[GRASS-SVN] r58253 - grass/trunk/raster/r.what
svn_grass at osgeo.org
Mon Nov 18 15:35:52 PST 2013
Author: neteler
Date: 2013-11-18 15:35:52 -0800 (Mon, 18 Nov 2013)
New Revision: 58253
grass/trunk/raster/r.what/main.c
grass/trunk/raster/r.what/r.what.html
r.what: file output parameter added (from r.stats) incl. example
Modified: grass/trunk/raster/r.what/main.c
--- grass/trunk/raster/r.what/main.c 2013-11-18 23:32:28 UTC (rev 58252)
+++ grass/trunk/raster/r.what/main.c 2013-11-18 23:35:52 UTC (rev 58253)
@@ -51,6 +51,7 @@
int i, j;
int nfiles;
+ char *name;
int fd[NFILES];
struct Categories cats[NFILES];
struct Cell_head window;
@@ -70,7 +71,7 @@
char buffer[1024];
char **ptr;
struct _opt {
- struct Option *input, *cache, *null, *coords, *fs, *points;
+ struct Option *input, *cache, *null, *coords, *fs, *points, *output;
} opt;
struct _flg {
struct Flag *label, *cache, *cat_int, *color, *header;
@@ -100,6 +101,7 @@
module->description =
_("Queries raster maps on their category values and category labels.");
+ /* TODO: should be G_OPT_R_INPUTS for consistency but needs overall change where used */
opt.input = G_define_standard_option(G_OPT_R_MAPS);
opt.input->description = _("Name of existing raster map(s) to query");
@@ -121,6 +123,11 @@
opt.null->description = _("Char string to represent no data cell");
opt.null->guisection = _("Print");
+ opt.output = G_define_standard_option(G_OPT_F_OUTPUT);
+ opt.output->required = NO;
+ opt.output->description =
+ _("Name for output file (if omitted or \"-\" output to stdout)");
opt.fs = G_define_standard_option(G_OPT_F_SEP);
opt.fs->guisection = _("Print");
@@ -161,6 +168,13 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
+ name = opt.output->answer;
+ if (name != NULL && strcmp(name, "-") != 0) {
+ if (NULL == freopen(name, "w", stdout)) {
+ G_fatal_error(_("Unable to open file <%s> for writing"), name);
tty = isatty(0);
fs = G_option_to_separator(opt.fs);
Modified: grass/trunk/raster/r.what/r.what.html
--- grass/trunk/raster/r.what/r.what.html 2013-11-18 23:32:28 UTC (rev 58252)
+++ grass/trunk/raster/r.what/r.what.html 2013-11-18 23:35:52 UTC (rev 58253)
@@ -56,6 +56,27 @@
</pre></div>
+<h3>Input coordinates given as a vector points map, output into CSV file</h3>
+Coordinates can be read from exising vector points map by
+specifing <b>points</b> option. Other features than points or
+centroids are ignored. The output is stored in a CSV file including header
+row. Example: query North Carolina county number for each community college:
+<div class="code"><pre>
+g.region rast=boundary_county_500m -p
+r.what map=boundary_county_500m points=comm_colleges \
+ separator=comma output=result.csv -n
+cat result.csv
+easting,northing,site_name,boundary_county_500m
+145096.859150,154534.264884,,39
+616341.437150,146049.750884,,51
+410595.719150,174301.828884,,71
+</pre></div>
<h3>Input from a text file containing coordinates</h3>
The contents of an ASCII text file can be redirected to <em>r.what</em>
@@ -134,7 +155,6 @@
<h2>TODO</h2>
<ul>
- <li>Add <b>file</b> option</li>
<li>Fix <b>400 maps</b> limit</li>
</ul>
