[GRASS-SVN] r56445 - grass/trunk/gui/wxpython/core
svn_grass at osgeo.org
Tue May 28 03:19:45 PDT 2013
Author: hamish
Date: 2013-05-28 03:19:45 -0700 (Tue, 28 May 2013)
New Revision: 56445
grass/trunk/gui/wxpython/core/render.py
better use of tempfile.mkstemp() (#560, #943,comment:10, merge from devbr6 r56444)
Modified: grass/trunk/gui/wxpython/core/render.py
--- grass/trunk/gui/wxpython/core/render.py 2013-05-28 07:32:13 UTC (rev 56444)
+++ grass/trunk/gui/wxpython/core/render.py 2013-05-28 10:19:45 UTC (rev 56445)
@@ -69,17 +69,17 @@
# generated file for each layer
if USE_GPNMCOMP or ltype == 'overlay':
- tmpfile = tempfile.mkstemp()[1]
- self.maskfile = tmpfile + '.pgm'
if ltype == 'overlay':
- self.mapfile = tmpfile + '.png'
+ tempfile_sfx = ".png"
else:
- self.mapfile = tmpfile + '.ppm'
- grass.try_remove(tmpfile)
+ tempfile_sfx = ".ppm"
+ self.mapfile = tempfile.mkstemp(suffix = tempfile_sfx)[1]
+ self.maskfile = self.mapfile.rsplit(".",1)[0] + ".pgm"
else:
self.mapfile = self.maskfile = None
- # stores class which manages rendering instead of simple command - e. g. wms
+ # stores class which manages rendering instead of simple command - e.g. WMS
self.renderMgr = None
self.Map = Map
