[GRASS-SVN] r58244 - grass/trunk/vector/v.in.ogr
Sun Nov 17 03:10:34 PST 2013
Author: martinl
Date: 2013-11-17 03:10:30 -0800 (Sun, 17 Nov 2013)
New Revision: 58244
   grass/trunk/vector/v.in.ogr/main.c
v.in.ogr: fix producing external formats
Modified: grass/trunk/vector/v.in.ogr/main.c
--- grass/trunk/vector/v.in.ogr/main.c	2013-11-17 11:08:06 UTC (rev 58243)
+++ grass/trunk/vector/v.in.ogr/main.c	2013-11-17 11:10:30 UTC (rev 58244)
@@ -77,7 +77,8 @@
     /* Vector */
     struct Map_info Map, Tmp, *Out;
     int cat;
+    int delete_table = FALSE; /* for external output format only */
     /* Attributes */
     struct field_info *Fi = NULL;
     dbDriver *driver = NULL;
@@ -1094,7 +1095,6 @@
 	if (!flag.notab->answer) {
 	    db_commit_transaction(driver);
-	    db_close_database_shutdown_driver(driver);
 	if (nogeom > 0)
@@ -1414,8 +1414,18 @@
+    delete_table = Vect_maptype(&Map) != GV_FORMAT_NATIVE;
     Vect_close(&Map);
+    if (delete_table) {
+        sprintf(buf, "drop table %s", Fi->table);
+        db_set_string(&sql, buf);
+        if (db_execute_immediate(driver, &sql) != DB_OK) {
+            G_fatal_error(_("Unable to drop table: '%s'"),
+                          db_get_string(&sql));
+    db_close_database_shutdown_driver(driver);
     /*      Extend current window based on dataset.                         */
