[GRASS-SVN] r56318 - grass/trunk/locale/po
svn_grass at osgeo.org
Sun May 19 11:38:49 PDT 2013
Author: neteler
Date: 2013-05-19 11:38:49 -0700 (Sun, 19 May 2013)
New Revision: 56318
grass/trunk/locale/po/grasswxpy_fr.po
Sylvain Maillard: cont'ed
Modified: grass/trunk/locale/po/grasswxpy_fr.po
--- grass/trunk/locale/po/grasswxpy_fr.po 2013-05-19 18:38:36 UTC (rev 56317)
+++ grass/trunk/locale/po/grasswxpy_fr.po 2013-05-19 18:38:49 UTC (rev 56318)
@@ -12,7 +12,7 @@
"Project-Id-Version: grasswxpy_fr\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2013-02-26 14:45+0100\n"
-"PO-Revision-Date: 2013-05-12 16:42+0100\n"
+"PO-Revision-Date: 2013-05-18 23:03+0100\n"
"Last-Translator: Sylvain Maillard <sylvain.maillard at gmail.com>\n"
"Language-Team: français <grass-translations at lists.osgeo.org>\n"
"Language: fr\n"
@@ -7513,7 +7513,6 @@
msgstr "Point de contrôle au sol"
#: ../gui/wxpython/menustrings.py:414
-#, fuzzy
msgid "Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions."
msgstr "Calcul numérique pour les eaux souterraines transitoires, confinées et non confinées, en deux dimensions."
@@ -7572,7 +7571,7 @@
#: ../gui/wxpython/menustrings.py:428
msgid "Calculates contrast weighted edge density index on a raster map"
-msgstr ""
+msgstr "Calculer l'index de densité de bords pondérée par le contraste sur une carte raster"
#: ../gui/wxpython/menustrings.py:429
msgid "Patch area mean"
@@ -7677,7 +7676,7 @@
#: ../gui/wxpython/menustrings.py:455
msgid "Recursively traces the least cost path backwards to cells from which the cumulative cost was determined."
-msgstr ""
+msgstr "Trace de façon récursive le plus court chemin vers les cellules pour lequelles le coût cumulé est déterminé."
#: ../gui/wxpython/menustrings.py:456
msgid "Anisotropic spread simulation"
@@ -7685,7 +7684,7 @@
#: ../gui/wxpython/menustrings.py:457
msgid "Simulates elliptically anisotropic spread on a graphics window and generates a raster map of the cumulative time of spread, given raster maps containing the rates of spread (ROS), the ROS directions and the spread origins."
-msgstr ""
+msgstr "Simule une propagation elliptique anisotropique sur une fenêtre graphique et génère une couche raster du temps cumulé de propagation, à partir de couches raster contenant des taux (ROS), directions, et origine des propagations."
#: ../gui/wxpython/menustrings.py:458
msgid "Change category values and labels"
@@ -7739,7 +7738,7 @@
#: ../gui/wxpython/menustrings.py:470
msgid "Rescales histogram equalized the range of category values in a raster map layer."
-msgstr ""
+msgstr "Rééchelonne l'histogramme sur l'étendue des valeurs de catégories de la couche raster."
#: ../gui/wxpython/menustrings.py:471
msgid "Generate random cells"
@@ -7775,7 +7774,7 @@
#: ../gui/wxpython/menustrings.py:479
msgid "Gaussian kernel density surface"
-msgstr ""
+msgstr "Surface avec un noyau de densité gaussienne"
#: ../gui/wxpython/menustrings.py:480
#, fuzzy
@@ -7802,7 +7801,7 @@
#: ../gui/wxpython/menustrings.py:486
msgid "Produces a raster map of uniform random deviates whose range can be expressed by the user."
-msgstr ""
+msgstr "Produit une couche raster de données aléatoires uniformément réparties dans un gamme donnée par l'utilisateur."
#: ../gui/wxpython/menustrings.py:487
msgid "Random surface with spatial dependence"
@@ -7933,11 +7932,11 @@
#: ../gui/wxpython/menustrings.py:519
msgid "Statistics for clumped cells"
-msgstr ""
+msgstr "Statistiques pour des amas de cellules"
#: ../gui/wxpython/menustrings.py:520
msgid "Calculates the volume of data \"clumps\", and (optionally) produces a GRASS vector points map containing the calculated centroids of these clumps."
-msgstr ""
+msgstr "Calcul le volume de données en amas et produit (en option) une couche vectorielle de points contenant les centroïdes de ces amas."
#: ../gui/wxpython/menustrings.py:521
msgid "Total corrected area"
@@ -7974,7 +7973,7 @@
#: ../gui/wxpython/menustrings.py:530
msgid "Outputs a covariance/correlation matrix for user-specified raster map layer(s)."
-msgstr ""
+msgstr "Sortir la matrice de covariance/corrélation pour des"
#: ../gui/wxpython/menustrings.py:531
msgid "Linear regression"
@@ -7986,11 +7985,11 @@
#: ../gui/wxpython/menustrings.py:533
msgid "Mutual category occurrences"
-msgstr ""
+msgstr "Occurences mutelles de catégories"
#: ../gui/wxpython/menustrings.py:534
msgid "Tabulates the mutual occurrence (coincidence) of categories for two raster map layers."
-msgstr ""
+msgstr "Tabuler les occurences mutuelles (coincidence) des catégories de deux rasters"
#: ../gui/wxpython/menustrings.py:535
msgid "&Vector"
@@ -8265,7 +8264,7 @@
#: ../gui/wxpython/menustrings.py:614
msgid "Building contour determination and Region Growing algorithm for determining the building inside"
-msgstr ""
+msgstr "Détermination des contours de bâtiments et algorithme d'agrandissement de la région pour déterminer les bâtiments à l'intérieur"
#: ../gui/wxpython/menustrings.py:615
msgid "Correct and reclassify objects"
@@ -8862,9 +8861,8 @@
msgstr "Détection des bordures"
#: ../gui/wxpython/menustrings.py:763
-#, fuzzy
msgid "Zero-crossing \"edge detection\" raster function for image processing."
-msgstr "Fonction raster croisement de zéros de \"détection des angles\" pour l'analyse d'images."
+msgstr "Fonction raster de \"détection des bords\" sans croisement pour l'analyse d'images."
#: ../gui/wxpython/menustrings.py:764
msgid "Matrix/convolving filter"
@@ -17386,3 +17384,9 @@
#~ msgid "degrees (clockwise from grid-north)"
#~ msgstr "degrés (sens horaire)"
+#~ msgid "Generates three, or four raster map layers showing 1) the base (perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the direction of the maximum ROS, and optionally 4) the maximum potential spotting distance."
+#~ msgstr "Génère trois ou quatre couches raster montrant 1) la la vitesse de propagation de base (ROS), 2) la propagation maximale, 3) la direction dela propagation maximale, et en option 4) la distance potentielle maximale de propagation."
+#~ msgid "Generates a raster density map from vector point data using a moving kernel or optionally generates a vector density map on a vector network."
+#~ msgstr "Génère une carte raster de densité à partir de données vecteurs points en utilisant un noyau mouvant et optionnellement génère une carte de densité sur un réseau vectoriel."
