[GRASS-SVN] r58195 - grass/trunk/lib/python/pygrass
svn_grass at osgeo.org
Mon Nov 11 07:28:13 PST 2013
Author: zarch
Date: 2013-11-11 07:28:13 -0800 (Mon, 11 Nov 2013)
New Revision: 58195
grass/trunk/lib/python/pygrass/functions.py
Add optional parameters to functions: copy, rename, remove and add new functions to split a list in chunk, and to check if a table already exist in the DB
Modified: grass/trunk/lib/python/pygrass/functions.py
--- grass/trunk/lib/python/pygrass/functions.py 2013-11-11 12:47:26 UTC (rev 58194)
+++ grass/trunk/lib/python/pygrass/functions.py 2013-11-11 15:28:13 UTC (rev 58195)
@@ -4,8 +4,10 @@
@author: pietro
+import itertools
import fnmatch
import os
+from sqlite3 import OperationalError
import grass.lib.gis as libgis
import grass.lib.raster as libraster
@@ -91,20 +93,19 @@
return find_in_gisdbase(type, pattern, gis)
-def remove(oldname, maptype):
+def remove(oldname, maptype, **kwargs):
"""Remove a map"""
- grasscore.run_command('g.remove', quiet=True,
- **{maptype: '{old}'.format(old=oldname)})
+ kwargs.update({maptype: '{old}'.format(old=oldname)})
+ grasscore.run_command('g.remove', quiet=True, **kwargs)
-def rename(oldname, newname, maptype):
+def rename(oldname, newname, maptype, **kwargs):
"""Rename a map"""
- grasscore.run_command('g.rename', quiet=True,
- **{maptype: '{old},{new}'.format(old=oldname,
- new=newname), })
+ kwargs.update({maptype: '{old},{new}'.format(old=oldname, new=newname), })
+ grasscore.run_command('g.rename', quiet=True, **kwargs)
-def copy(existingmap, newmap, maptype):
+def copy(existingmap, newmap, maptype, **kwargs):
"""Copy a map
>>> copy('census', 'mycensus', 'vect')
@@ -112,9 +113,8 @@
>>> remove('mynewcensus', 'vect')
- grasscore.run_command('g.copy', quiet=True,
- **{maptype: '{old},{new}'.format(old=existingmap,
- new=newmap), })
+ kwargs.update({maptype: '{old},{new}'.format(old=existingmap, new=newmap)})
+ grasscore.run_command('g.copy', quiet=True, **kwargs)
def getenv(env):
@@ -286,3 +286,47 @@
else:
path = None
return path
+def split_in_chunk(iterable, lenght=10):
+ """Split a list in chunk.
+ >>> for chunk in split_in_chunk(range(25)): print chunk
+ [0, 1, 2, 3, 4, 5, 6, 7, 8, 9]
+ [10, 11, 12, 13, 14, 15, 16, 17, 18, 19]
+ [20, 21, 22, 23, 24]
+ >>> for chunk in split_in_chunk(range(25), 3): print chunk
+ [0, 1, 2]
+ [3, 4, 5]
+ [6, 7, 8]
+ [9, 10, 11]
+ [12, 13, 14]
+ [15, 16, 17]
+ [18, 19, 20]
+ [21, 22, 23]
+ [24]
+ it = iter(iterable)
+ while True:
+ chunk = tuple(itertools.islice(it, lenght))
+ if not chunk:
+ return
+ yield chunk
+def table_exist(cursor, table_name):
+ """Return True if the table exist False otherwise"""
+ try:
+ # sqlite
+ cursor.execute("SELECT name FROM sqlite_master"
+ " WHERE type='table' AND name='%s';" % table_name)
+ except OperationalError:
+ try:
+ # pg
+ cursor.execute("SELECT EXISTS(SELECT * FROM "
+ "information_schema.tables "
+ "WHERE table_name=%s)" % table_name)
+ return False
+ one = cursor.fetchone() if cursor else None
+ return True if one and one[0] else False
