[GRASS-SVN] r58252 - grass/trunk/raster/r.what
svn_grass at osgeo.org
Mon Nov 18 15:32:28 PST 2013
Author: neteler
Date: 2013-11-18 15:32:28 -0800 (Mon, 18 Nov 2013)
New Revision: 58252
grass/trunk/raster/r.what/r.what.html
r.what manual: examples rewritten to North Carolina
Modified: grass/trunk/raster/r.what/r.what.html
--- grass/trunk/raster/r.what/r.what.html 2013-11-18 21:42:27 UTC (rev 58251)
+++ grass/trunk/raster/r.what/r.what.html 2013-11-18 23:32:28 UTC (rev 58252)
@@ -33,56 +33,66 @@
maximum input line length (e.g. 4096 characters).
<div class="code"><pre>
-g.region rast=soils,aspect
-r.what map=soils,aspect coordinates=635342.21,7654321.09,653324.88,7563412.42
+g.region rast=landuse96_28m,aspect -p
+r.what map=landuse96_28m,aspect coordinates=633614.08,224125.12,632972.36,225382.87 -f
-635342.21|7654321.09|45|21
-653324.88|7563412.42|44|20
+633614.08|224125.12||2|Low Intensity Developed|209.5939|209 degrees ccw from east
+632972.36|225382.87||15|Southern Yellow Pine|140.7571|140 degrees ccw from east
</pre></div>
<h3>Input coordinates given as a vector points map</h3>
Coordinates can be read from exising vector points map by
-specifing <b>points</b> option. Other features then points or
-centroids are ignored.
+specifing <b>points</b> option. Other features than points or
+centroids are ignored. Example: query North Carolina county number for
+each community college:
-r.what map=soils,aspect points=bugsites
+g.region rast=boundary_county_500m -p
+r.what map=boundary_county_500m points=comm_colleges
+145096.859150|154534.264884||39
+616341.437150|146049.750884||51
</pre></div>
<h3>Input from a text file containing coordinates</h3>
The contents of an ASCII text file can be redirected to <em>r.what</em>
as follows. If we have a file called <i>input_coord.txt</i> containing the
-coordinates and labels given in the example above:
+whitespace separated coordinates and optionally labels, the resulting
+raster map values are extracted:
-r.what map=soils,aspect < input_coord.txt
+cat input_coord.txt
+633614.08 224125.12 site 1
+632972.36 225382.87 site 2
-635342.21|7654321.09|site 1|45|21
-653324.88|7563412.42|site 2|44|20
+r.what map=landuse96_28m,aspect < input_coord.txt
+633614.08|224125.12|site 1|2|209.5939
+632972.36|225382.87|site 2|15|140.7571
</pre></div>
<h3>Input from standard input on the command line</h3>
-Input coordinates may be given directly from standard input (<tt>stdin</tt>), for example
-(input data appears between the "<tt>EOF</tt>" markers):
+Input coordinates may be given directly from standard input (<tt>stdin</tt>),
+for example (input data appears between the "<tt>EOF</tt>" markers):
-r.what map=soils,aspect << EOF
-635342.21 7654321.09 site 1
-653324.88 7563412.42 site 2
+r.what map=landuse96_28m,aspect << EOF
EOF
</pre></div>
-echo "635342.21 7654321.09" | r.what map=soils,aspect
+echo "633614.08 224125.12" | r.what map=landuse96_28m,aspect
+633614.08|224125.12||2|209.5939
</pre></div>
<h3>Input coordinates piped from another program</h3>
@@ -93,7 +103,12 @@
<em><a href="v.out.ascii.html">v.out.ascii</a></em> module.
-v.out.ascii bugsites separator=space | r.what map=soils,aspect
+v.out.ascii comm_colleges separator=space | r.what map=boundary_county_500m
+145096.8591495|154534.26488388|1|39
+616341.4371495|146049.75088388|2|51
+410595.7191495|174301.82888388|3|71
</pre></div>
<h3>Output containing raster map category labels</h3>
@@ -102,13 +117,13 @@
associated with the raster cell(s), as well as values (categorical maps only).
-r.what -f map=soils,aspect << EOF
+r.what -f map=landuse96_28m,aspect << EOF
EOF
-635342.21|7654321.09|site 1|45|NaC|21|30 degrees NW
-653324.88|7563412.42|site 2|44|NdC|20|15 degrees NW
+633614.08|224125.12|site 1|2|Low Intensity Developed|209.5939|209 degrees ccw from east
+632972.36|225382.87|site 2|15|Southern Yellow Pine|140.7571|140 degrees ccw from east
</pre></div>
<h2>NOTE</h2>
@@ -120,6 +135,7 @@
<ul>
<li>Add <b>file</b> option</li>
+ <li>Fix <b>400 maps</b> limit</li>
</ul>
<h2>SEE ALSO</h2>
