[GRASS-SVN] r58196 - in grass-addons/grass7/vector: . v.what.strds
svn_grass at osgeo.org
Mon Nov 11 14:23:52 PST 2013
Author: lucadelu
Date: 2013-11-11 14:23:51 -0800 (Mon, 11 Nov 2013)
New Revision: 58196
Added:
grass-addons/grass7/vector/v.what.strds/
grass-addons/grass7/vector/v.what.strds/Makefile
grass-addons/grass7/vector/v.what.strds/v.what.strds.html
grass-addons/grass7/vector/v.what.strds/v.what.strds.py
first version v.what.strds, please test it
Added: grass-addons/grass7/vector/v.what.strds/Makefile
--- grass-addons/grass7/vector/v.what.strds/Makefile (rev 0)
+++ grass-addons/grass7/vector/v.what.strds/Makefile 2013-11-11 22:23:51 UTC (rev 58196)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = v.what.strds
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/vector/v.what.strds/Makefile
___________________________________________________________________
Added: svn:mime-type
+ text/x-makefile
Added: svn:eol-style
+ native
Added: grass-addons/grass7/vector/v.what.strds/v.what.strds.html
--- grass-addons/grass7/vector/v.what.strds/v.what.strds.html (rev 0)
+++ grass-addons/grass7/vector/v.what.strds/v.what.strds.html 2013-11-11 22:23:51 UTC (rev 58196)
@@ -0,0 +1,12 @@
+<h2>DESCRIPTION</h2>
+<em>v.what.strds</em> is useful to query a space time raster datasets
+using a point vector.
+<h2>SEE ALSO</h2>
+<em>
+<a href="v.what.rast.html">v.what.rast</a>,
+<a href="t.vect.observe.strds.html">t.vect.observe.strds</a>
+</em>
+<h2>AUTHORS</h2>
+Luca Delucchi<br>
Property changes on: grass-addons/grass7/vector/v.what.strds/v.what.strds.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Added: grass-addons/grass7/vector/v.what.strds/v.what.strds.py
--- grass-addons/grass7/vector/v.what.strds/v.what.strds.py (rev 0)
+++ grass-addons/grass7/vector/v.what.strds/v.what.strds.py 2013-11-11 22:23:51 UTC (rev 58196)
@@ -0,0 +1,196 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE: v.what.strds
+# AUTHOR(S): Luca delucchi
+# PURPOSE: Observe specific locations in a space time raster dataset
+# COPYRIGHT: (C) 2013 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (version 2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Observes specific locations (vector points) in a space time raster dataset.
+#% keywords: vector
+#% keywords: temporal
+#% keywords: sampling
+#% keywords: position
+#% keywords: querying
+#% keywords: attribute table
+#%end
+#%option G_OPT_V_INPUT
+#%end
+#%option G_OPT_STRDS_INPUTS
+#% key: strds
+#%end
+#%option G_OPT_V_OUTPUT
+#%end
+#%option G_OPT_DB_WHERE
+#%end
+#%option G_OPT_T_WHERE
+#% key: t_where
+#%end
+import grass.script as grass
+import grass.temporal as tgis
+from grass.pygrass.functions import copy as gcopy
+class Sample(object):
+ def __init__(self, start=None, end=None, raster_names=None,
+ strds_name=None):
+ self.start = start
+ self.end = end
+ if raster_names != None:
+ self.raster_names = raster_names
+ else:
+ self.raster_names = []
+ self.strds_name = strds_name
+ def __str__(self):
+ return "Start: %s\nEnd: %s\nNames: %s\n" % (str(self.start),
+ str(self.end),
+ str(self.raster_names))
+ def printDay(self, date='start'):
+ if date == 'start':
+ return str(self.start).split(' ')[0].replace('-', '_')
+ elif date == 'end':
+ return str(self.end).split(' ')[0].replace('-', '_')
+ else:
+ grass.fatal("The values accepted by printDay in Sample are:" \
+ " 'start', 'end'")
+def main():
+ # Get the options
+ input = options["input"]
+ output = options["output"]
+ strds = options["strds"]
+ where = options["where"]
+ tempwhere = options["t_where"]
+ if where == "" or where == " " or where == "\n":
+ where = None
+ overwrite = grass.overwrite()
+ # Check the number of sample strds and the number of columns
+ strds_names = strds.split(",")
+ # Make sure the temporal database exists
+ tgis.init()
+ # We need a database interface
+ dbif = tgis.SQLDatabaseInterfaceConnection()
+ dbif.connect()
+ samples = []
+ first_strds = tgis.open_old_space_time_dataset(strds_names[0], "strds",
+ dbif)
+ # Single space time raster dataset
+ if len(strds_names) == 1:
+ rows = first_strds.get_registered_maps(
+ "name,mapset,start_time,end_time", tempwhere, "start_time", dbif)
+ if not rows:
+ dbif.close()
+ grass.fatal(_("Space time raster dataset <%s> is empty") %
+ first_strds.get_id())
+ for row in rows:
+ start = row["start_time"]
+ end = row["end_time"]
+ raster_maps = [row["name"] + "@" + row["mapset"], ]
+ s = Sample(start, end, raster_maps, first_strds.get_name())
+ samples.append(s)
+ else:
+ # Multiple space time raster datasets
+ for name in strds_names[1:]:
+ dataset = tgis.open_old_space_time_dataset(name, "strds", dbif)
+ if dataset.get_temporal_type() != first_strds.get_temporal_type():
+ grass.fatal(_("Temporal type of space time raster datasets must be equal\n"
+ "<%(a)s> of type %(type_a)s do not match <%(b)s> of type %(type_b)s"%\
+ {"a": first_strds.get_id(),
+ "type_a":first_strds.get_temporal_type(),
+ "b":dataset.get_id(),
+ "type_b":dataset.get_temporal_type()}))
+ mapmatrizes = tgis.sample_stds_by_stds_topology("strds", "strds", strds_names,
+ strds_names[0], False, None,
+ "equal", False, False)
+ for i in xrange(len(mapmatrizes[0])):
+ isvalid = True
+ mapname_list = []
+ for mapmatrix in mapmatrizes:
+ entry = mapmatrix[i]
+ if entry["samples"]:
+ sample = entry["samples"][0]
+ name = sample.get_id()
+ if name is None:
+ isvalid = False
+ break
+ else:
+ mapname_list.append(name)
+ if isvalid:
+ entry = mapmatrizes[0][i]
+ map = entry["granule"]
+ start, end = map.get_temporal_extent_as_tuple()
+ s = Sample(start, end, mapname_list, name)
+ samples.append(s)
+ # Get the layer and database connections of the input vector
+ gcopy(input, output, 'vect')
+ for sample in samples:
+ raster_names = sample.raster_names
+ # Call v.what.rast for each raster map
+ for name in raster_names:
+ coltype = "DOUBLE PRECISION"
+ # Get raster map type
+ raster_map = tgis.RasterDataset(name)
+ raster_map.load()
+ if raster_map.metadata.get_datatype() == "CELL":
+ coltype = "INT"
+ day = sample.printDay()
+ column_name = "%s_%s" % (sample.strds_name, day)
+ column_string = "%s %s" % (column_name, coltype)
+ column_string.replace('.', '_')
+ ret = grass.run_command("v.db.addcolumn", map=output,
+ column=column_string, overwrite=overwrite)
+ if ret != 0:
+ dbif.close()
+ grass.fatal(_("Unable to add column %s to vector map <%s> ") \
+ % (column_string, output))
+ ret = grass.run_command("v.what.rast", map=output, raster=name,
+ column=column_name, where=where, quiet=True)
+ if ret != 0:
+ dbif.close()
+ grass.fatal(_("Unable to run v.what.rast for vector map <%s> "
+ "and raster map <%s>") % \
+ (output, str(raster_names)))
+ dbif.close()
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
Property changes on: grass-addons/grass7/vector/v.what.strds/v.what.strds.py
+ text/x-python
+ native
