: hamish
Date: 2013-05-15 03:55:27 -0700 (Wed, 15 May 2013)
New Revision: 56258
grass/branches/releasebranch_6_4/gui/wxpython/location_wizard/wizard.py
mostly cosmetic sync with trunk for easier diffs (merge from devbr6)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/location_wizard/wizard.py
--- grass/branches/releasebranch_6_4/gui/wxpython/location_wizard/wizard.py 2013-05-15 10:53:42 UTC (rev 56257)
+++ grass/branches/releasebranch_6_4/gui/wxpython/location_wizard/wizard.py 2013-05-15 10:55:27 UTC (rev 56258)
@@ -28,7 +28,7 @@
@author Michael Barton
@author Jachym Cepicky
- at author Martin Landa <landa.martin gmail.com>
+ at author Martin Landa <landa.martin gmail.com>
import os
import locale
@@ -747,7 +747,7 @@
paramSBSizer.Fit(self.panel)
self.panel.SetSizer(self.prjParamSizer)
- if event.GetDirection():
+ if event.GetDirection():
self.prjParamSizer.Clear(True)
self.paramSBox.SetLabel(_(" Enter parameters for %s projection ") % self.projdesc)
self.pparam = dict()
@@ -762,7 +762,7 @@
# default values
if param['type'] == 'bool':
param['value'] = 0
- elif param['type'] == 'zone':
+ elif param['type'] == 'zone':
param['value'] = 30
param['desc'] += ' (1-60)'
else:
@@ -1043,10 +1043,10 @@
wx.ALL, border = 5, pos = (3, 1), span = (1, 4))
# events
- self.ellipselist.Bind(wx.EVT_LIST_ITEM_SELECTED, self.OnItemSelected)
+ self.ellipselist.Bind(wx.EVT_LIST_ITEM_SELECTED, self.OnItemSelected)
self.tellipse.Bind(wx.EVT_TEXT, self.OnText)
self.tellipse.Bind(wx.EVT_TEXT_ENTER, self.OnText)
- self.searchb.Bind(wx.EVT_TEXT_ENTER, self.OnSearch)
+ self.searchb.Bind(wx.EVT_TEXT_ENTER, self.OnSearch)
self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnEnterPage)
self.Bind(wiz.EVT_WIZARD_PAGE_CHANGING, self.OnPageChanging)
@@ -1182,12 +1182,12 @@
for setting coordinate system parameters"""
def __init__(self, wizard, parent):
- TitledPage.__init__(self, wizard, _("Select WKT file"))
+ TitledPage.__init__(self, wizard, _("Select WKT or PRJ file"))
self.wktfile = ''
# create controls
- self.lfile= self.MakeLabel(_("WKT file:"))
+ self.lfile= self.MakeLabel(_("WKT or PRJ file:"))
self.tfile = self.MakeTextCtrl(size = (300,-1))
self.bbrowse = self.MakeButton(_("Browse"))
@@ -1239,8 +1239,11 @@
def OnBrowse(self, event):
"""!Choose file"""
dlg = wx.FileDialog(self,
- _("Select WKT file"),
- os.getcwd(), "", "*.*", wx.OPEN)
+ message = _("Select WKT or PRJ file"),
+ defaultDir = os.getcwd(),
+ wildcard = "PRJ files (*.prj)|*.prj|Files (*.*)|*.*",
+ style = wx.OPEN)
if dlg.ShowModal() == wx.ID_OK:
path = dlg.GetPath()
self.tfile.SetValue(path)
@@ -1398,7 +1401,7 @@
self.tcode.SetValue('')
self.searchb.SetValue('')
self.OnBrowseCodes(None)
- else:
+ else:
try:
self.epsgcode, self.epsgdesc, self.epsgparams = \
self.epsglist.Search(index=[0,1,2], pattern=value)
@@ -1847,7 +1850,7 @@
self.grassdatabase = self.startpage.grassdatabase
self.georeffile = self.filepage.georeffile
# FIXME here was code for setting default region, what for is this if:
- # if self.altdb == False:
+ # if self.altdb == False:
else: # -> error
self.wizard.Destroy()
