[GRASS-SVN] r58245 - grass/trunk/display/d.vect
Sun Nov 17 09:58:15 PST 2013
Author: martinl
Date: 2013-11-17 09:58:14 -0800 (Sun, 17 Nov 2013)
New Revision: 58245
   grass/trunk/display/d.vect/label.c
d.vect: fix reading centroids from PostGIS Topology
Modified: grass/trunk/display/d.vect/label.c
--- grass/trunk/display/d.vect/label.c	2013-11-17 11:10:30 UTC (rev 58244)
+++ grass/trunk/display/d.vect/label.c	2013-11-17 17:58:14 UTC (rev 58245)
@@ -17,14 +17,18 @@
     struct line_cats *Cats;
     int ogr_centroids;
+    const struct Format_info *finfo;
     Points = Vect_new_line_struct();
     Cats = Vect_new_cats_struct();
     Vect_rewind(Map);
     ogr_centroids = FALSE;
+    finfo = Vect_get_finfo(Map);
     if (Vect_maptype(Map) == GV_FORMAT_OGR ||
-	Vect_maptype(Map) == GV_FORMAT_POSTGIS) {
+	(Vect_maptype(Map) == GV_FORMAT_POSTGIS &&
+         finfo->pg.toposchema_name == NULL)) {
 	if (Vect_level(Map) < 2)
 	    G_warning(_("Topology level required for drawing centroids "
 			"for OGR layers"));
