[GRASS-SVN] r56444 - grass/branches/develbranch_6/gui/wxpython/core
svn_grass at osgeo.org
Tue May 28 00:32:13 PDT 2013
Author: hamish
Date: 2013-05-28 00:32:13 -0700 (Tue, 28 May 2013)
New Revision: 56444
grass/branches/develbranch_6/gui/wxpython/core/render.py
really use tempfile.mkstemp() for GRASS_{PNG|CAIRO}FILE (but still not the pgm alpha file). (#560, #943,comment:10)
Modified: grass/branches/develbranch_6/gui/wxpython/core/render.py
--- grass/branches/develbranch_6/gui/wxpython/core/render.py 2013-05-28 06:47:39 UTC (rev 56443)
+++ grass/branches/develbranch_6/gui/wxpython/core/render.py 2013-05-28 07:32:13 UTC (rev 56444)
@@ -87,13 +87,14 @@
self.opacity, self.hidden))
# generated file for each layer
- self.gtemp = tempfile.mkstemp()[1]
- self.maskfile = self.gtemp + ".pgm"
if self.type == 'overlay':
- self.mapfile = self.gtemp + ".png"
+ tempfile_sfx =".png"
else:
- self.mapfile = self.gtemp + ".ppm"
+ tempfile_sfx =".ppm"
+ self.mapfile = tempfile.mkstemp(suffix = tempfile_sfx)[1]
+ # do we need to `touch` the maskfile so it exists?
+ self.maskfile = self.mapfile.rsplit(".",1)[0] + ".pgm"
def __del__(self):
Debug.msg (3, "Layer.__del__(): layer=%s, cmd='%s'" %
(self.name, self.GetCmd(string = True)))
@@ -124,17 +125,18 @@
if self.type not in layertypes:
raise GException(_("<%(name)s>: layer type <%(type)s> is not supported") % \
{'type' : self.type, 'name' : self.name})
# start monitor
- if UserSettings.Get(group='display', key='driver', subkey='type') == 'cairo':
- if not self.mapfile:
- if self.type == 'overlay':
- else:
+ if not self.mapfile:
+ if self.type == 'overlay':
+ else:
+ if UserSettings.Get(group='display', key='driver', subkey='type') == 'cairo':
if self.mapfile:
os.environ["GRASS_CAIROFILE"] = self.mapfile
@@ -142,16 +144,7 @@
# the first one works as expected.
# if 'cairo' not in RunCommand('d.mon', flags='p', read = True):
# RunCommand('d.mon', start = 'cairo', select = 'cairo')
else:
- else:
if self.mapfile:
os.environ["GRASS_PNGFILE"] = self.mapfile
