[GRASS-SVN] r56319 - in grass-addons/grass7/raster/r.agent: .	libagent tests
    svn_grass at osgeo.org
    Sun May 19 14:15:50 PDT 2013
Author: mic
Date: 2013-05-19 14:15:49 -0700 (Sun, 19 May 2013)
New Revision: 56319
   grass-addons/grass7/raster/r.agent/libagent/ant.py
   grass-addons/grass7/raster/r.agent/libagent/anthill.py
   grass-addons/grass7/raster/r.agent/libagent/grassland.py
   grass-addons/grass7/raster/r.agent/r.agent.aco
   grass-addons/grass7/raster/r.agent/tests/test_grassland.py
implement basic ant behaviour
Modified: grass-addons/grass7/raster/r.agent/libagent/ant.py
--- grass-addons/grass7/raster/r.agent/libagent/ant.py	2013-05-19 18:38:49 UTC (rev 56318)
+++ grass-addons/grass7/raster/r.agent/libagent/ant.py	2013-05-19 21:15:49 UTC (rev 56319)
@@ -24,20 +24,60 @@
         @param list coordinate of the current position
         super(Ant, self).__init__(timetolive, world, position)
-        self.position.extend([None,None,0,0])
+        self.position.extend([None,None])
         self.home = self.position[:]
         self.laststeps = [self.position[:]]
         self.visitedsteps = []
         self.done = False
-        self.nextstep = [None,None,0,0,0,0]
+        self.nextstep = [None,None,None,0]
         self.goal = []
         self.penalty = 0.0
-        if self.world.decisionbase == "default":
+        if self.world.decisionbase == "standard":
             # TODO: for now like 'else'..
-            self.chooseposition = self.randomposition
+            self.decide = self.randomposition
         else:
+        if self.world.evaluationbase == "standard":
+            self.evaluate = self.check
+        else:
+    def check(self, positions):
+        for p in positions[:]:
+            if self.world.getpenalty(p) < 0:
+                # this is what we are looking for!
+                if p[0] == self.home[0] and p[1] == self.home[1]:
+                    # ok, unfortunately we have only found the home position..
+                    positions.remove(p)
+                    # no other special should be so close to home, return..
+                    return False
+                else:
+                    # goal node found!
+                    # add one to the counter
+                    #self.world.nrop += 1
+                    self.done = True
+                    # now, head back home..
+                    self.nextstep = self.laststeps.pop()
+                    return True
+        return False
+    def choose(self):
+        positions = self.world.getneighbourpositions(self.position)
+        if not self.evaluate(positions):
+            self.nextstep = self.decide(positions)
+    def walk(self):
+        self.laststeps.append(self.position)
+        self.position = self.nextstep
+        self.world.setsteppheromone(self.position)
     def work(self):
         Wander around searching for fields of interest, mark the
@@ -47,7 +87,15 @@
         # we are all only getting older..
         if self.age() == False:
             return False
-        self.position = self.chooseposition(
-                self.world.getneighbourpositions(self.position))
-        self.world.setsteppheromone(self.position)
+        # past this point we must have decided yet where to go to next..
+        if self.nextstep[0] == None:
+            self.choose()
+            self.penalty += self.nextstep[3] + \
+                                self.world.getpenalty(self.nextstep)
+        # if penalty is positive, wait one round
+        if self.penalty > 0:
+            self.penalty -= 1
+            return True
+        else:
+            self.walk()
Modified: grass-addons/grass7/raster/r.agent/libagent/anthill.py
--- grass-addons/grass7/raster/r.agent/libagent/anthill.py	2013-05-19 18:38:49 UTC (rev 56318)
+++ grass-addons/grass7/raster/r.agent/libagent/anthill.py	2013-05-19 21:15:49 UTC (rev 56319)
@@ -71,8 +71,8 @@
         self.maxants = 100
         ## the ants ttl will be set by user or based on playground size
         self.antslife = 0
-        self.decisionbase = "default"
-#TODO        self.rememberbase = "default"
+        self.decisionbase = "standard"
+        self.evaluationbase = "standard"
     def bear(self):
Modified: grass-addons/grass7/raster/r.agent/libagent/grassland.py
--- grass-addons/grass7/raster/r.agent/libagent/grassland.py	2013-05-19 18:38:49 UTC (rev 56318)
+++ grass-addons/grass7/raster/r.agent/libagent/grassland.py	2013-05-19 21:15:49 UTC (rev 56319)
@@ -130,6 +130,8 @@
         layer = self.layers[layername]
         if halflife > 0:
             layer = layer*0.5**(1.0/halflife)
+            #TODO find out why 'filename' is lost - numpy vs. garray..
+            #self.layers[layername] = layer
         #TODO think about moving 'minimum' to a predifined matrix in anthill
         if minimum > 0:
             mask = garray.numpy.ones_like(layer) + minimum
Modified: grass-addons/grass7/raster/r.agent/r.agent.aco
--- grass-addons/grass7/raster/r.agent/r.agent.aco	2013-05-19 18:38:49 UTC (rev 56318)
+++ grass-addons/grass7/raster/r.agent/r.agent.aco	2013-05-19 21:15:49 UTC (rev 56319)
@@ -160,16 +160,16 @@
 #% gisprompt: algorithm
 #% description: Algorithm used for walking step
 #% answer: standard
-#% options: default,random,test
+#% options: standard,random,test
 #% required : yes
 #%end
 #%option
-#% key: validposition
+#% key: evaluateposition
 #% type: string
 #% description: Algorithm used for finding and remembering paths
 #% answer: avoidorforgetloop
-#% options: specials,avoidloop,forgetloop,avoidorforgetloop
+#% options: standard,avoidloop,forgetloop,avoidorforgetloop
 #% required : yes
 #%end
 #%option
@@ -307,10 +307,10 @@
             world.maxants = int(options['maxants'])
         if options['antslife']:
             world.antslife = int(options['antslife'])
-#        if options['decisionalgorithm']:
-#            world.decisionbase = str(options['decisionalgorithm'])
-#        if options['validposition']:
-#            world.validposition = str(options['validposition'])
+        if options['decisionalgorithm']:
+            world.decisionbase = str(options['decisionalgorithm'])
+        if options['evaluateposition']:
+            world.evaluationbase = str(options['evaluateposition'])
 #        if options['agentfreedom']:
 #            world.globalfreedom = int(options['agentfreedom'])
         if options['pheromoneweight']:
Modified: grass-addons/grass7/raster/r.agent/tests/test_grassland.py
--- grass-addons/grass7/raster/r.agent/tests/test_grassland.py	2013-05-19 18:38:49 UTC (rev 56318)
+++ grass-addons/grass7/raster/r.agent/tests/test_grassland.py	2013-05-19 21:15:49 UTC (rev 56319)
@@ -122,11 +122,23 @@
             # force write it again..
             self.pg.writelayer(self.rastlayername, self.rastlayername, True)
-    def test_parsegrasslayer(self):
+    def test_parsevectorlayer(self):
         if self.vectlayername:
             #TODO find a way to write vector files..
             pass
+    def test_decaycellvalues(self):
+        l = "bar"
+#        self.pg.createlayer(l)
+#        self.pg.layers[l][0][0] = 100
+#        self.pg.decaycellvalues(l, 3)
+#        self.assertEqual(int(round(self.pg.layers[l][0][0])), 79)
+#        self.assertEqual(int(round(self.pg.layers[l][0][0])), 63)
+#        self.assertEqual(int(round(self.pg.layers[l][0][0])), 50)
     def tearDown(self):
         if self.rastlayername:
             grass.try_remove(grass.find_file(name = self.rastlayername,
